ÊýÄ£/Ä£Êýת»»Æ÷ ESI - DR.DAC prime
viptem
2009-2-27 16:44:11
DAC²©Ê¿.¾«Ö°׽ð°æÊÇESI×îÐÂÍÆ³öµÄÒ»¿î¼¯ºÏÁËÖ§³ÖASIO2.0רҵÉù¿¨µÄ×î¸ßÖ§³Ö24bit/192kHzµÄ¹âÏ˸߼¶½âÂëÆ÷¡£ËüµÄÍâ¹Û¼òԼʱÉУ¬ÈáºÍ¾«Ö£¬ÈÃÄúÔÚ¼ÒÀ°ì¹«ÊÒÉõÖÁÂÃ;ÖУ¬¶¼¿ÉÒÔËæÐÄËùÓûµØÐÀÉÍ´¿¾»µÄÒôÀÖ¡£
DAC ²©Ê¿¾«Ö°׽ð°æ×î¸ß´ïµ½24bit/192kHzµÄ²ÎÊýÈÃËüת»»¸ßÇåÎúÒôƵ´ïµ½ÍêÃÀµÄת»»Ð§¹û¡£Ëü²»½ö½öÊÇÒ»¿î°üº¬¹âÏË£¨Í¨¹ý¸½Ë͵Äminiplug- toslinkÊÊÅäÆ÷£©ºÍͬÖáÊý×ÖÊäÈ룬¶øÇÒ»¹ÊÇÒ»¿îUSB2.0£¬24bit/96kHzµÄÖ§³ÖASIO2.0µÄרҵÉù¿¨¡£Òò²ÉÓÃTI SRC4382µÄ¸ß¶Ë²ÉÑùÂÊת»»Æ÷£¬DAC²©Ê¿ÄÜÇáËÉËæÒâµØ°ÑÊäÈëÐźÅÉýµ½192kHz.
ÏÂÃæÊÇDAC²©Ê¿¾«ÖÂ°×½ð°æµÄһЩ³¬Ç¿Âôµã£º
ÕæÊµ´¿¾»µÄÊä³öÐźÅÀ´×ÔTI PCM1796 DAC£¬¶¯Ì¬·¶Î§´ïµ½123dB(a)£¬ÍêÈ«²»Í¬µÄÊä³öÓÃ3 LME49860NA opamps (8 pin£¬±»±ã½ÝµØ°²·ÅÔÚ²å×ùÉÏ)À´¸ºÔð¡£ÄÚÖõĶú·ÅÖ§³Ö1/8" and 1/4" Á¬½Ó¿Ú¡£ÏßÐÔÊä³öµÄÒôÁ¿£¬Äܹ»·½±ãµØ´ÓÃæ°åÇ°ÃæµÄÒøÉ«ÒôÁ¿ÐýÅ¥À´µ÷ÕûºÍ»ìºÏ£¬ÓÃ×î´óµÄ¶¯Ì¬·¶Î§Êͷųö¡£
DAC²©Ê¿¾«ÖÂ°×½ð°æ»¹ÓÐÆäËû³¬·²ÍÑË×µÄÓŵ㣺ËüµÄÏßÐÔÊäÈë(AKM AK5386 ADC ´ïµ½110dB)£¬¹âÏ˺ÍͬÖáS/PDIFÊäÈ룬ÔÊÐíÄãÀ´Â¼ÖƳö×Ô¼ºÍêÃÀµÄÒôƵ¡£
DAC ²©Ê¿¾«Ö°׽ð°æÖ§³ÖWindows XP, Windows Vista, Windows 7 as well as Mac OS X£¬Èÿͻ§¸Ðµ½×î·½±ãµÄÊǾ¹È»ÎÞÐèÇý¶¯°²×°£¬¶ÔÄÇЩ²»»á°²×°µÄÈË£¬ÊÇ×î´óµÄ¸£Òô¡£»¹ÓУ¬ËüÌṩASIO2.0È«¼æÈݵÄÇý¶¯£¬ÔÚ Windows XP, Vista, 7 & 8¹¤×÷Îȶ¨£¡
É豸ÀàÐÍ
    * Êýģת»»Æ÷ºÍÄ£Êýת»»Æ÷
    * USB2.0 ÍâÖÃÉù¿¨
    * ¶ú·Å
¹Ø¼ü¼¼Êõ²ÎÊýºÍÌØÐÔ
    * ×î´ó24bit/192khz S/PDIF ÊäÈ룺 Ñ¡ÔñͬÖá&¹âÏËÊäÈëģʽ
      - S/PDIF ÊäÈë => S/PDIF Êä³ö Êý×ÖÅÔͨ
      - S/PDIF ÊäÈë => ÏßÐԺͶú»úÊä³ö
      - S/PDIF ÊäÈë => µçÄÔ¼Òô
    * ×î´ó24bit/96khz bit-perfect S/PDIFÊä³ö£º ͬÖá&¹âÏ˱äËÍÆ÷ģʽ
      - USBÊäÈë => S/PDIF Êä³ö
      - AC-3/DTS non-PCM ÅÔͨ(Vista/7)
