´øÄãÉîÈëÁ˽â¸÷Àà·ç¸ñµÄ»ìÏì
»ìÒô
¼àÌýÒôÏä¡¢»°Í²¡¢Ê°Òô¡¢ÒôÀÖ¡¢ÖÆ×÷¡¢VST¡¢RATS¡¢AU¡¢
Pro Tools¡¢Pyramix¡¢Logic¡¢Digital Performer¡¢
SAW Studio¡¢Cubase¡¢SONAR¡¢SAM¡¢¡­
Let's Start!
Air - causes sound to lose energy and tends to swallow up higher freq.'s
¿ÕÆø£­µ¼ÖÂÉùÒôÄÜÁ¿µÄËðʧÒÔ¼°¸ßƵËðʧµÄÔ­Òò¡£
Humidity - has an effect on the freq.'s as well.
¿ÕÆøÊª¶È£­Í¬Ñù¶ÔƵÂÊÓÐЧ¹ûÓ°Ïì¡£
Temperature - will effect the sound by breaking the "beam" of the wave as it moves between different temperatures. An open-air concert will have different sound during the day then at night.
ζȣ­ÔÚ²»Í¬µÄζÈÏ£¬¶¼»á¶ÔÉùÒô´«²¥Óв»Í¬µÄ×赲Ч¹û¡£Ò»¸ö¶ÌìÑݳª»áÔÚ°×ÌìºÍÍíÉÏ£¬ÉùÒôÉ϶¼Óв»Í¬¡£
Reflections - sound waves are reflected from objects and it changes it's angle. Important - the wave doesn't stop after one hit but it continues on to hit more surfaces until it losses so much energy that we can't hear it any more. We hear the different reflections because it comes to our ears at different times and at different levels. The more reflections, the less powerful we hear the sound. It losses energy due to...
·´É䣭Éù²¨»á±»ÎïÌå·´ÉäÒѾ­¸Ä±äËûµÄ½Ç¶È¡£ÖØÒªµÄÒ»µã£ºÉù²¨²»»áÔÚײ»÷ÎïÌåÒÔºó¾ÍÍ£Ö¹´«²¥£¬µ«ÊÇÔÚ¼ÌÐø×²»÷¶à´Î·´ÉäÃæ£¨Æ½Ã棩ÒÔºó£¬Éù²¨»áÏûºÄ´óÁ¿µÄÄÜÁ¿£¬Ö±´ïÎÒÃÇÎÞ·¨Ìýµ½ÈçºÎµÄÉùÒôλÖá£ÎÒÃÇÄÜÌýµ½²»Í¬µÄ·´ÉäÉù£¬ÊÇÒòΪÉùÒôµ½´ïÎÒÃǶú¶äµÄʱ¼ä²»Í¬ÒÔ¼°ÉùÒô´óС²»Í¬¡£Ô½¶à´ÎµÄ·´É䣬ÎÒÃÇÌýµ½µÄÉùÒô¾ÍԽС¡£
Absorption - as the wave hit's a surface, it is reflected. But, part of it is absorbed in the surface, thus, the reflected wave losses some of its energy. The amount absorbed is dependent on the material of the surface it hits. Of course it will also effect the freq.'s, and the reflected sound we'll be different then before it hit the surface, although some material (like wood) have less of a impact on the sound. In a concert hall, the audience will absorb some of the reflections as well as the chairs (with padding? without?).
ÎüÊÕ£­Èç¹ûÉùÒôײ»÷µ½Ò»¸öÆ½Ãæ£¬ÉùÒô¾ÍÊDZ»·´Éä¡£µ«ÊÇÒ»²¿·ÖµÄÉùÒô»á±»·´ÉäÃæÎüÊÕ£¬Òò´Ë±»·´ÉäµÄÉùÒô»áʧȥһ²¿·ÖµÄÄÜÁ¿¡£·´ÉäÃæµÄÎüÊÕÁ¿ÊÇÓÉÉù²¨×²»÷·´ÉäÃæµÄ²ÄÖÊËù¾ö¶¨¡£µ±È»·´ÉäÒ²ÊÇ»áÓ°Ïìµ½ÉùÒôµÄƵÂÊ£¬ÉùÒô±»·´ÉäµÄǰºó¶ÔÕÕ£¬ÊÇÓв»Í¬µÄ£¬¾¡¹ÜһЩ²ÄÁÏ£¨ÀýÈçľ²Ä£©¶ÔÉùÒôµÄÓ°ÏìºÜС¡£ÔÚÒ»¸öÑݳª´óÌüÀïÃæ£¬ÌýÖÚºÍÒÎ×Ó¶¼ÄÜÎüÊÕÒ»²¿·ÖµÄ·´ÉäÉù¡£
Reverberation - The size of the hall and it's absorption conditions will have an impact on the volume of the sound (in different halls the same guitar can sound loud or soft) and it's reverb quality.
»ØÏ죭´óÌõĴóС£¬ÒѾ­´óÌõÄÎüÊÕ»·¾³£¨ÏÞÖÆ£©»á¶ÔÉùÒôµÄ´óСÓÐÓ°Ï죨ÔÚ²»Í¬µÄ´óÌÃÀïÃæ£¬Í¬ÑùµÄ¼ªËûÌýÆðÀ´»áÓв»Í¬£¬¿ÉÄÜ´óÉù¿ÉÄÜСÉù£©£¬ÒÔ¼°ËûµÄ»ìÏìÖÊÁ¿¡£
When the direct source stops singing/playing, the waves continue to reflect off of objects, creating a mesh of echoes (losing energy at the same time) until it dies away. This is known as reverberation. The time it takes for the reverberation to die away is called reverberation time, or decay time.
µ±Ö±´ïÉùÔ´Í£Ö¹²¥·Å/Ñݳª£¬Éù²¨»¹ÔÚ¿Õ¼äÀïÃæ½øÐз´É䣬½¨Á¢³öÒ»¸ö»ØÒôÍø£¨Óë´ËÄÜÁ¿Ò²ÕýÔÚÏûºÄ£©Ö±µ½ÉùÒôÏûʧΪֹ¡£Õâ¸öÏÖÏó±»³ÉΪ»ØÏì¡£»ØÏì´Ó³öÏÖµ½ÏûʧµÄʱ¼ä±»³ÉΪµÄdecay¡£
The more absorption in a hall - the shorter the decay time.
£¨´óÌüÎüÊÕÔ½À÷º¦£¬decay time Ô½ÉÙ£©
The bigger the hall - the longer the decay time (it takes more time between reflections as they hit each object).
£¨´óÌüÔ½´ó£¬decay time ¾ÍÔ½³¤£¬ÒòΪÎïÌåÖ®¼äµÄ·´Éäʱ¼ä±äµÃ¸ü³¤ÁË£©
If the decay time is short - the sound will be drier.
£¨Èç¹ûdecay time ¶Ì£¬ÄÇôÉùÒô¾Í»á±äµÃ¸ÉÔ
If the decay time is longer - our sound will seem to sustain. Sort of like using the sustain pedal on a piano, and it can make a small voice sound bigger.Go sing in your shower. Not much absorption in there! Very hard surfaces, thus, longer decay time.
