查看: 20242|回复: 3
[转载] Avid Pro Tools HD v10.3.9 For Win
发表于 2007-12-3 17:56:52 | 显示全部楼层 |阅读模式
Pro Tools 系列
5 E% g! G0 {6 P" @6 n/ u利用业界标准音频制作平台 Pro Tools,在 Mac 或 PC 上为影片编曲、录制、编辑和混制高品质音乐或声音。 使用各种 Pro Tools 解决方案(从硬件接口和调音台到软件、插件等),根据需要构建完美配置。
. H/ R5 y9 @$ d; D; u% h6 S # m  \0 E  }- G+ B5 B: I; ]
Pro Tools | Software 是什么?
, a6 L1 X) b& S8 s6 c% K让功能最强大的数字音频工作台变得更为强大。 Pro Tools 重新定义了当今的专业音乐和音频制作流程。 Pro Tools 提供全新的音频和视频引擎、经过加速的 64 位性能、经过扩展的电平表以及新的 HD 视频工作流程,让您可以及时交付时限紧迫的工程,最大限度地发挥自己的创作能力。' A7 h* f0 J- w8 v" S3 N
/ K! q7 n" O# [2 s6 J: ^Whether you create music or sound for picture, the right tools can help you achieve the highest quality mixes faster. Pro Tools 10 is the next generation of the best sounding, most widely-used audio production software in the industry, enabling you to record, compose, edit, and mix with great speed and ease.
# Y! c. ]5 V% V7 ANew Pro Tools 10 software adds major new features to the world's leading digital audio workstation, delivering on top requests from both audio post and music professionals. With it, Avid introduces several new tools and timesaving workflows, such as the top-requested Clip Gain, which separates pre-mix levels from Pro Tools software's renowned mixing automation, greatly speeding up and improving the workflow between sound editors and mixers. Customers will also be able to achieve higher sound quality and better performance than ever, whether they're recording, composing, editing, mixing, or playing back their sessions.: X' W* r, c2 r. `4 r$ O3 U
3 Y5 F9 q" F& }9 ?6 H" l# h3 m - z& O% n3 C5 ]6 F! y
What is Pro Tools 10?
- b9 u* u+ J. z4 B8 p; M/ pWhether you create music or sound for picture, the right tools can help you achieve the highest quality mixes faster. Pro Tools 10 is the next generation of the best sounding, most widely-used audio production software in the industry, enabling you to record, compose, edit, and mix with great speed and ease.
: e( v( ^. c. Z- L" x
$ z- E8 @8 R( B: I! `) n: v& I5 EGo bigger with Pro Tools HD 10" }1 ?. \# s% L5 ?, Q
For projects that demand the utmost in sound quality and performance, Pro Tools HD software enables you to compose, record, edit, and mix big productions quickly and easily. The software comes with Pro Tools|HDX and Pro Tools|HD Native systems only. What’s more, you get all of the same benefits of Pro Tools software 10 along with several additional features and workflows % A) O. s" p/ B& j/ }" S+ n
1 G7 L. K+ j; g1 K/ PMix it up—at higher resolutions$ e+ G" O# U& T4 _9 z2 U
With Pro Tools 10, you can mix multiple audio file formats and bit depths within the same session— including interleaved—without any file duplication to cause project bloat. 1 Z# Z. |( Z" m8 c
Plus, with support for 32-bit floating-point file formats, you’ll get higher resolution sound when recording or importing, with more headroom to preserve the integrity of your audio from beginning to end.
/ D8 T% K% g+ }% [ ' r; t% n' Y! [" Z7 |' _
Drive faster—with better performance! R- m8 ]# d+ W5 H
Gain better recording and playback performance when working on a laptop with an external drive or a network-attached storage device. Speed up editing and mixing with Clip Gain. Work more easily with AudioSuite-rendered clips. Get 4x more* Automatic Delay Compensation and 2x more busses to handle bigger mixes with more plug-ins. And get snappier performance when working on sessions with lots of fades. & E# t! p4 ?, N7 Q, X7 _* e7 \/ Q! ~
3 l" M- v: o' O' \Plug into legendary sound.. ]4 a# f% ^' D
With the included Avid Channel Strip plug-in, you get the renowned channel strip of the Avid (formerly Euphonix) System 5, one of the most sought-after consoles used to create some of the greatest mixes ever produced. Work with exact replications of the console’s EQ and compression algorithms to add life to your mix ' r. V2 x& a/ N
. P# r: I5 t4 F4 M! O8 O* F( ZPro Tools HD 10 — new features
: v/ M4 t+ H3 k# L1 W/ c* _9 ]* Get all of the same great new features of Pro Tools 10 software 3 y: O3 L8 \9 e! L8 h8 [9 K5 c7 t. a
* Create way bigger mixes, with up to 768 voiceable audio tracks and 512 aux tracks** a4 P* W1 Z; H5 ]. @% O
* Get highly responsive recording and playback performance with the extended disk cache, which loads entire sessions into RAM. a5 L% {# N# a$ A* U
* Connect with up to 12 Pro Tools HD-based systems using Satellite Link- u; b9 N. Y  W" `4 W! O
* Get improved workflows for field recorders
