Vegas pro8.0 Video ¿ì½Ý¼ü
Create new project ½¨Á¢Ð·½°¸ Ctrl+N
Exit Vegas Í˳öVegas Alt+F4
Open existing project ´ò¿ªÒÑ´æÔڵķ½°¸ Ctrl+O
Project properties ·½°¸ÌØÐÔ Alt+Enter
Save project ±£´æ·½°¸ Ctrl+S
Window view µ÷ÓÃÊÓ´°ÊÓͼ
ÃüÁî Èȼü
Set focus to track view Alt+0
Explorer µ¼³ö Alt+1
Trimmer ÐÞ¼ôÆ÷ Alt+2
Mixer »ìÒǫ̂ Alt+3
Edit Details ±à¼­Ï¸½Ú Alt+4
Media Pool ýÌå´æ´¢±í Alt+5
Video Preview ÊÓÆµÔ¤ÀÀ Alt+6
Transitions ת±ä Alt+7
Video FX ÊÓÆµÌؼ¼ Alt+8
Text/Backgrounds Îı¾/±³¾°£¨×ÖÄ»£© Alt+9
Plug-Ins ²å¼þ Ctrl+Alt+1
Next window ÏÂÒ»¸öÊÓ´° F6»òCtrl+Tab
Previous window ǰһ¸ö´°¿Ú
Shift+F6 »ò
Ctrl+Shift+Tab
Toggle focus between track list and timeline
ÔÚ¹ìµÀ±íÓëʱ¼äÏßÖ®¼ä½»Ìæ
Tab
ÔÚǰһ¹ìÓëÏÂÒ»¹ìÖ®¼äÇл»¡¡¡¡¡¡¡¡Alt+Shift+ÉÏ/ϼýÍ·¼ü
==========================Vegas Video ¿ì½Ý¼ü 2===========================
Edit ±à¼­ÃüÁî
ÃüÁî ¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡Èȼü
Cut selection ÇеôÑ¡ÔñÇø Ctrl+X»òShift+Delete
Copy selection ¿½±´Ñ¡ÔñÇø Ctrl+C»òCtrl+Insert
Paste Õ³Ìù Ctrl+V »ò Shift+Insert
Paste Insert ²åÈëÕ³Ìù Ctrl+Shift+V
Paste repeat ÖØ¸´Õ³Ìù Ctrl+B
Delete selection ɾȥѡÔñÇø Delete
Mix to new track »ìºÏµ½Ð¹ì Ctrl+M
Open in audio editor ÔÚÒôƵ±à¼­Æ÷Öдò¿ª Ctrl+E
Undo »Ö¸´ Ctrl+Z»òAlt+Backspace
Redo ÖØ×ö Ctrl+Shift+Z »òCtrl+Y
Split ·ÖÁÑ S
Trim/crop selected events ÐÝÕû/ÐÞ¼ô±»Ñ¡Ôñʼþ Ctrl+T
Rebuild Peaks ÖØÐ¼ÆË㲨ÐÎͼ F5
Normal tool Çл»µ½ÆÕͨ¹¤¾ß Ctrl+D
Cursor placement °²Öùâ±ê
ÃüÁî ¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡Èȼü
Center view around cursor °Ñ¹â±ê·ÅÖÃÔÚÊÓ´°ÖÐÐÄ Go to °Ñ¹â±ê·ÅÖõ½£¨¼ÆÊýÆ÷±ä³ÉÀ¶É«ºó£¬Ö±½ÓÔÚ¼ÆÊýÆ÷ÖÐÊäÈëʱ¼ä£© Ctrl+G
Go to beginning of selection or view (if no selection)
°Ñ¹â±ê·ÅÖõ½Ñ¡ÔñÇø»òÊÓ´°£¨Èç¹ûûÓÐÑ¡ÔñÇø£©µÄ¿ªÊ¼Î»Öã¬Home
Go to end of selection or view (if no selection)
°Ñ¹â±ê·ÅÖõ½Ñ¡ÔñÇø»òÊÓ´°£¨Èç¹ûûÓÐÑ¡ÔñÇø£©µÄ½áβλÖÃEnd
