Cubase¿ì½Ý¼ü´óÈ«
Cubase
Cubase¿ì½Ý¼ü´óÈ«
Tool Tool 1 ѡȡ²Ù×÷¹¤¾ß¡°1¡±¡ªÑ¡Ôñ¹¤¾ß 1
Tool Tool 2 ѡȡ²Ù×÷¹¤¾ß¡°2¡±¡ª·¶Î§Ñ¡Ôñ¹¤¾ß 2
Tool Tool 3 ѡȡ²Ù×÷¹¤¾ß¡°3¡±¡ª¼ôµ¶¹¤¾ß 3
Tool Tool 4 ѡȡ²Ù×÷¹¤¾ß¡°4¡±¡ªð¤½Ó¹¤¾ß 4
Tool Tool 5 ѡȡ²Ù×÷¹¤¾ß¡°5¡±¡ªÏðÆ¤¹¤¾ß 5
Tool Tool 6 ѡȡ²Ù×÷¹¤¾ß¡°6¡±¡ªÏÔʾËõ·Å¹¤¾ß 6
Tool Tool 7 ѡȡ²Ù×÷¹¤¾ß¡°7¡±¡ªÑÆÒô¹¤¾ß 7
Tool Tool 8 ѡȡ²Ù×÷¹¤¾ß¡°8¡±¡ªÇ¦±Ê¹¤¾ß 8
Tool Tool 9 ѡȡ²Ù×÷¹¤¾ß¡°9¡±¡ªÍ϶¯ÊÔÌý¹¤¾ß 9
Tool Tool 10 ѡȡ²Ù×÷¹¤¾ß¡°0¡±¡ªÑ¡Ôñ¹¤¾ß 0
Tool Next Tool ÏÂÒ»¸ö²Ù×÷¹¤¾ß F10
Tool Previous Tool ǰһ¸ö²Ù×÷¹¤¾ß F9
Tool Toggle Range Selection
Edit Autoscroll ÆÁÄ»×Ô¶¯¸úËæ²¥·ÅÖ¸ÕëÏÔʾ F
Edit Zoom In ÆÁÄ»ÏÔʾ·Å´ó H
Edit Zoom Out ÆÁÄ»ÏÔʾËõС G
Edit Snap On/Off ÒÆ¶¯Ê¼þÌõʱÊÇ·ñ°´SnapeֵΪµ¥Î» J
Edit Duplicate ÔÚʼþÌõºó¸´ÖÆÒ»¸öͬÑùµÄʼþÌõ Ctrl + D
Edit Open ÓÃÏàÓ¦µÄ±à¼­Æ÷´ò¿ªÊ¼þÌõ Ctrl + E
Edit Repeat ÖØ¸´Ê¼þÌõ£ºÌîÊý×ÖÈ·¶¨Öظ´µÄ´ÎÊý Ctrl + K
Edit Move to Front °Ñµ±Ç°Ê¼þÌõÔÚÖØºÏ´¦ÏÔʾÔÚÇ°Ãæ Alt + F
Edit Move to Back °Ñµ±Ç°Ê¼þÌõÔÚÖØºÏ´¦Òþ²ØÔÚºóÃæ Alt + B
Edit Group ½«Èô¸ÉʼþÌõ±à³ÉÒ»×é¿Éͳһ²Ù×÷ Ctrl + G
Edit Ungroup ½â¿ª±à×é Ctrl + U
Edit To Real Copy
Edit Lock Ëø×¡Ê¼þÌõ£¬²»Äܱ༭ºÍÒÆ¶¯ Ctrl + Shift + L
Edit Unlock ½âËø Ctrl + Shift + U
Edit Cut Time   Ctrl + Shift + X
Edit Delete Time   Shift + Back
Edit Paste Time   Ctrl + Shift + V
Edit Paste at Origin °´ÒôƵÎļþµÄԭʱ¼äÂë²åÈëÏîÄ¿ÖÐ Alt + V
Edit Split Range ½«ËùÑ¡·¶Î§´ÓԭʼþÌõÖÐÇпª Shift + X
Edit Crop Range ½«Ô­Ê¼þÌõÖзÇÑ¡·¶Î§É¾µô
Edit Insert Silence ÔÚËùÑ¡µÄ·¶Î§²åÈëÒ»¶ÎµÈ³¤µÄ¾²Òô Ctrl + Shift + E
Edit Fill Loop
Edit Select Event
Edit Select in Loop
Edit Select All on Tracks
Edit Zoom to Selection ½«ËùÑ¡·¶Î§·Åµ½×î´ó Alt + S
Edit Zoom to Event   Shift + E
Edit Zoom Full   Shift + F
Edit Split At Cursor ÒÔ²¥·ÅÖ¸ÕëΪ·Ö¸ôÏßÇпªËùÑ¡µÄʼþ Alt + X
