Legatone Hand Chimes KONTAKT | 325 Mb
ÊÖÒ¡ÁåÊÇÓÃÊÖ°´ÊÖÒ¡µÄÀÖÆ÷£¬ÀàËÆÓÚÊÖÁå¡£Ò»°ãÇé¿öÏ£¬ËüÃÇÊÇÓÃÍⲿµÄclapper»úÖÆµ÷Õû·½Ðιܡ£ÊÖÏàµÄÌØµãÊÇÈáºÍ¡¢ÇåÎú¡¢ÏìÁÁ¡£ÓÐ24λ/ 96ºÕ×ȸ߷ֱæÂʵĸ߷ֱæÂÊÒôÖÊ¡£Í¨¹ý¶Ôÿһ¸ö¿Ì¶ÈµÄÈý¸öÖ§³Å½øÐвÉÑù£¬Ëü¶ÔÓ¦ÓÚÿһ´Î²úÉú²»Í¬Ñù±¾µÄ¡°Ô²¡±£¬¶øÇÒ¿ÉÒÔÓøü×ÔÈ»µÄÊÖÀ´ÑÝ×à¡£³ýÁËÓйæÂɵÄÊÖ¹¤²Ù×÷£¬Â¼ÖƵIJ¹¶¡»¹°üº¬ÁË¡°e - piano¡±²¹¶¡£¬ÓÃÓÚ×÷ΪһÖֵ綯¸ÖÇٺ͡°Glocken¡±ÌùƬ½øÐÐÓÅ»¯£¬ÒÔÓÃ×÷glockenspiel¡£
ϸ½Ú:
ÒªÇóKONTAKT 5.3»ò¸ü¸ß(²»ÓëKONTAKT²¥·ÅÆ÷ºÏ×÷)
Ñù±¾¼Ç¼·¶Î§G2 - G4(¿É²¥·Å·¶Î§G1 - G5)
ÿ3¸ö³ß¶ÈµÄÔ²Ðκ¯Êý
24λ/ 96 khzÁ¢ÌåÉù
°üÀ¨×¨ÓúìÍâ»ìÏì
ÔÎÄ
Hand chimes are musical instruments which are rung by hand, similar to handbells. Typically, they are tuned square tubes with an external clapper mechanism. The hand chime is characterized by a soft, clear, sonorous tone. A rich sustain of up to 20 seconds or more is carefully recorded with 24 bit / 96 kHz high resolution sound quality. By sampling three sustains for each scale, it corresponds to RoundRobin which produces different samples each time, and it is possible to play a more natural hand chime sound. In addition to the regular hand chime, the recorded patch also contains the "E. piano" patch optimized for use as an Electric piano plus the "Glocken" patch optimized for use as a glockenspiel.
Details:
Requires KONTAKT 5.3 or higher (does not work with KONTAKT PLAYER)
Sample recording range G2 - G4 (playable range G1 - G5)
RoundRobin function of each 3 scales
24bit / 96kHz stereo
Dedicated IR reverb included
ÏÂÔØµØÖ·£ºÓοͣ¬Èç¹ûÄúÒª²é¿´±¾ÌûÒþ²ØÄÚÈÝÇë »Ø¸´ |