Go to beginning of project °Ñ¹â±ê·ÅÖõ½·½°¸µÄ¿ªÊ¼Î»Öà Ctrl+Home »òW
Go to end of project °Ñ¹â±ê·ÅÖõ½·½°¸µÄ½áβλÖà Ctrl+End»òE
Jump to opposite side of selection °Ñ¹â±êÌøÖõ½Ñ¡ÔñÇøµÄÁíÒ»±ß 5 (Êý×Ö¼ü)
==========================Vegas Video ¿ì½Ý¼ü 3===========================
Jump to marker # °Ñ¹â±êÌøÖõ½Ò»¸ö±ê¼ÇºÅÉÏ 0-9 keys (·ÇÊý×Ö¼ü)
Move left by grid marks °Ñ¹â±êÏò×óÌøÖõ½Ç°Ò»¸öÍø¸ñÏßÉÏ Page Up
Move right by grid marks °Ñ¹â±êÏòÓÒÌøÖõ½ºóÒ»¸öÍø¸ñÏßÉÏ Page Down
Move to previous marker °Ñ¹â±êÒÆ¶¯µ½Ç°Ò»¸ö±ê¼ÇÉÏ Ctrl+×ó¼ýÍ·¼ü
Move to next marker °Ñ¹â±êÒÆ¶¯µ½ÏÂÒ»¸ö±ê¼ÇÉÏ Ctrl+ÓÒ¼ýÍ·¼ü
Move to previous CD track °Ñ¹â±êÒÆ¶¯µ½Ç°Ò»¸öCD ¹ì Ctrl+Comma
Move to next CD track °Ñ¹â±êÒÆ¶¯µ½ÏÂÒ»¸öCD ¹ì Ctrl+¾äºÅ
Move to previous CD index or region
°Ñ¹â±êÒÆ¶¯µ½Ç°Ò»¸öCD Ë÷Òý»òƬ¶Î
Comma
Move to next CD index or region °Ñ¹â±êÒÆ¶¯µ½ÏÂÒ»¸öCD Ë÷Òý»òƬ¶Î ¾äºÅ
Move left to event edit points including fade edges
°Ñ¹â±êÒÆ¶¯µ½Ê¼þ±à¼­µã£¨°üÀ¨Ë¥¼õÏߵı߽çµã£©µÄ×ó±ß¡¡Ctrl+Alt+×ó¼ýÍ·¼ü
Move right to event edit points including fade edges
°Ñ¹â±êÒÆ¶¯µ½Ê¼þ±à¼­µã£¨°üÀ¨Ë¥¼õÏߵı߽çµã£©µÄÓұߡ¡Ctrl+Alt+ÓÒ¼ýÍ·¼ü
Nudge cursor on timeline °Ñ¹â±êÔÚʱ¼äÏßÉÏÒÆ¶¯ ×ó»òÓÒ¼ýÍ·¼ü
Move one frame left/right °Ñ¹â±êÏò×ó»òÏòÓÒÒÆ¶¯Ò»Ž¬ Alt+×ó»òÓÒ¼ýÍ·¼ü
Time selection commands ʱ¼äÑ¡ÔñÃüÁî
ÃüÁî¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡ Èȼü
Snap select to event edges °ÑÑ¡ÔñÇøÒ§ºÏµ½Ê¼þ±ß½çÉÏ Ctrl+Shift+Alt+×ó»òÓÒ¼ýÍ·¼ü
Select loop region Ñ¡ÔñҪѭ»·µÄƬ¶Î Ctrl+Q
Recover previous selection areas »Ö¸´ÏÈǰËùÑ¡ÔñÇøÓò Backspace
Select left by grid marks °´Íø¸ñÏßÏò×óÑ¡ÔñÇøÓò Shift+Page Up
Select right by grid marks °´Íø¸ñÏßÏòÓÒÑ¡ÔñÇøÓò Shift+Page Down
Make a selection during playback ÔڻطÅʱ±ê¼ÇÑ¡ÔñÇø I (Èëµã)ºÍO (³öµã)
Select to previous/next CD track Ñ¡ÔñǰһÌõ/ÏÂÒ»ÌõCD ¹ì Shift+Comma »ò Shift+¾äºÅ