Edit Move to Cursor ½«ËùѡʼþµÄÆðʼµãÒÆ¶¯µ½²¥·ÅÖ¸Õë Ctrl + L
Edit Split Loop
Edit Zoom In Vertical
Edit Zoom Out Vertical
Edit Solo ½«µ±Ç°Òô¹ìÉ趨Ϊ¶À×à S
Edit Mute ½«µ±Ç°Òô¹ì¾²Òô M
Edit Record Enable ½«µ±Ç°ÒôƵÉ趨Ϊ¼Òô×¼±¸×´Ì¬ R
Edit Mute Objects ½«ËùѡʼþÌõ¾²Òô Shift + M
Edit Unmute Objects ½â³ýµ±Ç°±»¾²ÒôµÄʼþÌõ Shift + U
Edit Open/Close Editor ´ò¿ªµ±Ç°Ê¼þÌõÏàÓ¦µÄ±à¼­Æ÷ ´óEnter
Edit Left Selection Side to Cursor ËùÑ¡·¶Î§µÄÆðʼλÖÃΪ²¥·ÅÖ¸Õë E
Edit Right Selection Side to Cursor ËùÑ¡·¶Î§µÄ½áÊøÎ»ÖÃΪ²¥·ÅÖ¸Õë D
Edit Select from Start to Cursor   Alt + E
Edit Select from Cursor to End   Alt + D
Edit Undo È¡Ïû¸Õ²ÅµÄ²Ù×÷ Ctrl + Z
Edit Redo ÖØ¸´¸Õ²Å±»È¡ÏûµÄ²Ù×÷ Ctrl + Shift + Z
Edit History ´ò¿ª²Ù×÷µÄÀúÊ·¼Ç¼ Ctrl + H
Edit Cut ¼ôÇÐËùÑ¡µÄʼþÌõ Ctrl + X
Edit Copy ¸´ÖÆËùÑ¡µÄʼþÌõ Ctrl + C
Edit Paste Õ³ÌùÒѱ»¼ôÇлò¸´ÖƵÄʼþÌõ Ctrl + V
Edit Delete ɾ³ýËùÑ¡µÄʼþÌõ Del
Edit Delete ɾ³ýËùÑ¡µÄʼþÌõ Back
Edit Select All Ñ¡ÔñËùÓеÄʼþÌõ Ctrl + A
Edit Select None ·ÇÑ¡ËùÓеÄʼþÌõ Ctrl + Shift + A
Edit Paste Time at Origin ÒÔÒôƵʼþÔ­ÓеÄʱ¼äÂëÕ³Ìù
Devices VST Mixer ´ò¿ªVSTµ÷Òǫ̂ F3
Devices VST Send Effects ´ò¿ªVST·¢ËÍЧ¹ûÆ÷ÉèÖô°¿Ú F6
Devices VST Master Effects ´ò¿ªVSTÖ÷Êä³öЧ¹ûÉèÖô°¿Ú F7
Devices VST Outputs ´ò¿ªÏµÍ³µÄÊä³ö¿ÚÉèÖô°¿Ú F4
Devices VST Inputs ´ò¿ªÏµÍ³µÄÊäÈë¿ÚÉèÖô°¿Ú F5
Devices VST Performance ´ò¿ªµ±Ç°ÏµÍ³×ÊÔ´Õ¼Óò鿴´°¿Ú F12
Devices VST Instruments ´ò¿ªVSTÀÖÆ÷ÉèÖô°¿Ú F11
Devices Video ´ò¿ªÊÓÆµ´°¿Ú¹Û¿´ÊÓÆµ F8
Devices Set-up ´ò¿ªÏµÍ³É豸ÉèÖô°¿Ú Shift + Q
Devices Show Panels ÏÔʾ¸÷ÖÖÉèÖõİ´Å¥Ãæ°å
Devices 9-Pin Device 1 ´ò¿ªµÚÒ»¸ö9ÕëÉ豸ÉèÖô°¿Ú
Devices 9-Pin Device 2 ´ò¿ªµÚÒ»¸ö9ÕëÉ豸ÉèÖô°¿Ú
Devices VST Master Set-up ´ò¿ªVSTÖ÷Êä³öÉèÖô°¿Ú Alt + Q
