Maya ²Ëµ¥ÖÐÓ¢ÎĶÔÕÕ
Standard±ê×¼²Ëµ¥
FileÎļþ
New Scene½¨Á¢Ð³¡¾°
Open Scene´ò¿ª³¡¾°
Save Scene´æÅ̳¡¾°
Save Scene As¸ÄÃû´æÅÌ
Importµ¼Èë
Export Allµ¼³öËùÓÐ
Export Selectionµ¼³öÑ¡¶¨ÎïÌå
Create ReferenceÒýÈ볡¾°Îļþ
Reference EditorÒýÈ볡¾°±à¼Æ÷
Project씀New½¨Á¢ÐÂÏîÄ¿
Edit Current±à¼µ±Ç°ÏîÄ¿
SetÖ¸¶¨µ±Ç°ÏîÄ¿
ExitÍ˳ö
Edit±à¼
UndoÈ¡ÏûÉÏÒ»´Î²Ù×÷
Redo»Ö¸´ÉÏÒ»´Î²Ù×÷
RepeatÖØ¸´×îºóÒ»´Î²Ù×÷
Keys¹Ø¼üÖ¡
Cut Keys²Ã¼ô¹Ø¼üÖ¡
Copy Keys¿½±´¹Ø¼üÖ¡
Paste KeysÕ³Ìù¹Ø¼üÖ¡
Delete Keysɾ³ý¹Ø¼üÖ¡
Scale KeysËõ·Å¹Ø¼üÖ¡
Bake SimulationÄ£Äâ¸´ÖÆ
Deleteɾ³ý
Delete by Type¸ù¾ÝÀàÐÍɾ³ý
History¹¹ÔìÀúÊ·
ChannelsͨµÀ
Static Channels¾²Ö¡Í¨µÀ
Motion PathsÔ˶¯Â·¾¶
Expressions±í´ïʽ
ConstraintsÔ¼Êø
Rigid Bodies¸ÕÌå
Delete All by Type¸ù¾ÝÀàÐÍɾ³ýËùÓÐ
History¹¹ÔìÀúÊ·
ChannelsͨµÀ
Motion PathsÔ˶¯Â·¾¶
Expressions±í´ïʽ
ConstraintsÔ¼Êø
Unused TransformsδÓñäÐÎ
JointsÁ¬½Ó
IK HandlesÄæÏòÔ˶¯¿ØÖƱú
Lattices³µÏ÷
Clusters×å
Sculpt Objectsµñ¿ÌÎïÌå
WiresÍø¸ñ
LightsµÆ¹â
CamerasÕÕÏà»ú
Image PlanesͼÏñ°å
Shading Groups and MaterialsÒõÓ°×éºÍ²ÄÖÊ
ParticlesÁ£×Ó
Rigid Bodies¸ÕÌåÎïÌå
Rigid Constraints¸ÕÌåÔ¼Êø
Select AllÑ¡ÔñËùÓÐ
Select All by Type¸ù¾ÝÀàÐÍÑ¡ÔñËùÓÐ
JointsÁ¬½Ó
Lattices³µÏ÷
Clusters×å
WiresÍø¸ñ
Transforms±äÐÎ
Geometry¼¸ºÎÌå
NURBS Geometry NURBS¼¸ºÎÌå
Polygon Geometry¶à±ßÐμ¸ºÎÌå
LightsµÆ¹â
CamerasÕÕÏà»ú
Image PlanesͼÏñ°å
ParticlesÁ£×Ó
Quick Select Set¿ìËÙÑ¡Ôñ¼¯
Layers²ã
New Layers½¨Á¢Ð²ã
Rename Layer¸ü¸Ä²ãÃû³Æ
Remove Current LayerÒÆÈ¥µ±Ç°²ã
Layer Editor²ã±à¼Æ÷
Transfer to Layerת»¯Îª²ã
Select All on LayerÑ¡Ôñ²ãÉÏËùÓÐÎïÌå
Hide LayerÒþ²Ø²ã
Hide All LayersÒþ²ØËùÓвã
Show LayerÏÔʾ²ã
Show All LayersÏÔʾËùÓвã
Template LayerÁÙʱ²ã
Untemplate Layer½â³ýÁÙʱ²ã
Hide Inactive LayersÒþ²Ø·Ç»î¶¯²ã
Template Inactive LayersÁÙʱ·Ç»î¶¯²ã
Duplicate¸´ÖÆ
Group³É×é
Ungroup½â³É×é
Create Empty Group½¨Á¢¿Õ³É×é
Parent½¨Á¢¸¸ÎïÌå
Unparent½â³ý¸¸ÎïÌå
