Avid Pro Tools专业影视级音频音乐制作工作流程视频教程
+ C" _# D# b1 b @: z" i本视频教程是关于Avid Pro Tools专业影视级音频音乐制作工作流程视频教程,时长:4小时,大小:3.1 GB,MP4高清视频格式,附工程源文件,教程使用软件:Avid Pro Tools,共48个章节,语言:英语。
+ O0 x( S6 Z+ Z$ g( Y8 o0 d
. |7 _* B* d- p' `# F+ TAvid Pro Tools是Avid公司精心打造的一款功能非常强大的音频制作软件,可以帮助用户在Mac和pc上快速的进行录音、编曲、编辑和混音。6 {% f& p! l" ?- ?$ o2 L
" {7 q; F5 d! R( ] _- @! \
Avid Pro Tools是Digidesign公司出品的工作站软件系统,最早只是在苹果电脑上出现,后来也有了PC版。* ~+ }: L D! R7 y* g$ Z4 o2 f- ~
1 f7 o& N. _& ^& C! b( UProTools软件内部算法精良,对音频、MIDI、视频都可以很好地支持,由于其算法的不同,单就音频方面来讲,其回放和录音的音质,是大大优于我们现在PC上流行的各种音频软件的。( _* O3 ~) h# v# K! n+ K/ Q8 l
+ t0 F+ \) t0 f1 V9 S" s
在Protools 8版本以前,ProTools系统是由ProTools软件和它所支持的硬件共同组成。" R$ G7 |3 ]+ l0 N
9 c3 [- A" |" P" U) G并不是说你有ProTools软件,就可以安装在你的电脑上用的,如果没有它所支持的硬件,这个软件你是根本无法安装使用的。1 I1 ?( b0 e' `" z3 O0 z" j
: y, Z' V, T. t从Protools 9以后,AVID公司解除了与硬件的强行捆绑,软件可以单独发售单独安装在PC和MAC电脑上,PC电脑需要有支持ASIO驱动的音频卡即可正常运行;而苹果电脑上则板载声卡都可以运行。
5 m6 |8 K3 x. V! [3 j& @0 X( w9 y$ z) p# K5 ?5 p* G! C4 C" h* p+ f
Avid’s Pro Tools is the premiere DAW for editing dialog for TV and Film. Learn the Pro Tools audio editor’s workflow in this advanced, 4-hour course by post-production expert, Roy Vargas.Editing dialog to picture is complex. There’s a lot of interactivity, when audio and video sync in post-production, that makes it essential for you to master all the concepts and tools. That’s why we called upon experienced Pro Tools expert Roy Vargas to break down the process and show you everything you need to know as a professional dialog editor.The course starts with a collection of tutorials that breakdown the anatomy of a post-production session. Roy explains the various kinds of sessions, tracks, file formats and organizational hierarchies that Pro Tools operators must know. Next, he shows you, from experience and by example, how a Pro Tools operator constructs and sets up a dialog-to-picture editing session. Then Roy dives into timecode, reference tones, sync pops, reel splitting and much more to assure that your session is built on solid ground.From there you explore the tools and techniques he uses to edit, crossfade, clean, sync, time-stretch and fix any kind of audio situation you might come across in post-production. By the time you finish this 48-tutorial course, you will “own” all the tools, techniques and, most importantly, the confidence to run your own Pro Tools post-production dialog editing sessions!Video date 2014 |