9 b+ o- |/ v9 W: M" e+ d& s2 ?* Control two Pro Tools HD-based systems with a D-Command console in Multi-mode. ~% S1 p% h$ t/ J, ?7 P% i
* Get more tracks and streaming support when using Avid ISIS
, L! O7 G4 h+ ^% [ 4 Y0 f3 H" T4 v% R+ |- w4 _, r6 g
Pro Tools HD 10 — additional features( x3 k9 g( a( g! @" C
Get top-quality sound and performance with Avid hardware
# J- v9 i' U/ x1 C& gBecause Pro Tools HD is designed and optimized to be part of an integrated hardware/software solution, you can capture audio in pristine clarity with near-zero latency. Even when mixing large, complex projects, you’ll experience uncompromised performance—on a Pro Tools|HDX DSP-powered system or on the host with Pro Tools|HD Native. " X5 W0 ^) u$ P( W8 ^
Record and edit with advanced audio tools 4 i% E( q# H# S. m; y
Record solo tracks in PFL (pre-fader listen) or AFL (after-fader listen) mode. Work more efficiently when punching performances with TrackPunch and DestructivePunch. Enhance and speed up editing tasks with Continuous Scrolling, Scrub Trim tool, Replace Clip command, Time Compression and Expansion Edit to Timeline Selection command, field recorder workflows, and more. ) ~6 Y1 ]* S# ^6 m" j2 A
Work more easily with video
- Z+ l( Q" i' c+ |, o$ e, S5 iEdit and mix sound for larger, more complex video productions, and display up to 64 video tracks in the timeline. Expand your post capabilities with advanced video features. Including multiple video playlists and basic video editing tools. Share audio mixes with Media Composer editors (and vice-versa) through AAF. Or integrate directly into the Media Composer workflow with the Video Satellite option, eliminating the need to render effects, transcode video, or copy files. ) `# h3 Y1 c; F2 p7 g9 [
" b2 f9 n* ]" a" Y8 VMix in stereo or surround
9 k5 E/ l; [9 _2 N7 ^With Pro Tools HD, you can mix in everything from mono up to 7.1 surround sound. Build up your sonic landscape and add movement to your mix with the built-in surround panner. Work with groups of tracks faster and easier with VCA Group mixing. And with advanced automation tools, you can tackle even the largest, most complex mixes with ease. " q; z/ F  R& E6 q  I
' j6 k1 k6 H% ]% EPro Tools HD 10 System Requirements
# U, R* h  [6 GWindows Systems 9 E& O2 y. c5 x  K
* Computer: Avid-qualified Windows-based computer (see details). M  h# c% i" ]
* System Software (32 or 64-bit) Windows 7 Home Premium, Professional, or Ultimate edition with Windows 7 Service Pack 1
/ S$ {; U1 C7 a+ w! x' C) Q8 d* Total System RAM: 4GB minimum, 8GB (or more) recommended
7 i' p* L- C3 S3 e
4 x/ t* C! f8 k/ y% y- KAdditional Requirements
2 H% R; }0 ~. @- P! M/ M, g9 i+ \+ N* Pro Tools|HD Audio Interfaces (required) and Peripherals (see details)
" a' K( M  U/ b* Audio Drive Requirements: One or More Hard Disk Drives Dedicated for Audio Record and Playback (see details)
6 k( {: e  }7 `: O6 w. r* System Hard Drive: Minimum 15GB free space on startup drive required for Pro Tools installation
% L. m7 d3 n3 B- K4 N* Graphics Card: Dedicated Graphics Card highly recommended (see details)  U3 r7 O$ w, Y
* Video Peripherals (see details)
/ P! v, D" [5 L5 n# @* Avid Shared Storage and Interplay (see details)& L0 o3 J, Y; B! h2 |9 w
* ^, e* [% u+ D. m7 p" b
Pro Tools Software Options5 y& r; \/ G9 j; h1 K' f
* Video Satellite with Media Composer (see details)
' K1 N3 {: F! Y% B* Machine Control (see details)! q+ s' ^* P2 W
* Satellite Link (see details)& t* x" g/ Q8 W& Z& B( @! |
* Video Satellite LE (see details)$ H( {1 j9 h/ F
640 (4).jpg , I% m- o$ I8 k5 a1 g
Other6 C3 j, D* O* i! h; O
* Media Composer Co-install (see details)
1 v9 C& K  _& u, G1 V4 N) s. E* Mac Aggregate Device Info (see details)# F! z; P0 j! n- l) a: {$ Y
5 j* Z7 {) g" cDriver Updates
' v# |/ J& ^1 V6 h5 Y1 `* v. C* Please download and install the latest drivers for your hardware.; E. W& h+ E0 ]0 n% h) }: T$ z
Languages : English (US), French, German, Japanese, Chinese ( Simplified), Chinese (Traditional), Korean, Spanish.$ J3 [, T- A  P- C* J7 S
Avid Pro Tools HD v10.3.9 For Win( J3 b, W. t) w
下载地址:
游客,如果您要查看本帖隐藏内容请回复
1万
发表于 2007-12-3 18:13:08 | 显示全部楼层
谢谢 ,就是棒!Avid Pro Tools HD v10.3.9 For Win
3万
音频应用初级会员
Rank: 6Rank: 6
发表于 2007-12-5 09:33:58 | 显示全部楼层
:victory: :victory:
6179
发表于 2007-12-6 08:35:18 | 显示全部楼层
搬板凳去.....:victory: :victory: :victory:
GMT+8, 2025-5-31 10:36 , Processed in 0.032977 second(s), 8 queries , Redis On.
