TELEFUNKEN M62 FET СÕñĤ³¬ÐÄÐ;§Ìå¹Ü»°Í²
×ªÔØ
TELEFUNKEN M62 FET СÕñĤ³¬ÐÄÐ;§Ìå¹Ü»°Í²$ \, n- x( ^6 H. t: j  j
4 ~0 z, I! R5 U& @: I
. f! h4 A* j3 m/ U% b
+ S2 m3 A. f' g7 v# b% f, J+ |) h Éè¼ÆµÄ M62 FET£¨Field Effect Transistor/³¡Ð§Ó¦¾§Ìå¹Ü£©Ð¡ÕñĤÂó¿Ë·ç TELEFUNKEN Elektroakustik µÄÊ׿î·ÇÕæ¿Õµç×ӹܣ¬»ùÓÚ FET µÄ¹Ì̬µçÈÝÂó¿Ë·ç¡£ 1 Y$ `8 T9 D$ }( c' S0 |
Õâ¿î Éè¼ÆµÄ M62 FET£¨Field Effect Transistor/³¡Ð§Ó¦¾§Ìå¹Ü£©Ð¡ÕñĤÂó¿Ë·ç TELEFUNKEN Elektroakustik µÄÊ׿î·ÇÕæ¿Õµç×ӹܣ¬»ùÓÚ FET µÄ¹Ì̬µçÈÝÂó¿Ë·ç¡£
; U# H/ L7 f0 w) {  U( z9 WÀûÓÃÒ»¸ö¶ÀÌØµÄרÀûµç·½á¹¹£¬ÖØÐÂÚ¹ÊÍÁ˾­µäµÄ FET Âó¿Ë·ç·Å´óÆ÷£¬´´ÔìÁ˽ܳöµÄ˲̬ÏìÓ¦ÒÔ¼° SPL£¨Éùѹ¼¶£©´¦ÀíÄÜÁ¦¡£¾«ÐÄÌôÑ¡ºÍ²âÊÔµÄÔ­¼þÊÖ¹¤×°Åä½ø¶Æ½ðµç·°å£¬ÌṩÁËÇåÎú¡¢ÕæÕý Class A ÀëÉ¢·Å´óÆ÷£¬¾ß±¸´Ó 20Hz µ½ 50kHz +/- 2 dB µÄƵÂÊÏìÓ¦¡£
4 C5 P8 P. m# M# s+ A, _Êä³öÅäÓж¨ÖƵÄÃÀÖÆ±äѹÆ÷£¬ÌṩÁ˳¬µÍµÄ×ÔÉíÔëÒôÒÔ¼°µäÐ굀 0.015% »ò¸üºÃµÄ THD+N£¬ÕâÈÃËüÖØÒªÂ¼ÒôÓÃ;µÄºÜºÃÑ¡Ôñ¡£ ' b. w7 u! Z# R# A
Éè¼ÆÉÏͬÑùÀûÓÃÁË TEC Award »ñ½±µÄ ELA M 260 СÕñĤµç×Ó¹ÜÂó¿Ë·çµÄ¿É»¥»» TK6X µçÈݲÕϵͳ£¬M62 FET Ò²ÊÇÊÊÓÃÓÚÔ­ÉùºÍ´ò»÷ÀÖÉùÔ´¡£TK60 ÐÄÐÍÇúÏߣ¬TK61 ȫָÏòÒÔ¼° TK62 ³¬ÐÄÐͲÕÌṩÁ˵¥¶À»òÍêÕûµÄÌ×¼þ£¬È»ºó M62FET ·Å´óÆ÷ºÍµçÈݲÕÌ×¼þÅä¶Ô¿ÉÓÃÓÚÁ¢ÌåÉù¼Òô¡£ , C% p- m* f/ l# n* d% L# M
; @) p4 [: e9 r4 R4 x
¼¼Êõ²ÎÊý£º
* Z0 c* C' N, l6 E( J7 AÀàÐÍ£ºµçÈÝѹÁ¦ÌݶÈʽ
5 }$ F  n; c; r6 Z% oʰÒôÍ·£ºTK62 - 15 mm Edge Terminated Diaphragm ; _6 C' Z3 h+ l3 I0 G( f% F( j
µç×Ó¹ÜÀàÐÍ£ºActive FET Transistor (ÎÞÕæ¿Õµç×Ó¹Ü) - |' O. h2 Z, g0 y2 ?% P
±äѹÆ÷£º¶¨ÖƲøÈÆTelefunken T61CT
/ B6 q8 i% c8 NÖ¸ÏòÐÔ£º³¬ÐÄÐÍ 3 }' C. r( R: \) [# e" I, R0 \
ƵÂÊÏìÓ¦£º20 Hz - 31.5 kHz, ¡À 2 dB (·Å´óÆ÷)
& j% @! I+ J! r/ _4 |ÁéÃô¶È£º8.6 mV/PA, ¡À 1db $ [: |+ w# h  v+ B6 J
THD at 1kHz at 1Pa ((·Å´óÆ÷)£º<0.01%
  H( t& T% S* SÊä³ö×迹£º120 ¦¸
! g" J0 y. h; |/ vÉùѹ¼¶(for 1% THD)£º> 130 dB ( P% \; C' ^" y
S/NÐÅÔë±È£º> 89 dBA 2 {5 P/ @' t" a+ m
×ÔÔëÉù£¨·Å´óÆ÷)£º ¡Ü 5 dBA 6 @5 \2 k" a, u, {- s& n+ l
³ß´ç/ ³ß´ç£º140 mm L x 21 mm Dia . s6 A8 r1 x- ]& _3 V
ÖØÁ¿£º110 g ; _& y* T( R6 x$ G; v- u6 b
Ö÷ÒªµçÁ÷ÏûºÄ£º2 mA
6 Y0 L2 a+ c4 G2 \+ C. N; ^Ï߲ģºSGMC-5R - 5 Meter (16.9 ft) Cable, Right Angle Female 3 Pin XLR, 3 Pin Male XLR3 ]9 b  X0 y6 B/ x" [
Ö§¼Ü£ºM 961 - Suspended Elastic Mount 4 h! P+ @) z$ r% j; |! p) O
$ e  D' C$ j! G& bº½¿ÕÏ䣺ZC61 Soft Foam Zip Case, ZC62 for Stereo Set
7 \1 v7 e( f0 B- S' @6 e5 c, m, L# P9 ^! G2 T
" q' d8 r; }  R  H5 W- D  L% i6 A
. i. ~) a0 X- v, |1 ?' uTELEFUNKEN M62 FET СÕñĤ³¬ÐÄÐ;§Ìå¹Ü»°Í²& z# G- X9 _# g" K
ÆÀÂÛÁÐ±í£¨1£©
518310 Â¥Ö÷
:victory: ×Ô¼ºÀ´ÓéÀÖÒ»ÏÂ:victory:
2008-9-8 20:41:51 »Ø¸´
