查看: 36946|回复: 1
[转帖] BAE 1073 话放/话筒放大器
3万
音频应用初级会员
Rank: 6Rank: 6
发表于 2008-5-6 16:31:32 | 显示全部楼层 |阅读模式
BAE 1073 话放/话筒放大器
这是最正宗的1073,比任何1073都要完美,甚至比目前Neve公司生产的某些设备,你可以得到原版1073的一切,具有完全相同的Carnhill变压器、原版模块、Elma开关以及内部的导线,所有一切包括模块接口、连接器、印刷电路板、手工焊接以及全部电路设计完全等同于原版。
高频:固定频率 12kHz下+/-16dB可调
低频:可选频率35Hz, 60Hz, 110Hz & 220Hz 下+/-16dB可调
中频:可选频率0.36kHz, 0.7kHz, 1.6kHz, 3.2kHz, 4.8kHz ,7.2kHz下+/-18dB可调
高通滤波器: 可选频率50Hz, 80Hz, 160Hz ,300Hz下每倍频的斜率18分贝
The BAE 1073 is as authentic as you can get to the original, featuring the same St Ives (Carnhill) transformers as the vintage modules, Elma switches and Canford wire.
The BAE 1073 looks identical to the original vintage module and will happily retrofit in vintage Neve 80 Series consoles because the entire product is engineered in exactly the same way as the originals: the same chassis construction, connectors, printed circuit board layouts, hand-wired looms, and circuitry.
High Frequency: +/-16dB fixed frequency shelving at 12kHz
Low Frequency: +/-16dB shelving with selectable frequencies of 35Hz, 60Hz, 110Hz & 220Hz
Mid Range: +/-18dB peaking, fixed 'Q' with, selectable centre frequencies of 0.36kHz, 0.7kHz, 1.6kHz, 3.2kHz, 4.8kHz & 7.2kHz
High Pass Filter: 18dB per octave slope, switchable between 50Hz, 80Hz, 160Hz & 300Hz
242
发表于 2008-5-6 16:41:08 | 显示全部楼层
欣赏  BAE 1073 话放/话筒放大器
GMT+8, 2025-6-8 13:42 , Processed in 0.030643 second(s), 8 queries , Redis On.
