Chris Hein Ensemble Strings KONTAKT
×ªÔØ
Chris Hein - Ensemble StringsÊÇÒ»¸öÁîÈËÄÑÒÔÖÃÐŵÄϸ½Ú£¬Áé»îÇÒ¸»ÓÐÒôÀָеÄ×Ö·û´®¼¯ºÏ¿â¡£Õâ¸öͼÊé¹ÝµÄÒ»¸öÌØµãÊÇ£¬ºÏ×àÉùÒôûÓб»¼Ç¼ÔÚÒ»¸ö×éÖС£Ïà·´£¬¾«ÐÄÌôÑ¡ºÍÆ¥ÅäµÄÀÖÆ÷Òѱ»·Ö¿ªÂ¼Öƺͱ༭¡£Òò´Ë£¬Ã¿¸öÀÖÆ÷¶¼ÊÇÍêÃÀµ÷ºÍµÄ£¬Ìṩ׿ԽµÄʱ»ú£¬²¢ÇÒÈÔÈ»£¨»òÒò´Ë£©ÎÞ·ìµØÊÊÓ¦ÀÖÍŵÄÉùÒôÌØÕ÷¡£Äã²»»á·¢ÏÖÒ»¸ö´íÎóµÄÒô·û£¬»ÙÁËÕû¸öÀÖÍÅ¡£
¾­¹ý¾«ÐļǼ£¬¾­¹ý¾«Ðı༭²¢ºÏ²¢³ÉΪʮ¸öÓÐÓõÄKontakt PlayerÀÖÆ÷£¬ÆäÖаüº¬Ò»¸ö¶¨ÖƵÄÓû§½çÃæºÍÈ«ÃæµÄ½Å±¾£¬Chris Hein - Ensemble StringsÌṩ×î¸ßµÄÒôÖÊ£¬´óÁ¿µÄ·¢ÒôºÍÁîÈËÄÑÒÔÖÃÐŵıÆÕæÐ§¹û¡£
Ô­ÎÄ
Chris Hein ¨C Ensemble Strings is an incredibly detailed, flexible and musical string-ensemble-library. A special characteristic of this library is the fact that the ensemble-sounds have not been recorded in a group. Instead, the carefully selected and matched instruments have been recorded separately and edited. Consequently, each instrument is perfectly in tune, offers excellence in timing and still (or thereby) seamlessly fits the ensemble¡¯s sonic character. You won¡¯t find a wrong note that ruins the whole ensemble.
Recorded with greatest care, precisely edited and combined into ten useful Kontakt Player instruments with a custom made user interface and comprehensive scripting, Chris Hein ¨C Ensemble Strings offers highest sound-quality, lots of articulations and incredibly realistic results.
Main Features:
- 10 Instruments
- 2 Ensemble sizes „Full¡° & „Small¡°
- 30 GB Content
- 53.000 Samples
- 32 Articulations
- Up To 8 Dynamic Layers
- 4 Dynamic Modes
- Dynamic Expression Sustains
- Special „designed¡° articulations
- Note-Head Designer
- Hot-Keys
- Intelligent Legato & Portamento
- Glide-Mode To play realistic runs
- 10 built in DSP-Effects
- 2 independent Convolution Reverbs
- 63 high class impulse responses
- Ensemble Maker
- Micro-Tuner
- Adjustable Fader Settings in the UI
- Intelligent LFO-Vibrato including EQ
- Customizable Auto-Vibrato
- Key-Vibrato
Chris Hein Ensemble Strings KONTAKT | 35.2 Gb
ÏÂÔØµØÖ·£º
Óοͣ¬Èç¹ûÄúÒª²é¿´±¾ÌûÒþ²ØÄÚÈÝÇë»Ø¸´
ÆÀÂÛÁÐ±í£¨7£©
2008-1-1 16:46:22 »Ø¸´
ºÃÌý£¡×£ÐÂÄê¿ìÀÖ£¡
2008-1-2 18:01:44 »Ø¸´
ÔÙÐÀÉÍ£¡:P :victory:
2008-1-26 15:32:14 »Ø¸´
ÐÀÉÍ.......................
2008-1-31 13:12:25 »Ø¸´
лл·ÖÏí£¬Ö§³ÖÖ§³Ö!
2022-7-27 09:37:27 »Ø¸´
111111111111111111111111111
2022-12-2 07:18:04 »Ø¸´
Chris Hein ¨C Ensemble Strings ¨¦ uma biblioteca de conjuntos de cordas incrivelmente detalhada, flex¨ªvel e musical. Uma caracter¨ªstica especial desta biblioteca ¨¦ o fato de que os sons do conjunto não foram gravados em grupo.
os instrumentos foram gravados separadamente e editados Consequentemente, cada instrumento est¨¢ perfeitamente afinado, oferece excel¨ºncia no tempo e ainda (ou assim) se ajusta perfeitamente ao car¨¢ter sonoro do conjunto.
com o maior cuidado, editados com precisão e combinados em dez instrumentos ¨²teis do Kontakt Player com uma interface de usu¨¢rio personalizada e scripts abrangentes, Chris Hein ¨C Ensemble Strings oferece
a mais alta qualidade de som, muitas articulações e resultados incrivelmente realistas.
Tamanhos de conjunto „Full¡° e „Small¡°
- Conte¨²do de 30 GB
- 53.000 amostras
- 32 articulações
- At¨¦ 8 camadas dinâmicas
- 4 modos dinâmicos
- Sustentação de expressão dinâmica
- Articulações especiais "projetadas"
- Designer de cabeça de nota
- Teclas de atalho
- Inteligente Legato & Portamento
- Glide-Mode Para reproduzir execuções realistas
- 10 efeitos DSP integrados
- 2 reverbs de convolução independentes
- 63 respostas de impulso de alta classe
- Ensemble Maker
- Micro-Tuner
- Configurações de Fader ajust¨¢veis na UI
- LFO-Vibrato inteligente incluindo EQ
- Auto-Vibrato personaliz¨¢vel
- Key-Vibrato
2024-8-1 06:48:35 »Ø¸´
