ƽºâÒôƵÐźÅÏß,¸ü´ÖµÄµ¼Ìå²¢²»¼ûµÃÄÜ´øÀ´¸üºÃµÄЧ¹û
tongxiao
2008-5-31 20:04:16
ÎÒÃdz£³£ÔÚ±êÊéµ±Öп´µ½Ò»Ð©¹æ¸ñ,¶¯²»¶¯¾ÍÄóö0.5mm2³öÀ´×÷ΪÓÅÖʵġ± Ë«½ÊÏß´ú±í¡±.ÕâÑùÕæµÄºÃÂð? ÕâÑùÕæµÄºÃÂð? ÕâÑùÕæµÄºÃÂð?
¡¡¡¡ÆäʵÕâ¸öÎÊÌâ,С±àÒÔǰû×ÐϸÏë¹ý,¾õµÃ»¹ËãºÏÀí!¿ÉÊÇÓÖ¸úÎÒÒѾ­ÖªµÀµÄËõ¶Ì½Ê¾àÊDZ³µÀ¶ø³ÛµÄ!µ«ÊÇÔڰݶÁÃÀ¹úÁ½´óרҵÒôƵÁ¬½Ó·½°¸¹©»õÉÌÖ®Ò»PROCO SOUNDµÄÎÄÕ¡± CABLE ANATOMY I: UNDERSTANDING THEMICROPHONE CABLE.¡±Ö®ºó,¾õµÃ·Ç³£ÔÚÀíµ±ÖÐ×îΪ¹Ø¼ü,Ò²¾ÍÊǽñÌìҪ̸µÄÒ»¶ÎÊÇ:
¡¡¡¡What gauge and stranding should the two conductors be?
¡¡¡¡Á½¸öµ¼ÌåÓ¦¸ÃÊÇʲô³ß´çºÍ½ÊºÏ?
¡¡¡¡However, the sonic properties of the cable maybe compromised by using largeconductors.
¡¡¡¡È»¶ø£¬Í¨¹ýʹÓôóµ¼Ìå¿ÉÄÜË𺦵çÀµÄÉùÒôÌØÐÔ¡£
¡¡¡¡Why are the two conductors twisted together?
¡¡¡¡ÎªÊ²Ã´Á½¸ùµ¼ÌåŤÇúÔÚÒ»Æð?
¡¡¡¡As previously explained, theinterference-canceling common-mode rejection of the balanced line is based
¡¡¡¡on the premise that the unwanted external noiseis induced into both signal conductors equally. Minimizing
¡¡¡¡the distance between the two conductors bytwisting them together helps to equalize their reception of external
¡¡¡¡interference and improve the common-mode rejection ratio(CMRR) of the line.
¡¡¡¡The two conductors also form a sort of ¡°loopantenna¡± for stray magnetic fields. The farther apart the two
¡¡¡¡conductors are the larger the ¡°antenna¡±becomes, and the more interference it picks up from sources like
¡¡¡¡transformers, fluorescent lighting ballasts,SCR-chopped AC lines to stage lighting, etc. Minimizing the loop
¡¡¡¡area of the cable helps to reduce the unwanted humand buzz from this type of interference, which the cable¡¯s
¡¡¡¡shieldis almost totally ineffective against.
