ÑïÉùÆ÷ÐÔÄÜÊǵçѧ¡¢Á¦Ñ§¡¢Éùѧ¡¢´ÅѧµÈÎïÀí²ÎÊý¹²Í¬×÷ÓõĽá¹û£¬ÓɹÄÖ½¡¢µ¯²¨¡¢ÒôȦ¡¢´Å·µÈ¹Ø¼üÁ㲿¼þµÄÐÔÄܹ²Í¬È·¶¨£¬ÆäÖÐһЩ²ÎÊýÏà»¥ÖÆÔ¼Ï໥ӰÏ죬Òò¶ø±ØÐë×ۺϿ¼ÂǺÍÉè¼Æ¡£
1¡¢Ö÷Òª²ÎÊý×ÛºÏÉè¼ÆºÍ·ÖÎö
ÑïÉùÆ÷³£Óûúµç²ÎÊýÒÔ¼°¼ÆË㹫ʽ¡¢²âÁ¿·½·¨¼òÊöÈçÏ£º
Ö±Á÷µç×èRe
ÓÉÒôȦ¾ö¶¨£¬¿ÉÖ±½ÓÓÃÖ±Á÷µçÇŲâÁ¿¡£
¹²ÕñƵÂÊFo
ÓÉÑïÉùÆ÷µÄµÈЧÕñ¶¯ÖÊÁ¿MmsºÍµÈЧ˳ÐÔCms¾ö¶¨£¬¼û¹«Ê½(5)£¬ Fo¿ÉÖ±½ÓÓÃFo²âÊÔÒDzâÁ¿»òͨ¹ý²âÁ¿×迹ÇúÏß»ñµÃ¡£
¹²ÕñƵÂÊ´¦µÄ×î´ó×迹Zo
ÓÉÒôȦ¡¢´Å·¡¢Õñ¶¯ÏµÍ³(¹ÄÖ½¡¢µ¯²¨)¹²Í¬¾ö¶¨£¬¿ÉÓÃÌæ´ú·¨²âÁ¿»òͨ¹ý²âÁ¿×迹ÇúÏß»ñµÃ¡£
Zo = Re+[(BL)2/(Rms+Rmr)] (10)
»úеÁ¦×èRms
ÓɹÄÖ½¡¢µ¯²¨µÄÄÚ²¿×èÄἰʹÓýºË®µÄÌØÐÔ¾ö¶¨£¬¿ÉÓɲâÁ¿³ö»úеƷÖÊÒòÊýQmsºóͨ¹ýÏÂÁй«Ê½¼ÆË㣺
Rms =(1/Qms)*SQR(Mms/Cms) (11)
ÕâÀïSQR( )±íʾ¶ÔÀ¨ºÅ( )ÖеÄÊýÖµ¿ªÆ½·½¸ù£¬ÏÂͬ¡£
·øÉäÁ¦×èRmr
Óɿھ¶¡¢ÆµÂʾö¶¨£¬µÍƵʱ¿ÉºöÂÔ¡£
Rmr = 0.022*(f/Sd)2 (12)
µÈЧ·øÉäÃæ»ýSd
Ö»Óë¿Ú¾¶(µÈЧ°ë¾¶a)Óйء£
Sd =¦Ð* a2 (13)
»úµçñîºÏÒò×ÓBL
ÓÉ´Å·BgÖµºÍÒôȦÏßÓÐЧ³¤¶ÈL¾ö¶¨£¬Ò²¿Éͨ¹ý²âÁ¿µçÆøÆ·ÖÊÒòÊýQesºóÓÃÏÂÁй«Ê½¼ÆËã:
(BL)2 =(Re/Qes)*SQR(Mms/Cms) (14)
µÈЧÕñ¶¯ÖÊÁ¿Mms
ÓÉÒôȦÖÊÁ¿Mm1¡¢¹ÄÖ½µÈЧÖÊÁ¿Mm2¡¢·øÉäÖÊÁ¿Mmr¹²Í¬¾ö¶¨£¬ Mms¿ÉÓɸ½¼ÓÖÊÁ¿·¨²âÁ¿»ñµÃ¡£
Mms=Mm1+Mm2+2Mmr
·øÉäÖÊÁ¿Mmr
Mmr =2.67*¦Ño* a3 (16)
ÆäÖЦÑo=1.21kg/m3Ϊ¿ÕÆøÃܶȣ¬ aΪÑïÉùÆ÷µÈЧ°ë¾¶¡£
µÈЧ˳ÐÔCms
ÊÇÖ¸ÑïÉùÆ÷Õñ¶¯ÏµÍ³µÄÖ§³Å²¿¼þµÄÈá˳¶È.ÆäÖµÔ½´ó,ÑïÉùÆ÷µÄÕû¸öÕñ¶¯ÏµÍ³Ô½Èí.µ¥Î»:ºÁÃ×/Å£¶Ù(mm/N).
