·¿¼äÂó¿Ë·ç¼°Æä°Úλ
ÒôÏì
This area is tricky. Room frequency ¡°build-ups¡± and ¡°suck outs¡± have a major influence. Condensers are the typical choice but each room sounds different, so try every mic that¡¯s left over. It¡¯s a good idea to use two of the same model with the overheads.
    Õâ¸öÇøÓòÊDZȽϸ´Ôӵġ£·¿¼äƵÂʵġ°×¤²¨¡±ºÍ¡°ÎüÉù¡±¶ÔʰÒôÓнϴóµÄÓ°Ïì¡£µçÈÝÂó¿ËÊDZê×¼µÄÑ¡Ôñµ«ÊÇÿ¸ö·¿¼äµÄÉùÒôÌØÐÔ¶¼²»Í¬£¬ËùÒÔÒª³¢ÊÔʣϵÄÿһ֧Âó¿Ë¡£ÓÃÁ½Ö§ºÍOHÂóÏàͬÐͺŵÄÂó¿ËÊÇÒ»¸ö²»´íµÄÖ÷Òâ¡£
    You might think an omni pickup pattern would work well, meaning the condenser mics would hear behind as well as the sides. Maybe, but I use cardioid most of the time. Start by placing the mics about 15 feet in front of the drums, about four feet above the floor. Spread apart the mics around eight feet or more, using the bass drum as center.
    Äã»òÐí»áÈÏΪȫָÏòµÄʰÒôÖÆÊ½»á¸üÊʺϣ¬Õâ¾ÍÒâζ×ŵçÈÝÂó»áʰµ½ºóÃæºÍÅԱߵÄÉùÒô¡£»òÐí¿ÉÒÔ£¬µ«ÊÇÎÒ´ó¶àÊýÇé¿öÏ»áʹÓÃÐÄÐÍÖ¸Ïò¡£Ê×ÏȰÑÂó¿Ë¹Ì¶¨ÔÚ¹Äǰ·½´óÔ¼15Ó¢³ß£¬¾àµØ°å¸ß¶È´óÔ¼4Ó¢³ßµÄλÖá£È»ºó°ÑÁ½¸öÂó¿ËÒÔµ×¹ÄλÖÃΪÖÐÐÄ£¬·ÖÕ¹¿ª´óÔ¼8Ó¢³ß»ò¸ü¶à¡£
    This is what works for me in my studio, but every studio will have ¡°sweet spots¡± so experiment! Even a ¡°semi-dead room¡± might like room mics.
    Õâ¾ÍÊÇÎÒÔÚ×Ô¼ºÂ¼ÒôÅïÀïµÄ°ì·¨£¬µ«ÊÇÿ¸ö¼ÒôÅï¶¼»áÓÐʰÒôµÄ¡°»ÊµÛλ¡±£¬ËùÒÔ»¹ÊÇÊÔÑé°É£¡¼´Ê¹Ò»¸ö¡°°ëÏûÉùÊÒ¡±¿ÉÄÜÒ²ÄÜÓ÷¿¼äÂó¿Ë¡£
    It is possible to use more room mics, especially if the room is big with high ceilings. If this is the case, for high distant miking, try the Neumann M50 (nickel capsule is best) which is designed to be a room mic. This mic sounds bright even when distant from the sound source. It¡¯s a hard mic to find, but it¡¯s great for this application.
ÆÀÂÛÁÐ±í£¨4£©
mixing Â¥Ö÷
ÓпÉÄÜ»áÓõ½¸ü¶àµÄ·¿¼äÂó¿Ë£¬ÌرðÊÇÈç¹ûÊÇÌ컨°åºÜ¸ßµÄ´ó·¿¼ä¡£Èç¹ûÊÇÕâÖÖÇé¿ö£¬ÎªÁËÔ¶¾àÀë¸ß´¦Ê°Òô£¬¿ÉÒÔ³¢ÊÔÒ»ÏÂרÃÅÉè¼Æ·¿¼äÂóµÄNeumann M50£¨¶ÆÄøÕñĤ×îºÃ£©¡£¼´Ê¹Ô¶ÀëÉùÔ´£¬Õâ¸öÂó¿ËÒ²ÄÜÉùÒôÃ÷ÁÁ¡£Õâ¸öÂó¿ËºÜÄÑÕÒµ½£¬µ«ÊÇÕâ¸öÓÃ;ÉÏÊǷdz£°ôµÄ¡£
    Typical Drum Recording Rooms
    µäÐ͵ļ¹Ä·¿¼ä
    There are three main categories of studio recording rooms.
    ÕâÀïÓÐÈýÖÖ¼Òô¼äµÄÖ÷ÒªÀàÐÍ¡£
    The Dead Room: This has major padding on the walls and ceiling, with a carpet floor. There are very few ¡°live surfaces,¡± so this type of room does not generate natural reverberations as the surfaces absorb the sound. The 1970s pop and R&B (rhythm and blues) era favored this type of drum sound.
