Sample Logic Electro City KONTAKT
ELECTRO CITYÊÇÒ»¸ö¶¯Ì¬µÄ½Ú×àÅÅÐòºÍЧ¹ûÒýÇæ£¬°éËæ×ÅÒ»¸öÊÀ½ç¼¶µÄÑ»·¿â£¬·Ç³£ÊʺÏËùÓÐÀàÐ͵ĵç×ÓÒôÀÖÖÆ×÷¡£ ELECTRO CITY²ÉÓÃNative InstrumentsµÄ¹¤Òµ±ê×¼KONTAKT PLAYERƽ̨£¬Îª¹µ²Û¶¨ÒåÁ˵ç×ÓÒôÀÖµÄδÀ´£¬²¢ÖØÐ¶¨ÒåÁËÈçºÎ²úÉúÓнÚ×àµÄÐýÂɺÍÐýÂÉ¡£Í¨¹ýÀûÓÃSample LogicµÄRHYTHMOLOGYÒýÇæµÄÇ¿´ó¹¦ÄܺÍÁé»îÐÔ£¬ELECTRO CITY½«ÎªÄúµÄÉùÒôÌṩ¶¯Á¦£¬½«ÆäÔËË͵½¸ü¸ß²ã´Î£¡ ELECTRO CITYÓµÓÐÎÞÏ޵Ĵ´ÔìÁ¦£¬ÈÚºÏÁËËùÓеĵçÓ°£¬ºÏ³É£¬ industrial, trap, house, dubstep, EDM, trance, techno, breakbeat,µÈµÈ¡£´Ó×ÖÃæÉÏ¿´£¬ÊýÒÔǧ¼ÆµÄÑ»·ºÍÔ¤ÉèÓëÒôƵÒýÇæÏ࿹ºâ£¬Ê¹µÃELECTRO CITY³ÉΪÈËÃÇÉú²úµç×ÓÒôÀÖËùÐèµÄ×îºóÒ»¸öÑ»·²¥·ÅÆ÷µÄ½Ú×àÒýÇæ¡£
Å䱸ÁËÖ±¹ÛµÄʵʱÉùÒôÕûÐοØÖÆ£¬Electro CityÒýÇæºÍ½Ó¿ÚÌṩÁËÒ»¸öÏêϸµÄ¶¨ÖÆÆ½Ì¨¡£Ã¿¸öÑ»·Ô´±»·Ö³É½Ú×àÆ¬¶Î£¬Ã¿¸ö½Ú×àÆ¬¶Î¿ÉÒÔ±»ÅÅÐò²¢ÖØÐÂÅÅÐò³ÉÈκλطÅ˳Ðò£¬·½Ïò£¬Ë³ÐòºÍ×éºÏ¡£Ã¿¸öƬ¶ÎÒ²¿ÉÒÔʹÓÃÄÚÖõľ²Ì¬Ð§¹û£¨Èç¶ÏÐø£¬ÒƵ÷£¬µ¹×ª£¬ÒôÁ¿ºÍÉùÏñ×Ô¶¯»¯µÈµÈ£©¶ÀÁ¢µØ½øÐÐÓ°Ïì¡£ÕâЩƬ¶ÎÒ²¿ÉÒÔʹÓÃÈȲå°Î¶¯Ì¬Ð§¹û¶¯»À´Ó°Ï죬ËùÓÐÕâЩ¶¼¹¹³ÉÑ»·ÐòÁС£Ã¿¸öЧ¹ûÄ£¿é¿ÉÒÔ°´ÕÕÿ¸ö²½Öè/Ƭ¶Î½øÐÐÅÅÐò£¬»òÕßÉèÖÃΪÓû§¶¨ÒåµÄËÙ¶È·Ö±æÂÊ¡£¿ÉÒÔͨ¹ý¼¤»îºÍÈ¥¼¤»îËùÓÐËĸö»·Â·ºËÐĵĶÎÀ´½«»·Â·ÈÚºÏÔÚÒ»Æð¡£´ËÍ⣬Electro City»¹ÍêÈ«¼æÈÝNative Instruments NKS±ê×¼£¬ÕâÊÇÒ»¸öÀ©Õ¹µÄ²å¼þ¸ñʽ£¬¿ÉÒÔÓëNIµÄKontrol¼üÅÌ¿ØÖÆÆ÷ºÍMaschineÓ²¼þ½øÐи߼¶¼¯³É¡£ Electro City°üÀ¨Ê¹ÓÃKontaktÎÞËðÑùÆ·´æ´¢Ñ¹Ëõ£¨5GBδѹËõ£©µÄ1010¸ö»·Â·Ô´£¬487¸ö»·Â·ºËÐÄ£¬325¸ö¶àºËÒÇÆ÷ºÍ1.75¸öѹËõÑù±¾¿â¡£ËùÓÐÑùÆ·¶¼ÒÔ44.1kHz / 24λ´«Êä¡£
ϸ½Ú£º
³¬¹ý1,800¸öÉùÒôÔ¤É裬ÓжàÖÖ×éºÏ
ËĸöÑ»·ºËÐÄÒýÇæ
ÈȲå°ÎЧ¹ûÁ´¼¼Êõ
ÍêÈ«¡°¿ÉËæÒ⡱µÄ½çÃæ
ÊýÊ®¸ö¿É¶¨ÖƵÄЧ¹ûÔ¤Éè
Native InstrumentsµÄNKSºÍMaschine×¼±¸¾ÍÐ÷
ÔÎÄ
ELECTRO CITY is a dynamic rhythmic sequencing and effects engine accompanied by a world-class loop library ¡ª perfect for all styles of electronic music production. Powered by Native Instruments¡¯ industry-standard KONTAKT PLAYER platform, ELECTRO CITY generates grooves that define the future of electronic music and redefine how rhythmic beats and melodic loops are produced. By harnessing the power and flexibility of Sample Logic¡¯s RHYTHMOLOGY engine, ELECTRO CITY will energize your sound, transporting