ÓɹÄֽ˳ÐÔCm1¡¢µ¯²¨Ë³ÐÔCm2¹²Í¬¾ö¶¨£¬´Ë˳ÐÔ¼´ÊÇÎÒÃÇËù³ÆµÄ±äλ£¬Ö»Êǵ¥Î»Ðè»»ËãΪ¹ú¼Êµ¥Î»ÖÆ£ºm/N£¬¶ø±äλ¿ÉÒÔÓñäλÒÇÖ±½Ó²âÁ¿¡£Cms¿ÉÓɸ½¼ÓÈÝ»ý·¨²âÁ¿»ñµÃ¡£
Cms=(Cm1*Cm2)/(Cm1+Cm2) (17)
µÈЧÈÝ»ýVas
Ö»ÓëµÈЧ˳ÐÔ¡¢µÈЧ·øÉäÃæ»ýÓйء£
Vas =¦Ño*c2*Sd2*Cms (18)
´Ë´¦cΪ¿ÕÆøÖеÄÉùËÙ£¬c=344m/s
»úеƷÖÊÒòÊýQms
ÓÉÕñ¶¯ÏµÍ³µÄµÈЧÕñ¶¯ÖÊÁ¿Mms¡¢µÈЧ˳ÐÔCms¡¢»úеÁ¦×èRms¹²Í¬¾ö¶¨£¬Qms¿ÉÓÉ×迹ÇúÏߵIJâÁ¿»ñµÃ¡£
Qms =(1/Rms)*SQR(Mms/Cms)=(Fo/¦¤f)*(Zo/Re) (19)
f Ϊ×迹ÇúÏßÉÏ×迹µÈÓÚSQR(Zo*Re)Ëù¶ÔÓ¦µÄÁ½¸öƵÂʵIJîÖµ¡£
µçÆøÆ·ÖÊÒòÊýQes
ÓÉÕñ¶¯ÏµÍ³µÄµÈЧÕñ¶¯ÖÊÁ¿Mms¡¢µÈЧ˳ÐÔCms¡¢»úµçñîºÏÒò×ÓBL¹²Í¬¾ö¶¨£¬ÓÉ×迹ÇúÏߵIJâÁ¿»ñµÃ¡£
Qes =[Re/(BL)2]*SQR(Mms/Cms)=(Fo/¦¤f)*SQR(Zo*Re)/(Zo-Re) (20)
×ÜÆ·ÖÊÒòÊýQts
ÓÉ»úеƷÖÊÒòÊýQmsºÍµçÆøÆ·ÖÊÒòÊýQes¹²Í¬¾ö¶¨¡£
Qts =(Qms*Qes)/(Qms+Qes)=(Fo/¦¤f)*SQR(Re/Zo) (21)
²Î¿¼µçÉùת»»Ð§ÂʦÇo
ÓÉ»úµçñîºÏÒò×ÓBL¡¢µÈЧ·øÉäÃæ»ýSd¡¢µÈЧÕñ¶¯ÖÊÁ¿Mms¹²Í¬¾ö¶¨¡£
¦Ço =(¦Ño/2¦Ðc)*(BL*Sd/Mms)2/Re (22)
²Î¿¼ÁéÃô¶È¼¶SPLo
Óë²Î¿¼µçÉùת»»Ð§ÂʦÇoÖ±½ÓÏà¹Ø¡£
SPLo = 112+10lg¦Ço (23)
²Î¿¼Õñ·ù¦Î