    * 24bit/192kHz ÉϲÉÑùS/PDIF Êä³ö(optical & coaxial)
      - USB ÊäÈë => 192kHz S/PDIF Êä³ö
      - coaxial ÊäÈë => 192kHz S/PDIF Êä³ö
      - optical ÊäÈë => 192kHz S/PDIF Êä³ö
    * Á½¸ö3.5mmÃÔÄãplug-toslink¹âÏ˽ӿÚ
    * 32kHz-192kHzÊäÈ룬²ÉÓø߶ËTISRC4382 COMBO²ÉÑùÂÊת»»Æ÷
    * S/PDIFÊäÈëºÍUSBÊäÈëÅÔ·£¬SRC4382Ìṩ192kHzµÄ²ÉÑùÖ§³Ö
    * S/PDIFÊäÈëÓµÓÐ+-1ppm 24.576MHz TCXO£¨Î¶Ȳ¹³¥Ê¯Ó¢¾§ÌåÕñµ´Æ÷£©
    * Tenor TE7022L USBÒôƵ¿ØÖÆÆ÷
    * USBÊäÈëµ½S/PDIF/I2SÊä³ö£º+-1ppm 12MHz TCXO(ζȲ¹³¥Ê¯Ó¢¾§ÌåÕñµ´Æ÷)
    * 2ͨµÀRCA½Ó¿ÚÏßÐÔÊäÈë
      - Ïß·ÊäÈë¡úÏß·Êä³ö & ¶ú»úÊä³ö
      - AKM AK5386 24bit/192kHz ADC (S/N ratio 110dB)
      - 1pc 8pin DIPÔË·Å(S4580P)´ø²å×ù
    * 2ͨµÀRCA½Ó¿ÚÏßÐÔÊä³ö
      - ·À±¬Òôµç·֧³Ö
      - Èý¸öÈ«²î·ÖÔËËã·Å´óÆ÷Êä³ö£º3pcs 8pin DIPÔË·Å(LME49860NA)´ø²å×ù
      - TI/Burr Brown PCM1796 24bit/192kHz 123dB DAC
    * Á¢ÌåÉù¶ú»úÊä³ö
      - 6.3mm(1/4")¶ú»ú½Ó¿Ú
      - 3.5mm(1/8")¶ú»ú½Ó¿Ú
    * ÒôÁ¿¿ØÖÆÔöÒæÐýÅ¥
      - ¹Ì¶¨Ïß·µçƽÊä³ö - FIX
      - ¶¯Ì¬Ïß·µçƽÊä³ö - VAR
      - ¸ßÆ·ÖÊÄ£ÄâÒôÁ¿µçλÆ÷
      - ÒøÉ«µÄÂÁÇÐÒôÁ¿ÐýÅ¥
    * Çл»¹Ì¶¨(FIX)»ò¶¯Ì¬(VAR)Êä³öÒôÁ¿µÄÏß·Êä³ö¿ª¹Ø
    * À´Ô´Ñ¡Ôñ(USB-Ä£Äâ-Êý×ÖÇл»)£º3벦¶¯¿ª¹ØºÍÂÌÉ«LEDָʾµÆ
    * Ïß·Êä³ö¾²Òô¿ª¹Ø(²»Ó°Ïì¶ú»úÊä³ö)
    * ´ý»ú/µçÔ´¿ª¹Ø
      - ´ý»ú״̬(ºìÉ«)
      - ¹¤×÷״̬(À¶É«)
    * S/PDIF & USBÊäÈëÅÔ· / 192kHzÉý²ÉÑùÂÊ£º2벦¶¯¿ª¹Ø
    * ¶àÉ«LEDָʾµÆÏÔʾ
      - ¾²Òô(ºìÉ«)
      - ÎÞÐźÅ(³ÈÉ«)
      - PCM״̬(ÂÌÉ«)
      - 192kHzÉý²ÉÑùÂÊ(À¶É«)
    * DC 9V~12V¿í·¶Î§µçÔ´ÊäÈë
    * °üº¬Ò»¸ö12V / 1.5A DCµçÔ´ÊÊÅäÆ÷
    * Ö§³Ö Windows XP, Vista, 7 & 8 µÄASIO 2.0Çý¶¯