ModifyÐÞ¸Ä
Transformation Tools±äÐι¤¾ß
Move ToolÒÆ¶¯¹¤¾ß
Rotate ToolÐýת¹¤¾ß
Scale ToolËõ·Å¹¤¾ß
Show Manipulator ToolÏÔʾÊÖ¶¯¹¤¾ß
Default Object ManipulatorĬÈϵ÷½ÚÆ÷
Proportional Modi Tool±ÈÀýÐ޸Ť¾ß
Move Limit ToolÒÆ¶¯ÏÞÖÆ¹¤¾ß
Rotate Limit ToolÐýתÏÞÖÆ¹¤¾ß
Scale Limit ToolËõ·ÅÏÞÖÆ¹¤¾ß
Reset TransformationsÖØÐÂÉèÖñäÐοØÖÆ
Freeze Transformations¶³½á±äÐοØÖÆ
Enable NodesÊÚȨ¶¯»½Úµã
AllËùÓÐ
IK solversÄæÏòÔ˶¯Á¬½ÓÆ÷
ConstraintsÔ¼Êø
Expressions±í´ïʽ
ParticlesÁ£×Ó
Rigid Bodies¸ÕÌå
Snapshots¿ìÕÕ
Disable Node·ÏÆú¶¯»½Úµã
Make Live¼¤»î¹¹ÔìÎï
Center PivotÖÃÖÐÊàÖáµã
Prefix Hierarchy Names¶¨Òåǰ׺
Add AttributeÔö¼ÓÊôÐÔ
Measure²âÁ¿
Distance Tool¾àÀ빤¾ß
Parameter Tool²ÎÊý¹¤¾ß
Arc Length Tool»¡¶È¹¤¾ß
Animated Snapshot¶¯»¿ìÕÕ
Animated SweepÓɶ¯»ÇúÏß´´½¨¼¸ºÎÌåÇúÃæ
DisplayÏÔʾ
Geometry¼¸ºÎÌå
Backfaces±³Ãæ
Lattice Points³µÏ÷µã
Lattice Shape³µÏ÷ÐÎ
Local Rotation Axes¾Ö²¿ÐýתÖá
Rotate PivotsÐýתÊàÖáµã
Scale PivotsËõ·ÅÊàÖáµã
Selection HandlesÑ¡¶¨¾ä±ú
NURBS Components NURBSÔªËØ
CVs CVÇúÏß
Edit Points±à¼µã
Hulls¿É¿Øµã
Custom¶¨ÖÆ
NURBS Smoothness NURBSÇúÃæ¹â»¬´¦Àí
HullÎïÌåÍâ¿Ç
Rough±ß¿òÖÊÁ¿
MediumÖеÈÖÊÁ¿
Fine¾«Ï¸ÖÊÁ¿
Custom¶¨ÖÆ
Polygon Components¶à±ßÐÎÔªËØ
Custom Polygon Display¶¨Öƶà±ßÐÎÏÔʾ
Fast Interaction¿ìËÙ½»´íÏÔʾ
Camera/Light ManipulatorÕÕÏà»ú/µÆ¹â²Ù×÷Æ÷
SoundÉùÒô
Joint Size¹Ø½Ú³ß´ç
IK Handle Size IK°ÑÊֳߴç
Window´°¿Ú
General EditorsͨÓÃ±à¼Æ÷
Set EditorϵͳÉèÖÃ±à¼Æ÷
Attribute Spread SheetÊôÐÔ±à¼Æ÷
Tool Settings¹¤¾ßÉèÖÃ
Filter Action EditorÂ˾µ¶¯×÷±à¼Æ÷
Channel ControlͨµÀ¿ØÖÆÐÅÏ¢
Connection EditorÁ¬½Ó±à¼Æ÷
Performance SettingsÐÔÄÜÉèÖÃ
Script Editor Script±à¼Æ÷
Command ShellÃüÁî´°¿Ú
Plug-in ManagerÂ˾µ¹ÜÀíÆ÷
Rendering EditorsäÖȾ±à¼Æ÷
Rendering FlagsäÖȾ±ê¼Ç
Hardware Render BufferÓ²¼þäÖȾ»º³åÇø
Render ViewäÖȾÊÓͼ
Shading Groups EditorÒõÓ°×é±à¼Æ÷
Texture ViewÖʵØÊÓͼ