¡¡¡¡ÈçǰËùÊö£¬Æ½ºâÏß·ÊÇ͸¹ý¹²Ä£ÒÖÖÆ½«¸ÉÈÅÏû³ýÕâÊÇ»ùÓÚ½«²»ÐèÒªµÄÍⲿÔëÉù¡±¾ùÔȵء±¸ÐÓ¦µ½Á½¸öÐźŵ¼ÌåµÄǰÌᡣͨ¹ý½«Á½¸öµ¼ÌåÖ®¼äµÄŤÇú¼õСµ½×îСÏÞ¶È£¬ÓÐÖúÓÚʹËüÃǽÓÊÕµ½Íⲿ¸ÉÈÅ£¬²¢Ìá¸ßÏß·µÄ¹²Ä£ÒÖÖÆ±È(CMRR)¡£Á½¸ùµ¼ÌåÒ²ÐγÉÒ»ÖÖÓÃÓÚÔÓÉ¢´Å³¡µÄ¡°»·ÐÎÌìÏß¡±¡£Á½¸öµ¼ÌåÖ®¼äµÄ¾àÀëÔ½Ô¶£¬µ±¡°ÌìÏß¡±Ô½´ó£¬´Ó±äѹÆ÷£¬Ó«¹âµÆÕÕÃ÷ÕòÁ÷Æ÷£¬SCRÇжϵĽ»Á÷µçÏß·µ½Îę̀ÕÕÃ÷µÈÔ´Ëù»ñµÃµÄ¸ÉÈÅÔ½´ó¡£¡¡µçÀµĻ·Â·Ãæ»ý×îС»¯ÓÐÖúÓÚÒÔ¼õÉÙ²»±ØÒªµÄÎËÎËÉùºÍÎËÎËÉù´ÓÕâÖÖÀàÐ͵ĸÉÈÅ¡£
¡¡¡¡²»¹ý!¿Ú˵ÎÞÆ¾!ΪºÎÐèҪʹÓýÏϸµÄµ¼ÌåÄØ?±¾ÎĽ«ÕûÀíһЩ֤¾Ý,·ÖÏí¸ø¸÷λ!Ï£Íû¸÷λÔÚ½ñÌìÕâÆªÖ®ºó,Äܹ»´óµ¨!¶øÇÒÔÚÀíµÄ!¸ú¹ýÓÚ¿äÕÅ,²»ºÏÀí´ÖϸµÄ¡± Ë«½ÊÏß¡±Ëµ²»!½øÈëÕýÌâ!½ñÌìÎÒÃÇÒªÀ´½²:Ò»¸ö²»±ØÒª,Ò»¸ö³¤½Ê¾à,Ò»¸ö´óÌìÏßµÄÈý¸ö´óÎÊÌâ¡£
¡¡¡¡Ò»¡¢Ê×ÏÈÊÇ¡± Ò»¸ö²»±ØÒª¡±?
¡¡¡¡µ±ÎÒÃÇÐźÅÏß,´«ÊäµçÉùÄÜÁ¿ÔÚÏßÒª¸ºµ£¶àÉÙµçѹÓëµçÁ÷ÄØ?ÎÒÃÇÒªÖªµÀÕâÊǷdz£·Ç³£µÍµÄ!
¡¡¡¡»ùÓÚP=I*UU=I*R
¡¡¡¡¼´Ê¹µ±Äã¸øÒ»¸ö+16dBu½ÓÊÕ¶ËÊÇ600ohm
¡¡¡¡ÄǾÍÊÇ4.89v(rms) =8.15*10-3 A
¡¡¡¡»»ÑÔÖ®¾ÍÊÇ8.15mA
¡¡¡¡ÄÇÈç¹û½ÓÊÕ¶ËÊǽü´úµÄ¾§Ìå¹Ü»òÔË·ÅÊÇ3k»ò10kohm
¡¡¡¡ÄǾ͸üµÍÁË,ÊÇ1.63*10-3A 0.489*10-3 A
¡¡¡¡»»ÑÔÖ®,µçÁ÷Á¿µÄÐèÇó·Ç³£·Ç³£µÍ£¬½Ó×ÅÓÐÈË˵,ÄÇ»¹ÓлÃÏóµçÔ´ÄØ!ºÃµÄ!Çë¿´:
¡¡¡¡NeumannÎÞ±äѹÆ÷Âó¿Ë·çΪ2-4mA£¬
¡¡¡¡Schoeps CMC(¡°Colette¡±)ϵÁкÍԼɪ·òÑ·(Josephson)Âó¿Ë·çΪ5mA£¬
¡¡¡¡´ó²¿·ÖÊæ¶ûSHURE KSMϵÁÐÂó¿Ë·ç£¬CAD EquityksΪ8 mA£¬
¡¡¡¡EarthworksΪ10 mA)¡£
¡¡¡¡IEC±ê×¼¸ø³ö10 mA×÷Ϊÿ¸öÂó¿Ë·çµÄ×î´óÔÊÐíµçÁ÷¡£
ÆÀÂÛÁÐ±í£¨3£©
tongxiao Â¥Ö÷
ͼƬÀ´×ÔÍøÂçSWEETWATER¡¡¡¡
Òò´ËÖ»ÐèÒª¸ø10mA 52V¾ÍÄܽ綨ÕâÒ»¸öÏßÀµĴÖϸÓë¾øÔµÕâÐèÒª¶à´ÖÄØ?¡¡¡¡Ò»°ã³£¼ûµÄ 0.2mm2 ÃÀ±ê24AWGµ¼Ïß¾ÍÄÜͨ800mA¡¡¡¡
¼´Ê¹ÊÇ0.08mm2ÃÀ±ê28AWGµ¼ÏßÒ²ÄÜͨÉÏ300mA µÄµçÁ÷¡¡¡¡
µ±È»µ¼Ìå´ÖÊÇ¿ÉÒÔ½µµÍÖ±Á÷ѹ½µµÄ¡¡¡¡
ĪÍüÁË,ÎÒÃÇÔÚÊý×Öϵͳ֮ºó,¸ü¶àʱºòÊÇ´ÓÎę̀±ß½Ó¿ÚÏ乩Ӧ,¾àÀëÖ»ÓÐ20Ã××óÓÒ,±ÈÆðÔçÆÚµÄË¥¼õËãÊÇÉٺܶàµÄÁË!ËùÒÔ±ØÐëÒª´ÖµÄµÚÒ»¸öÃÕ˼,ÒѾ­´òÆÆ!!!¡¡¡¡
¶þ¡¢Ò»¸ö³¤½Ê¾à¡¡¡¡
Ò»¸ö·Ç³£ÏÖʵµÄÎÊÌâ,Ô½´ÖµÄÏßÀÂ,Òª°ÑËûÅ¡½ô¾Í´æÔÚ²»¿ÉÐÐÐÔ£¬´Óšë½íÑ¡ÔñµÄºñ¶ÈÓë´Öϸ¾ÍÄÜ×Ô¼ºÌå»áÁË!Òò´ËÔÚÎÒÃÇ2016Ä꿪ʼÉè¼ÆÓëÍÆ¹ã4.8mm»°Í²Ïßʱ,ÎÒÃǾͷdz£Çå³þÖªµÀ,²»½µµ¼Ìå,¾ÍÎÞ·¨Ëõ¶Ì½Ê¾à!¡¡¡¡ÎÒÃÇ¿ÉÒÔ¿´µ½Ï±í,µ±µ¼Ìå¾øÔµËõСÁË,Õû¸ö¶Ô½Ê¾ÍÄÜ×öµÃ¸üÃÜ¡£²»¹ýÓÐÒ»¸öÌØÀý¾ÍÊÇ1988,ÒòΪAES3±ê×¼¹æ¸ñÊÇĬÈϵÄ48 kHz²ÉÑùÂÊÏ£¬Ã¿ÃëÖÓÓÐ250¸öÒôƵ¿é£¬Ã¿Ãë3072¸öǧ±ÈÌØ£¬Ë«ÏàʱÖÓΪ6.144 