Devices ReBirth Audio ReWireÒôƵµÄÉèÖà Alt + R
Devices Plug-in Information ÒôƵ²å¼þµÄÐÅÏ¢¿ØÖÆ´°¿Ú
Media Import Medium µ¼ÈëÒ»¸öϵͳ֧³ÖýÌåÎļþ
Media New Version Ϊһ¸öýÌåÎļþ½¨Á¢Ò»¸öеÄÎĵµ
Media Converter ת»»ÎļþµÄ¸ñʽ»òÆäËüÖ¸Êý
Media Conform Files
Media Check Files ²é¿´ÎĵµµÄÐÅÏ¢
Media Remove Missing Files ɾ³ýÒÅʧµÄÎļþ
Media Create Folder ½¨Á¢Ò»¸öеÄÎļþ¼Ð
Media Empty Trash Çå¿ÕNuendoµÄ»ØÊÕÕ¾
Media Remove Unused Media Çå³ý²»ÓõÄýÌåÎļþ
Media Prepare Archive ´ò°üÒôƵÎļþµ½Ò»¸öÎļþ¼Ð
Media Insert into Project at Origin ½«ÒôƵÎļþµ¼Èëµ½Ô­À´µÄʱ¼äλÖà
Media Insert into Project at Cursor ½«ÒôƵÎļþµ¼Èëµ½µ±Ç°²¥·ÅÖ¸ÕëλÖà
Media Insertinto Project at Timecode °´Ê±¼äÂ뽫ÒôƵÎļþµ¼Èëµ½ÏîÄ¿ÖР
Media Find In Project ÔÚÏîÄ¿Îļþ¼ÐÖвéÕÒ
Media Find ²éÕÒ
Media Set Record Folder É趨¼ÒôÒôƵÎļþ´æ·ÅµÄĿ¼
Media Reconstruct ÖØ½¨
Media Update Origin
File New Library ½¨Ò»¸öеÄËØ²Ä¿â Alt + N
File Open Library ´ò¿ªÒ»¸öÒÑÓеÄËØ²Ä¿â Alt + O
File Import Audio file µ¼ÈëÒôƵÎļþ Shift + O
File Import Video file µ¼ÈëÊÓÆµÎļþ Shift + V
File Import Audio from Video ´ÓÊÓÆµÎļþÖÐץȡÒôƵ
File Replace Audio in Video file Ìæ´úÊÓÆµÎļþÖеÄÒôƵ
File Import Cubase Song µ¼ÈëCubase SongÎļþ
File Import MIDI File µ¼ÈëMIDIÎļþ
File Export MIDI File ½«MIDI¹ìµ¼³öΪMIDIÎļþ
File Import from Audio CD ´ÓCDÉÏץȡÒôƵ Ctrl+Alt+O
File Import OMF µ¼ÈëOMF
File Export OMF µ¼³öΪOMF
File Import OpenTL µ¼ÈëOpenTLÎļþ
File Export OpenTL µ¼³öOpenTLÎļþ
File Import Premiere µ¼ÈëPremiereÎļþ
File Export Audio Mixdown µ¼³öËùÓÐÒôƵ¹ìµÄ»ìÒôÁ½¹ìÎļþ
File Save As Template µ±×öÄ£°å±£´æ
File Clean-up ϵͳÇåÁã
File Save Pool ±£´æPoolµÄÎļþÐÅÏ¢
File Import Pool µ¼ÈëÒѱ£´æµÄPoolµÄÎļþÐÅÏ¢
File Export Pool µ¼³öPoolµÄÎļþÐÅÏ¢
File Print ´òÓ¡¹ìµ¥
File New н¨Ò»¸öÏîÄ¿Îļþ Ctrl + N
