µ¤ÄÃ|Dynaudio BM 6A MKII ¼àÌýÒôÏä
Õâ¿îË«·ÖƵÓÐÔ´Ä£Äâ½ü³¡¼àÌýÓÃ6.9¡°µÍÒôµ¥ÔªºÍÒ»¸ö1.1¡±ÈíÇò¶¥¸ßÒôµ¥ÔªÌṩÁ˶ÀÌØµÄDynaudioµÄÇåÎú¶ÈºÍ׼ȷ¶È£¬Â¶³öÿ·¢Éùϸ½ÚµÄ¹Ø¼ü£¬²¢ÒªÇ󹤳Ìʦ¡£°åÔØLF/ MF/ HF·ÅÖùýÂËÆ÷£¬ÒÔ¼°µÍÒôÅڵĸßͨÂ˲¨Æ÷ʹÏÔʾÆ÷Äܹ»ÇáËÉÊÊÓ¦Èκλ·¾³¡£
A Powerful Active Monitor with Exceptional Clarity!
This two-way active analog nearfield monitor with a 6.9" woofer and a 1.1" soft dome tweeter delivers distinctive Dynaudio clarity and accuracy, exposing every audible detail for the critical and demanding engineer. Onboard LF/MF/HF placement filters, as well as subwoofer highpass filters allow the monitor to easily adapt to any environment.
Dynaudio BM 6A mk II 2-way Active Analog Nearfield Monitor Features:
Integrated positioning filters (LF/MF/HF shelving/notch)
60/80Hz highpass filter for subwoofer adaptation
Balanced analog XLR input
50W/100W tweeter/woofer amplifier
Input sensitivity switch (-10/+4dB range)
Clip indicator LED
The Dynaudio BM 6A mk II active nearfield monitor gives you accurate sound with headroom to spare!
Tech Specs
PoweredYes
Power ConfigurationBi-amped
LF Driver Size7"
LF Driver TypeCone
LF Driver MaterialPolypropylene
HF Driver Size1.1"
HF Driver TypeSoft Dome
HF Driver MaterialAluminum
LF Driver Power Amp100W
HF Driver Power Amp50W
Total Power150W
Frequency Range40Hz-21kHz (¡À3 dB)
Crossover Frequency1500Hz 6 dB/Oct
Maximum Peak SPL120 dB Peak @ 1m
Enclosure TypeSealed
Input Types1 x XLR
Height13.2"
Width8"
Depth12.9"
Weight23.12 lbs.
ÆÀÂÛÁÐ±í£¨1£©
µ¤ÄÃ|Dynaudio BM 6A MKII ¼àÌýÒôÏä......:'( :'( :'( :victory: :victory: :victory:
2007-9-21 08:30:05 »Ø¸´
