查看: 14082|回复: 1
[Sawstudio] Sony Sound Forge Pro 11.0 Build 299 Multilingual For Win
3万
音频应用初级会员
Rank: 6Rank: 6
发表于 2007-12-20 08:38:21 | 显示全部楼层 |阅读模式
SOUND FORGE Pro 11
Advanced audio waveform editor
STATE OF THE ART SOUND DESIGN & EDITING
SOUND FORGE Pro is the application of choice for a generation of creative and prolific artists, producers, and editors. Record audio quickly on a rock-solid platform, address sophisticated audio processing tasks with surgical precision, and render top-notch master files with ease. New features include one-touch recording, metering for the new critical standards, more repair and restoration tools, and exclusive round-trip interoperability with SpectraLayers Pro. Taken together, these enhancements make this edition of SOUND FORGE Pro the deepest and most advanced audio editing platform available.
Recording
Record multichannel audio in ultra high quality. The redesigned recording dialog make for even more efficient workflows.
Sound Design
Select from thousands of included samples and create unique sounds for your productions.
Post Production
Professional mastering and processing tools help you edit audio and video files with ease.
GOLD STANDARD
SOUND FORGE assists you from importing media to finishing your masterpiece. Create Red Book compatible DAO CD masterings and prepare your project for replication.
ART AND CRAFT
The professional mastering tools by iZotope enable you to create both technical and creative masterings within SOUND FORGE. This makes it a true one stop solution for recording and editing audio.
PRISTINE SOUND QUALITY
Record up to 32 simultaneous channels of 64-bit/192kHz audio for the ultimate in fidelity. In the mastering suite, select from among twelve included iZotope DSP modules and access superb mastering chain processing tools for sparkle and punch, excellent repair and restoration plug-ins, and precise format conversion tools for the best in sonic integrity preservation.
ONE-TOUCH RECORDING
SOUND FORGE Pro 11 has a brand new recording interface with features that make even the most demanding work a snap. From running punch-and-roll sessions to managing multiple takes, we have you covered.
PRECISE AUDIO EDITING
The editing experience that you expect from SOUND FORGE Pro just got even better. New in SOUND FORGE Pro 11: convert regions to events, lock event markers, region markers, and envelope points to events, and automatically ripple successive events forward in time while editing.
EFFECTS PROCESSING
SOUND FORGE Pro 11 includes a full complement of native signal and effects processing plug-ins, including our own popular Noise Reduction 2 audio restoration suite. Partner contributions from iZotope and zplane make the latest edition of SOUND FORGE Pro an even more incredible one-stop solution for delivering master quality audio.
SEAMLESS INTEROPERABILITY WITH SPECTRALAYERS PRO
Transfer audio data between SOUND FORGE Pro 11 and SpectraLayers Pro and experience the thrill of working freely across the world's premiere waveform and spectral editing applications.
RED BOOK AUDIO CDS
SOUND FORGE Pro 11 includes fully integrated DAO CD mastering to generate Red Book compliant masters for duplication. Additionally, perform PQ code editing, add CD text and metadata, and prepare high resolution audio tracks with iZotope resampling technology.
AUDIO-FOR-VIDEO
SOUND FORGE Pro 11 software supports multiple video formats including AVI, WMV, MPEG-1 and MPEG-2. Precisely synchronize audio and video frame by frame. SOUND FORGE Pro 11 includes MPEG-2 templates for writing HDV-compliant files at both 720p and 1080i resolutions, and AVI templates using the CineForm CFHD codec for 720p and 1080i intermediate renders.
Features:
AUDIO RECORDING
CRYSTAL CLEAR SOUND QUALITY
State of the art metering tools and the completely overhauled recording workflow make SOUND FORGE the center of your studio.
Redesigned recording workflow
SOUND FORGE Pro 11 features a completely redesigned recording interface that keeps you anchored in the workspace at all times while you shape and monitor incoming audio, arm and record takes, review your work, and prepare for the next pass.
Waveform overview bar
SOUND FORGE Pro 11 features a new Waveform Overview Bar that makes file navigation easier than ever. More than just a simple strip that displays your exact location, this new feature also serves as an excellent locator and auditioning tool.
Double-click in the bar to center your cursor in a time range defined by the waveform display, or click-drag to audition looping segments with customizable pre-roll and loop duration times.
PLANNING AHEAD
Select between threshold, MTC or timestamp recording via the recording options. Configure the recording process the way you want.
Threshold recording
Set a threshold via the options menu and recording will start automatically.  This is an easy way to record yourself without the need of remote controlling the control room while you're in the booth.
MIDI timecode
Working with artists can be challenging. The recording process in SOUND FORGE won't get in the way of that. Just select a timecode compatible input – SOUND FORGE takes care of the rest.
Timestamp recording
You want to record the pristine sound of church bells without being anywhere near the tower? Just time your recording in SOUND FORGE and listen from a comfortable distance, while SOUND FORGE starts recording just in time.
Input bus effects
Create a vibe for your talent by sweetening your source signal with plug-in effects.
Input bus effects
AUDIO EDITING
PROFESSIONAL EDITING
SOUND FORGE Pro 11 is the editor's choice for shaping audio in an infinite variety of ways. Our latest edition comes prepared to deliver broadcast ready, master quality finished products right out of the gate, using its own popular built-in signal and effects processing tools as well as premier contributions from our staple of high-end DSP developers.
Event mode improvements
Convert regions to events, lock event markers, region markers, and envelope points to events, and automatically ripple successive events forward in time while editing.
