TELEFUNKEN M60 FETСÕñĤÐÄÐ;§Ìå¹Ü¼Òô»°Í²
! c( X B1 \! @/ ?
& K9 K f/ S3 o# i1 D F+ D( A3 D; ]& l; Y q4 c7 J4 ?+ l) g! P) \* c. C
6 b2 @( E4 u `0 \' `# L/ yÉè¼ÆµÄ M60 FET£¨Field Effect Transistor/³¡Ð§Ó¦¾§Ìå¹Ü£©Ð¡ÕñĤÂó¿Ë·ç TELEFUNKEN Elektroakustik µÄÊ׿î·ÇÕæ¿Õµç×ӹܣ¬»ùÓÚ FET µÄ¹Ì̬µçÈÝÂó¿Ë·ç¡£ 1 R7 N& T/ j5 ?5 a; Z
ÀûÓÃÒ»¸ö¶ÀÌØµÄרÀûµç·½á¹¹£¬ÖØÐÂÚ¹ÊÍÁ˾µäµÄ FET Âó¿Ë·ç·Å´óÆ÷£¬´´ÔìÁ˽ܳöµÄ˲̬ÏìÓ¦ÒÔ¼° SPL£¨Éùѹ¼¶£©´¦ÀíÄÜÁ¦¡£¾«ÐÄÌôÑ¡ºÍ²âÊÔµÄÔ¼þÊÖ¹¤×°Åä½ø¶Æ½ðµç·°å£¬ÌṩÁËÇåÎú¡¢ÕæÕý Class A ÀëÉ¢·Å´óÆ÷£¬¾ß±¸´Ó 20Hz µ½ 50kHz +/- 2 dB µÄƵÂÊÏìÓ¦¡£ . n+ u# |9 L& D/ D7 c O7 J# f
Êä³öÅäÓж¨ÖƵÄÃÀÖÆ±äѹÆ÷£¬ÌṩÁ˳¬µÍµÄ×ÔÉíÔëÒôÒÔ¼°µäÐ굀 0.015% »ò¸üºÃµÄ THD+N£¬ÕâÈÃËüÖØÒªÂ¼ÒôÓÃ;µÄºÜºÃÑ¡Ôñ¡£
+ v4 @6 A: _) R5 J y2 eÉè¼ÆÉÏͬÑùÀûÓÃÁË TEC Award »ñ½±µÄ ELA M 260 СÕñĤµç×Ó¹ÜÂó¿Ë·çµÄ¿É»¥»» TK6X µçÈݲÕϵͳ£¬M60 FET Ò²ÊÇÊÊÓÃÓÚÔÉùºÍ´ò»÷ÀÖÉùÔ´¡£TK60 ÐÄÐÍÇúÏߣ¬TK61 ȫָÏòÒÔ¼° TK62 ³¬ÐÄÐͲÕÌṩÁ˵¥¶À»òÍêÕûµÄÌ×¼þ£¬È»ºó M60 FET ·Å´óÆ÷ºÍµçÈݲÕÌ×¼þÅä¶Ô¿ÉÓÃÓÚÁ¢ÌåÉù¼Òô¡£ % ~7 p- i, |% u; k9 |
: x( _! W6 ^( Z. c; e¼¼Êõ²ÎÊý£º 9 ~9 j+ O( f8 M" n A, x" T
ÀàÐÍ£ºµçÈÝѹÁ¦ÌݶÈʽ
7 j$ \2 e: d0 O. g$ _% bʰÒôÍ·£ºTK60 - 15 mm Edge Terminated Diaphragm * b% D" T# E# I; D3 o, O) L
µç×Ó¹ÜÀàÐÍ£ºActive FET Transistor (ÎÞÕæ¿Õµç×Ó¹Ü) + a, F* d, w' O0 q# |, W: d
±äѹÆ÷£º¶¨ÖƲøÈÆTelefunken T61CT 3 {7 }1 N& g9 Q4 A3 P7 K: |# h
Ö¸ÏòÐÔ£ºÐÄÐÍ
8 I: B! A. \4 P& j8 [+ N: i0 l8 _2 C1 zƵÂÊÏìÓ¦£º20 Hz - 31.5 kHz, ¡À 2 dB (Amplifier) I' J- ?( y# ~ ~$ h$ i* b
ÁéÃô¶È£º8.6 mV/PA, ¡À 1db & l( V# y# c& n: v
THD at 1kHz at 1Pa (Amplifier)£º<0.01% / M- c! V. q- G6 e0 B4 {
Êä³ö×迹£º120 ¦¸
; Z+ I, Q3 h$ g8 [4 q- U JÉùѹ¼¶ (for 1% THD)£º> 130 dB
3 s2 f- E/ ^0 N& w4 dS/NÐÅÔë±È£º> 89 dBA
7 J @4 L- z! n4 A5 p! R1 B2 n& J×ÔÉíÔëÉù (·Å´óÆ÷)£º¡Ü 5 dBA
5 Q* N3 S t, W8 _" l, P6 M³ß´ç/³ß´ç£º140 mm L x 21 mm Dia T, ~. v( h/ J k( |
ÖØÁ¿£º110 g 1 x& H4 O+ ]* ?7 C( b# W8 q
Ö÷ÒªµçÁ÷ÏûºÄ£º2 mA 0 i9 S* r7 n; w! S: s# b
ÏßÀ£ºSGMC-5R - 5 Meter (16.9 ft) Cable, Right Angle Female 3 Pin XLR, 3 Pin Male XLR5 v: A2 o, y3 H1 ]
Ö§¼Ü£ºM 961 - Suspended Elastic Mount % j' X" R1 K; E, k/ c8 ?! N8 e
& ]+ a) F9 v: I' y1 |4 V) p7 V" h& sº½¿ÕÏ䣺ZC61 Soft Foam Zip Case, ZC62 for Stereo Set |
