Samplitude Pro X Suite combines the outstanding features of the Samplitude Pro X audio workstation with a high-quality add-on package. The precise audio engine with full bit transparency guarantees 100% neutral sound. Discover the unique possibilities offered by real-time editing, individually customizable interfaces, an optimized workflow, and high-quality mastering tools. And that¡¯s not all ¨C Samplitude Pro X Suite also includes the Analogue Modelling Suite Plus, Vandal guitar and bass amplifier as well as the Independence Sampler. All these components transform your system into a powerful all-in-one solution covering all stages involved in sophisticated audio productions.
Features:
-64-bit support: take advantage of a 64-bit application and 64-bit plug-ins. Naturally, Samplitude Pro X is capable of running on both 32-bit and 64-bit systems and 32-bit plug-ins are still supported.
-100% sound neutrality & fidelity: transparency, neutrality, spaciousness and retention of transients ¨C even during intense digital editing processes, the sound retains its acoustic nuances thanks to full bit transparency.
-Hybrid Audio Engine ¨C Perfect performance on any system
-Object editing: complete editing at object level, including effects, plug-ins, fades, equalizing, timestretching, pitchshifting, AUX sends and freeze. Completely non-destructive & real-time.
Magix ¨C Samplitude Pro X Suite
New highlights ¨C why the new version is worth it:
-NEW! 64-Bit support
-NEW! New docking for a program interface that is individually adjustable via drag & drop. Includes docking for Object & MIDI Editor and visualization!
-NEW! Spectral cleaning at track level
-NEW! Tempo track for adjusting playback speed of any segment of a MIDI arrangement
-NEW! essentialFX Suite with 10 effects
-NEW! Analogue Modelling Suite Plus
-NEW! AAF / OMF export
Professional audio processing from recording to mastering ¨C realize your creative ideas with Samplitude Pro X Suite. As a purely native digital audio workstation, Samplitude Pro X Suite is independent of proprietary audio hardware and can be used on a comprehensive audio workstation as well as on a laptop.
ÏÂÔØµØÖ·£ºÓοͣ¬Èç¹ûÄúÒª²é¿´±¾ÌûÒþ²ØÄÚÈÝÇë »Ø¸´ |