Óë²Î¿¼µçÉùת»»Ð§ÂʦÇo¡¢µç¹¦ÂÊPe¡¢µÈЧ°ë¾¶a¡¢ÆµÂÊfÓйء£
¦Î = 0.481*SQR(Pe*¦Ço)/(a*f)2
ÒÔÉÏÕâЩ²ÎÊýÏÖÔÚ¾ù¿ÉÓÃÑïÉùÆ÷¼ÆËã»ú²âÊÔϵͳ½øÐвâÁ¿ºÍ¼ÆË㣬³£ÓõIJâÊÔϵͳÓÐLMS¡¢CLIO¡¢MLSSA¡¢DAAS¡¢SYSID¡¢LAUD¡¢IMPµÈ¡£ÁíÍ⣬Ҳ¿ÉÀûÓÃһЩ¼ÆËã»úÄ£ÄâÈí¼þ½øÐÐÑïÉùÆ÷²ÎÊýµÄ»ù±¾Éè¼Æ£¬ÈçLEAP¡¢CALSOD¡¢Speaker Easy¡¢DLC Design¡¢AudioCad¡¢SOUNDEASYµÈ¡£
ÑïÉùÆ÷µÄ¹¦ÂÊ¡¢Ê§ÕæÖ¸±êÎÞ·¨Ö±½ÓÓù«Ê½½øÐж¨Á¿¼ÆË㣬ֻÄÜ×÷Щ¶¨ÐÔ·ÖÎöºÍ̽ÌÖ¡£
ÑïÉùÆ÷µÄ¶î¶¨ÕýÏÒ¹¦ÂÊÒÔ¼°´¿Òô¼ìÌý¹¦ÂÊ£¬»ù±¾ÉÏÓÉµÍÆµ×î´óÕñ·ù¦Îo¾ö¶¨¡£Ò»°ãµÍƵ×î´óÕñ·ùÊÇÔÚ¹²ÕñƵÂÊFo´¦¡£ÑïÉùÆ÷µÄµÍƵ×î´óÕñ·ùÖ÷Ҫȡ¾öÓÚ´Å·½á¹¹ºÍÒôȦ¾í¿í£¬µ±È»ÓëÕñ¶¯ÏµÍ³Ò²ÓкܴóµÄ¹ØÏµ¡£ÑïÉùÆ÷Õý³£¹¤×÷ʱ£¬ÒôȦ²»ÄÜÌø³ö´Å¼ä϶£¬¼´ÓЦÎo¡ÜXmax£¬·ñÔò»á²úÉúºÜ´óµÄ·ÇÏßÐÔÊ§Õæ(±íÏÖΪÕñ·ùÒì³£Òô)¡¢ÉõÖÁ»áµ¼ÖÂÒôȦËð»µ(¿¨ËÀ»òÉÕ»Ù)¡£Fo´¦×î´óÕñ·ù¦Îo¿ÉÓÉÏÂÁй«Ê½¼ÆË㣺
¦Îo = 1.414*BL*I*Cms*Qts (25)
ʽÖÐIΪÀ¡¸øÑïÉùÆ÷µÄµçÁ÷£¬I=SQR(Pe/Re)¡£¿É¼û£¬¼ÙʹÑïÉùÆ÷µÄ»ù±¾»úµç²ÎÊý(BL¡¢Cms¡¢Qts)È·¶¨£¬ÆäµçÁ÷I¾ö¶¨µÄ¹¦ÂÊPe=I2*Re¾ÍÊܵ½µÍƵ×î´óÕñ·ù¦Îo¡ÜXmaxµÄÏÞÖÆ¡£·´Ö®£¬¼ÙʹÑïÉùÆ÷µÄ¹¦ÂʱØÐè´ïµ½Ò»¶¨Öµ£¬ÔòÑïÉùÆ÷µÄµÈЧ˳ÐԾͲ»ÄÜÌ«´ó£¬Ò༴Fo²»ÄÜ̫С¡£µ±ÓÐ(BL)2/Re>>Rmsʱ£¬¹«Ê½(25)Óֿɼò»¯ÈçÏ£º