Shading Group AttributesÒõÓ°×éÊôÐÔ
Animation Editors¶¯»±à¼Æ÷
Graph EditorͼÐÎ±à¼Æ÷
Dope Sheet
Blend ShapeÈÚºÏÐÎ
Device EditorÉ豸±à¼Æ÷
Dynamic Relationships¶¯Ì¬¹ØÏµ
Attribute EditorÊôÐÔ±à¼Æ÷
Outliner¿ò¼Ü
Hypergraph³¬Í¼ÐÎ
Multilister¶à¹¦ÄÜäÖȾ¿ØÖÆ
Expression Editor±í´ïʽ±à¼Æ÷
Recent Commandsµ±Ç°ÃüÁî
Playblast²¥·ÅÔ¤ÀÀ
View ArangementÊÓͼ°²ÅÅ
FourËÄ·Ö
3 Top SplitÉÏÈý·Ö
3 Left Split×óÈý·Ö
3 Right SplitÓÒÈý·Ö
3 Bottom Splitµ×²¿Èý·Ö
2 Stacked¶þµþ·Ö
2 Side By Side¶þƽ·Ö
Singleµ¥Í¼
Previous Arrangementǰ´Î°²ÅÅ
Next ArrangementÏ´ΰ²ÅÅ
Saved Layouts±£´æ²¼¾Ö
Single Perspective Viewµ¥Í¸ÊÓͼ
Four ViewËÄ·Öͼ
Persp/Graph/Hyper͸ÊÓ/ͼÐÎ/³¬Í¼ÐÎ
Persp/Multi/Render͸ÊÓ/¶à¹¦ÄÜ/äÖȾ
Persp/Multi/Outliner͸ÊÓ/¶à¹¦ÄÜ/ÂÖÀª
Persp/Multi͸ÊÓ/¶à¹¦ÄÜ
Persp/Outliner͸ÊÓ/ÂÖÀª
Persp/Graph͸ÊÓ/ͼÐÎ
Persp/Set Editor͸ÊÓ/×é±à¼Æ÷
Edit Layouts±à¼²¼¾Ö
Frame Selected in All ViewsËùÓÐÊÓͼѡ¶¨Ö¡
Frame All in All ViewsËùÓÐÊÓͼµÄËùÓÐÖ¡
Minimize Application×îС»¯Ó¦ÓÃ
Raise Application WindowsÒÆ¶¯´°¿ÚÏòǰ
Options¿ÉÑ¡Ïî
General PreferencesÒ»°ãÉèÖÃ
UI PreferencesÓû§½çÃæÉèÖÃ
Customize UI¶¨ÖÆÓû§½çÃæ
Hotkeys¿ì½Ý¼ü
ColorsÑÕÉ«
Marking Menus±ê¼Ç²Ëµ¥
ShelvesÊé¼Ü
PanelsÃæ°å
Save Preferences±£´æÉèÖÃ
Status Line״̬À¸
ShelfÊé¼Ü
Feedback Line·´À¡À¸
Channel BoxͨµÀÃæ°å
Time Sliderʱ¼ä»¬¶¯°ô
Range Slider·¶Î§»¬¶¯°ô
Command LineÃüÁîÐÐ
Help Line°ïÖúÐÐ
Show Only Viewing Panes½öÏÔʾÊÓÍ¼Ãæ°å
Show All PanesÏÔʾËùÓÐÃæ°å
Modeling½¨Ä£ÏµÍ³
Primitives»ù±¾ÎïÌå
Create NURBS´´½¨NURBSÎïÌå
SphereÇòÌå
CubeÁ¢·½Ìå
CylinderÔ²ÖùÌå
ConeԲ̨£¨×¶£©Ìå
PlaneÆ½ÃæÎïÌå
CircleÔ²
Create Polygons´´½¨¶à±ßÐÎÎïÌå
SphereÇòÌå
CubeÁ¢·½Ìå
CylinderÔ²ÖùÌå
ConeԲ̨£¨×¶£©Ìå
PlaneÆ½ÃæÎïÌå
TorusÃæ°üȦ
Create Text´´½¨Îı¾
Create Locator´´½¨Ö¸Ê¾Æ÷
Construction Plane¹¹ÔìÆ½Ãæ
Create Camera´´½¨ÕÕÏà»ú
Curves´´½¨ÇúÏß
CV Curve Tool CVÇúÏß¹¤¾ß
EP Curve Tool EPÇúÏß¹¤¾ß
Pencil Curve Tool±ÊÇúÏß¹¤¾ß
