SSL X Logic Alpha Channel ͨµÀÌõ»°Í²·Å´óÆ÷¾ùºâ¶¯Ì¬´¦ÀíÆ÷
Alpha ChannelÌṩһ¸ö¼ÒôÊÒ¼¶±ðµÄ»°Í²Ç°Ö÷ŴóºÍ´¦Àí£¬»ùÓÚSSLÔÚÄ£Äâ¼Òôµ÷̨É϶àÄêµÄ¾­Ñé¡£ºÜ´óÒ»²¿·ÖÒôÀÖ¶¼ÊÇÔÚSSLÉÏÂ¼ÖÆµÄ£¬ÒÔ³öÉ«µÄÒôÖÊÖø³Æ.ÄÇÒ²ÊÇAlpha ChannelͬÑù¾ßÓеÄÒòËØ¡£ ͨ¹ý»°Í²·Å´ó£¬Â˲¨£¬EQºÍ¶¯Ì¬µÄ½Ü³ö×éºÏ£¬ XLogic Alpha ChannelΪÄãµÄÊý×ÖÒôƵ¹¤×÷Õ¾´øÀ´ÁËÍêÃÀµÄǰ¶Ë£¬ÖÁ½ñΪֹÔÚÄ£ÄâͨµÀÌõÉÏÌṩµÄSSLµÄÒôÉ«¡£
Ö÷ÒªÌØÕ÷£º
רҵµÄ¼«¸É¾»»°Í²Ç°Ö÷Ŵ󣬴øÏß·µçƽºÍHi ZÀÖÆ÷ÊäÈ뿪¹Ø
¿É±äг²¨Çý¶¯µç·----Ê§ÕæÌØÕ÷µÄʱ¼ä»úÆ÷
´ø¿ÉÑ¡µÄ40Hz£¬ 80Hz »ò 120Hz·ÖƵµãµÄ¸ßͨÂ˲¨Æ÷
ÄÚ½¨×¨ÒµÆ·ÖʵÄÄ£Äâ-Êý×Öת»»£¬±ê×¼ÅäÖÃ
3¶ÎSSL±äÁ¿EQ´øÖÐÆµQÖµ¿ØÖƺÍ˫ͨµÍƵÇúÏß
ÖÇÄÜ×Ô¶¯Ñ¹ËõÆ÷£¬¿ÉÏÞ¶ÈÀûÓüÒô¶¯Ì¬ÓàÁ¿ºÍ±ÜÃâDACÏ÷²¨
¼¼ÊõÖ¸±ê£º
Éî¶È£º230mm / 9"
¸ß¶È£º44.5mm / 1.75" (1 RU)
¿í¶È£º482mm / 19" inc¡¯ rack ears
ÖØÁ¿£º3.0kg / 7 Ó¢°÷
¹¦ÂÊ£º< 20 Watts
×°Ï乿¸ñ£º320mm x 550mm x 80mm 12.75" x 21.75" x 3.25"
×°ÏäÖØÁ¿ 3.5kg / 8 Ó¢°÷
»°Í²ÔöÒæÖÁÊä³ö: 20dB min£¬ 76 dB max
ÀÖÆ÷ÔöÒæÖÁÊä³ö: 26dB min£¬ 82 dB max
»ÃÏàË¥¼õ: 20 dB
ÊäÈë×迹 (¦¸): »°Í²: 1K/10K
ÀÖÆ÷: 1 MEG
ÔëÒôÌØÕ÷
µÈЧÊäÈëÔëÉù:
Mic£¬ ×迹 = 10R -130.5 dBU
Mic£¬ ×迹 =150R -127.5 dBU
¶¯Ì¬·¶Î§:
»°Í²ÔöÒæ×îС: 105 dB
»°Í²ÔöÒæ: 76 dB
ƵÂÊÏìÓ¦
Mic - Êä³ö: +/- 0.2 dB£¨10Hz - 70KHz£©
-3dB (LF) : 6 Hz
-3dB (HF) : 250 KHz
Ä£ÄâÊä³ö: +24.3 dBU (10K)
»ÃÏñ¹©µç: 47.5V typical
Êä³öÔöÒæ·¶Î§: +/- 19.5 dB
Á¬½Ó
µçÔ´ IEC320 3-pinÁ¬½Ó, 100 ¨C 240 Vac, 50 ¨C 60 Hz
Ä£ÄâI/O
»°Í²£ºÆ½ºâ, 3-pin XLR-F, Zin = 1k? (10k? for Hi Z)
ÀÖÆ÷£º·Çƽºâ, ?" Mono Jack, Zin = 1M?
Êä³ö£ºÆ½ºâ, ?" Stereo Jack, Zo = 40?
²åÈë·¢ËÍ£ºÆ½ºâ, ?" Stereo Jack, Zo = 40?
²åÈë·µ»Ø£ºÆ½ºâ, ?" Stereo Jack, Zin = 10k?
Link (2 of) £ºRCA phono, ÏÞÖÆ²àÁ´¿ØÖƵçѹ (dc.)
Êý×ÖI/O
SPDIF In£ºRCA phono, 1V pk-pk, Zin = 75?, SPDIF format.
The ADC will lock to this signal if present.
SPDIF Out£ºRCA phono, 1V pk-pk, Zo = 75?, SPDIF 24bit format.
Synchronised to SPDIF In, else free-runs at 44.1kHz.
Ö÷ÒªÌØµã
¾ßÓÐHi Z×迹¿ª¹ØµÄרҵ³¬¸É¾»Âó¿Ë·çǰÖ÷ŴóÆ÷
VHD£¨¿É±äг²¨Çý¶¯£©µç·¿ÉÔö¼ÓÄ£ÄâÒôµ÷
Ç°Ãæ°åCombi XLRÂó¿Ë·ç/Ïß·/ÀÖÆ÷ÊäÈë
1/4¡± jackÀÖÆ÷×Ô¶¯¸ÐÓ¦£¬¾ßÓÐÎÞÔ´DIÐÍ×迹¼ì²âºÍµçƽƥÅ书ÄÜ
¸ßͨÂ˲¨Æ÷£¬¿ÉÑ¡Ôñ40Hz£¬80Hz»ò120Hz½ØÖ¹
DC²àÁ´Á´½ÓÊä³ö£¨RCA£©
ÄÚÖÃרҵƷÖʵÄÄ£Êýת»»
1/4Ó¢´çÄ£ÄâÊä³öºÍS / PDIF I / O
×Ô¶¯²ÉÑùÂʸÐÓ¦ºÍ×ÔÎÒµ÷Õû
¾ßÓÐÖÐÆµQ¿ØÖƺÍË«LFÇúÏßµÄÈý¶ÎSSL²ÎÊý¾ùºâÆ÷
ÖÇÄÜ×Ô¶¯ÏÞÖÆ¹¦Äܿɳ̶ȵØÌá¸ß¼ÒôÓàÁ¿²¢±ÜÃâDACÏ÷²¨
ÆÀÂÛÁÐ±í£¨1£©
2008-7-21 12:25:46 »Ø¸´