File Open ´ò¿ªÒ»¸öÏîÄ¿ Ctrl + O
File Close ¹Ø±Õµ±Ç°µÄÏîÄ¿ Ctrl + W
File Save ±£´æµ±Ç°ÏîÄ¿ Ctrl + S
File Save New Version Ϊµ±Ç°ÏîÄ¿±£´æÒ»¸öеİ汾 Ctrl + Alt+ S
File Save As ÏîÄ¿Áí´æÎª Ctrl + Shift + S
File Revert ÏîÄ¿»Øµ½×îºóÒ»´Î±£´æµÄ״̬ Alt + R
File Quit Í˳öNuendo Ctrl + Q
File Preferences ´ò¿ªPreferencesÉèÖô°¿Ú Alt + P
File Key Commands ¿ì½Ý¼üÉèÖô°¿Ú Alt + K
File Page Set-up ¹ìµ¥´òÓ¡ÉèÖà
Project Remove Track ɾȥµ±Ç°¹ì Ctrl+Shift+Del
Project Open Pool ´ò¿ªPool´°¿Ú Ctrl + P
Project Open Markers ´ò¿ª±ê¼Çʼþ´°¿Ú Ctrl + M
Project Open Master Track ´ò¿ª ÏîÄ¿Ëٶȱ仯´°¿Ú Ctrl + T
Project Open Browser ´ò¿ªÏîÄ¿ÐÅÏ¢ä¯ÀÀ´°¿Ú Ctrl + B
Project Set-up ÏîÄ¿×ÜÌåÐÅÏ¢ÉèÖà Shift + S
Project Beat Calculator ÏîÄ¿ËٶȼÆËãÆ÷ Alt+C
Project Auto Fades Settings ×Ô¶¯µ­Èëµ­³ö²ÎÊýÉèÖô°¿Ú Ctrl+Alt+A
Project Open Track Sheet ´ò¿ª¹ìµ¥´°¿Ú
Audio Detect Silence ¼ì²âÒôƵʼþÌõÖÐûÓÐÉùÒôµÄÇøÓò
Audio Crossfade ½»*µ­Èëµ­³ö X
Audio Remove Fades Çå³ýËù×öµÄµ­Èëµ­³ö´¦Àí Ctrl+Shift+F
Audio Open Fade Editors ´ò¿ªµ­Èëµ­³ö²ÎÊý±à¼­Æ÷
Audio Open Process History ´ò¿ªÒôƵ´¦ÀíµÄ²Ù×÷¼Ç¼ Shift+H
Audio Freeze Edits Çå³ýÒôƵ´¦ÀíµÄ²Ù×÷¼Ç¼
Audio Bounce ºÏ²¢ËùÑ¡µÄÒôƵʼþÌõΪһ¸öÎļþ ¾äºÅ
Audio Minimize File ×îС»¯Îļþ
Audio Find Selected in Pool ÔÚPoolÀï²éÕÒËùÑ¡µÄÒôƵʼþ Ctrl + F
Audio Event as Region
Audio Events from Regions
Audio Create Regions
Audio Events to Part
Audio Dissolve Part
Audio To Origin
Audio Sync Point To Cursor
Audio Adjust Fades to Range   A
Transport Panel ÏÔʾ¿ØÖÆÃæ°å F2
Transport Play from Selection Start ´ÓËùÑ¡µÄʱ¼äµÄ¿ªÊ¼Î»Öò¥·Å
Transport Play from Selection End ´ÓËùÑ¡µÄʱ¼äµÄ½áÊøÎ»Öò¥·Å
Transport Play to Selection Start ²¥·Åµ½ËùÑ¡¿ªÊ¼Î»Öà
Transport Play to Selection End ²¥·Åµ½ËùÑ¡½áÊøÎ»Öà