Add Points Tool¼Óµã¹¤¾ß
Curve Editing ToolÇúÏ༹߱¤¾ß
Offset CurveÇúÏßÒÆ¶¯
Offset Curve On SurfaceÇúÏßÔÚ±íÃæÒÆ¶¯
Project TangentÇúÏßÇÐÏßµ÷Õû
Fillet Curve´ø×´ÇúÏß
Rebuild CurveÖØ½¨ÇúÏß
Extend CurveÀ©Õ¹ÇúÏß
Insert Knot²åÈë½Úµã
Attach CurvesÁ¬½ÓÇúÏß
Detach Curves¶Ï¿ªÇúÏß
Align Curves¶ÔÆëÇúÏß
Open/Close Curves´ò¿ª/¹Ø±ÕÇúÏß
Reserse Curves·´×ªÇúÏß
Duplicate Curves¸´ÖÆÇúÏß
CV HardnessÓ²»¯ÇúÏß
Fit B-splineÊÊÅä±´ËþÇúÏß
SurfacesÇúÃæ
Bevelб½Ç
Extrude͹³ö
Loft·ÅÑù
PlanarÇúÃæ
RevolveÐýת
Boundary±ß½ç
Birail 1 Tool¶þ¶ÔÒ»¹¤¾ß
Birail 2 Tool¶þ¶Ô¶þ¹¤¾ß
Birail 3+ Tool¶þ¶ÔÈý¹¤¾ß
Circular FilletÔ²±ßб½Ç
Freeform Fillet***ÐÎб½Ç
Fillet Blend Toolб½ÇÈںϹ¤¾ß
Edit Surfaces±à¼ÇúÃæ
Intersect SurfacesÇúÃæ½»²æ
Project CurveͶӰÇúÏß
Trim ToolÐÞÕûÇúÏß¹¤¾ß
Untrim Surfaces³·ÏûÐÞÕû
Rebuild SurfacesÖØ½¨ÇúÃæ
Prepare For Stitch×¼±¸·ìºÏ
Stitch Surface Pointsµã·ìºÏÇúÃæ
Stitch Tool·ìºÏ¹¤¾ß
NURBS to Polygons NURBSת»¯Îª¶à±ßÐÎ
Insert IsoparmsÌí¼ÓÔªËØ
Attach SurfacesÇúÃæ½áºÏ
Detach SurfacesÇúÃæ·ÖÀë
Align SurfacesÇúÃæ¶ÔÆë
Open/Close Surfaces´ò¿ª/¹Ø±ÕÇúÃæ
Reverse Surfaces·´×ªÇúÃæ
Polygones¶à±ßÐÎ
Create Polygon Tool´´½¨¶à±ßÐι¤¾ß
Append to Polygon Tool×·¼Ó¶à±ßÐÎ
Split Polygon Tool·ÖÀë¶à±ßÐι¤¾ß
Move ComponentÒÆ¶¯ÔªËØ
Subdivide¶à±ßÐÎϸ»¯
CollapseÃæ×ªµã
Edges±ß½ç
Soften/HardenÈữ/Ó²»¯
Close Border¹Ø±Õ±ß½ç
Merge ToolºÏ²¢¹¤¾ß
Bevelб½Ç
Delete and Cleanɾ³ýºÍÇå³ý
FacetsÃæ
Keep Facets Together±£Áô±ßÏß
Extrude͹³ö
ExtractÆÆËé
Duplicate¸´ÖÆ
TriangulateÈý½Ç·ÖÁÑ
QuadrangulateËıßÐκϲ¢
Trim Facet ToolÃæÐÞÕû¹¤¾ß
Normals·¨Ïò
Reverseµ¹×ª·¨Ïò
Propagate´«²¥·¨Ïò
Conformͳһ·¨Ïò
TextureÖʵØ
Assign Shader to Each ProjectionÖ¸¶¨Í¶Ó°
Planar MappingÆ½ÃæÌùͼ
Cylindrical MappingÔ²ÖùÌåÌùͼ
Spherical MappingÇòÌåÌùͼ
Delete Mappingɾ³ýÌùͼ
Cut Texture²Ã¼ôÎÆÀí
Sew TextureбÀÎÆÀí
UniteÁªºÏ
Separate·ÖÀë
Smooth¹â»¬
Selection ConstraintsÑ¡¶¨ÏÞ¶¨¹¤¾ß