You will not hear the reverb immediately. It has a build up process. At first you will hear the direct sound then early reflections then later reflections, as little by little the multiple reflections will wash together until they die away.
£¨Èç¹ûdecay time ±È½Ï³¤£­ÎÒÃǵÃÉùÒô¾Í»áά³ÖÒ»¸öʱ¼ä¡£ÀýÈç¸ÖÇÙÔËÓõÃÑÓÒô̤°å£¬¶øÇÒÔÚÄãµÃÑݳªÖл¹ÄÜʹµÃÒôÁ¿±ä´ó¡£Èç¹ûÄÇÀïµÄµÄÎüÊÕÂʺÜС£¬·Ç³£Ó²µÄ±íÃæ£¨·´ÉäÃæ£©£¬ÄÇôdecay time »á±ä´ó¡£ÔÚ²úÉú»ìÏìµÄʱºòÄã²»»áÁ¢¿ÌÌýµ½£¬ÒòΪËûÓÐÒ»¸ö±ä´óµÄ¹ý³Ì£¬ÔÚ¶à´Î·´Éäºó£¬ÉùÒô»áÔ½±äԽС£¬ÖªµÀÉùÒôÍêÈ«ÏûʧΪֹ£©
Diffraction - not only will a wave of sound reflect or absorb but it can go over the obstacle. That is why we can hear somebody even with a baffle between.
ÑÜÉ䣭ÉùÒôËäÈ»»á±»·´ÉäÒѾ­ÎüÊÕ£¬µ«ÊÇËûÄÜÈÆ¹ý×èµ²Îï¡£Õâ¸ö¾ÍÊÇΪʲôÄÜÌýµ½Ä³ÈËÔÚ×èµ²ÎïºóÃæËµ¹þµÄÉùÒôÁË¡£
Shape - the shape of a room can have a big effect on the sound. For example, a room with an ellipse shape will cause the sound to focus more at certain points in the room.
I hope you followed until now. If not, don't despair because now we will discuss the reverb unit itself, and you can still pick up some helpful info.
ÐÎ×´£­·¿¼äµÄÐÎ×´»á¶ÔÉùÒôÓÐÒ»¸ö·Ç³£´óµÄÓ°Ïì¡£ÀýÈ磬һ¸öÍÖÔ²Ð͵ķ¿¼ä»áµ¼ÖÂÉùÒô´ó²¿·Ö¾Û½¹ÔÚ·¿¼äµÄijһµã£¨»òÕßij¼¸µã£©¡£ÎÒÏ£ÍûÄãµÄÇé¿öÒ»Ö±¶¼ÊÇÕâÑù£¬Èç¹û²»ÊÇ£¬Ò²²»ÒªÊ§Íû£¬ÎÒÃǽ«»áÔÚ»ìÏìµ¥ÔªÒ»ÕÅÌÖÂÛµ½Ëû£¬ÄãÈÔÈ»ÄÜÔÚÆäÖеõ½°ïÖú¡£
The Reverb Unit£¨»ìÏìµ¥Ôª£©
A reverb unit simulates the sound of different acoustical areas. This area can be as small as a closet or as big as a gym, or even bigger. Digital Reverb can even create spaces that don't exist in reality.
»ìÏìµ¥ÔªÊÇÄ£ÄⲻͬÉùѧ¿Õ¼äÖеÄÉùÒô¡£ÄÜÄ£ÄâµÄ¿Õ¼ä¿ÉÒÔÊÇСµÄ·â±Õ¿Õ¼ä£¬´óµÄÌå²Ù¹Ý£¬»òÕ߯äËû¸ü´óµÄ¡£Êý×Ö»ìÏ컹ÄÜ´´Ôì²»ÕæÊµµÄ¿Õ¼ä¡£
When you combine the direct sound of your instrument with the reflections in the room, decay time, etc., you hear the sonic character of that specific environment. How does the reverb do this? In simple terms, it reproduces Delays and Echoes similar to the reflections of a acoustic space and then combines them and Kazam!, you hear a natural reverb in a room.
µ±Äã°ÉÀÖÆ÷µÄÖ±´ïÉùÒÔ¼°·¿¼äµÄ·´ÉäÉù¡¢decay time µÈµÈÁªÏµÆðÀ´ÒÔºó¡£Äã»áÔÚÌØ¶¨µÄ»·¾³Ìýµ½ÉùÒôµÄÌØÕ÷¡£»ìÏìÊÇÈçºÎ¹¤×÷µÄ£¿ÔÚsimple terms(¼òµ¥ÊõÓï)£¬Ëû¸´ÖÆÁËÑӳٺͻØÒôȥģÄâÉùѧ¿Õ¼äµÄ·´ÉäÒÔ¼°°ÑËûÃÇÁªºÏÆðÀ´and Kazam£¨kazam²»ÖªµÀÊÇʲôÒâ˼£¬ËùÒÔÖ»ÓÐÔ­ÎÄÕÕ³­ÁË£©¡£ÄÇôÄã¾ÍÔÚ·¿¼äÀïÃæÌýµ½Ò»¸ö×ÔÈ»»ìÏìÁË¡£
On each reverb the parameters are set under an algorithm. Here is where you can edit the parameters. Only one problem here, some reverb units works a bit differently. They give their parameters different names and they react differently then you might expect compared to another unit you might know. Every time I come across a unit I don't know well, I have to sit and tweak the parameters quite a bit to understand what effect I'm going to get from this specific parameter.
ÿ»ìÏìµÄ²ÎÊý¶¼ÊÇÉèÖÃÔÚÔËËã·¨Ôò֮ϣ¨¾ÍÊÇËã·¨À²£©¡£Õâ¾ÍÊÇÄãΪʲôÄܱ༭²ÎÊýµÄÔ­ÒòÁË¡£µ«ÊÇÓÐÒ»¸öÎÊÌ⣬һЩ»ìÏìµ¥ÔªµÄ¹¤×÷Çé¿ö»áÓÐÒ»µã²»Í¬¡£¸øÓèËûÃǵIJÎÊýÃû³Æ»áÓв»Í¬ÒÔ¼°×÷ÓÃÉϵIJ»Í¬£¬ÔÚÓëÆäËû²»Í¬µ¥Î»ºóÄã¿ÉÄÜÖªµÀËûÃÇÖ®¼äµÄ²»Í¬¡£
Also, not all Reverbs are created equally. You get what you pay for. You can find nice budget compressors, decent gates or efficient pre-amplifiers. But Reverbs! You got to pay big bucks for a high quality reverb unit, and you will hear the difference!