MHz£¬Ñ¡ÓõľøÔµ²ÄÁÏÊÇFPE, Äܹ»Óнϵ͵Ľéµç³£ÊýÀ´ÒòÓ¦AES/EBUµÄ³¤¾àÀë´«Ê䣬¾øÔµ²ÄÁÏÊÇFPE ·¢ÅݵĹØÏµ,²»ºÃÔÙÅ¡µÃ¸üÃÜ,ÒÔÃâÔì³É¾øÔµ±äÐÎ,½ø¶øÓ°ÏìÌØÐÔ×迹£¬Ïß²ÄSR Æ·ºÅµ¼Ìå½ØÃæ»ýmm2µ¼Ìå¾øÔµÍê³ÉÖ±¾¶mm¶Ô½Ê½Ê¾àmm¡¡¡¡4.8mm(XLPE)30701000980.12561.220¡¡¡¡6.0mm(XLPE)30701017100.331.6527¡¡¡¡6.0mm DMX (XLPE)30701017580.2261.830¡¡¡¡6.0mm DMX (FPE)30701019880.21981.230¡¡¡¡RVVP ÎÞ0.5¡¡¡¡(Í­Ë¿½ÊºÏÖ±¾¶0.92)1.95Ò»°ã¶Ô½ÊºÜËÉ¡¡¡¡RVVYPÎÞ0.5(¹æ·¶¹æ¶¨Ö±¾¶0.8)1.832¡¡¡¡~2.032GB5023.7¡¡¡¡Î޹淶¶Ô½Ê
¡¡¡¡»ùÓÚGB5023.7
¡¡¡¡ÓÉÕâ¶ÎÎÄ×Ö,ÎÒÃÇ¿ÉÒÔ¿´µ½¡¡¡¡ÈôÊÇ0.5mm2µÄRVVYP,¡¡¡¡ÔòÄÚ²ã¾øÔµºñ¶È½«ÊÇ0.02*0.8+0.6=0.616¡¡¡¡
ÔÊÐíÏÂÏÞ85%=0.5236¡¡»òÊÇ-0.1mm µÃµ½0.516mm¡¡¡¡Òò´ËRVVYPÁ½±ß¼Ó×ܵõ½µÄÕûÌåÖ±¾¶ÊÇ1.832~2.032mm¡¡¡¡
RVVPÍê³É¾øÔµµÄÕûÌåÖ±¾¶ÊÇ1.95mm¡¡¡¡Òò´Ë0.5mm2µÄRVVPµÄ¶Ô½Ê½Ê¾à½«»á±»·Å´óµÃ·Ç³£µÄ¶à¡¡¡¡ÕâÊÇÓÉÓÚ:¡¡¡¡
1. ¶Ô½Ê¼ä¾àûÓб»¹æ·¶¡¡¡¡
2. ¸ßÃܶȶԽʵIJ»¿É²Ù×÷ÐÔ¡¡¡¡
3. Êг¡¶ÔÓÚ¼Û¸ñµÄÃô¸Ð¶È,»áÈýʾ౻·Å´ó¡¡¡¡
ÏßÀÂÐÐÒµµ±ÖÐÒ»¸öÏÔÖøµÄ³É±¾²î¾à¾ÍÔÚÓڶԽʵÄÄíÈëÂÊ,ƽÐÐÖ±·ÅÓë¸ß¶Ô½Ê¿ÉÒÔÔì³ÉÏß¶Ô²¿Î»10%µÄ³É±¾Âä²î£¬ÎÒÃÇ¿ÉÒÔ¿´µ½ÕâÕžøÔµÓë¶Ô½Ê¼ä¾à¶ÔÕÕ±í¡£¿´µÃ³öÀ´¾øÔµ´ÖϸÓë¶Ô½Ê¼ä¾à±ØÈ»³ÉÕýÏà¹Ø!