н»Ïì¿Ö¾åÖ¢¶þ´úProjectSAM Symphobia 2 v1.6 KONTAKT
ÒôÔ´
²úÆ·Ãû³Æ :        н»Ïì¿Ö¾åÖ¢¶þ´úProjectSAM Symphobia 2 v1.6 KONTAKT
¹ÙÍø£ºhttps://www.projectsam.com/products/symphobia-series/1390
ProjectSAM Symphobia 2 v1.6 | 23.75 GB
¡¡¡¡symphobia 2ÊÇÔ­symphobia¹ãÊÜºÃÆÀµÄÐø¼¯¡£ËùÓÐеĹÜÏÒÀÖЧ¹û£¬´óÁ¿ÐÂÏʵĺ͹ÄÎèÈËÐĵĽ»ÏìЧ¹û£¬¶À¼ÒÁ¬ÒôºÏ×àÕæÊµÁ¬×à¹ý¶É£¬·´ÎÚÍаîIIIºÍÒ»¸öȫеĽçÃæ¡£2ÊÇÐÂsymphobiaÏÔ¶øÒ×¼ûµÄ³ýÁËÈκεçÓ°µÄsymphobiaϵÁУ¬ÓÎÏ·»òµçÊÓ×÷Çú¼Ò¡£
¡¡¡¡symphobia 2²»°üÀ¨symphobia 1¡£ÕâÁ½¸ö¿â¶¼ÊǶÀÒ»ÎÞ¶þµÄ²úÆ·£¬¾ßÓжÀÌØµÄÄÚÈÝ¡£
¡¡¡¡Èç¹ûÄã×Ô¼ºµ±³õsymphobia£¬symphobia 2½«´ó´óÀ©´óÄãµÄ¿ÉÄÜÐÔ¡£µÈµÈ£¬2µÄsymphobiaÏÒÀÖ²¿·ÖÔö¼ÓÁËÖ÷ÒªºÍ´ÎÒªµÄDXF²üÒô£¬²»Í¬³¤¶ÈµÄ½¥Ç¿½¥Èõ½¥Ç¿£¬ÐµĺÍеÄspiccatos¡£Èç¹ûÄãϲ»¶µÄЧ¹û£¬ÔÚÔ­À´µÄsymphobia£¬ÄãÒª°®µÄÈËÔÚsymphobia 2£¡ÓÐÁË»ù´¡£¬ÎÒÃÇ¿ÉÒÔ½øÒ»²½Ì½Ë÷¹ÜÏÒÀÖ¶ÓµÄЧ¹û£¬Ñ°ÕÒÓÐȤµÄÐÂÉùÒôºÍ¸ü¾ßÌåµÄ¼¼ÇÉ¡£symphobia 2»¹ÌṩÁ˲߻®×éÀÖÆ÷Á¬×à¹ý¶É·¿¡£¸÷ÖÖ²»Í¬ÅÅÁеĺÏ×à±íÑÝʱ±»×¥»ñµÄʱ¼ä¼ä¸ô£¬Í¬Ê±»òÒô½×ÑÝ×࣬²¢¾«Ðı༭ºÍ½Å±¾¡£
Ö÷ÒªÌØµã£º
½»ÏìºÏ×àºÏ×à¼Òô·¿
ÐÐÒµµÚÒ»²ß»®µÄÁ¬×àºÏ×àÁ¬×à¹ý¶É·¿
¹ã·ºµÄ¶à¹Ø½ÚÌùƬ
еĹÄÎèÈËÐĵĽ»ÏìÀÖЧ¹û
26 GBµÄͼÊé¹ÝÔÚÖйúµÄѹËõ²ÉÑù¸ñʽ£¨35 GBµÄѹËõ£©
44.1 24λ
ÕæÕýµÄÒôÀÖÌü¼Òô
ʵʱ»ìºÏµÄÇ×ÃܺÍÎę̀»°Í²
kontakt 5Ðí¿ÉÖ¤°üÀ¨
Library Content:
Full Orchestrator
Powerful articulations by full, preseated orchestra
Strings with Woodwinds
Subtle strings with winds recorded together
Long Textures and Effects
Dark Textures
Rhythmic Textures
High Textures
Tonal Textures
Tutti Clusters
Short Hits and Rips
Orchestral hits, stabs, rips & swirls
Symphobian Stacks
Stacked, premixed orchestral effects
Dreamy Textures & Phrases
Tutti Chords
Individual sections
String Ensemble Extensions articulations
String Ensemble Effects
Violins with Violas articulations
Violoncelli articulations
Music String Phrases
Eight Player Horn Ensemble articulations
Horns with Trombones
Trumpet Octaves articulations
Flute with Piccolo articulations
Legato ensembles
Bass Clarinet & Contra Bassoon in Octaves
Basoon & Celli in Unison
Flutes & Clarinet in Unison
Flutes & Violins in Unison
Horns & Trombones in Unison
Horns & Violins & Violas in Unison
Celli & Doublebasses in Unison
Violins in Octaves
Legato solo instruments
Solo Flute
Solo Horn
Solo Low Whistle (in D scale)
Solo Uilleann Pipes (in D scale)
Dystopia sound design
Processed and mangled sounds taken from the Symphobia 2 recordings
Trio Ensemble Chords
Brass trio chords in maj, min & dim
String trio chords in maj, min & dim
Wind trio chords in maj, min & dim
Miscellaneous
Orchestra Tuning
Concert Hall Noise
Multis
22 inspiring Multis
Download detailed articulation list
2016 Edition Update:
Native Kontrol Standard support
Komplete Kontrol Light Guide support
Tighter audio edits for string staccatos and pizzicatos
Speed control on selected instruments
Sustain pedal control
Improved loading speed
Learnable CC controls (v.151)
Updated interface
On-screen tooltips
Free update for all existing users
Library specs:
51.0 GB audio pool (actual recordings)
25.5 GB on disk (compressed Kontakt format on disk)
44.1 kHz 24 bit audio format
System requirements:
Minimum Kontakt version: 5.5.1
Mac: OS X 10.9 or higher
Windows: 7 or higher
Minimum CPU: Intel Core 2 Duo
Supported plug-in interfaces: Stand-alone, VST, AU, AAX
Works with Kontakt (full version) and Kontakt Player (free version)
ÆÀÂÛÁÐ±í£¨4£©
н»Ïì¿Ö¾åÖ¢¶þ´úProjectSAM Symphobia 2 v1.6 KONTAKT ²»´í
2007-6-25 15:18:47 »Ø¸´
9794520 Â¥Ö÷
:loveliness: :handshake
2007-7-13 16:13:47 »Ø¸´
¶àл¥Ö÷·ÖÏíºÃ×ÊÔ´£¡
2020-6-24 10:56:33 »Ø¸´
¶àл¥Ö÷·ÖÏíºÃ×ÊÔ´£¡
2020-6-24 10:56:52 »Ø¸´