µ±È»£¬²»ÊÇËùÓлìÏì¶¼±»Éè¼Æ³ÉÏàͬµÄ¡£ÄãÄÜÓÃʲô»ìÏì¾ÍÒª¿´Ä㸶³öµÄ½ðÇ®ÁË£¨Òâ˼¾ÍÊÇÕâÑùÀ²£©¡£Äã¿ÉÒÔÓÃÔ¤ËãÒÔÄÚµÄѹËõÆ÷£¬ÄÜÓùýµÃÈ¥µÄÃÅÏÞ»òÕßÄܸɵÄǰÖ÷Ŵ󣬵«ÊÇÄã±ØÐë°Ñ´ó°ÑµÄ½ðǮͶ×ʵ½Ò»¸ö¸ßÖÊÁ¿µÄ»ìÏìµ¥ÔªÉÏ£¬ÄÇôÄã¾ÍÄÜÌýµ½ËûÃÇÖ®¼äµÄ²»Í¬ÁË¡£
What are the common parameters on Reverbs?.£¨»ìÏìÉϵÄÒ»°ã²ÎÊýÓÐÄÇЩ£¿£©
Reverb types - What type of reverb it is. There are Halls, Rooms, Chambers, Plates, etc...£¨»ìÏìÀàÐÍ£¬ÕâÀï²»ÓÃ˵ÁË£¬½Ó´¥¹ýWAVESµÄÈ˶¼ÖªµÀ£©
Size - What the physical size of the space is. This can range from small through large. Diffusion - How far apart are the reflections from each other.£¨¿Õ¼äµÄÎïÀí´óС£¬²Î¿¼TC»ìÏì¡£À©É¢£¨Ãܶȣ¬diffusion£©£­·´ÉäÉùÖ®¼ä¼ä¸ôµÄ¾àÀ룩¡£
Pre-delay - Sets a time delay between the direct signal and the start of the reverb
£¨Ô¤ÑÓ³Ù£­ÉèÖÃÒ»¸ö¼ÆËãÖ±´ïÐźźͻìÏ쿪ʼµÄÑÓ³Ùʱ¼ä£©
Decay time - The time it takes for the reverb to die away after the direct signal stops.
£¨decay time£­´ÓÖ±´ïÉùÍ£Ö¹¿ªÊ¼£¬µ½»ìÏìʱ¼äÏûʧµÄʱ¼ä£©
Mix (Wet/Dry) - Sets the balance between the dry signal and the effect signal. When it's totally wet, the dry signal is shut off.
£¨»ìºÏ£¬ÕâÀï¾ÍÊǸÉʪ±ÈÀ²¡«ÓùýWAVES RVERBµÄ¶¼Ó¦¸ÃÖªµÀ£©¡£
Early reflection level - Controls the level of the first reflection you hear usually within 50-80 milliseconds.
£¨Ôç·´ÉäÉù£­¿ØÖÆ×îÏȱ»ÄãÌý¼ûµÄ·´ÉäÉùÒô£¬¾­³£ÔÚ50£­80MSÖ®¼ä£©
Hi Freq. Roll Off - Helps control the decay of high Freq.'s (as it's found in natural reverb).
£¨¸ßƵ¹ö½µ£©£­°ïÖú¿ØÖƵÄdecayµÄ¸ßƵ£¨ÓÃÀ´Ä£Äâ×ÔÈ»»ìÏ죩¡£
You can find even more parameters in some reverbs (in the case of a Lexicon PCM 90, you can have up to 90 parameter controls for certain algorithms!), or different names for the same parameters. But if you understand the concepts involved you should have little trouble figuring out parameters from unit to unit. The manual is helpful too.
We could sum up the order of how the parameters effect the sound in this way:
Äã¿ÉÒÔÕÒµ½Ä³Ð©»ìÏìÉÏÕÒµ½¸ü¶àµÄ²ÎÊý¿ØÖÆ£¨ÀýÈçLEXICON PCM 90,Äã¿ÉÒÔÀûÓÃÖÐÐÄËã·¨ÉèÖöà´ó90¸ö²ÎÊý¿ØÖÆ£©£¬»òÕßÏàͬ²ÎÊý²»Í¬µÄÃû×Ö¡£Èç¹ûÄãÃ÷°×ÁËÏà¹ØµÄ¸ÅÄÄÇôÄã¾ÍÄܺÜÈÝÒ×µÄÅжϳö²»Í¬»ìÏìµÄ²ÎÊý¹¦ÄÜÁË¡£µ±È»ÊýÃûÊéÒ²ÊÇÊ®·ÖÓÐÓõġ£ÎÒÃÇÄܰÑËùÓÐÓ°ÏìÉùÒôµÄ²ÎÊýÊýÁ¿×ÛºÏΪÒÔϼ¸¸ö£º
¡¤        Direct Sound £¨Ö±´ïÉùÒô£©
¡¤        Possible pre-delay time £¨¿ÉÄÜÓÐÔ¤ÑÓ³Ù£¬Ä³Ð©»ìÏìÊÇûÓеģ¬ÌرðÊÇÃâ·ÑµÄ²å¼þ£©
¡¤        Early reflections £¨Ôç·´É䣬WAVES/WIZOOµÄ»ìÏì¶¼ÓÐÔç·´É䣬WAVE ARTS ºÃÏñÒ²ÓУ©
¡¤        Late reflections £¨ºó·´É䣬Õâ¸öWAVESÒÔ¼°WIZOO¾Í¾ø¶ÔµÄÓÐÁË£¬ÆäËû²»Çå³þ£©
¡¤        Decay time £¨Õâ¸öÔÚH2O°æ±¾ÀïÃæ¾ÍWAVES/WIZOOºÍTCÓÐÁË£¬ÎÒ˵µÄÊÇH2O°æ±¾£©
Some Audio Examples of Reverb
In order for you to understand these parameters, Audio examples will be used to illustrate different situations in which the various parameters can be put to good use.
ΪÁËÈÃÄãÀí½âÕâЩ²ÎÊý£¬ÄÇЩÉùÒôÀý×ÓÄܰïÖúÄãÁ˽ⲻͬÇé¿öÏÂÓúÃÕâЩ²»Í¬µÄ²ÎÊý¡£
Hall reverbs - This is a simulation of a concert hall. It is one of the smoother and richer sounding reverbs. It usually has a high amount of density.
´óÌûìÏ죭ÕâÊÇÄ£·ÂÒ»¸öÑÝ×àÌü¡£ÊÇÒ»¸öÌýÆðÀ´Ë³»¬ÒÔ¼°¾ßÓзḻ»ØÏìÉùÒô»ìÏ졣ͨ³£ÓµÓбȽϴóµÄÃܶȡ£
Room reverbs - Typically smaller then a Hall but can vary from a very small room to a big room. It can also range from bathrooms (hard surface) to soft sounding rooms (soft surface). A room will provide mostly ambience and will usually have a small decay time.
·¿¼ä»ìÏì¡ªÌØµãÊDZȴóÌüС£¬µ«Êǵ÷½Ú´ÓÒ»¸öºÜСµÄ·¿¼äµ½Ò»¸ö·Ç³£µÄ·¿×Ó¡£Ò²ÄÜÉèÖóɴÓÔ¡ÊÒ£¨´ó·´É䣩µ½ÉùÒôÌýÆðÀ´±È½ÏСµÄ·¿×Ó£¨Ð¡·´É䣩¡£·¿¼äÄÜÌṩ´ó²¿·ÖµÄÆø·ÕÒÔ¼°ÍùÍùÈûìÏìÓµÓÐÒ»¸öСµÄdecay time¡£
Plate reverbs - It simulates a large sheet of metal in a box with a speaker attached to the plate to make it vibrate and mics to pick up the sound. This kind of reverb is very clean and bright sounding.