Enter location for end of selection ¼üÈëÑ¡ÔñÇø½áβµãµÄλÖà Ctrl+Shift+G
Create time selection while dragging on an event
ÔÚÒ»¸öʼþÉÏÍÏקʱ²úÉúʱ¼äÑ¡ÔñÇø
Ctrl+Shift+ÓÃÊó±êÍÏ×§
Expand selection one frame °ÑÑ¡ÔñÇø°´Ò»Ž¬Ò»Ž¬µÄÀ©´ó Shift+Alt+×ó»òÓÒ¼ýÍ·¼ü
==========================Vegas Video ¿ì½Ý¼ü 4===========================
Playback and preview »Ø·ÅÓëÔ¤ÀÀ
ÃüÁî ¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡Èȼü
Start/Stop playback Æð¶¯/Í£Ö¹»Ø·Å Spacebar
Stop playback Í£Ö¹»Ø·Å Esc
Play from any window ´ÓÈÎÒâÒ»¸ö´°¿Ú»Ø·Å Ctrl+Spacebar»òF12
Pause ÔÝÍ£ Enter
Looped playback Ñ­»·»Ø·Å Q
Record ¼Òô Ctrl+R
Scrub playback ¹Î²Á»Ø·Å J, K, or L
Selectively prerender video Ñ¡ÔñÐÔµØÔÙÏÖÊÓÆµ Shift+M
Preview in player ÔÚ²¥·ÅÆ÷ÖÐÔ¤ÀÀ Ctrl+Shift+M
Build dynamic RAM preview ¹¹Öþ¶¯Ì¬RAN Ô¤ÀÀ Shift+B
Event selection ʼþÑ¡ÔñÇø
ÃüÁî ¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡Èȼü
Range select ·¶Î§Ñ¡Ôñ Shift+µã»÷µÚÒ»¸öºÍ×îºóÒ»¸öʼþ
Multiple select Ñ¡Ôñ¶à¸öƬ¶Î Ctrl+µã»÷µ¥¸öʼþ
Select all Ñ¡ÔñËùÓÐµÄ Ctrl+A
Unselect all ²»Ñ¡ÔñËùÓÐµÄ Ctrl+Shift+A
Event editing ʼþ±à¼­
ÃüÁî¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡ Èȼü
Move selected events right one pixel °Ñ±»Ñ¡ÔñʼþÏòÓÒÒÆ¶¯Ò»¸öÏñËØ Êý×Ö¼üÅÌ 6
Move selected events left one pixel °Ñ±»Ñ¡ÔñʼþÏò×óÒÆ¶¯Ò»¸öÏñËØ Êý×Ö¼üÅÌ 4
Move selected events up one track °Ñ±»Ñ¡ÔñʼþÏòÉÏÒÆ¶¯Ò»¹ì Êý×Ö¼üÅÌ 8
Move selected events down one track °Ñ±»Ñ¡ÔñʼþÏòÏÂÒÆ¶¯Ò»¹ì Êý×Ö¼üÅÌ 2
Move selected events right on grid °Ñ±»Ñ¡ÔñʼþÏòÓÒ°´Íø¸ñÏßÒÆ¶¯ Êý×Ö¼üÅÌ 6
Move selected events left on grid °Ñ±»Ñ¡ÔñʼþÏò×ó°´Íø¸ñÏßÒÆ¶¯ Ctrl+Êý×Ö¼üÅÌ4
Move selected events right by the project frame period
°´·½°¸Ž¬ÏòÓÒÒÆ¶¯±»Ñ¡Ôñʼþ
Alt+Êý×Ö¼üÅÌ6
==========================Vegas Video ¿ì½Ý¼ü 5===========================