it to the next level! ELECTRO CITY possesses limitless creativity, fusing together all things cinematic, synth, industrial, trap, house, dubstep, EDM, trance, techno, breakbeat, and much more. Literally, thousands of loops and presets are paired up with an audio engine that defies definition, making ELECTRO CITY the last loop player and groove engine anyone will ever need for producing electronic music.
Equipped with intuitive real-time sound-shaping controls, the Electro City engine and interface provide a platform for detailed customization. Every loop source is divided into rhythmic segments, each of which can be ordered and re-ordered into any playback order, direction, sequence, and combination. Each segment can also be affected independently using built-in static effects, such as stutter, transpose, reverse, volume and pan automation, etc. These segments can also be affected using hot-swappable dynamic effects animation, all of which form part of the loop sequence.Each effect module can be sequenced on a per step/segment basis and or set to user-defined tempo resolutions. The loops can be fused together through activating and deactivating segments across all four loops cores. In addition, Electro City is fully compatible with the Native Instruments NKS standard, an extended plug-in format allowing advanced integration with NI¡¯s Kontrol keyboard controllers, and Maschine hardware. Electro City includes 1010 loop sources, 487 loop cores, 325 multi core instruments, and a 1.75 compressed sample library using Kontakt¡¯s lossless sample storage compression (5GB uncompressed). All samples are delivered at 44.1kHz/24-bit.
Details:
Over 1,800 sound presets, with many combinations
Four loop core engine
Hot-swappable effects chain technology
Fully ¡°randomizable¡± interface
Dozens of customizable effects presets
Native Instruments¡¯ NKS and Maschine ready
ÏÂÔØµØÖ·£ºÓοͣ¬Èç¹ûÄúÒª²é¿´±¾ÌûÒþ²ØÄÚÈÝÇë »Ø¸´
Sample Logic Electro City KONTAKT | 1.6 Gb