Smart Command Settings¸Ä±äÏÔʾÊôÐÔ
Convert Selectionת»¯Ñ¡¶¨
Uninstall Current Settins½â³ýµ±Ç°É趨
Animation¶¯»Ä£¿é
Keys¹Ø¼üÖ¡
SettingsÉèÖùؼüÖ¡
Auto Key×Ô¶¯ÉèÖùؼüÖ¡
SplineÑùÌõÇúÏßʽ
LinearÖ±Ïßʽ
Clamped¼Ð¾ßʽ
Stepped̨½×ʽ
Flatƽ̹ʽ
OtherÆäËûÐÎʽ
Set Driven KeyÉèÖÃÇý¶¯¹Ø¼üÖ¡
SetÉèÖÃ
Go To PreviousÇ°ÒÆ
Go To NextºóÍË
Set KeyÉèÖÃÖ¡
Hold Current Keys±£Áôµ±Ç°Ö¡
Paths·¾¶
Set Path KeyÉèÖ÷¾¶¹Ø¼üÖ¡
Attach to PathÖ¸¶¨Â·¾¶
Flow Path ObjectÎïÌå¸úËæÂ·¾¶
Skeletons¹Ç÷À
Joint Tool¹Ø½Ú¹¤¾ß
IK Handle Tool·´Ïò¶¯Á¦Ñ§¾ä±ú¹¤¾ß
IK Spline Handle Tool·´Ïò¶¯Á¦Ñ§ÑùÌõÇúÏß¾ä±ú¹¤¾ß
Insert Joint ToolÌí¼Ó¹Ø½Ú¹¤¾ß
Reroot SkeletonÖØÐÂÉèÖøù¹Ø½Ú
Remove JointÈ¥³ý¹Ø½Ú
Disconnect Joint½â³ýÁ¬½Ó¹Ø½Ú
Connect JointÁ¬½Ó¹Ø½Ú
Mirror Joint¾µÏò¹Ø½Ú
Set Preferred AngleÉèÖòο¼½Ç
Assume Preferred Angle
Enable IK Solvers·´Ïò¶¯Á¦Ñ§½âËãÆ÷ÓÐЧ
EIk Handle Snap·´Ïò¶¯Á¦Ñ§¾ä±ú²¶×½ÓÐЧ
ESelected IK Handles·´Ïò¶¯Á¦Ñ§¾ä±úÓÐЧ
DSelected IK Handles·´Ïò¶¯Á¦Ñ§¾ä±úÎÞЧ
Deformations±äÐÎ
Edit Menbership Tool±à¼³ÉÔ±¹¤¾ß
Prune Membership±äÐγÉÔ±
Cluster´Ø±äÐÎ
LatticeÐýת±äÐÎ
SculptÔìÐͱäÐÎ
WireÍø¸ñ»¯±äÐÎ
LatticeÐýת
SculptÔìÐÍ
Cluster´Ø
Point On CurveÏßµãÔìÐÍ
Blend Shape»ìºÏ±äÐÎ
Blend Shape Edit»ìºÏ±äÐαà¼
AddÔö¼Ó
Removeɾ³ý
Swap½»»»
Wire ToolÍø¸ñ»¯¹¤¾ß
Wire EditÍø¸ñ±à¼
AddÔö¼Ó
Removeɾ³ý
Add HolderÔö¼Ó¶¨Î»ÇúÏß
ResetÖØÖÃ
Wire Dropoff LocatorÍøÏß¶¨Î»Æ÷
Wrinkle ToolñÞç§±äÐι¤¾ß
Edit Lattice±à¼Ðýת
Reset LatticeÖØÖÃÐýת
Remove Lattice Tweeks»Ö¸´Ðýת
Display I-mediate ObjectsÏÔʾÖмäÎïÌå
Hide Intermediate ObjectsÒþ²ØÖмäÎïÌå
SkinningƤ·ô
Bind Skin°ó¶¨ÃÉÆ¤
Detach Skin¶Ï¿ªÃÉÆ¤
Preserve Skin Groups±£³ÖƤ·ô×é
Detach Skeleton·ÖÀë¹Ç÷À
Detach Selected Joints·ÖÀëÑ¡¶¨¹Ø½Ú
Reattach SkeletonÖØÐÂÁ¬½Ó¹Ç÷À
Reattach Selected JointsÖØÐÂÁ¬½Ó¹Ø½Ú
Create Flexor´´½¨Çü¼¡
Reassign Bone Lattice JointÔÙÖ¸¶¨¹ÇÍ·¹Ø½Ú
Go to Bind Pose»Ö¸´¹ÇÍ·°ó¶¨
Point¹Ø½Ú
AimÄ¿±ê
