Three-Body Tech Heavier7Strings v1.1.5 WiN
ÒôÔ´
ÈýÌå¼¼Êõ×ÔºÀµØ³ÊÏÖÁËHeavier7Strings£¬ÕâÊÇÒ»ÖÖʵʱ²¥·ÅµÄ»ùÓÚÑù±¾µÄÐéÄâÀÖÆ÷£¬¿É½«ÖؽðÊô´ø»ØÄúµÄ×÷Æ·ÖС£ÅäÓÐÍêÕûµÄЧ¹û¼ÜºÍͼ°¸¿â£¬ÕâÖÖ½ðÊô·ç¸ñµÄ¼ªËûͼÊé¹ÝÓµÓÐÄúÐèÒªµÄÒ»ÇУ¡
¶ÔÒôÀÖµÄÈȰ®ºÍ´´Ôì´´ÐÂÑݲ¥ÊÒ¼¼ÊõµÄÔ¸ÍûÊÇʹHeavier7Strings³ÉΪ¿ÉÄܵÄÖ÷Òª¶¯Á¦¡£ÔÚÖÆ×÷×ܹ²4ÄêµÄʱ¼äÀֻʹÓö¥¼¶ÖÊÁ¿µÄÉ豸£¬³¬¹ý10,000¸öÑùÆ·ÒÔ24λºÍ48 kHz¿Ì¼¡£×îÖØÒªµÄÊÇ£¬Heavier7StringsÓµÓÐ×ÔÖ÷¿ª·¢µÄÈ¡ÑùÆ÷£¬ÔÚÒôÖÊÉϺÁ²»Í×Э¡£
Ч¹û»ú¼Ü
µ±¿ªÊ¼Ò»¸öÐéÄ⼪Ëûʱ£¬Ê×ÏÈÒª×öʲô£¿Í¨³£Ëü»áÈÆ¹ýËùÓÐÄÚÖÃЧ¹û£¬ÒòΪËüÃǶÔÓÚÈκÎÑÏËàµÄ¹¤×÷À´Ëµ¶¼Ì«Ô­Ê¼ÁË¡£È»¶ø£¬Heavier7StringsÖÐÌṩµÄЧ¹û¼ÜÊÇÍêÕûµÄ£¬²¢ÇÒ¾ßÓÐÉú²ú¼¶ÖÊÁ¿£¬¶ø²»½ö½öÊÇÍæ¾ß£¡
Ч¹û¸ÅÊö£º
19ÖØ½ðÊôЧ¹ûÄ£¿é£ºScreamer£¬EQ12£¬AMP£¬Flanger£¬PingpongÑӳٵȡ£
16¸öAMP´ÓÖØ½ðÊôµ½¸É¾»µÄÉùÒô£¬´¦Àí²ÉÑùÂʸߴï8X
66¸ö»ú¹ñºìÍâÏߣ¬Ëĸö¿ÉÒÔͬʱ»ìºÏ£¬¾ßÓв»Í¬µÄÑÓ³Ù£¬ÒôÁ¿ºÍÏàλ
Ô¤Éè¹ÜÀíÆ÷ÔÊÐíÄú´æ´¢×Ô¼ºµÄЧ¹ûÔ¤ÉèÒÔ¼°200¸ö³ö³§Ô¤Éè
MIDIģʽ¿â
Heavier7Strings°üº¬200¸öÔ¤¶¨ÒåµÄMIDIģʽ£¬ÒÔ¼°Ð§¹û»ú¼ÜÅäÖá£ÕâЩģʽµÄ·ç¸ñ´Ó½ðÊô£¬Ò¡¹ö£¬Á÷ÐУ¬¸É¾»£¬ÒÔ¼°·Ç½Ú×àÔëÒôºÍ»·¾³ÉùÒô¡£ËùÓÐÕâЩģʽ¶¼¿ÉÒÔÍÏÈëÖ÷»úDAWÖУ¬Óû§¿ÉÒÔͨ¹ýMIDI¼ô¼­À´¶¨Òå×Ô¼ºµÄģʽ¡£
ģʽ¸ÅÊö£º
200ÖÖ¹¤³§MIDIģʽÒÔ¼°Ð§¹û»ú¼ÜÔ¤Éè
¸÷ÖÖ·ç¸ñ£º½ðÊô£¬Ò¡¹ö£¬Á÷ÐУ¬¸É¾»£¬ÒÔ¼°ÎÞ½Ú×àµÄÔëÒôºÍÖÜΧµÄÉùÒô¡£
¿ÉÍ϶¯µ½Ö÷»úDAWÖÐ
Óû§¿ÉÒÔͨ¹ýÍ϶¯MIDIÀ´¶¨Òå×Ô¼ºµÄģʽ
ÑùÆ·ºÍÈ¡ÑùÆ÷
Heavier7StringsÖÐʹÓõIJÉÑùÆ÷ÊÇ×ÔÐпª·¢µÄ£¬Ã»ÓÐʹÓõÚÈý·½²ÉÑùÆ÷¡£
Ëü¾ßÓÐÒÔÏÂÌØµã£º
Ö±½Ó´Ó´ÅÅ̶ÁÈ¡
ÔÚʵÀýÖ®¼ä¹²ÏíʾÀý»º³åÇøÒÔ¼õÉÙÄÚ´æÏûºÄ
×Ô¶¯µ­³ö´ÅÅ̶ÁÈ¡¼Ó°à£¬ÒÔ±ÜÃâµã»÷ºÍÅéÅéÉù¡£
Ô­ÎÄ
Three-Body Technology proudly presents Heavier7Strings, a real-time playable sample-based virtual instrument thats brings back Heavy Metal to your productions. Equipped with a complete effect rack and a patterns library, this metal-style guitar library has everything you need!