½ðÊô°å»ìÏ죭ËûÊÇÄ£ÄâÔÚÒ»¸ö¿Õ¼äÀïÃæµÄÒ»´ó¿é±¡½ðÊô£¬ÈÃÀ®°È¸¶ÔÚ½ðÊô°åÉÏ£¬Ê¹µÃ½ðÊô°åÕ𶯣¬Ò»¶¨°ÑÉùÒôÓÃMICÂ¼ÖÆÏÂÀ´¡£Õâ¸öÀàÐ͵ĻìÏìÊ®·ÖÇåÎú£¬ÌýÆðÀ´Ê®·ÖÃ÷ÁÁ¡£
         Õæ°å»ìÏìÊÔÌýVerb1.mp3
Õâ¸ö¾ÍÊÇÒ»¸öÕæÕýµÄ½ðÊô°å»ìÏ죬ÎÒÏëÔÚµ±½ñÊÀ½çÉÏÒ²Ö»ÓÐ100¸ö»¹ÔÚ¹¤×÷¡£Ò»¿ªÊ¼µÄËĸöС½ÚÊǸÉÉù£¬È»ºó4С ½ÚЧ¹ûÉù
Let's Get Practical Here!(ÈÃÎÒÃÇʵ¼ùһϰÉ)
What's important here is not how I would use reverb (this is a subjective matter and what works for me may not work for you) but to understand the outcome of adjusting any parameter. If you can conclude what will happen as you change each parameter, you will be well on your way to use reverb effectively!
Ó¦¸ÃÈçºÎÓûìÏ죬ÔÚÕâÀï²»ÊÇ×îÖØÒªµÄ£¨ÕâÊÇÒ»¸öÖ÷¹ÛÎÊÌ⣬¿ÉÄÜÊʺÏÄ㣬µ«²»ÊʺÏÎÒ£©£¬µ«ÊÇÒªÁ˽âÿһ¸ö²ÎÊýÔÚµ÷ÕûÒÔºó½á¹ûÊÇʲô¡£Èç¹ûÄãÄÜÅжϳöÄãËù¶¯µÄ²ÎÊý»á·¢ÉúʲôÊÂÇ飬ÄÇôÄ㽫»áºÜÓÐЧµØÔËÓûìÏì¡£
So, how do we use the various parameters?Lets start with Rooms.
ÄÇô£¬ÎÒÃÇÓ¦¸ÃÈçºÎÔËÓÃÕâЩ²»Í¬µÄ²ÎÊýÄØ£¿ÈÃÎÒÃÇ´Ó·¿¼ä£¨»ìÏ죩¿ªÊ¼¡£
The type of room you use is a personal choice, but certain music styles might just sound more natural in a certain type of room. Examples of this could be Classical music in a hall, or Jazz in a small to medium room.
·¿¼äµÄÀàÐ͵ÄÔËÓÃÊÇÒ»¸ö¸öÈË·ç¸ñ£¬µ«Ä³¼¸ÖÖÒôÀÖ·ç¸ñ¾Í±ØÐëÒªÔÚij¼¯Öз¿¼äÀàÐÍÖвÅÄܸü×ÔÈ»¡£ÀýÈç½»ÏìÀÖÒªÔÚ´óÌüÀïÃæÑÝ×࣬JAZZÒªÔÚС·¿×Ó»òÕßÖеȷ¿×ÓÀïÃæÒ»Ñù¡£
Here is some very General uses for room types that I like (remember, each to his own).
ÕâÀïÓÐһЩÎÒϲ»¶µÄ·¿¼äÀàÐ͵Ļù±¾Ó÷¨£¨¼Çס£¬Ã¿¸öÈ˶¼ÓÐËûÃÇ×Ô¼ºµÄÓ÷¨£¬²»ÒªÒ»¸Å¶øÂÛ£©
Rooms - since they have a short decay time this can help your mix sound clearer. Try to use them on pop mixes and some Hip-hop productions.
A tight room can be great for a piano (see also plate on piano).
Try to use bright rooms with short decay for things like - pop brass -blues/rhythm guitar - Hip-hop drums - Backing vocals.
Try to use with medium decay, things like drums - pop piano - rhythm E. guitars - bass - vocals - percussion - acoustic guitar - string quartet.
Try to use with longer decays, things like - solo instruments - rock drums - Ballad percussion -synth pads - Short cymbals - solo acoustic guitar ¨C strings
·¿¼ä»ìÏ졪¡ªÒòΪ·¿¼ä¾ßÓбȽ϶̵Ädecay time£¬Õâ¸öÌØµãÄܰïÖúµÄMIX±äµÃ¸É¾»¡£³¢ÊÔ°ÑËûÃÇÔËÓÃÓÚÁ÷ÐÐÒôÀÖµÄMIX£¬ÒÔ¼°Ò»Ð©HIP-HOPµÄÖÆ×÷ÖС£
Ò»¸öÃÜ·âµÄ·¿¼ä£¬ÄÜÈøÖÇٵĻìÏì·Ç³£ÓÅÐã¡££¨¸Ö°å»ìÏìÒ²ÓÐͬÑùµÄЧ¹û£©¡£
Ã÷ÁÁµÄ·¿¼ä»ìÏì·ç¸ñ£¬ÓµÓжÌdecay time£¬³¢ÊÔ°ÑËûÓÃÔÚBLUES µÄ POP BRASS(Ó¦¸ÃÊÇËûÃǵÄÍ­¹ÜÀÖÆ÷°É)/½Ú×༪Ëû¡¢HIP-HOPµÄ¹ÄÉù¡¢±³¾°ÈËÉù¡£
³¢ÊÔ°ÑÒ»¸öÖеÈdecay time µÄ·¿¼ä»ìÏìÔËÓÃÓÚ ¹ÄÉù¡¢Á÷ÐиÖÇÙ¡¢½Ú×àµç×Ó¼ªËû¡¢±´Ë¾¡¢ÈËÉù¡¢´ò»÷ÀÖ¡¢Éùѧ¼ªËû¡¢ÏÒÀÖËÄÖØ×à¡£
³¢Ê԰ѱȽϳ¤µÄdecay time ÔËÓÃÔÚ ÀÖÆ÷¶À×à¡¢ROCK DURMS¡¢ÃñÒ¥´ò»÷ÀÖ¡¢ºÏ³É³Äµ×¡¢Short cymbal£¨ÎÒµÄÖÐÎÄ´ò×Ö·¨ÎÞ·¨Êä³öÕâ¸öÖÐÎĽâÎö£¬ÓôÃÆ£©¡¢Éùѧ¼ªËû¶À×à¡¢ÏÒÀÖ¡£
»ìÏìÊÔÌýVerb2.mp3
ÖÃÓÚÕâ¸öÀý×ÓµÄDELAYÊÇ4¸É£­¡·4¶Ì£­¡·¸É£­¡·4ÖУ­¡·4¸É£­¡·4³¤¡£
Halls - The use of a hall can push your sound back in the mix and make your drums sound big, but can also make your mix muddy due to it's larger response to lower freq.'s and longer decay time. So on a Ballad you might prefer a hall because it fills the sound well. On a solo piano in a Ballad this can sound great. But on a fast tempo song you have to use so much effect to hear it and this would result in a muddy mix.