    ÏûÉùÊÒ£ºËüÓзdz£×¨ÒµµÄÌî³äÎïÔÚǽ±ÚºÍÌ컨°åÉÏ£¬»¹ÓеØÌº¡£ÕâÀXºõûÓС°live surfaces¡±£¨Ò²¾ÍÊÇÓÐЧ·´ÉäÃæ£©£¬ËùÒÔÕâÖÖÀàÐ͵ķ¿¼äÓÉÓÚ±íÃæÎüÒô²¢²»»á²úÉú×ÔÈ»µÄ»ìÏì¡£ÕâÖÖÀàÐÍ·¿¼äµÄ¹ÄÉùÔÚ70Äê´úµÄÁ÷ÐкÍR&BÀàµÄ¼ÒôÖбȽÏÊÜÆ«°®¡£
    Semi Open-Sounding Room: This has some reflective surfaces, such as wood wall panels and a hard wood floor, with a few ¡°soft spots¡± like a carpet border around the hardwood floor or padding on a few walls. The ceiling may have wood reflectors, or a few boxes filled with environmentally-safe fiberglass material may hang from the ceiling to stop any ringing caused by the ceiling. If you can only have one big room in your studio, this is the best option. You can change it into a dead room by adding foam, packing blankets, or commercial frequency absorbers. For any music other than hard rock, this room style is a happy medium.
    °ë»ìÏìÊÒ£ºÕâÖÖ·¿¼äÓÐһЩ·´ÉäÃæ£¬±ÈÈçÄ¾ÖÆÇ½È¹ºÍӲľµØ°å£¬ºÍһЩÀàËÆºÍӲľµØ°åÏà½ÓµÄµØÌº»òÕßǽÉÏÉÙÊýµÄÎüÒôÎïµÄ¡°ÈáÈí´¦¡±¡£Ì컨°åÉÏ¿ÉÄÜ»áÓÐľ֯·´ÉäÃæ£¬»òÕßÓÐһЩÓû·±£²£Á§ÏËάÌî³äµÄСºÐ×ÓÐü¹ÒÔÚÌ컨°åÉÏÒÔ·ÀÖ¹ÓÉÓÚÌ컨°å´øÀ´µÄÈκÎÏìÉù¡£Èç¹ûÄãµÄ¼ÒôÅïÖ»ÄÜÓÐÒ»¸ö´ó·¿¼ä£¬ÕâÖÖÀàÐÍÊÇ×îºÃµÄÑ¡Ôñ¡£Äã¿ÉÒÔͨ¹ýÔö¼ÓÅÝÄ­º£ÃÞ£¬Ìí¼Óë̺»òÕ߯µÂÊÎüÒôµÄ²úÆ·°ÑËü±ä³ÉÏûÉùÊÒ¡£Õâ¸öÀàÐ͵ķ¿¼äÊǸöÕÛÖÔ·½°¸£¬³ýÁËÓ²Ò¡¹öÊʺÏËùÓеÄÒôÀÖÀàÐÍ¡£
2009-10-3 16:15:11 »Ø¸´
   Open-Sounding Room: This type of room is usually quite large and is the key to a big exploding drum sound. The surfaces are typically cement and plaster; non-reflective surfaces are rare. When recording drums in an open-sounding room, you¡¯ll generally use room mics (mics distant from the sound source), so it is best to put only the drums in this room and all other instrument amps in other rooms for isolation.
    »ìÏìÊÒ£ºÕâÖÖÀàÐ͵ķ¿¼äͨ³£ºÜ´ó¶øÇÒÊÇʹ¹ÄÉù±¬·¢µÄ¹Ø¼ü¡£·´ÉäÃæ»ù±¾ÊÇË®ÄàºÍʯ»Ò£»·Ç·´ÉäÃæºÜÉÙ¡£µ±ÔÚ»ìÏìÊÒÀYĵÄʱºò£¬Äãͨ³£¶¼ÒªÓ÷¿¼äÂó¿Ë£¨Âó¿ËÒªÔ¶ÀëÉùÔ´£©£¬ËùÒÔΪÁ˸ôÒô×îºÃ°Ñ¹Äµ¥¶À·ÅÔÚÕâ¸ö·¿¼äÀÆäËüÀÖÆ÷·Å´óÆ÷ÔÚÆäËü·¿¼ä¡£
    Postscript:
    Jay Graydon is a Los Angeles-based songwriter, recording artist, guitarist, producer, arranger, engineer, and more, with two Grammy awards and 12 top five Grammy finalist nominations, including the prestigious title ¡°Producer of the Year¡± and others such as ¡°Record Engineer of the Year.¡± Some of Jay¡¯s greatest hits include the Grammy-winning ¡°Turn Your Love Around¡± with George Benson, many songs co-written with David Foster (e.g., the Grammy-winning ¡°After The Love Has Gone¡± ¡ª a huge #1 hit with Earth, Wind & Fire), and several hits with Al Jarreau, DeBarge, and Manhattan Transfer, to name a few.
2010-5-26 17:41:43 »Ø¸´
ÐÀÉÍÁË£¬Ð»Ð»Â¥Ö÷·¢²¼°¡ £¬ÎÒÊÕ²ØÁ˰¡ :victory::victory:
2010-5-27 19:50:30 »Ø¸´
·ÖÏíÁË£¬Ð»Ð»°¡
2010-6-2 08:43:18 »Ø¸´