¦Îo = 0.225*V/(BL*Fo) (26)
ʽÖÐVΪÀ¡¸øÑïÉùÆ÷µÄµçѹ£¬V=SQR(Pe*Re)¡£´Ëʽ¸üÖ±¹ÛµØÏÔʾ³ö×î´óÕñ·ù¦ÎoÓëµçѹV¡¢»úµçñîºÏÒò×ÓBL¡¢¹²ÕñƵÂÊFoµÄ¹ØÏµ¡£Ò»°ãËù³ÆµÄ×ÜÆ·ÖÊÒòÊýQts¶ÔµÍƵÕñ·ùµÄ¿ØÖÆÄÜÁ¦¾ÍÓɹ«Ê½(25)¡¢(26)ÌåÏֺͷ´Ó³£¬ÆäÖÐBLÖµµÄ×÷ÓøüÃ÷ÏÔ¡£
ÑïÉùÆ÷µÄµÍƵÉù¹¦ÂÊPaͬÑùÒ²Êܵ½ÏÞÖÆ£º
Pa= Pe*¦Ço=4.33*¦Î2*a 4*f 4 (27)
¿É¼û£¬Éù¹¦ÂÊPa¼ÈÓëµç¹¦ÂÊPeÓйء¢ÓÖÓëµçÉùת»»Ð§ÂʦÇoÖ±½ÓÏà¹Ø£¬Êµ¼ÊÉÏ×îÖÕÓëÑïÉùÆ÷µÄÕñ·ù¡¢¿Ú¾¶¡¢ÆµÂÊÓйء£ÎªÁË´ïµ½Ò»¶¨µÄÉù¹¦ÂÊPa£¬ÔÚÆµÂÊÒ»ÑùµÄÌõ¼þÏ£¬¿Ú¾¶Ô½Ð¡¡¢ÔòÆäÕñ·ùÔ½´ó£¬¶øÕñ·ùÒ»°ã¶¼Êܵ½ÏÞÖÆ£¬ËùÒÔ¿Ú¾¶¾Í²»ÄÜ̫С¡£Ò༴£¬Ð¡¿Ú¾¶ÑïÉùÆ÷²»¿ÉÄܲúÉúºÜ´óµÄÉù¹¦ÂÊ£¬ÒòΪС¿Ú¾¶ÑïÉùÆ÷Ò»°ã¶¼Êܵ½½á¹¹ÏÞÖÆ£¬ÆäÕñ·ù½ÏС£¬Ð§Âʽϵͣ¬¶øÒôȦ²»»áºÜ´ó¡¢ËùÓÃÏß¾¶ÓÐÏÞ¡¢ËùÄܳÐÊܵĵ繦ÂÊÒ²ÓÐÏÞ¡£
ÑïÉùÆ÷¶î¶¨ÔëÉù¹¦Âʺͳ¤ÆÚ×î´ó¹¦ÂÊ£¬¼ÈÓëµÍƵ×î´óÕñ·ùÓйأ¬ÓÖÓëÒôȦµÄÏß¾¶¡¢²ÄÁϺÍϵͳµÄÉ¢ÈÈÌõ¼þ¡¢Ê¹ÓõĽºË®µÈÖ±½ÓÏà¹Ø¡£´ó¹¦ÂÊÑïÉùÆ÷£¬Ò»°ã¾ùʹÓøßÇ¿¶ÈÄ͸ßεÄÒôȦÏß¡¢ÒôȦ¹Ç¼Ü¡¢½ºË®£¬²ÉÓôó³å³Ì¡¢É¢ÈÈÁ¼ºÃµÄ´Å·½á¹¹£¬ÒôȦ²ÉÓýϿíµÄ¾í¿íºÍÏß¾¶£¬µ¯²¨²ÉÓÃÇ¿¶ÈºÃ¡¢¿¹Æ£ÀÍÐÔÄܺõIJÄÁÏ£¬µ±È»Ò»°ãÒ²²ÉÓôó¿Ú¾¶ÏµÁС£ÑïÉùÆ÷¶î¶¨ÔëÉù¹¦Âʺͳ¤ÆÚ×î´ó¹¦ÂÊ£¬×îÖÕÖ»ÄÜͨ¹ý¸ººÉÊÔÑé»ñµÃºÍÑéÖ¤¡£
