ßB½Y:https://www.waves.com/support/ho ... gins-in-logic-pro-x
: C) i2 ~% u/ b, b( @) Z, Y% o1 b' ]$ l1 c0 g9 G# W5 ^, C6 |
ÕûƪƒÈÈÝÎÒÖ±½ÓÙNÔÚÏÂÃæ,½oÄú…¢¿¼¿´¿´,‘ªÔ“²»ëy,µ«¾ÍÊÇÓÐüc·±¬�,ÕˆÔ‡Ô‡¿´¡£;): H/ x. Q. j$ A. `! t
8 ^: [. |8 k( z! _: h$ qStep #1 ¨C Verify plugin software is correctly installed% i5 W5 A+ S' l9 T
5 r8 R3 _% P6 `: A$ Q3 ~! [First, check whether the relevant plugin file/s are correctly installed on your computer: ! p9 p0 V' T9 B, L
/ R7 X* M# C+ ~$ w! Z( M+ \, aGo to Macintosh HD > Applications > Waves > Plug-Ins V9.
. A8 X3 e; ?% W9 A+ N6 d* A: O6 \ }# U7 j0 {9 J L
The relevant plugin file will be named after the plugin, in this format: [PluginName].bundle. For example, the plugin file for Reel ADT will be named Reel ADT.bundle.
/ u% m. D) ^. ^5 j0 e; ?2 i6 m! E# P0 n% n
If the plugins you are looking for are not there, install the plugins by following the instructions in this link.. `+ E: x3 }' ^+ Z' y
+ E% \! O- _! z& k9 {* aStep #2 ¨C Rescan for Plugins2 a. a" w) |# ]( Y/ K
, z+ f& }6 G7 X. ~3 i$ l& gIf the relevant plugin files are in the above folders, restart your computer, launch Logic and see if the issue persists.6 ^" A- r& i* x: {9 [
. V+ |1 ?( r1 ]( q) i' ?* vIf the issue persists, perform a rescan:. e$ [8 ^6 P4 v( P7 m+ J( g. I9 m
) k9 ?# |0 f7 Y1 {Quit Logic.0 M/ T4 E& y) M" {* b$ j
In Finder, click on the Go menu, hold down the [Alt/Option] key and click on Library.9 Q4 P8 J% E6 O( k: P- K8 b
Go to Caches > AudioUnitsCache and move com.apple.audiounits.cache to your desktop.
1 q# q+ N# U4 `# I' `8 f0 Q5 ~In the same Library, now go to Preferences and move the Waves Preferences folder to your desktop.
/ g+ Y6 S2 n; C# J. w8 q& M: ]Go to Macintosh HD > Applications > Waves > Waveshells V9 and run the Waves AU Reg Utility 9.X, I9 N) u. l2 e
Click on Let¡¯s Go.
9 o/ E: d0 o2 a2 F% w1 F# AIf asked to Locate the Waves Plugins Folder, direct to Macintosh HD > Applications > Waves > Plug-Ins V9. S/ k5 S& ~) Z2 }9 Q) o
Launch Logic, go to Logic > Preferences > Plug-ins Manager.1 E) I4 ]6 ~2 {. w9 A4 C \ P
Make sure your Waves plugins are check-marked. If they are not, highlight all Waves listings and click Reset & Rescan Selection.
, x! O5 ^: r, V5 i* mCreate a new project with a supported sample rate, add a track and load your Waves plugins. |