Another example would be strings - A hall can smooth the harshness of a synth pad and make any sample sound more realistic due to the full sound a hall gives, especially with a long decay.
Careful using this type with different sounds that are not of the same character.
Try to use it on orchestras - choir's - strings - rock drums - Big bands - acoustic instruments - ethnic style music.
´óÌü»ìÏ졪¡ªÔËÓôóÌü·ç¸ñ£¬ÄÜÈÃÄãµÄÉùÒôÔÚMIXÖеĻìÏìÀ©´óµ½ºóÃæ£¨ÎÒÏëÊÇÕâÑù½âÊͰɣ©£¬¶øÇÒ»¹ÄÜÌá¸ßÄãµÄ¹ÄÉùÒôÁ¿£¬µ«ÊÇÒ²ÄÜÈÃÄãµÄ»ìÏì±äµÃäã×Ç£¬ÒòΪ´óÌü»ìÏì¶ÔµÍƵ·´Ó¦ºÜ´ó£¬ÒÔ¼°Óкܳ¤µÄDECAY TIME¡£ËùÒÔÄã¿ÉÒÔ°Ñ´óÌü»ìÏìÓÃÔÚÃñÒ¥ÉÏ£¬ÒòΪÕâ¸öÊʺÏÃñÒ¥µÄÉùÒôÒѾ­³äÂúÁ˸ÐÇ飨·Ç³£±¥Âú£©¡£¶øÃñÒ¥ÖеĶÀ×à¸ÖÇÙÔÚ´óÌü»ìÏìÖлáÓкܺÃÉùÒô¡£µ«Ò»¸ö½Ú×à¿ìµÄ¸èÇúÓÃÁ˺ܶàµÄЧ¹û£¬ÄÇôÄãµÄMIX¾Í»á±äµÃäã×Ç¡£
¶øÁíÍâÒ»¸öÀý×ÓÊÇÓÃÓÚÏÒÀÖ¡ª¡ª´óÌÃÄÜÈôֲڵÄsynth pad£¨Õâ¸öÕæµÄ²»»á·­Ò룩±äµÃ˳»¬ÁÒÔ¼°ÈÃÈκμòµ¥µÄ±äµÃèòèòÈçÉú£¬ÕâÊÇÒòΪ´óÌÃÄÜÈÃÉùÒô±ä´ó±¥Âú£¨À©É¢µ½¿ªÀ´£©£¬Êµ¼ÊÉϾÍÊÇÒ»¸ö³¤decay¡£
СÐĵÃÔËÓÃÕâ¸öÀàÐ͵ûìÏ죬²»Í¬µÄÒôÀÖÌØÖÆ£¨ÌØÐÔ£¬Ìص㣩ÌýÆðÀ´¶¼»áÓв»Í¬µÄ¸Ð¾õ¡£³¢ÊÔ°ÑÕâ¸öÀàÐ͵ĻìÏìÓÃÓÚÕâÀ¹ÜÏÒÀÖ£­ºÏ³ª£¨³ªÊ«°à£©£­strings£¨ÕâÀïÓ¦¸Ã·­Òë³ÉÏÒÀÖ°É£©£­ROCK DURMS£­big bands£¨ºÜ´óµÄÀÖ¶Ó£¿HOHO£©£­ÉùѧÀÖÆ÷£­ethnic style music£¨Òì×å·ç¸ñµÄÒôÀÖ£©
Plates - No two plates sound the same so beware as you switch from one reverb unit to another. A plate works very well on fast tempo songs. You can hear the effect without over doing it. Also on Trumpets a good plate can enhance the brilliance. Another example - If you want to mix in a piano but you know that using a "hall" might push your piano to the far end of the room or clutter the mix, use a short plate with a short pre-delay and you'll get a nice effect with the closeness you want.
I like Plates on vocals - percussion - woodwinds - Jazz drums - strings - trumpets - acoustic instruments ¨C guitar
½ðÊô°å»ìÏ졪ûÓÐÁ½¿éÉùÒôÒ»ÑùµÄ½ðÊô°å£¬ËùÒÔÄãÑ¡Ôñ»ìÏìÔª¼þµÄʱºò¾ÍҪСÐÄÑ¡ÔñÁË¡£ÔÚ¿ìÅÄ×ӵĸèÇúÀïÃæ½ðÊô°å»ìÏìÓзdz£ºÃµÄ±íÏÖ¡£Äã²»ÐèÒª¹ý¶àµÄµ÷Õû¾ÍÄÜÌýµ½Ð§¹ûÁË¡£ÎªÐ¡ºÅ¼ÓÉÏÒ»¸ö½ðÊô°å»ìÏ죬ÄÜÈÃÄãµÄСºÅ¸üÃ÷ÁÁ¡¢¸ü³öÉ«¡£ÁíÍâÒ»¸öÀý×Ó¡ª¡ªÈç¹ûÄãÐèҪΪһ¸ö¸ÖÇÙ¼Ó»ìÏ죬µ«ÊÇÄãÖªµÀÈç¹ûÓá°HALL¡±»ìÏìʹµÃÉùÒô±»ÍÆÏò·¿¼äÔ¶¶Ë,»òÕßÈÃÕû¸öMIX±äµÃ»ìÂÒ£¬¶øÓÃÒ»¸ö¶Ì½ðÊô°å»ìÏ죬ÅäºÏ¶ÌµÄPRE-DELAY£¨Ô¤ÑÓ³Ù£©£¬ÄÇô¾Í»áÈøÖÇÙÓµÓÐÊ®·ÖºÃµÄЧ¹û£¬È»¶øÔÚ·â±ÕµÄ¿Õ¼äÖУ¬Õâ¸öЧ¹ûÊÇÄãËùÐèÒªµÄ£¨ÕâÀïÓвÂÏëµÄ³É·Ö£©¡£
ÎÒϲ»¶°Ñ½ðÊô°å»ìÏìÓÃÔÚ ÈËÉù£­´ò»÷ÀÖ£­Ä¾¹ÜÀÖÆ÷£­Jazz ¹Ä£­ÏÒÀÖ£­Ð¡ºÅ£­ÉùѧÀÖÆ÷£­¼ªËû¡£
Gated/reverse reverb - I like to use on pop/rock drums - bass - E. guitar
ÃÅÏÞ»ìÏìºÍ·´Ïò»ìÏ죭ÎÒϲ»¶ÔÚPOP/ROCK ¹Ä£­±´Ë¾£­µç¼ªËûÉÏÓá£
Size - It means just what it would seem to be, the size of the room. Usually you can select small, medium, and large.
·¿¼ä´óС£­·¿¼äµÄ´óСͨ³£¿ÉÒÔÑ¡Ôñ´óÖÐС¡£
Why is size important?
