查看: 25007|回复: 1
打印 上一主题 下一主题
[硬件产品] Allen&Heath GL4800-848B 扩声调音台
2万
音频应用初级会员
Rank: 6Rank: 6
跳转到指定楼层
1#
发表于 2008-12-30 16:05:07 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
商品品牌:ALLEN&Heath
本站售价:¥238858元
The GL4800-848 is a large format, multi-function, LR, M, 8 group, 10 aux, 11x4 matrix console, with A,B,C,D options for more stereo channels:
GL4800-848A - all mono channels
GL4800-848B - 4 stereo channels to right of masters
GL4800-848C - 4 stereo channels on outside right
GL4800-848D - 8 stereo channels on outside right
Based on the highly successful GL4000, the GL4800 is a real thoroughbred multi-function mixer, with a mass of features and detail that makes this mixer a joy for engineers to use. This is a truly multi-functional console, offering features such as group output trims for recording, extended auxiliaries using matrix sends, multiple main outputs and trimmable direct outputs from channels.
The GL4800 is supremely adaptable to every application and is perfect for engineers in both live sound and recording. Rental companies will appreciate a mixer which will work hard for its living, delivering exceptional audio performance every day of the week.
Features
• A,B,C,D mono/stereo channel options
• Multi-functionality for FOH/Monitor mixing and live recording
• LR and M main mix
• 8 Audio groups with pan and routing to LR and M
• 11x4 Matrix
• 10 Auxiliary sends with faders, inserts and XLR
• Aux 10 can provide channel direct output pre/post and level trim
• Group out pre/post switching and level trim for recording
• Per channel pre/post fader aux switching for unlimited flexibility
• Second LR2 output with pre/post fader selection and level trim
• Output reverse mode to swap aux inserts and XLR with matrix and LR2
• 2-track replay to LR and monitor
• Stereo channel line inputs can be assigned independently to LR
• 4 band, 4 sweep EQ with switched Q on midrange
• Swept 20-400Hz high pass filters
• Matrix to aux link for quick monitors and grouped effects
• 128 snapshot memory mute automation with preview and safes functions
• 8 Mute groups or scenes
• Solo-in-Place with toggle last and safes
• Single press clear or set all mutes function
• Mutes on all fader masters
• Meters on all buses to prevent mix overload
• Simultaneous metering of the groups, LRM and auxes
• Integral LED-illuminated moving coil VU meterpod
• Simultaneous LED bar and VU monitor metering
• Mono/stereo PFL with trim
• PFL override AFL for logical input/output monitoring
• Engineers wedge fader control in monitor mode
• Separate headphones and local outputs
• Talkback to LR, M, groups, matrix, and to each aux
• Electronically balanced XLR outputs with +27dBu drive capability
• Preamp +34dBu maximum input capability for mic or line
• Ultra low noise mix head amp design
• Balanced inserts with separate send and return sockets
• 100mm, premium grade dual rail faders
• Metal jacks, gold-plated XLRs, sealed pots and switches
• Individual circuit card assembly with nutted pots
• Built-in combiner for redundant backup power supply
• Sys-Link V2 console input linking option
The GL4800 ships with mains leads, dust cover, user guide, A&H stickers
由GL 4800-848是一个很大的格式,多功能,英国LR,男,8组,10个辅助,11x4矩阵主机,甲,乙,丙,立体声道D选项的更多:
GL 4800-848A - all mono channels 吉尔4800 - 848A -所有单声道
GL 4800-848B - 4 stereo channels to right of masters 吉尔4800 - 848B - 4个立体声通道,以当家作主的权利
GL 4800-848C - 4 stereo channels on outside right 吉尔4800 - 848C -外右4个立体声通道
GL4 800-848D - 8 stereo channels on outside right GL4 800 - 848D -右外8路立体声通道
3462
2#
发表于 2009-1-10 16:48:54 | 只看该作者
:victory: :victory:
