ÒôƵ±à¼­½Ì³Ì£¨cool edit£©¡ª»ìÏì²ÎÊý£¡
Cooledit Õâ¿îÒôƵ±à¼­Èí¼þÕæÊÇÅ££¬¹Ö²»µÃÒ»¿îÈí¼þ¾ÍÄÜÑø»îÒ»´óȺÈË¡£ÏÖÔÚÓÐÒ»¿î¿ªÔ´µÄÒôƵ´¦ÀíÈí¼þAudacity£¬ÎÒÒ²ÊÇÀïÃæ¹¦ÄÜ¿ª·¢µÄÒ»Ô±£¬Õâ¸ö¿îÈí¼þÒ²ÓкܶàÁÁµã£¬´ó¼Ò¿ÉÒÔ¹Ø×¢£¬¸üÖØÒªµÄÊÇÓÐsource code´ó¼Ò¿ÉÒÔѧϰһÏ¡£
Reverb Hall 1 Ä£Äâ´óÒôÀÖÌüµÄ»ìÏì
²ÎÊýÊýÖµ·¶Î§ËµÃ÷
Rev.Time2.8s0.3-30.0s»ìÏìʱ¼ä
High Ratio0.80.1-1.0¸ßƵ˥¼õÂÊ
Diffusion60-10»ìÏìÀ©É¢
Ini.Dly40.0ms0.1-200.0msÖ±´ïÉùÓëÔçÆÚ·´ÉäÉùÖ®¼äµÄÑÓ³Ùʱ¼ä
LPF7.0kHz1KHz-16KHz,THRUµÍͨÂ˲¨Æ÷µÄ½ØÖ¹ÆµÂÊ
HPFTHRUTHRU,32Hz-8KHz¸ßͨÂ˲¨Æ÷µÄ½ØÖ¹ÆµÂÊ
Reverb Hall 2 Ä£Äâ´óÒôÀÖÌüµÄ»ìÏìµÄ±äÖÖ
²ÎÊýÊýÖµ·¶Î§ËµÃ÷
Rev.Time3.2s0.3-30.0s»ìÏìʱ¼ä
High Ratio0.70.1-1.0¸ßƵ˥¼õÂÊ
Diffusion80-10»ìÏìÀ©É¢
Ini.Dly38ms0.1-200.0msÖ±´ïÉùÓëÔçÆÚ·´ÉäÉùÖ®¼äµÄÑÓ³Ùʱ¼ä
LPF6.3kHz1.0kHz-16.0kHz,THRUµÍͨÂ˲¨Æ÷µÄ½ØÖ¹ÆµÂÊ
HPFTHRUTHRU,32Hz-8kHz¸ßͨÂ˲¨Æ÷µÄ½ØÖ¹ÆµÂÊ
Reverb Room 1 Ä£ÄâË®Äàǽ±Ú·¿¼ä²úÉú´óÁ¿»ØÉùµÄ»ìÏì *Ϊ¹ÄÒôÉ«Ôö¼ÓÏÖ³¡¸Ð
²ÎÊýÊýÖµ·¶Î§ËµÃ÷
Rev.Time1.4s0.3-30s»ìÏìʱ¼ä
Diffusion70-10»ìÏìÀ©É¢
Ini.Dly5.0ms0.1-200msÖ±´ïÉùÓëÔçÆÚ·´ÉäÉùÖ®¼äµÄÑÓ³Ùʱ¼ä
LPFTHRU1KHz-16KHz,THRUµÍͨÂ˲¨Æ÷µÄ½ØÖ¹ÆµÂÊ
HPFTHRUTHRU,32Hz-8kHZ¸ßͨÂ˲¨Æ÷µÄ½ØÖ¹ÆµÂÊ
Reverb Room 2 Room1µÄ±äÖÖ
²ÎÊýÊýÖµ·¶Î§ËµÃ÷
Rev.Time1.8s0.3-30s»ìÏìʱ¼ä
High Ratio0.60.1-1.0¸ßƵ˥¼õÂÊ
Ini.Dly17ms0.1-200msÖ±´ïÉùÓëÔçÆÚ·´ÉäÉùÖ®¼äµÄÑÓ³Ùʱ¼ä
LPF9kHz1KHz-16KHz,THRUµÍͨÂ˲¨Æ÷µÄ½ØÖ¹ÆµÂÊ
HPF80HzTHRU,32Hz-8kHZ¸ßͨÂ˲¨Æ÷µÄ½ØÖ¹ÆµÂÊ
Reverb STAGE ÀàËÆ³ÌÐò1£¬µ«¸üÃ÷ÁÁ£¬¸üÓÐÏÖ³¡¸Ð
²ÎÊýÊýÖµ·¶Î§ËµÃ÷
Rev.Time3.4s0.3-30s»ìÏìʱ¼ä
High Ratio0.90.1-1.0¸ßƵ˥¼õÂÊ
Ini.Dly45ms0.1-200msÖ±´ïÉùÓëÔçÆÚ·´ÉäÉùÖ®¼äµÄÑÓ³Ùʱ¼ä
HPF70HzTHRU,32Hz-8kHZ¸ßͨÂ˲¨Æ÷µÄ½ØÖ¹ÆµÂÊ
Reverb Plate Ä£Äâ¸ÖÅÌÀà»ìÏìϵͳ£¬ÊÊÓ¦ÐÔºÜ¹ã£¬ÌØ±ðÊÇÈËÉù£¬¹ÄºÍ´ò»÷ÀÖ
²ÎÊýÊýÖµ·¶Î§ËµÃ÷
Rev.Time2.4s0.3-30s»ìÏìʱ¼ä
Ini.Dly16ms0.1-200msÖ±´ïÉùÓëÔçÆÚ·´ÉäÉùÖ®¼äµÄÑÓ³Ùʱ¼ä
LPF8kHz1KHz-16KHz,THRUµÍͨÂ˲¨Æ÷µÄ½ØÖ¹ÆµÂÊ
Rev Ambience 1 Ä£ÄâÀÖÆ÷ÖÜΧµÄ»ìÏ죬ÓÃÓÚÈËÉù£¬ºÏ³ªºÍ´ò»÷ÀÖ
²ÎÊýÊýÖµ·¶Î§ËµÃ÷
Rev.Time1.2s0.3-30s»ìÏìʱ¼ä
High Ratio10.1-1.0¸ßƵ˥¼õÂÊ
Ini.Dly19ms0.1-200msÖ±´ïÉùÓëÔçÆÚ·´ÉäÉùÖ®¼äµÄÑÓ³Ùʱ¼ä
HPF45HzTHRU,32Hz-8kHZ¸ßͨÂ˲¨Æ÷µÄ½ØÖ¹ÆµÂÊ
Rev Ambience 2 ³ÌÐò7µÄ±äÖÖ
²ÎÊýÊýÖµ·¶Î§ËµÃ÷
Rev.Time0.8s0.3-30s»ìÏìʱ¼ä
Ini.Dly0.1ms0.1-200msÖ±´ïÉùÓëÔçÆÚ·´ÉäÉùÖ®¼äµÄÑÓ³Ùʱ¼ä
HPF56HzTHRU,32Hz-8kHZ¸ßͨÂ˲¨Æ÷µÄ½ØÖ¹ÆµÂÊ
Rev Live Room 1 Ä£ÄâÏÖ³¡·¿¼äµÄ»ìÏì,»ìÏì·´Éä±ÈRecerm RoomÇ¿
²ÎÊýÊýÖµ·¶Î§ËµÃ÷
LPF7kHz1KHz-16KHz,THRUµÍͨÂ˲¨Æ÷µÄ½ØÖ¹ÆµÂÊ
Rev Live Room 2 ³ÌÐò9µÄ±äÖÖ
²ÎÊýÊýÖµ·¶Î§ËµÃ÷
Rev.Time2.2s0.3-30.0s»ìÏìʱ¼ä
High Ratio0.50.1-1.0¸ßƵ˥¼õÂÊ
Ini.Dly12.0ms0.1-200.0msÖ±´ïÉùÓëÔçÆÚ·´ÉäÉùÖ®¼äµÄÑÓ³Ùʱ¼ä