Lets use an example. You have drums that sound good with your chosen reverb but as you hear it in the mix with those heavy guitars, it sounds a bit to small. Enlarge the size of your chosen reverb and you now have a bigger drum sound.
In a smaller room size you will have more direct sound, but the sound will decay faster.
Let's say I want a big lush sound. After reading the preceding lines we can come to the conclusion that, if I use a small Room on a sting patch, this will give me a sound as if it was recorded with a mic in a small room. In other words, ambience. Now if I add another reverb to this string sound (Yes a double reverb), lets say a hall, I will get a lush string sound.
ÈÃÎÒÃÇÔËÓÃÒ»¸öÀý×ÓÀ´ËµÃ÷°É¡£ÄãÏÖÔÚÓÐÒ»¸ö¹ÄÉù£¬ÄãÑ¡ÔñµÄ»ìÏìÈÃÄãµÄ¹ÄÉùÊ®·ÖÔöú£¬¿ÉϧÔÚMIXÖкÍheavy£¨ÉùÒô±È½ÏÖØ£©¼ªËû¶Ô±È£¬×ÜÊǾõµÃÓеãСÉù¡£°Ñ»ìÏìµÄSIZE²ÎÊýÌá¸ß£¬ÄÇôÄãÏÖÔڵĹÄÉù¾Í±ä´óÁË£¨Êǵ÷Õû¹ÄÉùµÄ»ìÏì°¡£¬Èç¹ûÄãÊÇÓÃAUXһͬ·¢Ë͵ģ¬Õâ¸ö·½·¨²»ÊÇ×îºÃµÄ°ì·¨£©¡£
ÔÚÒ»¸öС·¿¼äÀïÃæ£¬Äã»áÓиü¶àµÄÖ±´ïÉù£¨¸ÉÉù£©£¬µ«ÊÇÉùÒô»áºÜ¿ìµÄË¥¼õ£¨decay£©¡£
¼Ù¶¨ÎÒÒªÒ»¸öÊ®·ÖºÀ»ªµÄÉùÒô£¬ÔÚÔĶÁÍêÉÏÃæÒÔºó£¬ÎÒÃǵóöÕâÑùµÄ½áÂÛ£¬Èç¹ûÎÒ¶ÔÏÒÀÖÔËÓÃÒ»¸öС·¿¼äÀàÐ͵ĻìÏ죬ÄÇôÕâÑù¾Í»áÈÃÎÒ¾õµÃÉùÒôºÃÏñÊÇÔÚÒ»¸öС·¿¼äÀïÃæÂ¼ÖÆµÄ¡£»»¾ä»°Ëµ£¬¾ÍÊÇȱÉÙÆø·Õ£¨ÕâÀïÎÒ¾õµÃÊÇתÕÛµÄÒâ˼£©¡£ÏÖÔÚ£¬Èç¹û°ÑÁíÍâÒ»¸ö»ìÏì¼ÓÔÚÏÒÀÖÉÏ£¨Ë«»ìÏ죩£¬ÎÒÃǼÙÉèÊÇÒ»¸ö¡°hall¡±µÄ»ìÏ죬ÄÇôÎҾͻáµÃµ½ºÀ»ªµÄÏÒÀÖÁË¡£
»ìÏì¿Õ¼äµÄÉèÖôÓС±ä´ó£¬×ÐϸÌýSNAREµÄÉùÒô
Use of pre-delay - Why would I want to delay the reverb a bit to hear the instrument dry for a couple of milliseconds? Clarity is the key word. I can use the pre-delay to help move the sound in the stereo spectrum and to help the mix sound clearer and punchier. For example you can get a tighter mix and also help the text be much clearer using a long pre-delay on a small voice. This can give it a bigger sound.
ÔËÓÃPRE-DELAY(Ô¤ÑÓ³Ù)£­ÎªÊ²Ã´ÎÒΪÁËÒªÌýÄÇô¼¸ºÁÃëµÄÀÖÆ÷¸ÉÉùÒô£¬¶øÎª»ìÏì¼ÓÈëÑÓ³ÙÄØ£¿ÇåÎú¡«¾ÍÊÇÕâÑù×öµÄÔ­Òò¡£ÎÒÄÜÔËÓÃpre£­delayÈ¥°ïÖúÔÚÁ¢ÌåÉùƵÆ×ÖÐÒÆ¶¯ÉùÒô£¨ÓÐÕâ»áÊÂÇ飿ÎÒ»¹ÊǵÚÒ»´ÎÖªµÀ£¬¿ÉÄÜÊÇ¸Ä±äÆµÂʰɣ©ÒÔ¼°Ê¹µÃ»ìÏìµÄÉùÒôÌýÆðÀ´¸ü¼ÓÇåÎú£¬¸ü¼ÓÓÐÁ¦¡£ÀýÈçÄãÔÚÒ»¸öСµÄÈËÉùÉϼÓÈë±È½Ï³¤µÄpre£­delay£¬Äã¿ÉÒÔ»ñµÃÒ»¸ö½ô´ÕµÄMIXÒÔ¼°ÈÃÈËÉù¸üÇåÎú£¬¶øÇÒ»¹ÄÜÈÃÈËÉù±ä´ó¡£Pre£­delayÄÜÈÃÉùÒô±ä´ó¡£
A little pre-delay on Brass can simulate the typical feeling of hearing a brass section in a hall. First you hear the direct sound, then you hear the room reverberation.
Ò»µãµãpre£­delay¼ÓÔÚbrass£¨Í­¹ÜÀÖÆ÷£©ÉÏ£¬ÄÜÄ£ÄâÒ»×ébrassÔÚ´óÌüµÄÑÝ×àµÄ¸Ð¾õ¡£Ê×ÏÈÄãÌýµ½µÄÊÇÖ±´ïÉùÒô£¬È»ºóÄã¾ÍÌýµ½Á˱»ÑӳٵĻìÏìÉùÒôÁË¡£
On Vocals the pre-delay can simulate a "slap-back delay" effect. First you hear the dry vocals, then you hear the delay (due to the pre-delay setting) and then you hear the reverb fill out the sound. This is why every vocal note and lyric is clear.
ÔÚÈËÉùÉÏÓÃpre£­delayÄÜÄ£Äâ"slap-back delay"£¨²»ÖªµÀslap£­backÊÇʲôÒâ˼°¡£©µÄЧ¹û¡£Ê×ÏÈÄãÌýµ½ÁËÈËÉù¸ÉÉù£¬È»ºóÄãÌýµ½ÑÓ³Ù£¨pre£­delayÉèÖõĽá¹û£©£¬È»ºóÌýµ½»ìÏ쿪ʼ±ä´óµÄÉùÒô¡£Õâ¸ö¾ÍÊÇΪʲôÿһ¸öÈËÉùµÄÒô·ûºÍ¸è´Ê¶¼ÊÇÇåÎúµÄÔ­ÒòÀ²¡£
ÆÀÂÛÁÐ±í£¨2£©
phnxaudio Â¥Ö÷
һЩ²Î¿¼²ÎÊý
Use of Decay - The thing to understand about decay is that the longer the decay, the more the sound washes your mix. Too much and you'll lose clarity. You want a big hall sound? Great, but keep the decay under control. You like the sound of a big decay? Then keep the wet/dry of the effect low to keep the sound from getting lost in the mix.
