A-Designs 500 HR Rack Ч¹ûÆ÷
A-Designs 500 HR Rack Ч¹ûÆ÷ÊÛ¼Û£º£¤3200Ôª
$ r$ ]1 O0 Q" G; E1 m( [1 R9 |" {6 R5 U3 C
' w9 }5 ~% i/ u3 Z( C. H7 ]* i
5 l8 a- h: `8 G0 @7 y$ d* M! z7 M : O; }. a4 _" R+ g: `" C
: B& X' O7 i7 Y, U6 d' K" D( [8 jYou are able to use the 500HR and A Designs module combinations in four basic ways:
2 p/ {$ i+ ~. y1 |* ]* A5 A, W5 x! ?5 K) D" O& M0 q
1. Loaded with two preamps it becomes a dual channel Mic Pre( @) v, t3 S  D1 y
/ X7 N' m0 _1 _* A4 g8 C5 `2. Loaded with two EQ¡¯s it is a dual channel EQ( w* V+ {+ o0 t, v
8 ~; R% t4 H- `6 _- n/ S3. Loaded with one preamp and one EQ it is a complete pre/post EQ recording channel
5 q* k; q& e/ j  c/ M6 F; S& a
5 o4 ^' u& j5 y7 M& G6 v' s4. Use one preamp and the EQ in the 500HR and bypass your pre on your guitar/bass/keyboard amplifier and have a totally different amp for any live situation!
* V4 F1 ^; z9 w" {+ } 1284859371.jpg 7 k2 ?, |, t3 x$ v/ e
Features:
: u$ G! w# F0 H# f' c3 X6 \$ `2 c( [
- Compatible with all the A-Designs 500 series modules
4 X4 V8 D1 [) p  U; \4 X" F/ B- V' E7 t5 X: p' y
- Internal regulated power supply w/ 48v phantom power7 F; [$ y7 I' ?; F
+ h. R% T0 A8 D+ B- b, o2 g& e, @/ u- Steel chassis construction
1 ]" s+ P. c% S( u. x
" A- r+ E  r  j9 d  r* V- LED 48v indicator
" ?) K* ]' M( p7 s3 p7 W7 p6 \" m, Y8 O* l6 h
- Included power cord2 c# A( ~* U* Q$ c
  f" d: u8 M: H6 dConnections Two XLR Inputs, electronically balanced, Two XLR, electronically balanced
& ?* @. p  @% w; q6 u
' d6 T5 {1 S3 T8 m7 \1 ^Power Requirements are100/120/230 VAC - 14W4 B; ^; Q5 ]( U" J% K2 U- J8 o  z& J# w
9 g1 D! X2 C9 @5 J. m
DC Power Output / Channel is 140mA @ "16VDC
& g5 n8 l0 t# [4 m5 i) t: t$ l& Z7 h" u8 `" }1 [7 T
Dimensions are 19" x 1.75" x 8.25" [1RU]- d( r( I$ |" h" p
  n) Y: _! Z% K9 [- P% v% A( E  OWeight (empty) 6 lbs
& O: j0 r. C9 ]4 O- P$ v# z) ]6 F4 C. I1 _4 t* K
ÆÀÂÛÁÐ±í£¨1£©
:o :) :D :P :victory: :victory:
2007-10-26 18:14:23 »Ø¸´