Orient·½Ïò
ScaleËõ·Å
Geometry¼¸ºÎÌå
Normal·¨Ïò
Rendering
LightingµÆ¹â
Create Ambient Light´´½¨»·¾³¹â
Create Directional Light´´½¨·½ÏòµÆ
Create Point Light´´½¨µã¹âÔ´
Create Spot Light´´½¨¾Û¹âµÆ
Relationship Panel¹ØÏµÃæ°å
Light Linking ToolµÆ¹âÁ´½Ó¹¤¾ß
Shading ÒõÓ°
Create Shading Group´´½¨ÒõÓ°×é
LambertÀʲ®²ÄÖÊ
Phong Phong²ÄÖÊ
Blinn²¼ÁÖ²ÄÖÊ
OtherÆäËû²ÄÖÊ
Assign Shading GroupÖ¸¶¨ÒõÓ°×é
InitialParticleSE³õʼÁ£×Óϵͳ
InitialShadingGroup³õʼÒõÓ°×é
Shading Group ToolÒõÓ°×鹤¾ß
Texture Placement ToolÎÆÀíÎ»ÒÆ¹¤¾ß
RenderäÖȾ
Render into New WindowäÖȾÖÁд°¿Ú
Redo Previous RenderÖØ¸´ÉÏ´ÎäÖȾ
Test Resolution²âÊÔ·Ö±æÂÊ
Camera PanelÕÕÏà»úÃæ°å
Render GlobalsÒ»°ãäÖȾ
Batch RenderÅúäÖȾ
Cancel Batch RenderÈ¡ÏûÅúäÖȾ
Show Batch RenderÏÔʾÅúäÖȾ
Dynamics¶¯Á¦Ñ§ÏµÍ³
SettingsÉèÖÃ
Initial State³õʼ״̬
Set For Currentµ±Ç°ÉèÖÃ
Set For All DynamicÉèÖÃ×ÜÌ嶯Á¦Ñ§ÌØÐÔ
Rigid Body Solver¸ÕÌå½âËãÆ÷
Dynamics Controller¶¯Á¦Ñ§¿ØÖÆÆ÷
Particle Collision EventsÁ£×Ó±¬Õ¨
Particle CachingÁ£×Ó»º³å
Run-up and CacheÖ´Ðлº³å
Cache Current Frame»º³åµ±Ç°Ö¡
Set Selected ParticlesÉèÖÃÑ¡¶¨Á£×Ó
Dynamics On¶¯Á¦Ñ§¿ª
Dynamics Off¶¯Á¦Ñ§¹Ø
Set All ParticlesÉèÖÃËùÓÐÁ£×Ó
Particles All On When RunÖ´ÐÐʱÁ£×Óϵͳ¿ª
Auto Create Rigid Body×Ô¶¯´´½¨¸ÕÌå
ParticlesÁ£×Ó
Particle ToolÁ£×Ó¹¤¾ß
Create Emitter´´½¨·¢ÉäÆ÷
Add EmitterÔö¼Ó·¢ÉäÆ÷
Add CollisionsÔö¼ÓÅöײ
Add GoalÔö¼ÓÄ¿±ê
Fields³¡
Create Air´´½¨¿ÕÆø¶¯Á¦³¡
Create Drag´´½¨Í϶¯³¡
Create Gravity´´½¨¶¯Á¦³¡
Create Newton´´½¨Å£¶Ù³¡
Create Radial´´½¨·øÉ䶯Á¦³¡
Create Turbulence´´½¨Õðµ´³¡
Create Uniform´´½¨Í³Ò»³¡
Create Vortex´´½¨ÎÐÁ÷³¡
Add AirÔö¼Ó¿ÕÆø¶¯Á¦³¡
Add NewtonÔö¼ÓÅ£¶Ù³¡
Add RadialÔö¼Ó·øÉ䳡
Add TurbulenceÔö¼ÓÕðµ´³¡
Add UniformÔö¼Óͳһ³¡
Add VortexÔö¼ÓÎÐÁ÷³¡
ConnectÁ¬½Ó
Connect to Field³¡Á¬½Ó
Connect to Emitter·¢ÉäÆ÷Á¬½Ó
Connect to CollisionÅöײÁ¬½Ó
BodiesÈáÌåºÍ¸ÕÌå