ÔËÓÃdecay£­decayÊÇÄãÒªÁ˽âµÄ¶«Î÷£¬Ô½³¤µÄdecay£¬MIX¾ÍÔ½ÊDZ»decay³åÊ´¡£ÄãÏëÒªÒ»¸ö´óÌõÄÉùÒô£¿ºÃ£¬µ«±ØÐë±£³ÖdecayÔÚ¿ØÖÆÖ®ÄÚ¡£Äãϲ»¶´óDECAYµÄÉùÒô£¬ÄÇôÄã¾Í±£³ÖµÍ¸Éʪ±È£¬ÒԴ˱£³ÖÔÚMIXÖмõÉÙÉùÒôµÄ£¨ÖÊÁ¿£©µÄÁ÷ʧ¡£
Changing this parameter will enlarge your room size. The more the room is filled with absorbent the faster the sound decays. If you do a sound check before people walk in to the hall, expect it to sound different when they are sitting down! Too long of a decay time will usually mess up your mix, Keep it as long as needed, not longer.
µ÷´óÕâ¸ö²ÎÊý£¬ÄÜÈÃÄãµÄ·¿¼ä±ä´ó¡£·¿¼äµÄÎüÊÕÂÊÔ½¸ß£¬ÉùÒô¾ÍË¥¼õµÃÔ½¿ì¡£Èç¹ûÄã×öÒ»¸öÓÃÀ´¼ì²éÈËÃDz½Èë´óÌõÃÉùÒô£¬Ô¤Áϵ±ËûÃÇ×øÏµÃʱºò£¬ÉùÒô¾Í»á±ä»¯¡£Decay timeÔ½³¤£¬Í¨³£¶¼»áÈÃÄãµÃ»ìÏì±ä²î£¬±£³Ödecay×ã¹»³¤¾ÍºÃ£¬²»ÒªÌ«³¤ÁË¡£
In up-tempo songs, I like to use a short decay for most of the instruments. This helps keep the mix clear and have space for the other instruments. This also makes more room for the solo instruments where I might want a longer decay time.
ÔÚ·´ÅĵĸèÇúÀïÃæ£¬ÎÒϲ»¶Îª´ó²¿·ÖµÄÀÖÆ÷ÔËÓÃÒ»¸ö¶ÌË¥¼õ£¨decay£©¡£ÕâÑùµÄÉèÖÃÄÜʹµÃMIX±£³Ö¸É¾»ÇåÎú£¬ÒÔ¼°ÄÜÈÃÀÖÆ÷Ö®¼äÁôÓпռ䡣Èç¹ûÊÇÔÚ·¿¼äÀïÃæ½øÐÐÀÖÆ÷¶À×࣬ÄÇôÎÒ¿ÉÄÜ»áÓÃÒ»¸ö³¤Ë¥¼õʱ¼ä£¨decay time£©£»
One way to choose the correct amount of decay time is to work it out with the tempo of the song. For example: time the reverb on the snare on a ballad so that if the snare is being hit on the 2 and 4 beat, the decay will run for 2 beats long. On some higher end reverbs you can see the decay split into 3 frequencies, low, medium, and high. With this kind of parameter control, you can have more control over how the different frequency ranges decay. For example you can make the high freq.'s decay longer and the lower end, shorter. This can make a sound sharper or airy. If you prolong the lower freq.'s in relation to the higher ones you can also make the sound bigger.
ÎÒÃDZØÐëΪ¸èÇúµÄ½ÚÅÄÑ¡ÔñÕýÈ·µÄË¥¼õʱ¼ä£¨decay time£©¡£ÀýÈ磺ÔÚ¼ÆËãÃñÒ¥¸èÇúÖоü¹Ä»ìÏìµÄʱºò£¬Èç¹û¾ü¹ÄÊÇ2ÅĺÍ4Åĵģ¬ÄÇôdecay¾ÍÓ¦¸ÃÉèÖóÉ2¸öÅÄ×ӵij¤¶È¡£Ôڸ߶˵ĻìÏìÆ÷ÖУ¬ÄãÄÜ·¢ÏÖdecay±»·Ö¿ª³ÉΪ3¸öƵÂÊ£¬µÍƵ¡¢ÖÐÆµÒÔ¼°¸ßƵ£»¶ÔÓÚÕâÀàµÄ²ÎÊý¿ØÖÆ£¬Äã¿ÉÒÔÔÚ²»Í¬µÄƵÂÊÇøÓòÉÏÉèÖøü¶àµÄdecayµ÷Õû¿ØÖÆ¡£ÀýÈçÄãÄÜÈÃ¸ßÆµË¥¼õ±äµÃ¸ü³¤£¬¶øµÍƵ¾Í±äµÃ¸ü¶Ì£¨wavesµÄ»ìÏìRVERBºÍWAVES IR¾ÍÓÐÕâÑùµÄÉèÖã©£¬ÕâÑùÄÜÈÃÉùÒô±äµÃ¸üÈñÀû¸ü¾ßÓÐ¿ÕÆø¸Ð¡£
Èç¹ûÄãÀ­³¤µÍƵ˥¼õ£¬ÒÔ¼°ÁªÏµÇ°Ãæ¸ßƵµÄµ÷Õû£¨¸ßƵÒÀÈ»Êdz¤DECAY£©£¬ÄÇô¾Í¿ÉÒÔ°ÑÉùÒô±ä´óÁË¡£
First, listen to EX #2 to the different decays, then listen to EX. #5 - A snare with a hall then a cut in low freq's (starting from the fade in). Listen to the difference in color and texture.
Ê×ÏÈ£¬ñöÌýÀý×Ó2Öв»Í¬µÄdecay£¬È»ºóÌýÀý×Ó 5£¬Ò»¸ö¾ü¹ÄÓÃ"HALL¡°»ìÏ죬ȻºóCUTµôµÍƵ£¬ñöÌý±ä»¯
Diffusion - High settings of diffusion gives you a smoother sounding reverb because the reflections are closer to each other. With a busy arrangement your mix might sound too thick and unclear. I like to use a higher setting on ballads and open arrangements. Sometimes on rock drums I like the less smooth diffusion setting.
With a lower setting, it has a tendency to sound grainy. I like to use it on up-tempo stuff and drums.
