µ¤ÄÃ|Dynaudio BM Compact mkIII ¼àÌýÒôÏä
ÓëËûÃǵÄÀ©Õ¹ÆµÂÊÏìÓ¦ºÍ¾«È·³ÉÏñ£¬µ¤Äà BM Compact MKIIIË«·ÖƵÓÐÔ´¹¤×÷ÊÒ¼àÌýÒôÏ䣬ÒÔ׼ȷ£¬ÎÞÎóµØÔÙÏÖÒôƵÐźš£½ô´ÕµÄÉè¼Æ£¬²ÉÓÃÁË5.7¡°µÍÒôµ¥ÔªºÍÒ»¸ö1.1¡±µÄ¸ßÒôµ¥ÔªË«¹¦·Å100Íß¡£³ýÁËXLRºÍ²»Æ½ºâRCAÊäÈ룬BM Compact MKIIIÓÐÒ»¸öÈÃÄãÇáËɵ÷½ÚÒôÏäµ½ÄãµÄ·¿¼ä·½±ã¿ØÖÆ¡£ËüÉõÖÁ»¹´øÓÐÒ»¸öÑïÉùÆ÷IsoAcoustic´ú±íÁ˵Ķ¨Î»ºÍ¼õÕð¡£
These Little Monitors Tell You the Truth!
With their extended frequency response and precise imaging, Dynaudio&££39;s BM Compact mkIII two-way active studio monitors are engineered to reproduce your audio signal with unerring accuracy. The compact design incorporates a 5.7" woofer and a 1.1" tweeter biamped with 100 watts. In addition to XLR and unbalanced RCA inputs, the BM Compact mkIII has handy controls that let you easily tune the speakers to your room. It even comes with an IsoAcoustic speaker stand for optimal positioning and decoupling. Many of the Sales Engineers at Sweetwater rely on Dynaudio monitors to tell them the truth - and you can, too.
Dynaudio BM Compact mkIII 2-way Active Monitors at a Glance:
Cutting-edge technology and craftsmanship, for superior performance
Dynaudio knows what they&££39;re doing
Dynaudio&££39;s BM Compact mkIII gives you a well-defined sweet spot with reduced room reflections. Handcrafted aluminum drivers, updated amplification, and cutting-edge high-frequency waveguide technology join forces to give you a monitor with truly impressive accuracy, frequency response, dynamic range, and max SPL. The addition of high-, mid-, and low-frequency filters, as well as a highpass filter option, gives you all of the flexibility you need to tune your speakers to your room or to combine them with a subwoofer. If you&££39;re looking for a set of nearfield monitors that will tell you the truth about your program material, then you need to grab a pair of Dynaudio BM5A MKIIs!
With over 35 years of experience building speaker drivers, Dynaudio knows what goes into a great monitor speaker. Add to that 20-plus years of producing professional monitors for top studios, and you have a company perspective that few pro audio manufacturers can match. Dynaudio&££39;s proprietary driver technologies produce monitors that are neutral and uncolored. This silky clarity, in combination with amazing dynamic capabilities, give working pros like you monitors that let you work marathon sessions without ear fatigue.
Dynaudio BM Compact mkIII 2-way Active Monitors Features:
Active nearfield monitor with pure aluminum voice coil 5.7" woofer and 1.1" dome tweeter
Impressive SPL, frequency response, and dynamic range
50W LF and 50W HF RMS Class D amplifier with DSP crossover
116dB SPL peak power output
Frequency response of 49Hz-24kHz
HF, MF, LF analog room filters allow flexible positioning
High pass filters at 60/80Hz for perfect subwoofer adaption
Input sensitivity switch (-10/+4dB range)
XLR and RCA inputs give you setup flexibility
Bundled with IsoAcoustics ISO-L8R155 speaker stand for decoupling and proper angling
Precision made in Denmark
Hear the truth, with Dynaudio BM Compact mkIII monitors!
Tech Specs
Powered
Yes
Power Configuration
Bi-amped
LF Driver Size
5.7"
LF Driver Type
Cone
LF Driver Material
Thermo Formed MSP
HF Driver Size
1"
HF Driver Type
Soft Dome
LF Driver Power Amp
50W
HF Driver Power Amp
50W
Total Power
100W
Frequency Range
49Hz-24kHz
Crossover Frequency
12dB/octave @ 2100Hz
Maximum Peak SPL
116dB SPL @ 1m
Enclosure Type
Ported
Input Types
1 x XLR, 1 x RCA
Height
10.2"
Width
6.7"
Depth
7.6"
Weight
11.9 lbs.
ÆÀÂÛÁÐ±í£¨1£©
µ¤ÄÃ|Dynaudio BM Compact mkIII ¼àÌýÒôÏä ¡­¡­£¿
2007-8-10 10:24:22 »Ø¸´