The love for music, and a desire to create innovative studio technology was the mainspring that made Heavier7Strings possible. With total of 4 years in the making, using only top quality equipment, more than 10.000 samples were painstakingly recorded in 24-bit and 48 kHz. To top it all off Heavier7Strings comes with a self-developed sampler with no compromise on sound quality.
The Effect Rack
What is the first thing to do when one starts a virtual guitar? Usually it is to bypass all built-in effects, as they are mostly too primitive for any serious work. However, the effect rack provided in Heavier7Strings is complete and of production-level quality, not just a toy!
Effects Overview:
?19 Heavy Metal Effect Modules: Screamer, EQ12, AMP, Flanger, Pingpong delay, etc.
?16 AMPs with styles from heavy metal to clean sound, processing sample rate up to 8X
?66 cabinet IRs, four can be mixed simultaneously with different delay, volume and phasing
?Preset manager allows you to store your own effect presets, along with 200 factory presets
MIDI Patterns Library
Heavier7Strings contains a number of 200 predefined MIDI patterns, together with effect rack configuration. The style of these patterns ranged from metal, rock, pop, clean, and along with non-rhythmic noise and ambient sounds. All these patterns can be dragged into host DAWs, and users can define their own patterns by MIDI clip.
Patterns Overview:
200 factory MIDI patterns together with effect rack presets
Various styles: metal, rock, pop, clean, along with non-rhythmic noise and ambient sounds.
Draggable into host DAWs
Users can define their own patterns by dragging MIDI into
Samples and Sampler
The sampler used in Heavier7Strings is self-developed, no third-party samplers were used.
It has following characteristics:
Direct read from disk
Shared sample buffer between instances to reduce memory consumption
Automatic fade out on disk-read overtime to avoid clicks & pops.
Three-Body Tech Heavier7Strings v1.1.5 WiN | 9.51 GB
ÆÀÂÛÁÐ±í£¨15£©
ÐÀÉÍ,Ö§³Ö,ÎʺÃ.:handshake
2008-6-21 12:46:19 »Ø¸´
2008-6-21 19:57:19 »Ø¸´
Ïò¸÷λ̩¶·Ñ§Ï°:victory:
2008-6-21 21:09:57 »Ø¸´
:victory: :victory:
2008-6-27 09:10:53 »Ø¸´
¸Ðл¥Ö÷·ÖÏí
2021-1-6 10:44:26 »Ø¸´
ÍÛ£¬ÁîÈ˾ªÑÈ£¬¸Ðл·ÖÏí
2022-11-1 17:22:03 »Ø¸´
1111111111111111111
2022-11-1 22:58:58 »Ø¸´
лл·ÖÏí°¡
2023-4-25 20:11:23 »Ø¸´
666666666666
2023-6-21 02:16:21 »Ø¸´
лл´óÀÐлл´óÀÐлл´óÀÐлл´óÀÐ
2023-6-23 19:15:02 »Ø¸´
666666666666
2023-6-23 19:15:35 »Ø¸´
666666666666
2023-6-23 19:16:15 »Ø¸´
111111111111111111111111111
2023-7-25 00:07:04 »Ø¸´