Move selected events left by the project frame period
°´·½°¸Ž¬Ïò×óÒÆ¶¯±»Ñ¡Ôñʼþ¡¡Alt+Êý×Ö¼üÅÌ4
Move selected events by the first selected event's length
°´µÚÒ»¸ö±»Ñ¡ÔñʼþµÄ³¤¶ÈÒÆ¶¯±»Ñ¡Ôñʼþ¡¡Ctrl+Alt+4 »ò 6
Slip: move media within event without moving the event
»¬¶¯£ºÔÚʼþ·¶Î§Òƶ¯Ã½Ìå¶ø²»Òƶ¯Ê¼þ
Alt+ÓÃNormal edit¡¡tool ÍÏקýÌå
Slip trim: moves the media with the edge as it is trimmed
»¬¶¯ÐÞ¼ô£º¶ÔÒѱ»ÐÞ¼ôµÄýÌåÍÏ×§Æäǰºó±ßԵʹýÌåÒÆ¶¯
Alt+ÓÃNormal edit¡¡tool ÍÏקýÌåǰºó±ßÔµ
Trim adjacent: trims selected event ad adjacent event simultaneously
ÐÞÕûÅþÁ¬²¿Î»£ºÍ¬Ê±ÐÞÕûÁ½¸öÏàÁڵı»Ñ¡Ôñʼþ
Ctrl+Alt+Óá¡Normal edit tool¡¡ÍÏקýÌåǰºó±ßÔµ
Slide: trims both ends of event simultaneously
»¬¶¯£ºÍ¬Ê±ÐÞ¼ôÁ½¸öʼþ
Ctrl+Alt+ÓÃNormal edit toolÍÏקýÌå
Slide crossfade: moves crossfade
»¬¶¯½»²æµ­Èëµ­³ö£ºÒƶ¯½»²æµ­Èëµ­³ö
ÍÏקýÌ壬һ¸öýÌå¸ÇסÁíÒ»¸öý
Ìå
Stretch (compress) the media in the event while trimming
ÔÚÐÞÕûʱÀ­³¤£¨Ñ¹Ëõ£©Ê¼þÖеÄýÌå
Ctrl+ÓÃNormal¡¡edit tool ÍÏקʼþµÄ±ßÔµ
Select next take Ñ¡ÔñÏÂÒ»¹ì T
Select previous take Ñ¡Ôñǰһ¹ì Shift+T
Timeline ʱ¼äÏß
ÃüÁî¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡ Èȼü
New audio track еÄÒôƵ¹ì Ctrl+Q
New video track еÄÊÓÆµ¹ì Ctrl+Shift+Q
Enable/disable snapping ¼¤»î/ÆÁ±ÎÒ§ºÏ¹¦ÄÜ F8
Quantize to frames °´Ž¬Á¿»¯ Alt+F8
==========================Vegas Video ¿ì½Ý¼ü 6===========================
Snap to grid Ò§ºÏµ½Íø¸ñÏßÉÏ Ctrl+F8
Snap to markers Ò§ºÏµ½±ê¼ÇÉÏ Shift+F8
Ripple edit mode ²¨ÎƱ༭·½Ê½ Ctrl+L
Auto crossfade mode ×Ô¶¯½»²æµ­Èëµ­³öģʽ X
Normal tool Õý³£»¯¹¤¾ß Ctrl+D
Edit tool selection Ñ¡Ôñ±à¼­¹¤¾ß DºÍ Shift+D
Render to new track ºÏ²¢ÎªÐ¹ìµÀ£¨Ï൱ÓÚµ¼³öÃüÁ¡ªÒëÕߣ© Ctrl+M
Group selected events ½«±»Ñ¡ÖÐʼþ±à×é G
Ungroup selected events È¡Ïû±»Ñ¡ÖÐʼþ±à×é U
Clear group without deleting events Çå³ý±à×é¶ø²»É¾È¥Ê¼þ Ctrl+U
Select all events in group ÔÚ±à×éÖÐÑ¡ÔñÈ«²¿Ê¼þ Shift+G
