[DPA 4066]DPA 4066F΢ÐÍȫָÏòµçÈÝ»°Í²
DPA 4066ÊÇÒ»¿îÁé»îÇÒÒ×ÓÚµ÷½ÚµÄȫָÏòÍ·´÷»°Í²£¬ÄÜÌṩ´¿¾»µÄÉùÒôºÍ³ä×ãµÄ¶¯Ì¬ÓàÁ¿¡£¶àÄêÒÔÀ´£¬DPA 4066Ò»Ö±Êǹ㲥´ÓÒµÈËÔ±¡¢°ÙÀÏ»ãºÍÂ×¶ØÎ÷Çø¾çÔºµÄ¡£¼´Ê¹ÔÚ¶ñÁӺͳ±ÊªµÄ»·¾³ÖУ¬ËüÈÔÈ»·Ç³£¿É¿¿£¬±£Ö¤ÒôÖʺ㶨һÖ¡£»°Í²¿ÉÒÔÅå´÷ÔÚ×ó²à»òÓÒ²àÁ³¼Õ¡£DPA 4066 Í·´÷ʽÃÔÄãС»°Í²¾ßÓÐÓë4061ÏàͬµÄ»°Í²Í·£¬²»Í¬µÄÊÇËüÃÇ¿ÉÒÔ·½±ãµÄÅå´÷ÔÚÁ³¼Õ²àÃæ¡£4066»¹¿ÉÒԴӶƽðÖ§¼ÜÉϲðжÏÂÀ´£¬Óë4060ϵÁеݲװ¸½¼þ´îÅäʹÓá£ÔÚʵ¼ÊÓ¦ÓÃÖбíÏÖÁ˳öÉ«µÄÉùÒô͸Ã÷¶ÈºÍ×ÔÈ»ÐÔ£¬Í¬Ê±Ò²ÓгöÖڵķÀ³±ÄÜÁ¦ºÍ»úеÎȶ¨ÐÔ¡£
4066ÊÇÒ»¸öÁé»îµÄ΢ÐÍ»°Í²½â¾ö·½°¸£¬ÆäÌØµãÊǾßÓзdz£ÈÝÒ×ʹÓúͱã½ÝµÄµ÷½Ú¡£ÌØÓеÄÍ·´÷ʽ½á¹¹Éè¼Æ£¬ÒòΪËü¿ÉÒÔÈÃʹÓÃÕßÑ¡Ôñ×óÓÒ°²×°ºÍ¸Ä±äÉ«²Ê¡£ËüÒ²Äܹ»Ê¹ÓÃMMB4066΢ÐÍ»°Í²£¬È«Ö¸ÏòÐԵ쬷ÖÀëµØ£¬Ó¦ÓÃÔÚ²»ÐèҪͷ´÷»°Í²µÄµØ·½¡£
Miniature Microphone Solution
The 4066F is a flexible miniature microphone solution, that features very easy and fast adjustment possibilities and a beige color. The headband construction is unique in design, because it gives the user the choice between left and/or right mounting and colour change. It is also possible to use the MMB4066 Miniature Microphone Boom separately, in applications where the headband is not needed.
The 4066 offers a clean and transparent sound quality with lots of headroom. It uses a prepolarized omnidirectional cartridge element with a 5.4mm vertical diaphragm. It is specially designed for maximum performance and comfort under the often difficult conditions when mounted directly on the human body.
Attention has been paid to the humidity problems that often occur in theatrical applications and to the light weight construction of the headband itself. A double vent protection system, a drop stopper on the tube, together with water resistant materials inside the microphone, makes it more than difficult for the humidity to cause the headband Microphone to fail. The headband surface is matgold plated and headband earhooks are covered with a silicon hose.
The sensitivity is 6mV/Pa to match the level of the human voice to the general input sensitivity of most wireless transmitters. The noise floor of the Type 4066 is 26dB(A) re. 20 mUPa and if powered correctly the microphone will be able to handle sound pressure levels up to 144dB SPL before clipping occurs. A wide range of connection adapters makes it possible to use the 4066 with most of the professional wireless systems available plus 48 V phantom XLR connection.
DPA 4066F features:
Directional characteristics: Omnidirectional
Frequency range: Soft boost grid: 20Hz-20kHz +/-2dB, 3dB soft boost at 8-20kHz; High boost grid: 20Hz-20kHz +/-2dB, 10dB boost at 12kHz
Sensitivity: Nominally 6mV/Pa +/-3dB at 1kHz
Equivalent noise level A-weighted: Typ. 26dB(A) re. 20 mUPa (max. 28dB(A))
Equivalent noise leve l CCIR 468-1: Typ. 38dB (max. 40dB)
Maximum sound pressure level: 144dB SPL before clipping
Total harmonic distortion: 123dB SPL peak (<1% THD)
Cable drive capability: Up to 300m (984ft)
Cartridge lower limiting frequency (-3db): 20Hz
Output impedance: 30-40 Ohm
Weight: 14g (0.5oz) incl. cable and MicroDot connector
Microphone length: 12.7mm (0.5in)
Microphone diameter: 5.4mm (0.21in)
Tech Specs| Compatibility | Adapter Required for Wireless Connection | | Connector | MicroDot | | Color | Beige | | Polar Pattern | Omni | | Microphone Type | Condenser | | Frequency Response | 20Hz-20kHz | | Max SPL | 144dB SPL | | Signal to Noise Ratio | 68dB (A weighted) | | Self Noise | 26dB (A weighted) | | Cable Length | 3.9 ft. | | Weight | .03 lb. (14g) |
