ASP510¿ÉÎÞ·ìµØ¼¯³ÉÔÚAudient¿ØÖÆÌ¨£¬Ò²¿É»ùÓÚDAW»·ÈÆÉùÖÆ×÷£¬Ìṩ¶àÖÖ»·ÈÆÉù¸ñʽ£¬°üÀ¨»¹¼àÌýºÍÂ¼ÖÆ¹¦ÄÜ¡£¼æÈÝ£º5.1, LCRS, Dolby Surround, DVD-Video, DVD-Audio, DTS, and SACD. 4 R" x p" F* W: S7 w
( F2 |% y, K$ c& GÌØÐÔ²ÎÊý£º
! ] L/ E) I3 b; ^: C( i' i6ÖÖÔ¤ÉèMONITORÖÆÊ½¡£
$ q/ u: Y1 m! f! Q* O; o% G* O+ ZÖ§³ÖÈý¸ö5.1»·ÈÆÉùºÍÈý¸öÁ¢ÌåÉùÐźÅÔ´¡£ ' U- l6 j K5 J" K
¿ØÌ¨¿ÉÖ±½Ó8¸öÊäÈ루5.1»·ÈÆÉù¼ÓÁ¢ÌåÉù£©¡£
- Q- Z/ g; ^5 f p% g8Êä³öµ½Â¼Òô»ú£¨5.1»·ÈÆÉù¼ÓÁ¢ÌåÉù£©¡£
& K2 @6 I. U) L# D±àÂë/½âÂëÆ÷²åÈ뿪¹Ø¡£ + ^: ~ H0 n$ x2 V" Z2 E* f% U. `7 @
6¸öÑïÉùÆ÷Êä³ö£¬Ã¿Í¨µÀ¾ùÓÐÒôÁ¿Î¢µ÷¡£ 9 R |& j# T- l8 o0 Q
ÑïÉùÆ÷CUT /¸ôÀ빦ÄÜ¡£
; k, C/ K6 o( h. g9 q5 o% {¿ØÖÆÌ¨¿É¿ØµÄ¶À×àºÍ¼àÌýϵͳ¡£ ; R4 |% ^. j( f' A" M
Óû§¿É×Ô¶¨Òå¼àÁ¿ÒôÁ¿µÄ²Î¿¼ºÍDIMµçƽ¡£
$ |0 F% Z! f7 `ÄÚÖ÷ۺìÔëÉù·¢ÉúÆ÷¡£
# p0 L: n; y0 y2 T& K²Î¿¼¹ìµÀÊäÈë¡£
A% v- ^8 o4 t6 UÓÐÇåÎúµÄ״ָ̬ʾºÍÈËÌ幤ѧ¿ØÖƽçÃæ¡£
6 U! }$ r1 `: y2 P9 |Nominal levels: +4 dBu 3 K! K0 M: ]4 ?7 B+ G/ m+ ~* Q
Maximum input: > +20 dBu ) C) i: e ?; m0 X2 }
Maximum output: >+20 dBu , S, y$ @+ a0 r+ }
Frequency response: ¡À0.25 dB, 22 Hz -22 kHz
: q8 Y! N' I) m4 ETHD and noise: @+4 dBu, 1 kHz <0.003% ) ?6 {* Y# ~1 Y2 _5 K
Noise: 22 Hz - 22 kHz, -92dB 2 f k+ B' j4 K& I: g
Crosstalk (source/source): 1 kHz >80 dB + k3 w8 o$ l* n: F4 z% C8 \
Channel tracking: 0 to -24 dB ¡À0.25 dB
% b$ s- G" o6 r, s' z+ a' C5 L/ b" b" s7 T$ z* T6 Q9 f$ b6 p( R
ϵͳÁ¬½Ó£º
3 t5 z, p$ C8 b3 p25pin D-type females for: 5.1 Surround play A and B, 5.1 Surround bus inputs, Stereo record/transmission & play Console interface Decoder. . [; d- S/ o; |8 h2 R3 F* p
25pin D-type males for: 5.1 Surround record A and B, Speaker outputs, Encoder & a3 ?- M" {+ A! q8 `
RJ45 -¿ØÖÆÃæ°åÓëÖ÷»úÏàÁª
$ z3 M: X5 X; g6 F7 q8 l; j& _/ D
³ß´ç£º
: {# \/ J' U* ~& s6 ]; U4 X8 OÖ÷»ú: 1U x 280 mm ' M3 W0 K/ w9 `5 ^9 p! l/ _
¿ØÖÆÃæ°å: W 230 mm D 120 mm H 40 mm ) M$ `8 r. s) X+ M
µçѹ£º115/230V at 50-60 Hz (50VA) |