LPF4.0kHz1.0kHz-16.0kHz.THRUµÍͨÂ˲¨Æ÷µÄ½ØÖ¹ÆµÂÊ
Reverb Vocal ÓÃÓÚÈËÉù,ºÏ³ªµÄ»ìÏì
²ÎÊýÊýÖµ·¶Î§ËµÃ÷
Rev.Time1.9s0.3-30.0s»ìÏìʱ¼ä
Ini.Dly16ms0.1-200.0msÖ±´ïÉùÓëÔçÆÚ·´ÉäÉùÖ®¼äµÄÑÓ³Ùʱ¼ä
LPF12kHz1.0kHz-16.0kHz.THRUµÍͨÂ˲¨Æ÷µÄ½ØÖ¹ÆµÂÊ
HPF100HzTHRU,32Hz-8kHz¸ßͨÂ˲¨Æ÷µÄ½ØÖ¹ÆµÂÊ
Chorus Reverb Á¢ÌåÉùºÏ³ªºó½Ó»ìÏì
²ÎÊýÊýÖµ·¶Î§ËµÃ÷
Mod.Freq0.8Hz0.1-20Hzµ÷ÖÆËÙ¶È
Mod.Depth40%0-100%µ÷ÖÆÉî¶È
Mod.Dly1.3ms0-24msÔÚ¿ªÊ¼µ÷ÖÆÇ°µÄÑÓ³Ùʱ¼ä
High Ratio0.70.1-1¸ßƵ˥¼õÂÊ
Ini.Dly30ms0.1-139msÖ±´ïÉùÓëÔçÆÚ·´ÉäÉùÖ®¼äµÄÑÓ³Ùʱ¼ä
LPF6.3kHz1kHz--16kHz, THRUµÍͨÂ˲¨Æ÷µÄ½ØÖ¹ÆµÂÊ
HPFTHRUTHRU,32Hz--8kHz¸ßͨÂ˲¨Æ÷µÄ½ØÖ¹ÆµÂÊ
Rev.Depth24%0-100%»ìÏìÉî¶È
Flange Reverb Á¢ÌåÉùÆ®ºöºó½Ó»ìÏì
²ÎÊýÊýÖµ·¶Î§ËµÃ÷
Mod.Freq1.4Hz0.1-20Hzµ÷ÖÆËÙ¶È
Mod.Depth22%0-100%µ÷ÖÆÉî¶È
FB Gain 45%-99-- 99%´¦ÀíºóµÄÐźŷµ»ØÆ®ºöµÄÔöÒæ
Mod.Dly13ms0-15.5msÔÚ¿ªÊ¼µ÷ÖÆÇ°µÄÑÓ³Ùʱ¼ä
Ini.Dly26ms0.1-200msÖ±´ïÉùÓëÔçÆÚ·´ÉäÉùÖ®¼äµÄÑÓ³Ùʱ¼ä
LPF4.5kHz1kHz--16kHz, THRUµÍͨÂ˲¨Æ÷µÄ½ØÖ¹ÆµÂÊ
HPF45HzTHRU,32Hz--8kHz¸ßͨÂ˲¨Æ÷µÄ½ØÖ¹ÆµÂÊ
Rev.Depth30%0-100%»ìÏìÉî¶È
Delay L-C-R ×ó£¬ÖУ¬ÓÒÉùµÀ¶ÀÁ¢µÄÑÓ³Ù
²ÎÊýÊýÖµ·¶Î§ËµÃ÷
Dly L250ms0.1-661ms×óÉùµÀÑÓ³Ùʱ¼ä
Dly R500ms0.1-661msÓÒÉùµÀÑÓ³Ùʱ¼ä
Dly C125ms0.1-661msÖÐÑëÉùµÀÑÓ³Ùʱ¼ä
Level C700-100ÖÐÑëÉùµÀÑÓ³ÙÒôÁ¿
FB.Dly500ms0.1-661msÔÚ¿ªÊ¼·´À¡Ç°µÄÑÓ³Ùʱ¼ä
FB.Gain 40%-99-- 99%´¦ÀíºóµÄÐźŷµ»ØÑÓ³ÙµÄÔöÒæ
High Ratio0.80.1-1·´À¡µÄµ÷Ƶ˥¼õÂÊ
Monodly-Chorus µ¥ÉùµÀÑÓ³Ùºó½ÓÁ¢ÌåÉùºÏ³ª
²ÎÊýÊýÖµ·¶Î§ËµÃ÷
Delay400ms0.1-618msÑÓ³Ùʱ¼ä
FB.Gain 32%-99-- 99%´¦ÀíºóµÄÐźŷµ»ØÑÓ³ÙµÄÔöÒæ
Mod.Freq0.4Hz0.1-20HzºÏ³ªµ÷ÖÆËÙ¶È
Mod.Depth10%0-100%ºÏ³ªµ÷ÖÆÉî¶È
Mod.Dly0.1Ms0-24msºÏ³ª¿ªÊ¼µ÷ÖÆÇ°µÄÑÓ³Ùʱ¼ä
Chrous-Dly L C R Á¢ÌåÉùºÏ³ªºó½Ó×ó£¬ÖУ¬ÓÒÉùµÀ¶ÀÁ¢µÄÑÓ³Ù
²ÎÊýÊýÖµ·¶Î§ËµÃ÷
Mod.Depth24%0-100%µ÷ÖÆÉî¶È
Mod.Dly5.9ms0-24msÔÚ¿ªÊ¼µ÷ÖÆÇ°µÄÑÓ³Ùʱ¼ä
Dly L26.4ms0.1-618ms×óÉùµÀÑÓ³Ùʱ¼ä
Dly R33.2ms0.1-618msÓÒÉùµÀÑÓ³Ùʱ¼ä
Dly C13.1ms0.1-618msÖÐÑëÉùµÀÑÓ³Ùʱ¼ä
Level C600-100ÖÐÑëÉùµÀÑÓ³ÙÒôÁ¿
FB.Dly40.5ms0.1-618msÔÚ¿ªÊ¼·´À¡Ç°µÄÑÓ³Ùʱ¼ä
FB.Gain-48%-99-- 99%´¦ÀíºóµÄÐźŷµ»ØÑÓ³ÙµÄÔöÒæ
High Ratio0.10.1-1·´À¡µÄµ÷Ƶ˥¼õÂÊ
Delay-Chrous Á½¼¶ÑÓ³Ùºó½ÓÁ¢ÌåÉùºÏ³ª
²ÎÊýÊýÖµ·¶Î§ËµÃ÷
Dly 1250ms0.1-618ms1 ÑÓ³Ùʱ¼ä
Dly 2500ms0.1-618ms2 ÑÓ³Ùʱ¼ä
FB.Dly500ms0.1-618msÔÚ¿ªÊ¼·´À¡Ç°µÄÑÓ³Ùʱ¼ä
FB.Gain 33%-99-- 99%´¦ÀíºóµÄÐźŷµ»ØÑÓ³ÙµÄÔöÒæ
High Ratio0.70.1-1·´À¡µÄµ÷Ƶ˥¼õÂÊ
Mod.Freq1.2Hz0.1-20Hzµ÷ÖÆËÙ¶È
Mod.Depth25%0-100%µ÷ÖÆÉî¶È
Mod.Dly10ms0-24msÔÚ¿ªÊ¼µ÷ÖÆÇ°µÄÑÓ³Ùʱ¼ä
Karaoke Echo 1 ¿¨À­OKЧ¹û
²ÎÊýÊýÖµ·¶Î§ËµÃ÷
Dly L220ms0.1-332ms×óÉùµÀÑÓ³Ùʱ¼ä
FB.Gain L 40%-99-- 99%×óÉùµÀ´¦ÀíºóµÄÐźŷµ»ØµÄÔöÒæ