Transport Play Selection Range ²¥·ÅËùÑ¡µÄ·¶Î§ Alt + Space
Transport Locate Next Event ½«Ö¸Õ붨λÏÂһʼþÌõµÄ¿ªÊ¼Î»Öà N
Transport Locate Previous Event ½«Ö¸Õ붨λǰһʼþÌõµÄ¿ªÊ¼Î»Öà B
Transport Locators to Selection ×óÓÒÖ¸Õ붨λËùÑ¡·¶Î§µÄ¿ªÊ¼ºÍ½áÊø P
Transport Locate Selection ½«Ö¸Õ붨λËùÑ¡·¶Î§µÄ¿ªÊ¼Î»Öà L
Transport Loop Selection Ñ­»·²¥·ÅËùÑ¡·¶Î§ Shift + G
Transport Start ÔÚµ±Ç°Ö¸ÕëλÖò¥·Å Enter
Transport Stop Í£Ö¹²¥·Å Pad 0
Transport Start/Stop ²¥·Å/Í£Ö¹ Space
Transport Start/Stop Preview
Transport Record ¿ªÊ¼Â¼Òô Pad *
Transport Rewind Ïòºóµ¹´ø Pad -
Transport Forward Ïòǰ½ø´ø Pad +
Transport Return to Zero ½«Ö¸Õë»Øµ½Áãµã Pad . (point)
Transport Go to End ½«Ö¸Õëµ½½áÊøµã
Transport Cycle ÔÚ×óÓÒÖ¸ÕëÖ®¼ä²¥»·²¥·Å Pad /
Transport Auto Punch In ×Ô¶¯ÇÐÈë¼Òô I
Transport Auto Punch Out ×Ô¶¯Í˳ö¼Òô״̬ O
Transport Nudge Up ÒÔ×îСʱ¼äֵΪµ¥Î»Ç°½ø Ctrl + Pad +
Transport Nudge Down ÒÔ×îСʱ¼äֵΪµ¥Î»µ¹´ø Ctrl + Pad -
Transport Restart ÖØÐ¿ªÊ¼
Transport To Left Locator ²¥·ÅÖ¸Õëµ½×óµã Pad 1
Transport To Left Locator ²¥·ÅÖ¸Õëµ½×óµã Shift + 1
Transport To Right Locator ²¥·ÅÖ¸Õëµ½ÓÒµã Pad 2
Transport To Right Locator ²¥·ÅÖ¸Õëµ½ÓÒµã Shift + 2
Transport To Marker 3 ²¥·ÅÖ¸Õëµ½±ê¼Ç3 Pad 3
Transport To Marker 3 ²¥·ÅÖ¸Õëµ½±ê¼Ç3 Shift + 3
Transport To Marker 4 ²¥·ÅÖ¸Õëµ½±ê¼Ç4 Pad 4
Transport To Marker 4 ²¥·ÅÖ¸Õëµ½±ê¼Ç4 Shift + 4
Transport To Marker 5 ²¥·ÅÖ¸Õëµ½±ê¼Ç5 Pad 5
Transport To Marker 5 ²¥·ÅÖ¸Õëµ½±ê¼Ç5 Shift + 5
Transport To Marker 6 ²¥·ÅÖ¸Õëµ½±ê¼Ç6 Pad 6
Transport To Marker 6 ²¥·ÅÖ¸Õëµ½±ê¼Ç6 Shift + 6
Transport To Marker 7 ²¥·ÅÖ¸Õëµ½±ê¼Ç7 Pad 7
Transport To Marker 7 ²¥·ÅÖ¸Õëµ½±ê¼Ç7 Shift + 7
Transport To Marker 8 ²¥·ÅÖ¸Õëµ½±ê¼Ç8 Pad 8
Transport To Marker 8 ²¥·ÅÖ¸Õëµ½±ê¼Ç8 Shift + 8
