Apogee Symphony I/O 16x16 ThunderBridgeÌ××°
Apogee&££39;s Symphony I/O 16x16 System + ThunderBridge Bundle equips your studio with the pristine audio quality, high channel counts, and the ultra-low latency you need for major-league pro studio work. Apogee packed 25 years of industry-leading digital audio expertise into their amazing-sounding Symphony I/O interface/converter. Combine that with Apogee&££39;s 16x16 Analog I/O Module and 64 channels of lightning-fast Thunderbolt (courtesy of ThunderBridge), and you&££39;ve got a convenient, high-performance, cost-saving solution for your Mac-based studio. Supercharge your setup with the Apogee Symphony I/O 16x16 System + ThunderBridge Bundle.
Apogee Symphony I/O 16x16 System + ThunderBridge Bundle at a Glance:
Symphony I/O - the base unit
16 channels of impeccable analog I/O - plus coax S/PDIF
Blazing-fast Thunderbolt performance
Apogee&££39;s uncompromising digital audio quality
The Symphony I/O comes as a single base unit. This unit features built-in Ethernet and USB output, as well as Symphony/Pro Tools HD PC-32 I/O - but no additional I/O. A pair of module bays lets you decide what additional I/O you need, allowing you to build the system you want. Choose from five different modules, each with a different assortment of analog and digital I/O. You can even add banks of Apogee&££39;s ultra-transparent microphone preamps! Each of the Symphony I/O&££39;s module cards offers Apogee&££39;s finest conversion technology, and the Symphony I/O itself sports enhanced C777 clocking for completely reliable jitter-free performance.
The Symphony 16x16 Analog I/O Module adds a 16 channels of analog inputs and outputs to your Apogee Symphony I/O on four 25-pin D-Sub connectors: two for input and two for output, each carrying eight balanced channels. You also get two channels of S/PDIF coax I/O (up to 192kHz) on RCA.
Apple&££39;s Thunderbolt connectivity has opened up a world of professional recording possibilities. Apogee&££39;s Symphony 64 | ThunderBridge is a 64-channel Thunderbolt connection for Apogee&££39;s Symphony I/O. On the back panel, you&££39;ll find two PC-32 ports for connection to Apogee interfaces, and two Thunderbolt ports that let you take advantage of the protocol&££39;s daisy-chain feature. From the second port, you can connect high-bandwidth Thunderbolt devices such as hard drives and DisplayPort monitors in parallel from a single Thunderbolt port on your Mac. A trim desktop unit, Symphony | 64 ThunderBridge will also connect X-Symphony-equipped AD-16X, DA-16X, and Rosetta Series converters to Thunderbolt Macs.
For more than two decades, Apogee has developed some of the finest pro audio technology, including the famous X-series and Rosetta series converters, the Big Ben master clock, the Trak2 mic preamps, and the Symphony PCI protocol. Now, they put all that experience into one amazing interface: the Symphony I/O. You get to choose the I/O, so you can get up to 32 channels of jaw-dropping AD/DA conversion set up for any DAW, including native DAWs such as Logic, Cubase, and Ableton Live, as well as Pro ToolswithHD! And standalone operation even lets you use the Symphony I/O with proprietary systems such as Pro Tools LE.
Apogee Symphony I/O 16x16 System + ThunderBridge Bundle Features:
Pristine audio quality, high channel counts, and ultra-low latency
This system includes:
Symphony I/O base unit
ThunderBridge 64-channel Thunderbolt module
Requirements for Mac OS X:
Thunderbolt-equipped Mac including MacBook Air, MacBook Pro, Mac Mini, and iMac
Mac OS X 10.7 or later
Optimize your Mac-based studio with Apogee&££39;s Symphony I/O System + ThunderBridge Bundle!
Tech Specs| Form Factor | Desktop/Rackmount | | Simultaneous I/O | 16 x 16 | | A/D Resolution | 24-bit/192kHz | | Built In DSP/FX | Yes | | Audio Input Types | 2 x 25-pin D-Sub | | Audio Output Types | 2 x 25-pin D-Sub | | Digital Input Types | S/PDIF (Coax) | | Digital Output Types | S/PDIF (Coax) | | Clock I/O | 1 x Word Clock (In/Out via BNC), 1 x Sync Loop (In/Out via BNC) |