Dly R223ms0.1-332msÓÒÉùµÀÑÓ³Ùʱ¼ä
FB.Gain R 40%-99-- 99%ÓÒÉùµÀ´¦ÀíºóµÄÐźŷµ»ØµÄÔöÒæ
High Ratio0.40.1-1·´À¡µÄµ÷Ƶ˥¼õÂÊ
Karaoke Echo 2 ¿¨À­OKЧ¹û
²ÎÊýÊýÖµ·¶Î§ËµÃ÷
FB.Gain L 44%-99-- 99%×óÉùµÀ´¦ÀíºóµÄÐźŷµ»ØµÄÔöÒæ
Dly R180ms0.1-332msÓÒÉùµÀÑÓ³Ùʱ¼ä
FB.Gain R-55%-99-- 99%ÓÒÉùµÀ´¦ÀíºóµÄÐźŷµ»ØµÄÔöÒæ
High Ratio0.20.1-1·´À¡µÄµ÷Ƶ˥¼õÂÊ
ST.Pitch Change Á½²¿·ÖµÄÁ¢ÌåÉùÒô¸ß±ä»¯Æ÷£¬ÓжÀÁ¢µÄÉùÏñ²ÎÊý
²ÎÊýÊýÖµ·¶Î§ËµÃ÷
Pitch0-12-- 12Òô¸ß´Öµ÷
Fine 1 10-50-- 50±ä»¯Æ÷1µÄÒô¸ß΢µ÷
Fine 2-10-50-- 50±ä»¯Æ÷2µÄÒô¸ß΢µ÷
Out.Lvl 1 100-100-- 100±ä»¯Æ÷1µÄÊä³öÒôÁ¿
Out.Lvl 2 100-100-- 100±ä»¯Æ÷2µÄÊä³öÒôÁ¿
Pan 1L100L100--R100±ä»¯Æ÷1µÄÉùÏñ
Pan 2R100L100--R100±ä»¯Æ÷2µÄÉùÏñ
FB.Gain 1 28%-99-- 99%´¦ÀíºóµÄÐźŷµ»Ø±ä»¯Æ÷1µÄÔöÒæ
FB.Gain 2-28%-99-- 99%´¦ÀíºóµÄÐźŷµ»Ø±ä»¯Æ÷2µÄÔöÒæ
FB.Dly25ms0.1-223msÔÚ¿ªÊ¼·´À¡Ç°µÄÑÓ³Ùʱ¼ä
"MALE
VOCAL"ÄÐÐÔÉùÒô,Ç¿µ÷ÖеÍÒôG 3db 1db 2db
F280Hz1.8KHz5KHz
Q3oct3/4octÆÂ×´
"FEMALE
VOCAL"Å®ÐÔÉùÒô,Ç¿µ÷¸ßÖÐÒôG-1db 1db 2db
F220Hz2KHz7KHz
QÆÂ×´3oct3oct
CHROUSÈËÉùºÏ³ªG 1db 2db 5db
F280Hz1.4KHz5.6KHz
Q3oct3/2octÆÂ×´
"MALE
ANNOUCER"ÄÐÐÔ½²»°,Ôö¼ÓÇåÎú¶ÈG-3db 2db-4db
F100Hz4.5KHz7KHz
Q1oct3octÆÂ×´
"FEMALE
ANNOUCER"Å®ÐÔ½²»°,Ç¿µ÷ÖÐÒôG-3db 3db-1db
F200Hz2KHz8KHz
QÆÂ×´1octÆÂ×´
"TELEPHONE
VOICE"Ä£Äâµç»°Éù,¼õÉٸߵÍÒôG-15db 12db-10db
