8Dio CASE Solo Strings FX KONTAKT
ÒôÉ«
8Dio CASE Solo Strings FX KONTAKT | 21.84GB
»¶Ó­À´µ½CASE--ÓÐÊ·ÒÔÀ´×îÍêÕûµÄSolo¹ÜÏÒÀÖÍÅ¡£
CASE£¨Custom Aleatoric Solo Effects£©ÏµÁÐÓɰÂ˹¿¨½±£¬TECºÍG.A.N.GÂÅ»ñÊâÈÙµÄ×÷Çú¼ÒTroels FolmannÖÆ×÷¡£ CASEÔÚÏÒÀÖ£¬Í­¹ÜºÍľ¹ÜÀÖÆ÷µÄÈý¸öרÓÿâÖж¼»ùÓÚÏàͬµÄ¸ÅÄî¡£
CASEÏÒ°üº¬¶À×àСÌáÇÙ£¬¶À×àÖÐÌáÇÙ£¬¶À×à´óÌáÇٺͶÀ×àµÍÒô¡£Ã¿¸öÀÖÆ÷¶¼ÓÐ2¸ö²¥·ÅÆ÷Â¼ÖÆ£¬ËùÒÔÄú¿ÉÒÔ½«Á½¸ö²¥·ÅÆ÷·ÅÔÚÒ»Æð£¬Ò²¿ÉÒÔͨ¹ýSoloist SpotÂó¿Ë·ç½«Æä·Ö¿ª¡£ CASE´øÓÐ6¸öÂó¿Ë·çλÖ㬷ÖΪÁ½¸öºËÐÄ×飺Hall£¨Close£¬Far£¬WideºÍMixed£©ºÍSoloist 1£¨Spot 1£©ºÍSoloist 2£¨Spot 2£©¡£
CASE×Ö·û´®°æ±¾°üº¬Ê×ÇüÒ»Ö¸µÄÇåµ¥£¬²¢ÒԸ߷ֱæÂʲ¨ÐΣ¨.wav / 24λ/ 96khz¸ñʽ£©¡£ÎÒÃÇÏë´´ÔìһЩÃ÷È·¶øÎÞÓëÂױȵĶ«Î÷¡£µ¥¶ÀµÄÏÒÀÖ°æ±¾°üº¬³¬¹ý14.000¸öFXÑù±¾£¬¼¸ºõ²»¿ÉÄÜÕÒµ½Ã»Óк­¸ÇµÄЧ¹û¡£
ÎÒÃÇеÄË«²ãFXϵͳ֧³ÖÁîÈËÄÑÒÔÖÃÐŵÄÉî¶È¡£µÚÒ»¸öÊÇÎÒÃǵÄǰÁ³Ð§¹ûϵͳ£¬¿ÉÒÔÈÃÄã¿ØÖÆ»Ðã±µÄÃÅ£¬Â˲¨Æ÷£¬Òôµ÷£¬ÑÓ³Ù£¬Ñ¹ËõºÍеÄÎÆÀí¾í»ýÑÓ³Ù¡£ÐµÄÎÆÀí¾í»ýÔÊÐíÄú²ÉÈ¡¼¸Ê®¸öеľí»ý£¬²¢½«ÆäÓÃ×÷ÑÓ³Ù×é¼þ¡£ÎÒÃÇ»¹°üÀ¨ÁËÎÒÃÇеĻìãçFXÒýÇæ£¬Ëü¿ÉÒÔÈÃÄã¿ØÖÆÖîÈçEQ£¬Ïàλ£¬Ê§Õ棬Á¢ÌåÉùÑӳٺ͸½¼Ó¾í»ý»ìÏìÖ®ÀàµÄ¶«Î÷¡£
µ«×îÖØÒªµÄÊÇ£¬CASEÊÇÓÐÊ·ÒÔÀ´×îÍêÉÆµÄ¹ÜÏÒÀÖ×éºÏ¡£²ÉȡһЩ¼òµ¥µÄ¡°ÏÒÀÖÁ¢¹Ü¡±¡£Õâ²»ÔÙÊÇÄãÏëÒªÒ»¸öÉÏÉýµÄÏÒÀÖÉùÒôµÄÎÊÌâ¡£ÕâÊÇÒ»¸öÎÊÌ⣬ÄãÊÇ·ñÏëÒªÔÚÕý³£µÄÁ¬×໬×à»òÕß²üÒôÔ˶¯ÖÐ - Ò²ÐíÄãÏëÒª¸ü¶àµÄ»ùÓÚ²üÒôµÄ»¬Òô»òÕßÄãÖ»ÊÇÏëÒªÒ»¸ö¿ÉŵÄÄ¥Ïұ仯¡£
CASEÓµÓÐÒ»ÇУ¬ÊÇSolo Orchestral FXµÄȨÍþÊղء£
Ô­ÎÄ
Welcome to CASE ¨C the most comprehensive collection of Solo Orchestral Effects ever done.
CASE (Custom Aleatoric Solo Effects) series is produced by Academy Award, TEC and G.A.N.G Award Winning Composer, Troels Folmann. CASE comes in three dedicated libraries for Strings, Brass and Woodwinds all based on the same concept.
CASE Strings contains Solo Violins, Solo Violas, Solo Cellos and Solo Basses. Each instrument was recorded with 2 players, so you have the ability to either play both players together or separate them via the Soloist Spot microphones. CASE comes with 6 microphone positions divided into two core groups: Hall (Close, Far, Wide and Mixed) and Soloist 1 (Spot 1) and Soloist 2 (Spot 2).
The CASE Strings Edition contains an articulation list second to none and comes in high-resolution wave (.wav / 24 bit / 96khz format). We wanted to create something definitive and unrivaled. The String Edition alone contains over 14.000 FX samples and it is near impossible to find an effect not covered.
The incredible depth of articulations is supported by our new dual-layered FX system. The first of which is our front-face FX system that gives you control over a trance gate, filters, pitch, delay, compression and our new textural convolution delay. The new textural convolution allows you to take dozens of new convolutions and use them as delay components. We have also included our new Chaos FX engine, which gives you control over things such as EQ, Phasing, distortion, stereo delay and an additional convolution reverb.
But most importantly CASE is the most comprehensive collection of orchestral FX ever done. Take something as simple a ¡°string riser¡±. It¡¯s no longer matter of whether you want a rising string sound. It is a matter of whether you want it in normal legato glissando or perhaps with tremolo motion to it ¨C maybe you want more of a trill based glissando or maybe you just want a horrific grinding string variation.
CASE has it all and is the definitive collection of Solo Orchestral FX.
ÏÂÔØµØÖ·£º
Óοͣ¬Èç¹ûÄúÒª²é¿´±¾ÌûÒþ²ØÄÚÈÝÇë»Ø¸´
ÆÀÂÛÁÐ±í£¨1£©
2007-11-26 01:38:18 »Ø¸´