Transport To Marker 9 ²¥·ÅÖ¸Õëµ½±ê¼Ç9 Pad 9
Transport To Marker 9 ²¥·ÅÖ¸Õëµ½±ê¼Ç9 Shift + 9
Transport Locate Next Marker ²¥·ÅÖ¸Õëµ½ÏÂÒ»¸ö±ê¼Ç Shift + N
Transport Locate Previous Marker ²¥·ÅÖ¸Õ뵽ǰһ¸ö±ê¼Ç Shift + B
Transport Play to Next Marker ´ÓÏÂÒ»¸ö±ê¼Ç²¥·Å
Transport Set Left Locator ½«µ±Ç°²¥·ÅÖ¸ÕëÉèÖÃΪ×óµã Ctrl + Pad 1
Transport Set Left Locator ½«µ±Ç°²¥·ÅÖ¸ÕëÉèÖÃΪ×óµã Ctrl + 1
Transport Set Right Locator ½«µ±Ç°²¥·ÅÖ¸ÕëÉèÖÃΪÓÒµã Ctrl + Pad 2
Transport Set Right Locator ½«µ±Ç°²¥·ÅÖ¸ÕëÉèÖÃΪÓÒµã Ctrl + 2
Transport Set Marker 3 ½«µ±Ç°²¥·ÅÖ¸ÕëÉèÖÃΪ±ê¼Çµã3 Ctrl + Pad 3
Transport Set Marker 3 ½«µ±Ç°²¥·ÅÖ¸ÕëÉèÖÃΪ±ê¼Çµã3 Ctrl + 3
Transport Set Marker 4 ½«µ±Ç°²¥·ÅÖ¸ÕëÉèÖÃΪ±ê¼Çµã4 Ctrl + Pad 4
Transport Set Marker 4 ½«µ±Ç°²¥·ÅÖ¸ÕëÉèÖÃΪ±ê¼Çµã4 Ctrl + 4
Transport Set Marker 5 ½«µ±Ç°²¥·ÅÖ¸ÕëÉèÖÃΪ±ê¼Çµã5 Ctrl + Pad 5
Transport Set Marker 5 ½«µ±Ç°²¥·ÅÖ¸ÕëÉèÖÃΪ±ê¼Çµã5 Ctrl + 5
Transport Set Marker 6 ½«µ±Ç°²¥·ÅÖ¸ÕëÉèÖÃΪ±ê¼Çµã6 Ctrl + Pad 6
Transport Set Marker 6 ½«µ±Ç°²¥·ÅÖ¸ÕëÉèÖÃΪ±ê¼Çµã6 Ctrl + 6
Transport Set Marker 7 ½«µ±Ç°²¥·ÅÖ¸ÕëÉèÖÃΪ±ê¼Çµã7 Ctrl + Pad 7
Transport Set Marker 7 ½«µ±Ç°²¥·ÅÖ¸ÕëÉèÖÃΪ±ê¼Çµã7 Ctrl + 7
Transport Set Marker 8 ½«µ±Ç°²¥·ÅÖ¸ÕëÉèÖÃΪ±ê¼Çµã8 Ctrl + Pad 8
Transport Set Marker 8 ½«µ±Ç°²¥·ÅÖ¸ÕëÉèÖÃΪ±ê¼Çµã8 Ctrl + 8
Transport Set Marker 9 ½«µ±Ç°²¥·ÅÖ¸ÕëÉèÖÃΪ±ê¼Çµã9 Ctrl + Pad 9
Transport Set Marker 9 ½«µ±Ç°²¥·ÅÖ¸ÕëÉèÖÃΪ±ê¼Çµã9 Ctrl + 9
Transport Input Position ÉèÖõ±Ç°µÄ²¥·ÅÖ¸Õëʱ¼äλÖà Shift + P
Transport Input Left Locator ÉèÖÃ×óµãÖ¸Õëʱ¼äλÖà Shift + L
Transport Input Right Locator ÉèÖÃÓÒµãÖ¸Õëʱ¼äλÖà Shift + R
Transport Insert Marker ´òÈëÒ»¸ö±ê¼Çµã Insert
Transport Metronome Set-up ½ÚÅÄÆ÷²ÎÊýÉèÖà Alt+M
Transport Metronome On ´ò¿ª½ÚÅÄÆ÷ C
