Toontrack ¨C EZdrummer 3 v3.0.0 STANDALONE, VSTi3, AAX*, AU x64 (WIN/OSX)
EZdrummer 3 gives you creative options for a complete set of easy-to-use features that allow you to create full-fledged drum parts. Ready to write some songs? Meet your new drummer.
For mac drivers: If Installer and Updater do not start , replace them with these versions of Installer and Updater
Installation
1. Install EZdrummer 3
2. Install EZdrummer 3 Core Library
3. Install EZdrummer 2 Core Library (if necessary)
FAQ
Q: I have an older version of EZdrummer. Will I automatically receive a free update?
A: EZdrummer 3 is not a free update, it¡¯s a brand new program that includes many new features as well as a new core sound and MIDI library.
Q: What will happen to my already installed Toontrack EZX and MIDI packs when I upgrade to EZdrummer 3?
A: All your already installed EZX or Toontrack MIDI packages will be available through EZdrummer 3. However, you will need to download and install updates.
Q: What will happen to my previous version of EZdrummer?
A: EZdrummer 3 does not overwrite the earlier version you have installed.
Q: What will happen to projects where I used an earlier version of EZdrummer?
A: EZdrummer 3 does not overwrite previous versions. Until you uninstall the previous version, your old projects will remain intact.
Q: Can the EZDrummer 3 EZX libraries (and future libraries) be used in Superior Drummer 3?
A: Yes, after installing the appropriate updates, Superior Drummer 3 can read all existing and future EZX libraries.
Q: Can EZdrummer 3 read Superior Drummer SDX sound libraries?
A: No, EZdrummer 3 can only read EZX libraries.
List of distributions of EZX libraries
Action! EZX v1.0.1
Alt-Rock EZX v1.0.0
Americana EZX v1.5.2
Big Band EZX v1.0.0
Big Rock Drums EZX v1.0.0
Classic Rock EZX v1.0.0
Claustrophobic EZX v1.5.3
Custom Shop EZX v1.0.0
Dance EZX v1. 0.0
Dark Matter EZX v1.0.0
Death Metal EZX v1.0.1
Dream Pop EZX v1.0.0
Drumkit From Hell EZX v1.5.3
Drums of Destruction EZX v1.0.0
Electronic EZX v1.5.2
Electronic Edge EZX v1.0.0
Funkmasters EZX v1.5.4
Hard Rock EZX v1.0.1
Hip-Hop! EZX v1.0.0
In The Pocket EZX v1.0.0
Indie Folk EZX v1.5.0
Jazz EZX v1.5.1
Kicks & Snares EZX v1.0.0
Latin Cuban Drums EZX v1.0.0 ( v1.0.1 update )
Latin Cuban Percussion EZX v1.0.0 (v1.0.1 update )
Latin Percussion EZX v1.5.5Made
of Metal EZX v1.0.0
Metal Machine EZX v1.5.2
Metal! EZX v1.5.4
Metalheads EZX v1.5.1
Modern Metal EZX v1.0.0
Nashville EZX v1.5.3
Number 1 Hits EZX v1.5.3
Pop Punk EZX v1.0.0
Pop! EZX v1.0.0
Pop/Rock EZX v1.5.4 (upgrade to v1.5.5 )
Post-Rock EZX v1.0.0
Progressive EZX v1.0.0
Reggae EZX v1.0.2
Rock Solid EZX v1.5.3
Rock! EZX v1.5.3
Seventies Rock EZX v1.0.0
Southern Soul EZX v1.0.0
The Blues EZX v1.5.0
The Classic EZX v1.5.1
Traditional Country EZX v1.0.1
Twisted Kit EZX v1.5.1
UK Pop EZX v1.0.0
Vintage Rock EZX v1.5.3
midi grooves
https://audiostorrent.com/toontrack-drums-midi-pack-midi