ʹÓÃ×ã¹»µÄµ¼Ìå,¾ÍÄܽµµÍ¶Ô½Ê¼ä¾à,¿ÉÒÔ¸üƽ¾ù»¥»»Î»ÖÃÀ´µÄÎüÊÕÍâ½ç¸ÉÈÅ¡£ÔÚдÕâÆªÊ±,ÎÒÒ²³¢ÊÔ×ÅѰÕÒRVVP¶Ô½ÊµÄ¹æ·¶ÔÚ°Ù¶ÈÉϾͷ¢ÏÖÕâÑùÒ»¸öÎÊÌâ: ¡¡¾ÓÈ»ÓÐÈ˻شð:RS485µçÀÂÊôͨÐŲúÆ·£¬ÌØÐÔ×迹¡¢Ë¥¼õµÈ¶þ´Î²ÎÊý²ÅÊǵçÐÔÄܵÄÖØÒª²Î¿¼Ö¸±ê!²»ÄÜÓõ繤µçÀµĽʾàºâÁ¿µçÀÂµÄÆ·ÖÊ¡£¡¡¡¡Èý¡¢Ò»¸ö´óÌìÏß¡¡¡¡ÔÚÊÕÒô»ú»¹ÊÇÖ÷Á÷ÓéÀÖµÄÄê´ú,һ̨ÊÕÒô»ú»áÓÐÁ½¸ùÌìÏߣ¬Ò»¸ùÊDZÞ×´µÄFMÌìÏߣ¬Ò»¸öÊÇAMµÄ»·×´ÌìÏߣ¬µ±È»ÓÐЩûÓÐ,ÄÇÊÇÒòΪAMÓÃÌúÑõÌå×°ÔÚ»úÆ÷ÀïÃæ£¬¶øFMÔòÓöú»úÏßȨ³ä!¡¡¡¡ÎÒÃÇËùҪ˵µÄÒ»¸ö¶Ô½Ê+½Ï´Öµ¼ÌåµÄ×éºÏ£¬¾Í»áÔì³ÉÒ»¸öÌìÏß´óСµÄÂä²î!¿ÉÒÔ¿´µ½ÏÂͼ!Ï൱ÓÚËĸö´óС²»Í¬µÄÌìÏß,½ØÃæ»ýÂä²î£¬ÎÒÃÇ¿ÉÒÔ¿´µ½Ãæ»ýµÄ·Å´óÊǸüΪ¿Ö²ÀµÄn ÌìÏßÔöÒæ¸úÓÐÐ§Ãæ»ýµÄ¹ØÏµÊÇ¡¡¡¡
n G = ÌìÏßÔöÒæ¡¡¡¡n Ae =ÓÐÐ§Ãæ»ý¡¡¡¡n f =ÔØ²¨ÆµÂÊ¡¡¡¡
n c =¹âËÙ(»3¡ä108 m/s)¡¡¡¡n l =ÔØ²¨µÄ²¨³¤¡¡¡¡
ËùÒÔÔ½´óµÄÌìÏß»áÊÕµ½Ô½¶àµÄ¸ÉÈÅ¡­.Õâ²¢²»ÊÇÎÒÃÇËùÀÖ¼ûµÄ!½ÓמÍÓÐÅóÓÑ»á˵:ÎÒÃǶԽʲ»ÊǾÍÊÇÒªÎüÊÕ¸ÉÈÅÂð?ÊǵÄ,Äú´ð¶ÔÁËÒ»°ë!ÒªÎüÊÕ!µ«ÊÇÒª¾¡¿ÉÄܵĵÈÁ¿ÎüÊÕ!ÎüÊÕ? ÓëµÈÁ¿ÎüÊÕ?ÕâÓÐÉõôÎÊÌâÂð?ÎÊÌâÔÚÓÚʵÎñÉÏÎÒÃDz»ÖªµÀ¸ÉÈÅÔ´µÄλÖÃ,ʵ¼ÊÉÏ¿ÉÄܵ½´¦¶¼ÊÇ,¶øÇÒ±éÔÚ·¾¶ÉϷdz£¶à´¦£¬»òÊÇÀëÄãºÜ½ü¡£Òò´ËÒªµÈÁ¿ÎüÊÕ,¾ÍÒªÈÃÁ½ÈïºÜ¿¿½ü, ½Ê¾àºÜÃÜÕâÑù¸ÉÈŶÔÓÚÁ½ÈïµÄÃüÖÐÂʲŻᡱ¾¡¿ÉÄÜ¡±µÈÁ¿£¬ÎÒÃÇÀ´¿´¼¸¸öλÖã¬ÎªÁ˲»ÒªÌ«ÄÑÀí½â,ÎÒÃÇÏȸøÄú¿´Ò»¸öΨһµÈÁ¿µÄ¡£
