查看: 20997|回复: 2
[音效] CyberLink AudioDirector 6 智能音频编辑软件音效编辑工具
6万
音频应用高级会员
Rank: 7Rank: 7Rank: 7
发表于 2009-2-21 12:29:35 | 显示全部楼层 |阅读模式
     《AudioDirecto6r》是一款功能完善性能强大的音频编辑器。《AudioDirector6》拥有极为顺畅、无接缝的音效/视频工作流程,利用直觉式录音及混音工具,创作独一无二听觉特效,使用专业级视觉修复工具,移除多余声音,将声音还原至最纯净状态。如果你是喜欢音乐的朋友,那你一定不能错过它!
      绝佳音效让你的影音声视同样动人,更能为你的美妙创作画龙点睛!AudioDirector6内建全方位工具及直觉式接口,显著改善声音表现,完成音效创作就是如此简单。它更与威力导演完美整合,带来更高效率的创作流程,大幅缩短工作时间。
     运用AudioDirector6,即可先行编辑及修复视频音效表现,并与威力导演完美整合,快速接续创作。轻松拥有最顺畅及无缝式影音剪辑流程,大幅缩短工作所需时间。
AudioDirector 6极致版 - 创造声音无限可能、视频声动精彩! 立即试用,感受强大声音编辑魅力:
— 动态强化视频的声音质量,自打造精准的5.1或7.1声道动态环场音效
— 与威力导演完美整合,拥有极为顺畅、无接缝的音效/视频工作流程
— 利用直觉式录音及混音工具,创作独一无二听觉特效
— 使用专业级视觉修复工具,移除多余声音,将声音还原至最纯净状态
— 从DirectorZone云端资源网站免费下载各式音效风格文件套用至剪辑项目
— 使用iPhone app – AudioClipper随时录制各种声音并汇入使用
CyberLink AudioDirector Ultra 6.x Multilingual | 165 Mb
Audio is half of the movie experience, and improving the audio in video projects dramatically enhances the final result. AudioDirector contains cutting-edge tools that make editing and fixing audio tracks fast and **. With end-to-end audio features and seamless integration with PowerDirector, AudioDirector is a must-have application for extreme video makers.
Round-trip Editing
AudioDirector works flawlessly with PowerDirector, providing effortless round-trip editing. With round-trip editing there is no need to export your modified sound tracks and then re-import them your into your video project.
Support for H.265 Standard
High Efficiency Video Coding (HEVC) offers up to double the data compression ratio of H.264 at the same level of video quality. You can now also import and edit HEVC (H.265) video in MP4 and MKV file formats.
CyberLink Cloud Services
With CyberLink Cloud, you get fast and convenient uploading, dowloading, and sharing of your media creations. Cloud storage of all of your projects and settings allows for instant access when you need it most.
Synchronize Audio and Effects
Synchronize voice-overs or audio effects to specific video frames using a visually-referenced editing tool that also allows corrections to AV sync issues caused by equipment.
Popular Video Format Support
Import a wide range of video formats, including AVI, DivX, DV-AVI, DVR-MS, HD MPEG-2, M2T, MKV, MOD, MOV, MOV, MP4, MPEG-1, MPEG-2, WMV, and WMV-HD. Utra HD 2K & 4K resolution is also supported.
... and much more.
CyberLink AudioDirector 6 全方位音效编辑工具|智能音频编辑软件
CyberLink AudioDirector.txt (100 Bytes, 下载次数: 0)
4710
发表于 2009-2-22 02:42:58 | 显示全部楼层
........................下载等级不够啊
117
发表于 2009-5-17 05:29:44 | 显示全部楼层
GMT+8, 2025-7-18 14:45 , Processed in 0.030727 second(s), 8 queries , Redis On.