Transport Sync Online ¿ªÆôͬ²½ T
Transport Sync Set-up ͬ²½²ÎÊýÉèÖà Shift+T
Transport Edit Mode ÖÁ±à¼­Ä£Ê½
Transport Use Pre/Post-Roll ʹÓÃPre/Post-RollÖµ ¡®
Video Extract Audio ´ÓÊÓÆµÖнâ³öÒôƵ¹ì
Video Write Audio ½«ÒôƵдÈëµ½ÊÓÆµ
MIDI Quantize Á¿»¯ Q
MIDI Quantize Set-up Á¿»¯²ÎÊýÉèÖà
MIDI Quantize Lengths Á¿»¯µ¥Î»ÉèÖà
MIDI Quantize Ends
MIDI Undo Quantize È¡ÏûÁ¿»¯
MIDI Freeze Quantize ʹÁ¿»¯²Ù×÷ÎÞ·¨È¡Ïû
MIDI Fixed Lengths
MIDI Legato
MIDI Delete Doubles ɾȥ˫Òô
MIDI Delete Controllers ɾȥMIDI¿ØÖÆÐÅÏ¢
MIDI Transpose ¶ÔMIDIʼþ½øÐÐÉý½µµ÷
MIDI Velocity
MIDI Fixed Velocity
MIDI Delete Notes
MIDI Dissolve Part
MIDI Reset
MIDI Cycle Record Mode: Merge Ñ­»·MIDI¼Òôģʽ£ººÏ²¢
MIDI Cycle Record Mode: Overwrite Ñ­»·MIDI¼Òôģʽ£ºÌæ´ú
MIDI Merge Record Parts ºÏ²¢Â¼ÒôµÄʼþÌõ
MIDI Auto Quantize in Record ×Ô¶¯Á¿»¯Ëù¼µÄMIDI
Nudge Start Left ½«ËùÑ¡µÄ·¶Î§¿ªÊ¼Î»ÖÃÑÓÉìµ½×ó±ßÒ»¸öµ¥Î» Ctrl + Left Arrow
Nudge Start Right ½«ËùÑ¡µÄ·¶Î§¿ªÊ¼Î»ÖÃÑÓÉìµ½ÓÒ±ßÒ»¸öµ¥Î» Ctrl + Right Arrow
Nudge End Left ½«ËùÑ¡µÄ·¶Î§½áÊøÎ»ÖÃÑÓÉìµ½×ó±ßÒ»¸öµ¥Î» Alt + Left Arrow
Nudge End Right ½«ËùÑ¡µÄ·¶Î§½áÊøÎ»ÖÃÑÓÉìµ½ÓÒ±ßÒ»¸öµ¥Î» Alt + Right Arrow
Nudge Left ½«Ê¼þÌõÏò×óÒÆ¶¯Ò»¸öµ¥Î» Cl+Alt+Left Arrow
Nudge Right ½«Ê¼þÌõÏòÓÒÒÆ¶¯Ò»¸öµ¥Î» Cl+Alt+rightArrow
AddTrack Audio ¼ÓÈëÒ»¸öÒôƵ¹ìµÀ Alt + Z
AddTrack Group Channel ¼ÓÈëÒ»¸ö±à×é¹ìµÀ Alt + J
AddTrack MIDI ¼ÓÈëÒ»¸öMIDI¹ìµÀ Alt+·ÖºÅ
AddTrack Marker ¼ÓÈëÒ»¸ö±ê¼Ç¹ìµÀ Alt + W
AddTrack Master Automation ¼ÓÈëÒ»¸öÖ÷Êä³ö×Ô¶¯»¯ÐÅÏ¢¿ØÖƹìµÀ Alt + Q
AddTrack Plug-in Automation ¼ÓÈëÒ»¸öЧ¹ûÆ÷²ÎÊý¿ØÖƹì Alt + U
AddTrack Video ¼ÓÈëÒ»¸öÊÓÆµ¹ì Alt + I
AddTrack Multiple ¼ÓÈë¶à¸ö¹ìµÀ Alt + L
Process Acoustic Stamp Éùѧ»·¾³Ä£ÄâÒôƵ´¦Àí
Process Envelope °üÂçÏ߸ıäÒôƵ´¦Àí