À©É¢£¨ÂþÉ䣩£­ÉèÖøßÀ©É¢Öµ£¬ÄÜÈÃÄãµÄ»ìÏìÉùÒô±äµÃ¸ü˳»¬£¬ÒòΪ·´ÉäÉùÖ®¼ä±Ë´Ë¸ü¿¿½üÁË¡£ÔÚÒ»¸ö±È½Ï¡°ÈÈÄÖ¡±µÄ±àÅÅÏÂÄãµÄMIX¿ÉÄÜÌýÆðÀ´ºÜºñÒÔ¼°²»¸É¾»¡£ÎÒϲ»¶ÓÃÒ»¸ö¸ßÀ©É¢ÖµÔÚÃñÒ¥ÒÔ¼°¼ä¸ô±È½Ï¿ªµÄ±àÅÅÉÏ¡£Ä³Ð©Ê±ºò£¬ÔÚROCK DRUMSÉÏÎÒϲ»¶´Ö²ÚÒ»µã£¨less smooth¾ÍÊÇÉÙµÄ˳»¬À²£©µÄÀ©É¢ÉèÖá£
Èç¹ûÓÃÒ»¸öµÍÀ©É¢ÖµµÄÉèÖã¬ÄÇô¾Í»áÇãÏòÓÚ¿ÅÁ£µÄ¸Ð¾õ¡£ÎÒϲ»¶ÔÚ·´ÅĵÄÇú×ÓÒÔ¼°¹ÄÉùÉÏÕâÑùÔËÓá£
On some reverb units this parameter is called Density. However, Density may be a parameter that controls the early reflections while diffusion might control only the distance BETWEEN ALL reflections. Low density works well with smooth sounds like strings or to make a vocal sound fuller, while high density works well with percussion.
ÔÚһЩ»ìÏìÆ÷ÉÏ£¬Õâ¸ö²ÎÊý±»³ÆÎªÃܶȡ£ÃܶÈÖ»ÊÇÒ»¸ö¿ØÖÆÔçÆÚ·´ÉäÉùÒôµÄ²ÎÊý£¬µ±É¢ÉäÖ»ÊÇ¿ØÖÆÁËËùÓз´ÉäÖ®¼äµÄ¾àÀëµÄʱºò£¨Òâ˼¾ÍÊÇ˵£¬À©É¢¿ØÖÆ·´ÉäÉùÒôÖ®¼äµÄ¾àÀ룬¶øÃܶÈÖ»ÊÇ¿ØÖÆÔçÆÚ·´ÉäÉùÒôµÄ¾àÀ룩¡£µÍÃܶȵÄÉèÖÃÄÜÈÃÉùÒôÌýÆðÀ´Ë³»¬£¬ÀýÈçÏÒÀÖ£¬»òÕßÈÃÈËÉù±äµÃ·áÂú£¬µ±¸ßÃܶÈÉèÖõÄÇé¿öÏ£¬ÊʺÏÓÃÓÚ´ò»÷ÀÖ¡£
×îºó£¬
»ìÏì²»ÊÇÍòÄÜ£¬²»Òª²»Í£µÄ¼Ó£¬¼Ó¶àÁËÉùÒô¾ÍÓÐÎÊÌ⣬ÔÚ¼Ó»ìÏìµÄʱºò£¬±ØÐë¼Çס£ºÉùÒôÊÇ·ñÓÐËðʧ¡£ÉùÒôÊÇ·ñÇåÎú£¬ÉùÒôÊÇ·ñ±äµÃ±È¸ÉÉù¸üºÃÁË£¿
ÔÚµçÄÔÄê´ú£¬Ê²Ã´Èí¼þ¶¼ÊdzÔ×ÊÔ´µÄ£¬Èç¹û¹ìµÀÕæµÄ²»ÐèÒªÕâ¸ö»ìÏìÄÇô¾ÍËãÁË£¬±ðÒªÁË£»
³¢ÊÔÔÚÒ»¸ö»ìÏìÇ°Ãæ»òÕߺóÃæ¼ÓÒ»¸öEQ¡££¨Èç¹ûÄãÊÇSAW£¬ÄÇôÓðɣ¬SAWµÄ×Ô´øEQÈ«ÊÀ½ç×î½ÚÊ¡×ÊÔ´µÄEQ£¬¶øÇÒÖÊÁ¿ÔÚ·ÇÏßÐÔEQÖУ¬ÎÒ¾õÊǵÚÒ»¼¯Íŵģ©
³¢ÊÔÔÚ»ìÏìÇ°Ãæ¼ÓÒ»¸öDELAY£¬ÕâÑùÄÜÈÃMIX¸üÇåÎú£»£¨´úÌæ»ìÏìÖÐµÄ PRE-DELAY£¬Èç¹û×ÔÉí»ìÏìÓÐPRE-DELAY£¬ÇëÉèÖÃλ0¡£»¹ÊÇÖ§³ÖSAWµÄDELAY£¬ÎÒ¾õµÃËüÒ²ÊǵÚÒ»¼¯Íŵģ©£»
ÔÚÑ¡Ôñ»ìÏìÀàÐ͵Äʱºò£¨HALL/ROOM/PLATE£©ÕæµÄÒªÈÏÕæ¶àÌý£¬ÈÏÕæÀË·ÑһСʱ£¬ºÃ¹ýʺóºó»ÚÒ»ÕûÌì¡£
³¢ÊÔÔËÓÃÒ»¸öÒÔÉϵĻìÏìÔÚSNARE£¬»òÕßÄã»áÕÒµ½ºÜºÃµÄÉùÒô£¬µ«ÊÇǰÌáÊÇÄãµÄÓÃÒ»¸ö»ìÏìµÄÇé¿öÏÂʵÔÚÎÞ·¨´ïµ½ÄãµÄÒªÇó£¬ÁíÍâÒªÄãµÄµçÄÔÔÊÐíÄãÕâÑù×ö£¬±Ï¾¹ºÃµÄEQºÜ³Ô×ÊÔ´¡£
²»Òª°Ñ»ìÏìÓÃÔÚBASS ºÍ KICKÉÏ£¨Èç¹ûÕæµÄÐèÒª£¬Ò»µãµã»¹ÊÇ¿ÉÒԵģ©¡£
H2OûÁË£¬Ãâ·Ñ²å¼þҲûÁË£¬Èç¹ûÊÖÍ·ÉÏÓÐWAVES/WIZOOµÈ»ìÏì¾Í¹»ÁË£¬²»ÒªÔÙÕÒÁË£¬ÈçͬÎÄÖÐ˵µÄ£¬»ìÏìÒªÓÃ×îºÃµÄ£¬²»ÒªÓùýµÃÈ¥µÄ¡££¨Ä³Ð©Ê±ºò£¬¼ÛÇ®µÄÈ·µÈÓÚÒ»ÇУ©
ÎÒÔø¾­ÓÐÒ»¶Îʱ¼äÊÕ¼¯¹ýºÜ¶àµÄ»ìÏìÈí¼þ£¬ÓкõÄÓлµµÄ£¬µ«Êǵ½ÁË×îºó£¬ÄÜÉÏÌ¨ÃæµÄÕæ²»¶à£¨·ÇЧ¹û¿¨Ö§³Ö£©£¬WAVES/WAVE ARTS/WIZOO¶¼ÊDz»´íµÄ£¬¶øÆäËûÄØ£¿ÎҾݵͼÊйýµÃÈ¥µÄ£¨¸öÈËÒâ¼û£¬²»Òªµ±Õ棩
2005-6-14 08:48:00 »Ø¸´
·ÖÏí £¬µãÔÞ£¬Ñ§Ï°ÁË
2005-6-18 21:12:00 »Ø¸´