2¡¢À®°Èµ¥ÔªµÄ²ÎÊý
T/SÖ¸±ê(Thiele/Small-Specs)
T/SÖ¸±êÊÇÓɰĴóÀûÑÇÈËA.N. Thiele ºÍ Richard Small£¬ÔÚ70Äê´ú³õ·¢Ã÷µÄÑïÉùÆ÷ϵͳÊýѧģÐ͵Ļù±¾²ÎÊý¡£ÏÖ½ñ£¬¼¸ºõËùÓеÄÈ˶¼Êǰ´ÕÕ¸ÃÀíÂÛÀ´Éú²úÀ®°ÈÒôÏä¡£T/SÖ¸±êÓÐÈçϼ¸¸ö£º
Fs(Fo) ΪÀ®°ÈÔÚ×ÔÓɳ¡ÏµÄгÕñµãƵÂÊ¡£
Vas ΪµÈͬÓÚÀ®°È˳ÐÔµÄ¿ÕÆøÈÝ»ý¡£
Qes ΪÀ®°ÈµÄµçQÖµ£¬Ëü·´Ó³Á˵¥ÔªÔÚFoʱÓÚµç´Å¿ØÖÆÏµÄгÕñÄÜÁ¦£¬ÊýÖµÔ½µÍ£¬×èÄáԽǿ£¬Ð³ÕñÄÜÁ¦Ô½µÍ¡£
Qms ΪÀ®°ÈµÄ»úеQÖµ¡£Ëü·´Ó³Á˵¥ÔªÔÚFoʱÓÚ»úе½á¹¹·½ÃæµÄгÕñÄÜÁ¦£¬ÊýÖµÔ½µÍ£¬×èÄáԽǿ¡£
Qts ΪÀ®°ÈµÄ×ÜQÖµ(ÓÉQmsºÍQes²¢ÁªñîºÏ¶ø³É)Ëü·´Ó³Á˵¥ÔªÔÚFo´¦µÄгÕñÄÜÁ¦£¬ÊýÖµÔ½µÍ£¬×èÄáԽǿ¡£
»úµçÐÔÄÜÖ¸±ê(Electro-Mechanical parameter)
Mms£ºÀ®°ÈµÄ×ÜÕñ¶¯ÖÊÁ¿(°üÀ¨ÕñĤµÄÖÊÁ¿¡¢ÒôȦµÄÖÊÁ¿¡¢Ç°ºó¼ÓÔØµÄ¿ÕÆøµÈ)
Cms£ºÀ®°Èµ¥ÔªµÄ˳ÐÔ
Rms£º»úе×èÄᣬ°üÀ¨Õñ¶¯µÄĦ²Á¡¢·øÉä×è¡£
Rme £ºµçÆø×èÄáÒòÊý£¬·´Ó³µ¥Ôªµç´Åϵͳ¶ÔÕñĤµÄ»úе¿ØÖƺÍ×èÄᣬ³£ÓÃÀ´ºâÁ¿µ¥ÔªµÄµç´ÅϵͳµÄÄÜÁ¦¡£
Re£ºÒôȦµÄÖ±Á÷µç×è
BL£ºÏßȦ¼ä϶µÄ´Å³¡Ç¿¶È
Dd£ºÕñĤֱ¾¶
Le£ºÒôȦµç¸ÐÁ¿
Sd£ºÕñĤµÄ±íÃæ»ý
fLe£ºµç¸Ð²âÁ¿ÆµÂÊ
´óÐźÅÖ¸±ê(Large-Signal Parameter)