Process Fade In µ­Èë
Process Fade Out µ­³ö
Process Gain ÔöÒæµ÷Õû
Process Merge Clipboard ºÏ²¢µ½¼ôÌù°å
Process Noise Gate ÔëÉùÃÅ
Process Normalize ÔöÒæ×î´ó»¯
Process Phase Reverse Ïàλ·´×ª
Process Pitch Shift ±äµ÷´¦Àí
Process Remove DC Offset
Process Reverse ·´×ª
Process Silence ¾²Òô´¦Àí
Process Stereo Flip
Process Time Stretch ʱ¼äÉìËõ´¦Àí
Analyze Spectrum Analyzer ƵÆ×
Analyze Statistics ÉùÒôÐÔÖʼÆËã
Window Layout New н¨Ò»¸ö´°¿ÚÔ¤Öà Ctrl + Pad 0
Window Layout Toggle Lock State   Alt + Pad 0
Window Layout Organize   W
Window Layout Layout 1 °´µÚÒ»¸ö´°¿ÚÔ¤ÖÃÏÔʾ Alt + Pad 1
Window Layout Layout 2 °´µÚ¶þ¸ö´°¿ÚÔ¤ÖÃÏÔʾ Alt + Pad 2
Window Layout Layout 3 °´µÚÈý¸ö´°¿ÚÔ¤ÖÃÏÔʾ Alt + Pad 3
Window Layout Layout 4 °´µÚËĸö´°¿ÚÔ¤ÖÃÏÔʾ Alt + Pad 4
Window Layout Layout 5 °´µÚÎå¸ö´°¿ÚÔ¤ÖÃÏÔʾ Alt + Pad 5
Window Layout Layout 6 °´µÚÁù¸ö´°¿ÚÔ¤ÖÃÏÔʾ Alt + Pad 6
Window Layout Layout 7 °´µÚÆß¸ö´°¿ÚÔ¤ÖÃÏÔʾ Alt + Pad 7
Window Layout Layout 8 °´µÚ°Ë¸ö´°¿ÚÔ¤ÖÃÏÔʾ Alt + Pad 8
Window Layout Layout 9 °´µÚ¾Å¸ö´°¿ÚÔ¤ÖÃÏÔʾ Alt + Pad 9
alt + ¿Õ¸ñ£ºÔÚÑ¡¶¨Ê¼þÌõµÄÇé¿öÏ»á×Ô¶¯´ÓÍ·²¥·Å
alt + up»òdown£¬¾ÍÊÇÉÏÏ·½Ïò¼ü£ºÔÚÑ¡¶¨Ê¼þÌõµÄÇé¿öÏ¿ɵ÷ÕûʼþÌõÕ­¿í£¨¿Éȫѡ±à¼­£©·½±ã£¡
alt ¼üµ¥»÷£º¿Õ°×´¦¿É±äΪ»­±Ê¹¤¾ß²¢½Ó׿¤»î²Ëµ¥ÅäºÏ¹â±ê¼ü½øÐмüÅ̲Ù×÷£¬´ËÍâalt+²Ëµ¥Ê××Öĸ¿ÉÖ±½Ó¼¤»îÏÂÀ­²Ëµ¥£¬ ÈçÖ¸ÕëÐü¸¡ÔÚʼþÌõÉϿɱäΪ¼ôµ¶¹¤¾ß
alt + R £º È«²¿Ê¼þ½«´¦ÓÚ¼¤»îAutomation״̬
alt + w £º È«²¿Ê¼þ½«´¦ÓÚ¼¤»îAutomationдÈë״̬
alt + x £º   ¿ÉÖ±½Ó´Ó±ê³ßÏß´¦ÇпªÊ¼þ£¨´ó¼Ò¶¼ÖªµÀ£©
shift + G £ºÔÚÑ¡¶¨Ê¼þÌõµÄÇé¿öÏ»á×Ô¶¯´ÓÕâ¸öʼþ¿ªÍ·²¥·Å
shift + C £º´ò¿ª/¹Ø±ÕʼþÌõÇ°ÃæµÄÑÕÉ«±ê¼Ç
shift + M £ºÑ¡Öлòµã»÷ʼþÌõ¾²Òô
shift +L»òR£ºÔÚ×ß´øÌõ¼¤»îµÄÇé¿öÏ¿ÉÉèÖòåÈëµÄʱ¼ä
ctrl + K£ºÑ¡ÖÐʼþ£¬Ïñ½¨Á¢Òô¹ì»òmidi¹ìÒ»ÑùÊäÈëÊýÖµ¾Í¿É°´ÊýÖµ¸´ÖÆ£¬Òª¶àµÄ»°±Èctrl+D ·½±ã