F500Hz1.1KHz9KHz
QÆÂ×´2oct3/4oct
"NOTCH
4KHz"ÔÚ4Hz´¦Â˲¨ÒÔ¼õÉÙ·´À¡Ð¥½ÐG0db0db-10db
F80Hz2KHz4KHz
QÆÂ×´3/2oct1/6oct
"HUM
REDUCE
50Hz"ÔÚ50Hz´¦Â˲¨ÒÔ¼õÉÙÎËÎËÉùG-9db-10db0db
F50Hz160Hz10KHz
Q1/6oct1/6octÆÂ×´
"HUM
REDUCE
60Hz"ÔÚ60Hz´¦Â˲¨ÒÔ¼õÉÙÎËÎËÉùG-9db-10db0db
F60Hz180Hz10KHz
Q1/6oct1/6octÆÂ×´
"W.NOISE
REDUCE"Ϊ´Å´ø·ÅÒô¼õÉÙ¸ßÆµÔëÒôG0db0db-13db
F80Hz2KHz16KHz
QÆÂ×´3/2octÆÂ×´
»ìÒôµÄÐ¡ÃØ·½
¹ØÓÚcompressorµÄʹÓÃ:
»ìÒôʱ³£»áÓõ½compressor£¬ËüµÄºÃ´¦³ýÁËÈÃÕûÌåÒôÁ¿µÃÒÔ¿ØÖÆÔÚÒ»¶¨·¶Î§£¬Ò²¿ÉÒÔʹÒôÐÔÌýÆðÀ´½ÏΪÓÐÁ¦Á¿¡£µ«ÊÇʹÓò»ºÃÒ²ÈÝÒ×Ôì³ÉÒÔÏµļ¸µãÎÊÌâ¡£
1)Èô½«mixºÃµÄ¶«Î÷ÔÙ×÷È«ÃæÐÔµÄcompress£¬»áʹ×î´óÉùÓë×îСÉùÖ®¼ä²»Í¬Ö®²î¾à¼õÉÙÐí¶à£¬Õû¸öÉùÒôµÄ±íÏÖ¿ÉÄÜ»áÒòΪ̫ƽ¾ù·´¶øÊ§È¥ÁËÔ­À´µÄ¶¯Ì¬¡£
2)Èç¹û½«compressorµÄ×î¸ßpeak levelÉèÔÚ´óÔ¼ÓëδѹËõǰµÄ×î¸ßpeaklevelÏà֮ͬ´¦£¬ÔòÆä½á¹ûƽ¾ùlevel±Ø¶¨»áÌá¸ß¡£Ö÷¹Û¶øÑÔ£¬ÊÇ¿ÉʹÒôÀÖ¸üÓÐÄÜÁ¿¡£È»¶ø£¬Ò»¸öÉùÒô»á¸Ðµ½½Ï´óÉùͨ³£ÊÇÓнÏСÉùµÄÉùÒôÓëÆä×÷¶Ô±È£¬Òò´Ëµ±compressÌ«´óʱ£¬»áÓÐʹÒôÀÖµÄÉùÒô¸üСÉùµÄΣÏÕ¡£
3)µ±Ñ¹Ëõmixʱ£¬¿ÉÒÔ½«compressorµÄattacktimeͨ³£»áÈÃËü³¤Ò»µã£¬´ÙʹһЩ˲¼äµÄÉùÒôÈç´ò»÷ÀÖÆ÷Ôö¼ÓÆäpunch£¬¸üÓÐÁ¦¡£ÕâÕæµÄÒªÓöú¶äÈ¥Ìý£¬È¥Åжϡ£µ±È»ÔõÑù²ÅÊÇ×î¼ÑµÄÉ趨»áÒòΪÿ¸öÒôÀÖµÄ×´¿ö¶øÓÐËù²»Í¬¡£ÁíÍâҪעÒâµÄÊÇ£¬²¢·ÇÿÖÖ³§ÅÆÐͺŵÄcompressor½Ô¿ÉÓÃÔÚÕûÌåµÄ»ìÒôÉÏ¡£
¹ØÓÚexciterµÄʹÓÃ:
