UJAM Virtual Drummer BRUTE 2.1.1
ÆäËû
From the nineties to the noughties. Contemporary hard-and-heavy music genres are driven by a particular drumming style, loud, wild, edgy, and cutting through the mix. Both drum sounds and playing are rooted in aesthetics invented about two decades ago.
It features the essential sounds and styles from Grunge to NuMetal. In a nutshell, it is the Virtual Drummer for you if HEAVY 2 is too Metal-ish and SOLID 2 not rocking hard enough.
Its five drum kits are composed with specific styles in mind. Listen to these different drum kits starting from dry to wet, blending mixing presets and the ¡°Smack¡± control into the sound of each kit.
Features of UJAM Virtual Drummer BRUTE
Several essential sounds and styles
5 genre-specific drum kits
6 mix Presets
31 playing Styles, each with 23 phrases
Fast and easy so that you can focus on your music
System Requirements and Technical Details
Supported OS: Windows 10 / Windows 8.1 /Windows 7
Processor: Multi core Intel Series or above, Xeon or AMD equivalent
RAM: 4GB (8GB or more recommended)
Free Hard Disk Space: 4GB or more recommended
aHR0cHM6Ly9wZXNrdG9wLmNvbS91cGxvYWRzL2IwM2M0Mjk5N2EyYmY4MDY4ZTJlMjBiMzNlYzQ1YmUzLmpwZw.jpg
ÏÂÔØ:https://pesktop.com/en/windows/ujam-virtual-drummer-brute
ÆÀÂÛÁÐ±í£¨1£©
:victory: :victory: :victory: :D :D :D
2008-10-2 11:51:13 »Ø¸´