Xmax£º×î´óÏßÐÔÎ»ÒÆ£¬»ò½ÐÏßÐÔ³å³Ì£¬¼ÆËãΪȫ³å³ÌÎ»ÒÆÖµµÄ1/2£¬Í¨³£Õâ¸öÖµ±È½ÏÓÐË®·Ö£¬ÓÐЩ³§¼Ò»á¸ø³öµ¥ÔªµÄÎïÀí×î´óÎ»ÒÆ¡£¶øÒ»Ð©³§¼Ò²ÉÓÃÈ«³ÌµÄP-PÖµ(peak-to-peak)±íʾ,´ËʱÎÒÃÇҪעÒâÔÚ¶Ô±Èʱ¼õ°ë¡£
Xlim£º²»Ë𻵵Ä×î´óÎ»ÒÆ¡£(»òÓÖ±íʾΪÆäËûXmec£¬×î´ó»úÐµÎ»ÒÆ)
Hc£ºÏßȦ¸ß¶È
Hg£º¼ä϶¸ß¶È
Vd£ºÀ®°ÈÔÚÏßÐÔ·¶Î§ÄÚ£¬×î´óµÄÍÆ¶¯¿ÕÆøÌå»ý
Pe£º¿ÉÁ¬Ðø¹¤×÷²»ÉÕ»ÙµÄ×î´óÊäÈ빦ÂÊ¡£
ÌÖÂÛ£º
¡ôʵ¼ÊÉÏ£¬ËùÓÐT/S²ÎÊý¶¼ÊÇÎ§ÈÆµÍÒôµ¥ÔªµÄгÕñ·å²âÁ¿µÃÀ´µÄ£¬·´Ó³Á˵ÍÒôµ¥ÔªÐ³Õñ·åµÄÌØÐÔ£¬²¢¾Ý´ËÌØÐÔÉè¼Æ¸÷ÖÖÒôÏäÏäÌå¡£¶ø¸ßÒôµ¥ÔªµÄгÕñ·å¶ÔÓÚÏäÌåÖÆ×÷ÎÞÒâÒå(¸ßÒôµÄÕñ·ùÒ²ºÜС)£¬Ò²ÎÞÐë½øÐÐÌØ±ðµÄÃèÊöÈ¥Ó¦Óã¬ËùÒÔÎÒÃDz»»áÔÚ¸ßÒôµ¥ÔªÉϸãT/S²ÎÊý¡£
¡ôFoÖµÊÇÖ¸µ¥ÔªµÄгÕñƵÂÊ£¬¼´À®°ÈÕñ·ù×î´óʱµÄƵÂÊ¡£»ù±¾ÉÏÕâ¾ÍÊǵ¥ÔªµÄµÍÆµÖØ·Å¼«ÏÞ£¬ÒòΪ¹ýÁËгÕñµã£¬µ¥ÔªµÄÉùѹ½«¼±½µ£¬(Ò»°ã½«-3db´¦³ÆÎª½ØÖ¹ÆµÂʱíʾΪF3)
¡ôQÖµÔÚÎÒÃÇÐÎÈݵ¥ÔªÊ±£¬³öÏÖ¼«¶à£¬ËüÆäʵÊÇÃèÊöгÕñÔì³ÉµÄ×迹·åµÄ¼âÈñ¶ÈµÄÒ»¸öÊýѧֵ£¬QÖµÔ½¸ß£¬±íʾ×èÄáС£¬¿ØÖÆÈõ£¬Ð³ÕñµÄ·ù¶È´ó£¬´Ó¶ø²úÉú¸üÇ¿µÄµÍƵÉùѹ£¬µ«ÓÉ´Ë´øÀ´ÁËÕñ¶¯²»ÊܿزúÉúµÄÊ§Õæ¡£
