查看: 36812|回复: 3
[资讯] Toontrack Superior Drummer 3 v3.0.3 VST AAX WiN
发表于 2007-10-14 00:30:20 | 显示全部楼层 |阅读模式
在其前身的基础上,Superior Drummer 3从头开始重新设计,引入了全新的改进工作流程,无数的附加功能和无与伦比的原始音响素材。高级鼓手3,你完全控制。欢迎来到鼓生产的未来。
高级鼓手3的想法是让你步入虚拟演播室,以最好的原材料和混音选项在您的处置,在只有您的想象力设置极限的环境中创造鼓声。结合了声音的创造力,氛围和广泛的功能,高级鼓手3不仅仅是一个鼓采样器 - 它是一个无底洞的创造力。它弥合了声学和电子之间的差距,让你冒险进入全新的声波景观。这是打击乐声音设计的权威工具。
优质鼓手3核心音乐库由屡获殊荣的工程师乔治·马森堡(George Massenburg)录制,可能是世界上最安静和最理想的采样位置,比利时的银河工作室。图书馆拥有极其详细的信息。除了关闭麦克风和多个环境位置之外,Superior Drummer 3设置还包括一个额外的十一房间麦克风设置为环绕配置,适用于从立体声到5.1,9.1以及从11.1到11.1的所有系统。结合用于堆叠和声音设计的额外乐器的大量选择,Superior Drummer 3的声音为您提供了无与伦比的调色板选项,可以制作超出您最激动人心的想象力的鼓音。
原文
Building on the legacy of its predecessor, Superior Drummer 3 was redesigned from the ground up to introduce a completely new and improved workflow, countless added features and an unequalled amount of raw sound material. With Superior Drummer 3, you are in total control. Welcome to the future of drum production.
The idea with Superior Drummer 3 is to let you step into a virtual studio with the best possible raw material and mix options at your disposal to create drum sounds in an environment where only your imagination sets the limits. Combining the creative power of the sounds, the ambiences and the extensive set of features, Superior Drummer 3 is more than just a drum sampler – it’s a bottomless well of creativity. It bridges the gap between acoustic and electronic and lets you venture off into completely new sonic landscapes. This is the definitive tool for percussive sound design.
The Superior Drummer 3 core sound library was recorded by award-winning engineer George Massenburg at probably the world’s most quiet and ideal location for sampling, the Galaxy Studios in Belgium. The library boasts captured in extreme detail.
 In additional to close microphones and several ambience positions, the Superior Drummer 3 setup also includes an additional eleven room microphones set up in a surround configuration, for use in anything from stereo to 5.1, 9.1 and all the way up to 11.1 systems. In combination with the large selection of extra instruments added for stacking and sound design purposes, the sounds of Superior Drummer 3 give you an incomparable palette of options to craft drum tones beyond your wildest imagination.
Toontrack Superior Drummer 3 v3.0.3 VST AAX WiN | 301 Mb
下载地址:
游客,如果您要查看本帖隐藏内容请回复
 楼主| 发表于 2007-10-31 23:13:29 | 显示全部楼层
发表于 2021-8-22 17:38:33 | 显示全部楼层
GMT+8, 2025-9-17 17:57 , Processed in 0.046715 second(s), 21 queries , Redis On.