Insert/show/hide track-volume envelope
²åÈë/չʾ/Òþ²Ø¹ìµÀÒôÁ¿°üÂçÏß¡¡V
Remove track-volume envelope È¥µô¹ìµÀÒôÁ¿°üÂçÏß Shift+V
Insert/show/hide track-panning envelope ²åÈë/չʾ/Òþ²Ø¹ìµÀÉùÏñ°üÂçÏß P
Remove track-panning envelope È¥µô¹ìµÀÉùÏñ°üÂçÏß Shift+P
Insert command marker ²åÈëÃüÁî±ê¼Ç C
Insert marker ²åÈë±ê¼Ç M
Insert region ²åÈëÆ¬¶Î R
Insert CD track region ²åÈëCD ¹ìµÀƬ¶Î N
Insert CD track index ²åÈëCD ¹ìµÀË÷Òý Shift+N
View ÊÓͼ
ÃüÁî Èȼü
Decrease height of all tracks ¼õСȫ²¿¹ìµÀ¸ß¶È Ctrl+Shift+ϼýÍ·¼ü
Increase height of all tracks Ôö¼ÓÈ«²¿¹ìµÀ¸ß¶È Ctrl+Shift+ÉϼýÍ·¼ü
Minimize all tracks ×îС»¯È«²¿¹ìµÀ¸ß¶È ¡® ¼ü
Set track height smaller ÉèÖùìµÀΪ¼õСµÄ¸ß¶È Shift+¡¯ ¼ü
Set track heights to default size ÉèÖùìµÀȱʡµÄ¸ß¶È Ctrl+¡¯ ¼ü
Zoom in time (incremental) ʱ¼ä·Å´ó£¨Öð½¥Ôö¼Ó£© ÉϼýÍ·¼ü
Zoom in time until each video thumbnail represents one frame
ʱ¼ä·Å´ó£¬Ö±µ½Ã¿¸öÊÓÆµÁ¬»·»­ÎªÒ»Ž¬ÏÔʾ
Alt +ÉϼýÍ·¼ü
==========================Vegas Video ¿ì½Ý¼ü 7===========================
Zoom out time (incremental) ËõСʱ¼ä£¨Öð½¥¼õС£© ϼýÍ·¼ü
Zoom in large increments or selection (if one exists)
°´´ó¼¶±ð¼Ó´ó»ò¼Ó´óÑ¡ÔñÇø£¨Èç¹û´æÔڵϰ£©Ctrl+ÉϼýÍ·¼ü
Zoom out large increments or selection (if one exists)
°´´ó¼¶±ð¼õС»ò¼õСѡÔñÇø£¨Èç¹û´æÔڵϰ£©Ctrl+ϼýÍ·¼ü
Zoom waveforms in vertically (audio only) ´¹Ö±·Å´ó²¨ÐΣ¨Ö»ÓÐÒôƵ£© Shift+ÉϼýÍ·¼ü
Zoom waveforms out vertically (audio only)
´¹Ö±ËõС²¨ÐΣ¨Ö»ÓÐÒôƵ£©Shift+ϼýÍ·¼ü
Minimize/restore the window docking area
¼õС/»Ö¸´´°¿ÚËõ¶ÌµÄÇøÓò¡¡F11
Maximize/restore the timeline vertically and horizontally
(window docking area and track list will be hidden)
ˮƽºÍ´¹Ö±¼Ó´ó/»Ö¸´Ê±¼äÏߣ¨´°¿ÚÃæ»ýËõС²¢ÇÒÉùµÀÌõ±»Òþ²Ø£©Ctrl+F11
Minimize/restore the track list £¨¼õС/»Ö¸´ÉùµÀÌõ£© Shift+F11
Trimmer commands ÐÞÕûÆ÷ÃüÁî
