Valseana CR8 רҵÒôÏä ¼ÒôÅïÉ豸
תÌû
3 P( }) t0 H8 n9 m1 T: R 6 z( M% g2 H5 }" F$ l3 F1 s  P" M
¼¼Êõ²ÎÊý£º( B1 K& d0 Z- G0 Z. t$ r- a& N
& M' W+ P; X9 ZƵÂÊÏìÓ¦£º36Hz¡ª50kHz£¨¡À3dB£©5 H* F" j% C" B5 T  r
9 j% |: A5 C0 PµÍƵÏì¶ÈË¥¼õ£º-3dB@60Hz
3 |! n# V5 l2 Z3 o7 K4 v& A+ y9 |2 h" q
¸ßƵÏì¶ÈË¥¼õ£º-3dB@22KHz
9 I1 [7 A6 ]% S+ e3 i$ J3 V& k; |, ]5 k3 D$ D( c
Éùѹ¼¶£º100dB SPL@1m£¨@1 meter,+5dBu into Balanced Input)7 _9 j( l+ {# r; q; a% M
! B5 C6 l" V& }1 M# U2 MÉùѹ¼¶£º118dB SPL@1m£¨Per Pair£©; F7 Q1 j4 X, x: b
' Y6 V0 `% \5 p4 V" b# y  |µÍÒô                            µ¥Ôª£º1¸ö/£¨8in£©203mm3 h% p/ O7 q8 c3 |3 m
* D  Q: G. F& l* W
¸ßÒôµ¥Ôª£º1¸ö/£¨1in£©25mm
2 W9 O* x( v! A8 u+ I. `- e  @2 ?
µÍÒôµ¥Ôª¹¦ÂÊ£º100watts 4ohm (·åÖµ200watts£©
$ H3 A8 ]3 t5 g. ]2 g9 I, p0 R! L1 b( o. p
¸ßÒôµ¥Ôª¹¦ÂÊ£º50watts 4ohm£¨·åÖµ100watts£©
1 s. ?4 e: g9 R7 \6 G3 Y' q( x) u6 C# ^
ѹ°ÚÂÊ£º£¾15V/¦Ìs) P" R, z# j+ B0 L' W
! t+ [5 {. ~% |/ Y- M
г²¨Ê§Õ棨THD,SMPTEIMD,DIM100):£¼0.035£¥$ }$ U, C) x* f' n. M" \$ Y2 U' V
! j6 W+ u# Y3 e. ]" U¸ßƵÀàÐÍ£ºMonlithic IC,Class AB with DMOS power stage
" E) H5 C* r/ f! |4 H, M
$ o# C0 Z) z2 r* K4 fµÍƵÀàÐÍ£ºDiscrete bipolar Class AB$ r" z. w$ J4 U$ v8 X  f
6 V7 U5 O) B0 ~( _0 N) ~" S; A
ÀàÐÍ£º24dB/±¶Æµ³Ì; u/ B; O; L# E6 f
7 t; x. s+ C( r* S3 p$ r
·ÖƵµã£º3kHz. T- Z" N0 V' d  L- A! k
! o+ |: l8 J) W" w4 R
ÁéÃô¶È£º+4dBU at 300Hz for full output
8 P4 V  X/ z% k% ?! v# K
) r1 Q/ A" q4 f. vÊäÈë×迹£º20k¦¸£¨Æ½ºâ£©/10k¦¸£¨·Çƽºâ£©
8 d; X! n5 A# E; e7 I+ k
6 z: ^6 J1 M- Z5 }+ b' ^: d0 N& D¸ßƵ²¿·ÖEQ:+2dB/+4dB@100Hz£¬shelving
0 @2 f2 b( L2 i& d, U" p+ F" Q: a& w2 U
µÍƵ²¿·ÖEQ:+2dB@5kHz£¬shelving
7 O% x2 G9 D: S9 m. t) t2 @4 e- J: V- O: z! y- H5 w0 W/ N8 K
³ß´ç (¿í¡Á¸ß¡ÁÉî)£º 276 x 406x346mm- H# g9 c! A. W% G3 }3 K  A
4 U( K8 k* w; o' w& ~# j) iÖØÁ¿£º12.5Kg
5 [0 f1 b. n, ^9 W2 F; W4 u) H$ s- t2 o: s( o
4_511_192032_556_800.jpg & f9 C& z+ R% ~" g1 T+ W/ K
$ q0 s$ c' i% F0 C6 k! w, n5 l9 @( b2 z  x
7 q% Q9 ~# f* c' ~4 N8 @; X. n4 J" q$ f9 q
ÆÀÂÛÁÐ±í£¨2£©
: L$ O$ F& \6 c& I: e( R1 i! P7 e) Y4 r4 F) O# ~7 k4 j6 @% p
2007-11-5 14:45:00 »Ø¸´
:victory: :lol
2007-12-20 23:32:35 »Ø¸´
