TL Audio 5052(Á¢ÌåÉùµç×ӹܴ¦ÀíÆ÷)
²úÆ·Ãû³Æ£º TL Audio 5052(Á¢ÌåÉùµç×ӹܴ¦ÀíÆ÷)
²úÆ·Ðͺţº 5052
²úÆ·³§ÉÌ£º TL Audio
²úÆ·¼Û¸ñ£º 16280Ôª
²úÆ·ÐÅÏ¢£º >
► Ïêϸ˵Ã÷
¼¼ÊõÌØµã£ºµç×Ó¹ÜǰÖ÷Ŵó¿ÉÒÔ½ÓÊÜÂó¿Ë·ç¡¢Ïß·ºÍÀÖÆ÷ÊäÈ룬´øÓÐÔöÒæ¿ØÖÆ£¬90HzÂ˲¨Æ÷£¬30dBË¥¼õºÍÏàλ·´×ª¿ª¹Ø¡£µç×Ó¹ÜѹËõÆ÷°üº¬¿É±äÃż÷¡¢±ÈÂÊ¡¢Éϳ塢ÊͷźÍÔöÒæ²¹³¥£¬Ó²/Èíϥģʽ¡£µç×ӹܾùºâ²¿·ÖÓпɱäµÄLFºÍHF¶Î£¬2¸öÈ«²ÎÊýµÄÖжΣ¬¿ÉÒÔ·ÅÖÃÔÚѹËõÆ÷֮ǰ»òÖ®ºó£¬¿ÉÒÔת»»µ½Ñ¹ËõÅÔÁ´×öijһƵÂʵÄѹËõ¡£¹âѧÊä³öÏÞÖÆÆ÷ΪÊä³öÐźÅÌṩ͸Ã÷שǽÏÞÖÆ£¬ÓпɱäµÄÃż÷¿ØÖÆVU±íָʾÊäÈëºÍÊä³öµçƽ¡¢Ñ¹ËõºÍÏÞ·ù¼¶µÄÔöÒæ¼õС¡£±¸ÓС®+10dB¡¯ÉèÖÃÒÔ±ã¶Á³ö¸ü¸ßµÄÊäÈëºÍÊä³öµçƽ¡£Ñ¹ËõÆ÷¡¢¾ùºâÆ÷ºÍÏÞÖÆÆ÷·Ö±ð¿ÉÒÔ×öÁ¢ÌåÉùÁ´½Ó£¬AͨµÀ³ÉΪÖ÷ͨµÀ£¬BͨµÀ³ÉΪ´ÓͨµÀÊä³öµçƽ¿ÉÒÔ¿ØÖÆ£¬ÍêÈ«µÄÅÔ·¿ª¹ØÀûÓÚA-B±È½ÏÔʼÐźźʹ¦ÀíºóµÄÐźÅÍêÈ«µÄÄÚ²¿Á¬Í¨ÐÔ¡£Æ½ºâµÄÂó¿Ë·çÏß·ins/outs£¨Í¬Ê±Óв»Æ½ºâÁ¬½Ó£©£¬Æ½ºâµÄ²åÈ룬ѹËõÆ÷ÅÔÁ´²åÈëºÍÇ°Ãæ°åµÄÀÖÆ÷ÊäÈë¡£ÈÎÑ¡µÄDO-2Êý×Ö¿¨¿ÉÒÔÌṩÖ÷Êä³ö24 bit A-Dת»»£¬44.1/48kHz¿ÉÑ¡µÄ²ÉÑùÂʺÍ×ÖʱÖÓÊäÈë¡£
5052×ܹ²Ê¹ÓÃ6Ö§Èý¼«µç×ӹܣ¬¹¤×÷ÔÚÎȶ¨µÄ150Vµçѹ¡£
► ¼¼ÊõÖ¸±ê
¡ñǰÖ÷ŴóÊäÈëÔöÒæ
¡ñ£«16µ½£«60dB(Âó¿Ë·çÊäÈë)£¬£20µ½£«20dB£¨ÏßÐÔÊäÈ룩
¡ñÂó¿Ë·çÊäÈë
¡ñÊäÈëÔëÉù (EIN): -127dBu (150 ohmÐźÅÔ´,22Hz to 22kHz)
¡ñƽºâÏß·ÊäÈë
¡ñ×î´óµçƽ: +26dBu
¡ñƽºâÏß·Êä³ö
¡ñ×î´óµçƽ: +26dBu
¡ñƵÂÊÏìÓ¦: 10Hz to 40kHz, +0, -1dB
¡ñÔëÉù: -80dBu (22Hz to 22kHz)
¡ñ¶¯Ì¬·¶Î§: 100dB (Line input @ 0dB gain)
¡ñµçÔ´ÏûºÄ: 30VA
¡ñÌå»ý: 483 x 250 x132mm(3U 19")
¡ñÖØÁ¿£º9kg
Compressor
Threshold: +10 to -20dB
Ratio: 1:1.5 to 1:30
Attack: 0.5mS to 50mS
Release: 40mS to 4S
Gain Make Up: 0 to +20dB
Equaliser
LF band: +/-15dB from 30Hz to 1kHz, shelving or peaking modes
LM band: +/- 15dB from 50Hz to 3kHz, fully parametric
(Q variable between 0.5 and 5)
HM band: +/- 15dB from 1kHz to 12kHz, fully parametric
HF band: +/- 15dB from 3kHz to 20kHz, shelving or peaking modes
Limiter:
Threshold variable: 0 to +20dB
Master Section::
Output Gain: to +15dB
PSU:
Internally adjustable for 115/230V operation
Typical consumption: 30VA
Weights & Dimensions
Dimensions: 483 x 250 x 132mm (3U 19¡± rack mounting)
Shipping Weight: 9kg