ÏÂÊöÃüÁîÓ¦ÓÃÓÚTrimmer£¨ÐÞÕûÆ÷£©´°¿Ú¡£Ó¦ÓÃÓÚʱ¼äÏßÖеĿì½Ý¼üÒ²ÊÊÓÃÓÚTrimmer¡£
Õâ¸ö±íÖеÄÈȼüÃüÁîΪTrimmer ¶ÀÓеġ£
ÃüÁî¡¡¡¡ Èȼü
Add media from cursor
´Ó¹â±êλÖÃÔö¼ÓýÌ壨ýÌåÆðʼλÖ÷ÅÔÚ¹â±êλÖã©A
Add media to cursor Ôö¼ÓýÌåµ½¹â±êλÖã¨Ã½Ìåβ²¿·ÅÔÚ¹â±êλÖã© Shift+A
Transfer time selection from timeline to Trimmer after cursor
½«Ê±¼äÏßÖеÄʱ¼äÑ¡ÔñÇø×ªÒÆµ½Trimmer ÉϵĹâ±êÖ®ºóµÄʱ¼äÇøÓò¡¡T
Transfer time selection from timeline to Trimmer before cursor
½«Ê±¼äÏßÖеÄʱ¼äÑ¡ÔñÇø×ªÒÆµ½Trimmer ÉϵĹâ±ê֮ǰµÄʱ¼äÇøÓò¡¡Shift+T
Toggle selected stream: audio/video/both
Çл»±»Ñ¡ÔñµÄÁ÷ýÌ壺ÒôƵ/ÊÓÆµ/ÒôƵºÍÊÓÆµ¡¡Tab
Next media file in Trimmer Ñ¡ÔñTrimmer ÖеÄÏÂÒ»¸öýÌåÎļþ Ctrl+Tab
==========================Vegas Video ¿ì½Ý¼ü 8===========================
Previous media file in Trimmer Ñ¡ÔñTrimmer ÖеÄǰһ¸öýÌåÎļþ Ctrl+Shift+Tab
Toggle audio/video stream height ÒôƵ/ÊÓÆµ¹ìµÀ¸ß¶È Ctrl+Shift+ÉÏ/ϼýÍ·¼ü
Miscellaneous ÔÓÏî
ÃüÁî¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡Èȼü
Online Help Áª»ú°ïÖú F1
Shortcut menu Èȼü²Ëµ¥ Shift+F10
Rebuild audio peaks ÖØÐ¼ÆËãÒôƵ²¨ÐÎͼ F5
Make fine fader adjustments ΢µ÷ÍÆ×Ó Ctrl+ÓÃÊó±êÍÏ×§ÍÆ×Ó
Change relative keyframe spacing °´±ÈÀý¸Ä±ä¹Ø¼üެµÄ¼ä¸ô Alt+ÓÃÊó±êÍÏ×§¹Ø¼üެ
Move region without changing length ÒÆ¶¯Æ¬¶Î¶ø²»¸Ä±äËüµÄ³¤¶È Alt+ÓÃÊó±êÍÏ×§±êÇ©
Mouse wheel shortcuts Êó±êÂÖÈȼü£¨Ö¸µ¥ÂÖÊó±ê£©
ÃüÁî Êó±êÈȼü
Zoom in/out ´¹Ö±·Å´ó/ËõС ¾í¶¯Êó±êÂÖ
Scroll vertically ´¹Ö±¾íÆÁ Ctrl+¾í¶¯Êó±êÂÖ
Scroll horizontally ˮƽ¾íÆÁ Shift+¾í¶¯Êó±êÂÖ
Move the cursor in small increments
ÒÔºÜСµÄÔöÁ¿Òƶ¯¹â±ê¡¡Ctrl+Shift+¾í¶¯Êó±êÂÖ
Move the cursor by frames °´Ž¬Òƶ¯Êó±ê Ctrl+Alt+Shift+¾í¶¯Êó±êÂÖ
Auto-scroll ×Ô¶¯¾íÆÁ °´×¡Êó±êÂÖ°´Å¥²¢Òƶ¯Êó±ê
Move fader/slider ÒÆ¶¯ÍÆ×Ó/»¬¿é °ÑÊó±êÖ¸ÏòÍÆ×Ó»ò»¬¿é²¢×ª¶¯Êó±êÂÖ
Move fader/slider in fine increments ΢µ÷ÍÆ×Ó/»¬¿é Ctrl+°ÑÊó±êÖ¸ÏòÍÆ×Ó»ò»¬¿é²¢×ª¶¯Êó±êÂÖ
ÆÀÂÛÁÐ±í£¨1£©