»ìÒôʱҲ³£»áÓõ½exciter£¬ËüµÄÔ­ÀíÔÚÓÚÒÔԭʼ֮ѶºÅΪ»ù´¡£¬ºÏ³É³öharmonicsÀ´²¹×½mixµ±Öв»×ãµÄ²¿·Ý¡£Í¨³£ÕâÑùµÄ½á¹û»á±äµÃÒôÐԱȽÏÁÁÀö¡£ËüµÄºÃ´¦³ýÁËÇ¿µ÷ij¶ÎÏà¶ÔÓÚdynamicsignal֮ƵÆ×£¬Ê¹Ë²¼äÖ®ÉùÒôÓиü¸ßÖ®·Ö±æÂÊ£¬Ò²ÔÚÓÚʹÉùÒôÔڹ㲥ϵͳ(Èç¹ã²¥¡¢µçÊÓµÈ)Öиüstandout³öÀ´¡£È»¶øÈçcompressorÒ»°ã£¬exciterÒ²³£±»ÈËÀÄÓᣱØÐë×¢ÒâµÄÊÇ£¬Èç¹ûûÓоö¶ÔµÄ±ØÒª£¬ÔÚ»ìÒôʱ²»ÒªËæÒâʹÓÃexciter¡£
¹ØÓÚ¼àÌýϵͳµÄʹÓÃ:
ÁíÍâÔÚfinalmixÍê³Éǰ£¬Ó¦¸ÃÓò»Í¬µÄ¼àÌýϵͳ×÷²âÊÔ£¬ÕâÆäÖаüÀ¨Æû³µÒôÏì¼°¼ÒÓÃÒôÏìµÈ¡£ÓÐÐí¶àÈËϲ»¶ÓôóÐ͵ļàÌýÀ®°ÈÀ´×ö»ìÒô¡£ÄÇÑùµÄÒôÁ¿¼°ÆøÊƵÄÈ·ºÜÃÔÈË£¬µ«È´²»ÊÇÒ»¸öºÜºÃµÄ·½·¨£¬ÖÁÉÙ¾ö²»ÄÜÊÇΨһµÄÑ¡Ôñ¡£ÒòΪ´óÐ͵ļàÌýÀ®°ÈºÜÈÝÒ×Ôì³ÉÎóµ¼£¬¶øÄÇÑùµÄµÍƵÔÚÒ»°ãÈËµÄÆû³µÒôÏì¼°¼ÒÓÃÒôÏìÈ´ÍêÈ«ÎÞЧ¡£ËùÒÔ×îºÃÓò»Í¬µÄ¼àÌýϵͳ×÷²âÊÔ¡£ÁíÍâ±ÜÃâÔڸ߷ֱ´Ö®×´¿öÏÂ×÷»ìÒô£¬ÄÇ»áÓ°ÏìÄã¶ÔÓÚÉùÒôÖ®Åжϣ¬ÒòΪÈ˶ú¶ÔÓڸ߷ֱ´µÄÒôÁ¿Ê±µÄ¸ßµÍƵ·´Ó¦²¢²»Í¬ÓÚµÍÒôÁ¿Ê±µÄ·´Ó¦¡£ÊÂʵÉÏÒ»°ãÈ˵ÄÌýÒôÀÖϰ¹ßÒ²ÍùÍù¶¼ÊÇÖеÈÒôÁ¿ÒÔÏ¡£
¹ØÓÚDE-ESSERµÄʹÓÃ:
Compressor¶ÔÓÚÊäÈëѶºÅµÄÇ¿¶ÈÊÇ²ÉÆ½¾ùʽ·´Ó¦£¬ÇÒ²»ÂÛËüÃÇÊÇµÍÆµµÄÉùÒô»òÊÇ¸ßÆµµÄÀÖÆ÷¡£ÕâÊÇÒ»°ãµÄcompressor£¬µ«ÓÐʱºòÎÒÃÇÐèÒª¶ÔÓÚÌØ¶¨ÆµÂÊ,×÷¸üÇ¿´óµÄѹËõ¡£¡°De-esser¡±±ãÊÇÔÚ´ËÖÖÐèÇóϲúÉú¡£ËüÖ÷ÒªÊÇÓÃÀ´È¥³ý»ò¼õСÈËÉùѶºÅÖеĴ½³ÝÔÓÒô
´½³ÝÒôͨ³£·¢ÉúÓÚ2KÖÁ5K¼ä£¬Èç¹ûÎÒÃÇÕÒµ½´ËƵÂÊ£¬½«ËüÌá¸ß10DB£¬ÔÙÓÃcompressor»á½«´ËƵÂÊѹËõ £¬Ê¹´ËƵÂʵÄDBÊýÔ¶µÍÓÚÆäÓàÆµÂÊ10DB¡£Õâ¾ÍÊÇ¡°De-esser¡±ÓÃÀ´¼õÉÙ´½³ÝÔÓÒôµÄ·½·¨¡£