¡ô¹ØÓÚQÖµ¸ßµÍ£¬¶ÔÓ¦ÊʺÏ×öʲôÏäµÄÎÊÌâ,Õâ¸öÎÊÌâÓÐÐí¶àµÄ¿ÚË®ÕùÂÛ¡£Ò»°ã˵À´£¬µÍQÖµµÄÀ®°È£¬×èÄá¸ß¿ØÖÆÁ¦ºÃ£¬ÊʺÏ×öµ¹ÏàÏä¡£¶ø¸ßQÖµµÄµ¥ÔªÊʺÏ×öÃܱÕÏä¡£Õâ¸öʵ¼ÊÉÏÊǸö½ÏÄ£ºý½çÏßµÄÑ¡Ôñ£¬Ò»°ãQÖµ¸ßÓÚ0.5µÄµ¥ÔªÊÊÒËÃܱÕÏ䣬¶øQÖµµÍÓÚ0.3µÄÒª×öµ¹ÏàÏä¡£¶øÒµÄÚͨ³£²ÉÓÃEBPÖµÀ´ºâÁ¿µ¥ÔªÊʺÏÖÆ×÷ÄÄÖÖÏäÌå¡£
3¡¢Qtc£ºÒôÏäȫϵͳµÄ×ÜQÖµ
ÏäÌåµÄËðºÄQÖµ
Ql-й©ËðºÄQÖµ£¬ÓÉÏäÌå¼°µ¥ÔªÃÜ·â²»ºÃÔì³Éй©²úÉúµÄ£¬Í¨³£Õâ¸ö¶ÔÓÚµ¹ÏàÏäÓ°Ïì½Ï´ó. Ò»°ãÊýֵȡÔÚ5-20£¬Õâ¸öÖµÄÑÒÔÔ¤Öª¡£5±íʾΪÃÜ·â·Ç³£Á¼ºÃ! ͨ³£Ô¤ÉèֵΪ10¡£
Qa-ÎüÊÕËðºÄQÖµ£¬ÓÉÏäÌå¶ÔÉù²¨µÄÎüÊÕ²úÉúµÄ£¬ÏäÄÚµÄÌî³äÁÏ»á´ó´óÔöÇ¿ÎüÊÕ¡£Ò»¸ö¸ÉÔï¹â»¬¸ÕÐÔÏäÌåÄÚ±Úͨ³£Ô¼Qa=30-100£¬´óÁ¿Ìî³äʱ£¬½«´ïµ½3-5¡£
Qp-µ¹Ïà¹ÜËðºÄ£¬ Óɵ¹Ïà¹Ü²úÉú£¬ÓÉÓÚ¿ÕÆøÍ¨¹ýʱ£¬¹Ü±ÚµÄĦ²Á£¬µ¹Ïà¹Ü»áÓÐһЩ×èÄá¡£ÊÂʵÉÏ£¬Èç¹ûÄ㽫´ËQÖµÉèµÃºÜСµÄ»°(Òâζ×Å×èÄá·Ç³£´ó)£¬Äǵ¹ÏàÏä¾Í»á±ä³ÉÁËÃܱÕÏäÁË¡£
¹ØÓÚQÖµµÄÀí½â
QÖµÊÇÒ»¸öÃè»æÐ³ÕñÇéÐεÄÊýѧÁ¿,Ëü×ÜÊǰéËæ×èÄá¸ÅÄî(ÔÚгÕñϵͳÖÐ)±»½éÉܸø´ó¼Ò£¬»òÕßÓÐÈ˰ÑËüµÈͬÓÚ×èÄáÖµÀ´½éÉÜ¡£¶ÔÓÚÒ»¸öгÕñϵͳ£¬×èÄáÔ½´ó£¬ÄÇôϵͳµÄгÕñÔ½±»Ç¯ÖÆ£¬´Ó¶øµ¼ÖµÍQÖµµÄгÕñÇúÏß¡£µ±×èÄáСʱ£¬ÔòÇé¿öÏà·´£¬Ð³Õñ¾çÁÒ£¬ÐγɸßQµÄÇúÏß¡£