Create Active Rigid Body´´½¨Õý¸ÕÌå
Create Passive Rigid Body´´½¨¸º¸ÕÌå
Create Constraint´´½¨Ô¼ÊøÎïÌå
Create Soft Body´´½¨ÈáÌå
Create Springs´´½¨µ¯»É
Set Active KeyÉèÖÃÕýÏòÕý
Set Passive KeyÉèÖøºÏòÕý
Help°ïÖú
Product Information²úÆ·ÐÅÏ¢
Help°ïÖú
Maya¿ì½Ý¼üËټDZí
ÒÔÏÂÁгöµÄÊÇMaya 2.0/2.5°æ±¾ÖÐËùÓÐϵͳĬÈϵĿì½Ý¼ü¼°ËüÃǵÄʹÓ÷½·¨ºÍ¹¦ÄÜ¡£´ó²¿·ÖµÄ¿ì½Ý¼üʹÓ÷½·¨¶¼ºÜ¼òµ¥£¬Ö»ÐèÔÚ¼üÅÌÉÏÖ±½Ó°´Ï±íÖÐÁгöµÄÏàÓ¦°´¼ü¼´¿É¡£Óиö±ðµÄ¿ì½Ý¼ü´øÓÐ×¢ÊÍ£¬±íʾËüÃǵÄʹÓ÷½Ê½ÉÔÓв»Í¬¡£ÒÔÏÂÊÇÕâЩעÊ͵ĺ¬Ò壺
£¨1£©´øÓС°£¨¿ªÆô/¹Ø±Õ£©¡±×¢Ê͵쬱íʾ¸Ã¿ì½Ý¼üͬʱ¿ØÖÆÍ¬Ò»¹¦ÄܵĿªÆôºÍ¹Ø±Õ¡£
£¨2£©´øÓС°£¨°´ÏÂ/ÊÍ·Å£©¡±×¢Ê͵쬱íʾ¸Ã¿ì½Ý¼üµÄʹÓ÷½Ê½Îª°´ÏºÍÊÍ·ÅÕâ¸ö¼ü¡£
£¨3£©´øÓС°µ¥»÷Êó±ê×ó¼ü¡±ºÍ¡°£¨µ¯³öʽ±ê¼Ç²Ëµ¥£©¡±×¢Ê͵쬱íʾ¸Ã¿ì½Ý¼üʹÓ÷½Ê½ÎªÏȰ´Ï¿ì½Ý¼ü£¬ÔÙµ¥»÷Êó±ê×ó¼ü£¬½Ó×ÅÆÁÄ»Éϻᵯ³öÒ»¸ö±ê¼Ç²Ëµ¥¹©Äã×÷³öÑ¡Ôñ¡£
¹¤¾ß²Ù×÷ ¶¯»¹Ø¼üÖ¡
¿ì½Ý¼ü
¹¦ÄܽâÊÍ
¿ì½Ý¼ü
¹¦ÄܽâÊÍ
Enter Íê³Éµ±Ç°²Ù×÷ s ÉèÖùؼüÖ¡
~ ÖÕÖ¹µ±Ç°²Ù×÷ i ²åÈë¹Ø¼ü֡ģʽ£¨¶¯»ÇúÏ߱༣©
Insert ²åÈ빤¾ß±à¼Ä£Ê½ Shift E ´æ´¢ÐýתͨµÀµÄ¹Ø¼üÖ¡
W ÒÆ¶¯¹¤¾ß Shift R ´æ´¢Ëõ·ÅͨµÀµÄ¹Ø¼üÖ¡
e Ðýת¹¤¾ß Shift W ´æ´¢×ª»»Í¨µÀµÄ¹Ø¼üÖ¡
r Ëõ·Å¹¤¾ß ²Ù×ݸ˲Ù×÷
y ·Ç¹Ì¶¨ÅŲ¼¹¤¾ß ¿ì½Ý¼ü
¹¦ÄܽâÊÍ
Shift Q Ñ¡Ôñ¹¤¾ß£¬£¨Çл»µ½£©³É·Öͼ±ê²Ëµ¥ t ÏÔʾ²Ù×÷¸Ë¹¤¾ß
Alt q Ñ¡Ôñ¹¤¾ß£¬£¨Çл»µ½£©¶à±ßÐÎÑ¡Ôñͼ±ê²Ëµ¥ = Ôö´ó²Ù×ݸËÏÔʾ³ß´ç
q Ñ¡Ôñ¹¤¾ß£¬£¨Çл»µ½£©³É·Öͼ±ê²Ëµ¥ - ¼õÉÙ²Ù×ݸËÏÔʾ³ß´ç
´°¿ÚºÍÊÓͼÉèÖÃ ÒÆ¶¯±»Ñ¡¶ÔÏó
¿ì½Ý¼ü ¹¦ÄܽâÊÍ ¿ì½Ý¼ü ¹¦ÄܽâÊÍ
Ctrl a µ¯³öÊôÐԱ༴°/ÏÔʾͨµÀÀ¸ Alt ¡ü ÏòÉÏÒÆ¶¯Ò»¸öÏóËØ
a ÂúÆÁÏÔʾËùÓÐÎïÌ壨ÔÚ¼¤»îµÄÊÓͼ£© Alt ¡ý ÏòÏÂÒÆ¶¯Ò»¸öÏóËØ
f ÂúÆÁÏÔʾ±»Ñ¡Ä¿±ê Alt ¡û Ïò×óÒÆ¶¯Ò»¸öÏóËØ
Shift F ÔÚËùÓÐÊÓͼÖÐÂúÆÁÏÔʾ±»Ñ¡Ä¿±ê Alt ¡ú ÏòÓÒÒÆ¶¯Ò»¸öÏóËØ
Shift A ÔÚËùÓÐÊÓͼÖÐÂúÆÁÏÔʾËùÓжÔÏó ¡® ÉèÖüüÅ̵ÄÖÐÐļ¯ÖÐÓÚÃüÁîÐÐ
¿Õ¸ñ¼ü ¿ìËÙÇл»µ¥Ò»ÊÓͼºÍ¶àÊÓͼģʽ Alt ¡® ÉèÖüüÅÌÖÐÐÄÓÚÊý×ÖÊäÈëÐÐ
²¥·Å¿ØÖÆ Ñ¡ÔñÎïÌåºÍ³É·Ö
Alt ¡£ ÔÚʱ¼äÖáÉÏǰ½øÒ»Ö¡ F8 Çл»ÎïÌå/³É·Ö±à¼Ä£Ê½
Alt £¬ ÔÚʱ¼äÖáÉϺóÍËÒ»Ö¡ F9 Ñ¡Ôñ¶à±ßÐζ¥µã
. ǰ½øµ½ÏÂÒ»¹Ø¼üÖ¡ F10 Ñ¡Ôñ¶à±ßÐεıß
, ºóÍ˵½ÉÏÒ»¹Ø¼üÖ¡ F11 Ñ¡Ôñ¶à±ßÐεÄÃæ