¡¡¡¡Èç¹û¸ÉÈÅÂäÓڽʾཻԽ´¦,ÊÇ×îΪΪÀíÏëµÈÁ¿¸ÉÈÅ£¬»»µ½½»µü×î´óµÄλÖÃ,¿ÉÒÔ¿´µ½µ¼ÌåÔ½´Ö,¸ÉÈÅÔ½½ü,½ÓÊÕ¸ÉÈÅÔ½²»µÈÁ¿£¬ÉÏÃæ´ÖµÄ,Ò»¸ö·¾¶´ó°ëÔÚÈÈµã»ÆÉ«Çø,Ò»¸ö·¾¶È«ÔÚÂÌÉ«ÇøÓò,Òò´Ë·Ç³£ÈÝÒײ»µÈÁ¿£¬ÏÂÃæÏ¸µÄ,ÔòÏà¶Ô¶¼ÔÚ»ÆÉ«ÇøÓò,Ïà¶ÔÈÝÒ×µÈÁ¿¡£¡¡¡¡Èç¹ûÂäÔÚÐýת·¾¶ÉÏÄØ?Ö±¾¶´ÖµÄÏß¶Ô»¥»»Âý,Ïß¶Ôµ±ÖÐÒ»¸ö½ÏΪԶÀë¸ÉÈÅ,½ÓÊÕµ½µÄ¸ÉÈŽ«ÈÝÒײ»µÈÁ¿¡£Ö±¾¶Ï¸µÄÏß¶Ô»¥»»¿ì,Ïß¶Ôµ±ÖÐÒ»ÈïËä½ÏΪԶÀë¸ÉÈÅ,µ«ÄܽϽӽü,ÇÒѸËÙ»¥»»Î»ÖÃ,½ÓÊÕ¸ÉÈŵÈÁ¿»ú»á½Ï¸ß¡£¡¡¡¡Èç¹ûÔ¶Àë¸ÉÈÅÔ´ÄØ?ͬÑùµÄ,Ïß¶Ô»¥»»Î»ÖÃÊǹ̶¨µÄ,Ö±¾¶Ï¸µÄÏß¶Ô»¥»»¿ì,ѸËÙ»¥»»Î»ÖÃ,½ÓÊÕ¸ÉÈŵÈÁ¿·Ç³£ÈÝÒ×!Ö±¾¶´ÖµÄÏß¶ÔÒÀ¾É»¥»»Âý,Ïß¶Ôµ±ÖÐÒ»¸ö½ÏΪԶÀë¸ÉÈÅ,½ÓÊÕµ½µÄ¸ÉÈŽ«ÈÝÒײ»µÈÁ¿£¬ÈÃÎÒÃÇÔÙÔ¶Ò»µã°É¡¡¡¡Í¬ÑùµÄ,Ïß¶Ô»¥»»Î»ÖÃÊǹ̶¨µÄ,Ö±¾¶Ï¸µÄÏß¶Ô»¥»»¿ì,ѸËÙ»¥»»Î»ÖÃ,½ÓÊÕ¸ÉÈŵÈÁ¿·Ç³£ÈÝÒ×!Ö±¾¶´ÖµÄÏß¶ÔÒÀ¾É»¥»»Âý,Ïß¶Ôµ±ÖÐÒ»¸ö½ÏΪԶÀë¸ÉÈÅ,½ÓÊÕµ½µÄ¸ÉÈŽ«ÈÝÒײ»µÈÁ¿ÎÞÓ¹ÖÃÒɵÄË«½ÊÏß×å¾ÍÊÇҪΪ²î¶¯·Å´ó·þÎñ½ÏСµÄµ¼Ìå,½ôÃܶԽʺó¿ÉÒÔÆµ·±,½ôÃܵĽӽü¸ÉÈÅÔ´,͸¹ý»¥»»Î»ÖÃÀ´´ïµ½½ÏºÃµÄÎüÊÕÄÜÁ¦!
2008-6-1 15:42:48 »Ø¸´
лл¥Ö÷µÄ·¢²¼£¬ÎÒ µãÔÞÊÕ²ØÁË£¡~
2010-6-3 23:29:27 »Ø¸´
:victory::victory:
2010-6-3 23:38:03 »Ø¸´