Seamlessly sync with SpectraLayers Pro
Transfer audio data between SOUND FORGE Pro and SpectraLayers Pro and experience the thrill of working freely across the world's premiere waveform and spectral editing applications. Open a large file in SOUND FORGE Pro and transfer selections of any size to SpectraLayers Pro for fast, precise editing, then bring the result back to the source file in SOUND FORGE Pro - automatically and with sample-accurate precision.
Send multiple files to SpectraLayers Pro for deep layering, remixing, and sound design work, and then return your finished products back to SOUND FORGE Pro 11 for further editing, processing, and finalization.
WORKFLOW FEATURES
Multichannel file editing and processing
Open, edit, and save multichannel audio data from XDCAM™, field recorders, and surround mixes, with sample accurate precision.
Multitask background rendering
Work on one file while SOUND FORGE Pro 11 software processes another in the background.
ACID loop creation tools
Create your own loops for use in ACID software. Use grid lines to visually divide audio selections into equal parts based on time signature. Refine your loops in the Loop Tuner, and then embed basic ACIDization metadata to get a head start on making your own perfectly ACIDized loops and samples.
MASTERING
SOUND FORGE Pro 11 is a one-stop solution for producers who need to create and deliver master audio content for any purpose. iZotope is a premier developer of digital audio signal and effects processing plug-ins. SOUND FORGE Pro 11 includes iZotope's Mastering and Repair Suite, a collection of essential high-end processing plug-ins that you can use right away to achieve perfect masters.
In addition, SOUND FORGE Pro 11 includes two other important post-processing tools that specialize in file format integrity preservation: iZotope 64-bit SRC™ (sample rate conversion) and iZotope MBIT+ dither (bit-depth conversion).
THE FINAL TOUCH
Equalizer
The Mastering EQ is a six-band parametric equalizer featuring four bell filters, a high shelving filter, and a low shelving filter. It incorporates digital precision and analog modeling, as well as real-time spectrum analysis for essential visual feedback while adjusting parameters.
Reverb
The Mastering Reverb was designed to add depth to dull mixes and smooth over acoustic imperfections. It features two processing algorithms, plate and room, and a real-time spectrum analyzer.
Multiband Compressor
The Multiband Compressor is an essential tool for adding warmth and fullness to mixes. It allows independent control over the dynamics of four frequency bands, and adjustable crossover points that let you fine tune the range of each band.
Mastering Limiter
The Mastering Limiter lets you create louder and fuller masters by limiting the dynamic range and boosting the perceived overall level of the mix. IRC™ (Intelligent Release Control) lets you dial in aggressive yet transparent limiting.
Stereo Imager
Precisely adjust the stereo width and focus of your master using multiband stereo imaging. Work with up to four frequency bands for independent control over stereo width by frequency. Visualize the stereo image with a powerful phase/channel meter display that highlights imaging, phase and potential cancellation problems.
Harmonic Exciter
The Harmonic Exciter is a powerful tool for adding analog character to your masters. With a selection of Harmonic Exciter modes, you can easily add tube or tape saturation, accentuate even harmonics, and add punch and sparkle to your project.
TOOLS & AUDIO EFFECTS
POSTPRODUCTION. POSTMODERN.
Native DSP
SOUND FORGE Pro 11 includes a comprehensive selection of native signal and effects processes including normalization, Wave Hammer compression and limiting, graphic and multiband dynamics, noise gating, graphic/paragraphic/parametric equalization, envelope generation, phasing, flanging and chorus, reverb, tremolo and vibrato, distortion, pitch modifiers, the amazing Acoustic Mirror convolution reverb, the Gapper/Snipper effects processor, and more.
New plug-in chain interface
SOUND FORGE Pro 11 features a new floating Plug-in Chain window that provides a significantly refined workspace for conducting non-destructive signal and effects processing operations. Dock the chain and enjoy direct access to every component of the processing environment. Easily manage plug-in order, presets, interface controls, envelope automation and bypass controls, and retain unique plug-in configurations for every open data window.
Read more: http://www.magix.com/us/sound-forge-pro/features/
Follow us: Google+ | Facebook
MINIMUM SYSTEM REQUIREMENTS
Processor: 1 GHz
RAM: 512 MB
Graphics card: onboard
Sound card: onboard
Hard drive space: 500 MB for program installation
Internet connection: Program requires one-time registration.
FILE FORMATS
Import
AA3*, AAC, AIF, ASF, AU, AVI*, CDA, DIG, DLS, DV, DVF, FLAC, FRG, GIF, GIG, IVC, M2A, M2P, M2T, M4A, M4B, MMV, OGG, MOV, MSV, MP1, MP3, MP4, MPEG, MPEG-1, MPEG-2video, Sony MXF*, PCA, QT, RAW, SD, SFA, SF*, SND, TIF, VOX, W64*, WAV*, WMA*, WMV
*Supported multichannel format
Export
AA3*, AC3*, AIF, ATRAC*, AU, AVI*, DIG, DLS, FLAC, FRG, GIG, IVC, M1A, M1P, M2A, M2P, M2T, MMV, MOV, MSV, MP1, MP2, MP3, MP4, MPA, MPEG, MPEG-1, MPEG-2video, Sony MXF*, OGG, PCA, RAW, SF2, VOX, W64*, WAV*, WMA*, WMV
下载地址:
游客,如果您要查看本帖隐藏内容请回复
6818
发表于 2007-12-20 12:19:07 | 显示全部楼层
Sony Sound Forge Pro 11.0 Build 299 Multilingual For Win  :victory:
GMT+8, 2025-7-18 19:50 , Processed in 0.036625 second(s), 8 queries , Redis On.