Alt v ²¥·Å°´Å¥£¨´ò¿ª/¹Ø±Õ£© F12 Ñ¡Ôñ¶à±ßÐεÄUVs
Alt/Shift V »Øµ½×îС֡ Ctrl I Ñ¡ÔñÏÂÒ»¸öÖмäÎïÌå
K ¼¤»îÄ£Äâʱ¼ä»¬¿é Ctrl F9 Ñ¡Ôñ¶à±ßÐεĶ¥µãºÍÃæ
ÏÔʾÉèÖà ¿ì½Ý²Ëµ¥ÏÔʾ
¿ì½Ý¼ü ¹¦ÄܽâÊÍ
¿ì½Ý¼ü ¹¦ÄܽâÊÍ
Êó±ê×ó¼ü
4 Íø¸ñÏÔʾģʽ ¿Õ¸ñ¼ü µ¯³ö¿ì½Ý²Ëµ¥£¨°´Ï£©
5 ʵÌåÏÔʾģʽ ¿Õ¸ñ¼ü Òþ²Ø¿ì½Ý²Ëµ¥£¨ÊÍ·Å£©
6 ʵÌåºÍ²ÄÖÊÏÔʾģʽ Alt m ¿ì½Ý²Ëµ¥ÏÔʾÀàÐÍ£¨»Ö¸´³õʼÀàÐÍ£©
7 µÆ¹âÏÔʾģʽ »ìºÏ²Ù×÷
d ÉèÖÃÏÔʾÖÊÁ¿£¨µ¯³öʽ±ê¼Ç²Ëµ¥£© ¿ì½Ý¼ü ¹¦ÄܽâÊÍ
1 µÍÖÊÁ¿ÏÔʾ ] ÖØ×öÊÓͼµÄ¸Ä±ä
2 ÖеÈÖÊÁ¿ÏÔʾ [ ³·ÏûÊÓͼµÄ¸Ä±ä
3 ¸ßÖÊÁ¿ÏÔʾ Alt s ÐýתÊÖ±ú¸½×Å״̬
·Ô½²ã¼¶ Îļþ¹ÜÀí
¡ü ½øµ½µ±Ç°²ã¼¶µÄÉÏÒ»²ã¼¶ Ctrl N ½¨Á¢Ðµij¡¾°
¡ý Í˵½µ±Ç°²ã¼¶µÄÏÂÒ»²ã¼¶ Ctrl O ´ò¿ª³¡¾°
¡û ½øµ½µ±Ç°²ã¼¶µÄ×ó²à²ã¼¶ Ctrl S ´æ´¢³¡¾°
¡ú ½øµ½µ±Ç°²ã¼¶µÄÓÒ²à²ã¼¶ 1 ×ÀÃæÎļþ¹ÜÀí£¨IPX°æ±¾×¨ÓУ©
µñ¿Ì±ÊÉèÖà ²Ëµ¥Ä£Ê½Ñ¡Ôñ
¿ì½Ý¼ü ¹¦ÄܽâÊÍ
¿ì½Ý¼ü ¹¦ÄܽâÊÍ
Alt f À©Õŵ±Ç°Öµ Ctrl m ÏÔʾ£¨¹Ø±Õ£©+Ö÷²Ëµ¥
Alt r ¼¤»îË«ÖØ×÷Ó㨿ªÆô/¹Ø±Õ£© Êó±êÓÒ¼ü
h ת»»²Ëµ¥À¸£¨±ê¼Ç²Ëµ¥£©
Alt a ÏÔʾ¼¤»îµÄÏß¿ò£¨¿ªÆô/¹Ø±Õ£© F2 ÏÔʾ¶¯»²Ëµ¥
Alt c É«²Ê·´À¡£¨¿ªÆô/¹Ø±Õ£© F3 ÏÔʾ½¨Ä£²Ëµ¥
Êó±ê×ó¼ü
u Çл»µñ¿Ì±Ê×÷Ó÷½Ê½£¨µ¯³öʽ±ê¼Ç²Ëµ¥£© F4 ÏÔʾ¶¯Á¦Ñ§²Ëµ¥
o Ð޸ĵñ¿Ì±Ê²Î¿¼Öµ F5 ÏÔʾäÖȾ²Ëµ¥
b Ð޸ıʴ¥Ó°ÏìÁ¦·¶Î§£¨°´ÏÂ/ÊÍ·Å£© Îü¸½²Ù×÷
m µ÷Õû×î´óÆ«ÒÆÁ¿£¨°´ÏÂ/ÊÍ·Å£© ¿ì½Ý¼ü ¹¦ÄܽâÊÍ
n ÐÞ¸ÄÖµµÄ´óС£¨°´ÏÂ/ÊÍ·Å£© C Îü¸½µ½ÇúÏߣ¨°´ÏÂ/ÊÍ·Å£©
/ ʰȡɫ²Êģʽ--ÓÃÓÚ£º»æÖƳÉÔ±×ʸñ¡¢»æÖÆÈ¨ÖØ¡¢ÊôÐÔ»æÖÆ¡¢»æÖÆÃ¿¸ö¶¥µãÉ«²Ê¹¤¾ß X Îü¸½µ½Íø¸ñ£¨°´ÏÂ/ÊÍ·Å)
£¬ Ñ¡Ôñ´Ô£¨°´ÏÂ/ÊÍ·Å£©-ÓÃÓÚ»æÖÆÈ¨Öع¤¾ß V Îü¸½µ½µã£¨°´ÏÂ/ÊÍ·Å£©
±à¼²Ù×÷ £¨ÏÔʾ/Òþ²Ø£©¶ÔÏó
¿ì½Ý¼ü ¹¦ÄܽâÊÍ
¿ì½Ý¼ü ¹¦ÄܽâÊÍ
z È¡Ïû£¨¸Õ²ÅµÄ²Ù×÷£© Ctrl h Òþ²ØËùÑ¡¶ÔÏó
Shift Z ÖØ×ö£¨¸Õ²ÅµÄ²Ù×÷£© Ctrl/Shift H ÏÔʾÉÏÒ»´ÎÒþ²ØµÄ¶ÔÏó
g ÖØ¸´£¨¸Õ²ÅµÄ²Ù×÷£© Èý¼üÊó²Ù×÷
Shift G ÖØ¸´Êó±êλÖõÄÃüÁî ¿ì½Ý¼ü ¹¦ÄܽâÊÍ
Ctrl d ¸´ÖÆ Alt+Êó±êÓÒ¼ü ÐýתÊÓͼ
Shift D ¸´ÖƱ»Ñ¡¶ÔÏóµÄת»» Alt+Êó±êÖмü ÒÆ¶¯ÊÓͼ
Ctrl g ×é³ÉȺ×é Alt+Êó±êÓÒ¼ü+Êó±êÖмü Ëõ·ÅÊÓͼ
p ÖÆ¶¨¸¸×Ó¹ØÏµ Alt+Ctrl+Êó±êÓÒ¼ü ¿òÑ¡·Å´óÊÓͼ
Shift P È¡Ïû±»Ñ¡ÎïÌåµÄ¸¸×Ó¹ØÏµ Alt+Ctrl+Êó±êÖмü ¿òÑ¡ËõСÊÓͼ |