¶øÈçºÎÕÒ´ËÆµÂÊ? ÔÚÕâÎÒÌṩһ¸öС¼¼ÇÉ¡£Äã¿ÉÏȽ«¸ßƵËùÐ裨һ°ãΪ2-5kHz£©²¨¶ÎµÄDBÊýÔö¼Ó10DB£¬ÔÙ½«¸ßƵ²¨¶ÎµÄÐýÅ¥ÖÐÑëÆµÂÊ£¬ÓÃÀ´¾ö¶¨EQ¹ý³ÌÖб»EQ²¨¶ÎµÄÖÐÑëÆµÂÊÔں䦣¬´Ó×îµÍµÄƵÂÊÂýÂýתµ½×î¸ßµÄƵÂÊ£¨·´Ö®Òà¿É£©£¬Ôڴ˵±ÖÐÈôÓöµ½ÎÒÃÇÒªÕ񵀮µÂʵãʱ£¬´½³ÝÒô»áÌØ±ð´óÉù£¬ÔòÄ㽫֪µÀ´ËƵÂʾÍÊÇÄãÒªÕҵġ£
×îºóÈç¹û¾õµÃ»ìÒôµÄ½á¹û²»ÀíÏ룬¿ÉÒÀÏÂÁз½·¨¼ì²é:
1.»Øµ½×îԭʼµÄƽºâ״̬£¬È¥µôEQ¼°Ð§¹ûÆ÷£¬´ÓÍ·¿ªÊ¼£¬²¢Óõ¥ÉùµÀÈ·¶¨´Ë״̬ÊÇ·ñÓÐÏàλµÖÏûÖ®×´¿ö£¬²¢×¢ÒâÉùÏòµÄλÖÃÊÇ·ñÕýÈ·¡£
2.ÊÇ·ñÔÚͬһʱ¼ä³öÀ´Ì«¶à¶«Î÷£¬ÊÇ·ñÕâЩ¶«Î÷½ÔÊDZØÐèµÄ£¿Èç¹û¶¼Òª£¬ÊÇ·ñÓÐЩ¶«Î÷µÄ¿ÉÒÔÒôÁ¿Ð¡Ò»µã?
3.ÔÚÖÐÆµ²¿·ÝÊÇ·ñ½«mixŪµÃÓÐЩÔÓÂÒ£¬»òÊÇºÍµÍÆµ²¿·Ý»ìÔÚÒ»Æð£¿Èç¹ûÊÇ£¬ÓÃEQ½«ÕâЩÉùÒôÐÞ±¡£¬ÕâÑùµÄ½á¹ûÈÃËüÃÇÔÚµ¥¶ÀÌýʱ»òÐí»áÓÐµãÆæ¹Ö£¬µ«ÍùÍùÔÚmixµ±ÖÐʱ»áÏԵúÜÊʵ±¡£ÀýÈç: Äã¿É³¢ÊÔÓÃEQ ÂǵôһЩµÍƵ£¬¿ÉʹmixÖÐÆµ²¿·Ý¸üÇåÎö£¬¸É¾»Ð©¡£
4.Èç¹ûÄãÈÔ¾õµÃÓÐÎÊÌâ£¬ÖØÐµ÷Õû¹ÄÓ뱴˹µÄƽºâµã£¬ÔÙ½«ÈËÉù¼ÓÉÏÈ¥£¬È»ºó¼ÓÉÏÖ÷ÒªÀÖÆ÷¿´¿´ÊÇ·ñÓиÄÉÆ¡£
5.Ч¹ûÆ÷Òª½÷É÷ʹÓ᣺ܶàʱºò£¬ÈËÃÇÍùÍùʹÓÃÌ«¶àЧ¹ûÆ÷£¬»ò»ìÏì¼ÓÌ«¶à£¬ÒÔÖÁÓÚѶºÅ¼õËð»òÉùÒôÄ£ºý¡£
6.ÓÐʱÔÚfinal mix¼Óexciter¶ÔÓÚÉùÒôÇåÎú¶È¼°Ï¸Äå¶ÈÖ®¸ÄÉÆ£¬ÓÐÏ൱´óÖ®¹¦Ð§¡£
7.Èç¹ûÒÔÉϵķ½·¨¶¼ÊÔ¹ýÖ®ºó»¹ÊÇÎÞ·¨½â¾öÎÊÌ⣬ÄdzýÁËÔÙÊÔ¼¸´ÎÖ®Í⣬ֻºÃÖØÂ¼ÁË£¡
8.ËùÒÔ»ìÒô²»ÊÇÍòÁ鵤,¼Òô¼°±àÇúµÄºÃ»µ²ÅÊÇ»ìÒôµÄ¸ù±¾Ìõ¼þ!
ÆÀÂÛÁÐ±í£¨1£©
´óÁ¦Ö§³Ö ! ÒôƵ±à¼­½Ì³Ì£¨cool edit£©¡ª»ìÏì²ÎÊý£¡
2008-5-14 22:55:38 »Ø¸´