Ò»°ãÀ´Ëµ£¬¶ÔÓÚÑïÉùÆ÷ϵͳ£¬ºÏÊʵÄQÖµÔÚ0.5-1.5Ö®¼ä¡£µÍÓÚ0.5ʱ£¬×èÄá̫ǿÁË£¬´ËʱÒÑÎÞгÕñ·¢Éú¡£ËùÒÔ£¬Ò²ÓÐÈ˳Æ0.5Qֵʱ£¬ÎªÁÙ½ç×èÄᣬ³ÆÔÙСµÄQÖµ£¬Îª¹ý×èÄá¡£·´Ö®£¬ Q´óÓÚ1.5, ¿ÉÒÔ½ÐÇ·×èÄá¡£
ÔÚгÕñϵͳµÄƵÂÊ-Õñ·ùÇúÏßͼÉÏ£¬ÎÒÃÇ¿ÉÒÔÖ±¹ÛµØ¿´µ½²»Í¬QÖµËù´ú±íµÄÇúÏߣ¬ÒÔ¼°²»Í¬QÖµµÄÒâÒå¡£
4¡¢À®°ÈµÄQ
Qes ΪÀ®°ÈµÄµçQÖµ£¬Ëü·´Ó³Á˵¥ÔªÔÚFoʱÓÚµç´Å¿ØÖÆÏµÄгÕñÄÜÁ¦£¬ÊýÖµÔ½µÍ£¬×èÄáԽǿ£¬ÏµÍ³Ð³ÕñԽС¡£
Qms ΪÀ®°ÈµÄ»úеQÖµ¡£Ëü·´Ó³Á˵¥ÔªÔÚFoʱÓÚ»úе½á¹¹·½ÃæµÄгÕñÄÜÁ¦£¬ÊýÖµÔ½µÍ£¬×èÄáԽǿ£¬ÏµÍ³Ð³ÕñԽС¡£
5¡¢ÏµÍ³µÄQÖµ
ȫϵͳָ°üÀ¨¹¦·ÅÊä³ö¶Ë¡¢À®°ÈÏß¡¢ÒôÏä¡£ ÕâÊÇÒ»¸ö¹¤×÷ʱµÄʵ¼ÊQÖµ£¬ ÓëÏäÌåQÖµQtcÏà±È£¬ ÕâÀï¼ÓÈëÁË×èÄáϵÊýµÄÒòËØ¡£
×èÄáϵÊýµÄÓ°Ï죬 °üÀ¨¹¦·ÅµÄÊä³ö×èÄáϵÊý¡¢ À®°ÈÏßµÄ×èÄáϵÊý¡¢ ´®Á¬À®°ÈµÄ×èÄáϵÊý(Èç¹ûÓÐ)¡¢·ÖƵÆ÷µÄ×èÄáϵÊý¡£
ËùÒÔ£¬Îª±£Ö¤²»Ó°ÏìÔÏäµÄQÖµÉè¼Æ£¬ Ò»°ã¹¦·ÅÒªÇó²ÉÓÃ×èÄáϵÊý¾¡Á¿Ð¡µÄ£¬ ×î×îÆðÂëÊÇ10ÒÔÉÏ£¬ µ«Ò»°ãÒªÇó100ÒÔÉÏ¡£¶ø·ÖƵÆ÷ÖÐÖ÷ÒªÊǵç¸ÐµÄµç×èµÄÓ°Ï죬һ°ãÊÇ˵20ÒÔÉÏ¡£Ïß²ÄͬÑùÒ²Ó¦¸Ã¾¡Á¿Ð¡¡£
¶ÔÓÚ´®½ÓÀ®°È£¬ ×èÄáϵÊýÎ޿ɱÜÃâµÄÔÚ1ÒÔÉÏ£¬ ËùÒÔÒ»°ãÉè¼Æ¶¼ÊDz¢ÁªÀ®°ÈµÄ¡£
×èÄá¡¢QÖµ¶¼ÊÇÃè»æµ¥ÔªÔÚгÕñµã¸½½üµÄ¹¤×÷ÇéÐΣ¬ ¼´Ð³Õñµã¸½½üµÄ·¢Éù±ä»¯Çé¿ö£¬ ¶ÔÆäËûƵÂÊÇøÓòµÄƵÏì»ù±¾ÎÞÓ°Ïì¡£
