»ìÏì²ÎÊý- Ìṩ²Î¿¼
»ìÏì²ÎÊý- Ìṩ²Î¿¼
Reverb Hall 1 Ä£Äâ´óÒôÀÖÌüµÄ»ìÏì
²ÎÊýÊýÖµ·¶Î§ËµÃ÷
Rev.Time2.8s0.3-30.0s»ìÏìʱ¼ä
High Ratio0.80.1-1.0¸ßƵ˥¼õÂÊ
Diffusion60-10»ìÏìÀ©É¢
Ini.Dly40.0ms0.1-200.0msÖ±´ïÉùÓëÔçÆÚ·´ÉäÉùÖ®¼äµÄÑÓ³Ùʱ¼ä
LPF7.0kHz1KHz-16KHz,THRUµÍͨÂ˲¨Æ÷µÄ½ØÖ¹ÆµÂÊ
HPFTHRUTHRU,32Hz-8KHz¸ßͨÂ˲¨Æ÷µÄ½ØÖ¹ÆµÂÊ
Reverb Hall 2 Ä£Äâ´óÒôÀÖÌüµÄ»ìÏìµÄ±äÖÖ
²ÎÊýÊýÖµ·¶Î§ËµÃ÷
Rev.Time3.2s0.3-30.0s»ìÏìʱ¼ä
High Ratio0.70.1-1.0¸ßƵ˥¼õÂÊ
Diffusion80-10»ìÏìÀ©É¢
Ini.Dly38ms0.1-200.0msÖ±´ïÉùÓëÔçÆÚ·´ÉäÉùÖ®¼äµÄÑÓ³Ùʱ¼ä
LPF6.3kHz1.0kHz-16.0kHz,THRUµÍͨÂ˲¨Æ÷µÄ½ØÖ¹ÆµÂÊ
HPFTHRUTHRU,32Hz-8kHz¸ßͨÂ˲¨Æ÷µÄ½ØÖ¹ÆµÂÊ
Reverb Room 1 Ä£ÄâË®Äàǽ±Ú·¿¼ä²úÉú´óÁ¿»ØÉùµÄ»ìÏì *Ϊ¹ÄÒôÉ«Ôö¼ÓÏÖ³¡¸Ð
²ÎÊýÊýÖµ·¶Î§ËµÃ÷
Rev.Time1.4s0.3-30s»ìÏìʱ¼ä
Diffusion70-10»ìÏìÀ©É¢
Ini.Dly5.0ms0.1-200msÖ±´ïÉùÓëÔçÆÚ·´ÉäÉùÖ®¼äµÄÑÓ³Ùʱ¼ä
LPFTHRU1KHz-16KHz,THRUµÍͨÂ˲¨Æ÷µÄ½ØÖ¹ÆµÂÊ
HPFTHRUTHRU,32Hz-8kHZ¸ßͨÂ˲¨Æ÷µÄ½ØÖ¹ÆµÂÊ
Reverb Room 2 Room1µÄ±äÖÖ
²ÎÊýÊýÖµ·¶Î§ËµÃ÷
Rev.Time1.8s0.3-30s»ìÏìʱ¼ä
High Ratio0.60.1-1.0¸ßƵ˥¼õÂÊ
Ini.Dly17ms0.1-200msÖ±´ïÉùÓëÔçÆÚ·´ÉäÉùÖ®¼äµÄÑÓ³Ùʱ¼ä
LPF9kHz1KHz-16KHz,THRUµÍͨÂ˲¨Æ÷µÄ½ØÖ¹ÆµÂÊ
HPF80HzTHRU,32Hz-8kHZ¸ßͨÂ˲¨Æ÷µÄ½ØÖ¹ÆµÂÊ
Reverb STAGE ÀàËÆ³ÌÐò1£¬µ«¸üÃ÷ÁÁ£¬¸üÓÐÏÖ³¡¸Ð
²ÎÊýÊýÖµ·¶Î§ËµÃ÷
Rev.Time3.4s0.3-30s»ìÏìʱ¼ä
High Ratio0.90.1-1.0¸ßƵ˥¼õÂÊ
Ini.Dly45ms0.1-200msÖ±´ïÉùÓëÔçÆÚ·´ÉäÉùÖ®¼äµÄÑÓ³Ùʱ¼ä
HPF70HzTHRU,32Hz-8kHZ¸ßͨÂ˲¨Æ÷µÄ½ØÖ¹ÆµÂÊ
Reverb Plate Ä£Äâ¸ÖÅÌÀà»ìÏìϵͳ£¬ÊÊÓ¦ÐÔºÜ¹ã£¬ÌØ±ðÊÇÈËÉù£¬¹ÄºÍ´ò»÷ÀÖ
²ÎÊýÊýÖµ·¶Î§ËµÃ÷
Rev.Time2.4s0.3-30s»ìÏìʱ¼ä
Ini.Dly16ms0.1-200msÖ±´ïÉùÓëÔçÆÚ·´ÉäÉùÖ®¼äµÄÑÓ³Ùʱ¼ä
LPF8kHz1KHz-16KHz,THRUµÍͨÂ˲¨Æ÷µÄ½ØÖ¹ÆµÂÊ
Rev Ambience 1 Ä£ÄâÀÖÆ÷ÖÜΧµÄ»ìÏ죬ÓÃÓÚÈËÉù£¬ºÏ³ªºÍ´ò»÷ÀÖ
²ÎÊýÊýÖµ·¶Î§ËµÃ÷
Rev.Time1.2s0.3-30s»ìÏìʱ¼ä
High Ratio10.1-1.0¸ßƵ˥¼õÂÊ
Ini.Dly19ms0.1-200msÖ±´ïÉùÓëÔçÆÚ·´ÉäÉùÖ®¼äµÄÑÓ³Ùʱ¼ä
HPF45HzTHRU,32Hz-8kHZ¸ßͨÂ˲¨Æ÷µÄ½ØÖ¹ÆµÂÊ
Rev Ambience 2 ³ÌÐò7µÄ±äÖÖ
²ÎÊýÊýÖµ·¶Î§ËµÃ÷
Rev.Time0.8s0.3-30s»ìÏìʱ¼ä
Ini.Dly0.1ms0.1-200msÖ±´ïÉùÓëÔçÆÚ·´ÉäÉùÖ®¼äµÄÑÓ³Ùʱ¼ä
HPF56HzTHRU,32Hz-8kHZ¸ßͨÂ˲¨Æ÷µÄ½ØÖ¹ÆµÂÊ
Rev Live Room 1 Ä£ÄâÏÖ³¡·¿¼äµÄ»ìÏì,»ìÏì·´Éä±ÈRecerm RoomÇ¿
²ÎÊýÊýÖµ·¶Î§ËµÃ÷
LPF7kHz1KHz-16KHz,THRUµÍͨÂ˲¨Æ÷µÄ½ØÖ¹ÆµÂÊ
Rev Live Room 2 ³ÌÐò9µÄ±äÖÖ
²ÎÊýÊýÖµ·¶Î§ËµÃ÷
Rev.Time2.2s0.3-30.0s»ìÏìʱ¼ä
High Ratio0.50.1-1.0¸ßƵ˥¼õÂÊ
Ini.Dly12.0ms0.1-200.0msÖ±´ïÉùÓëÔçÆÚ·´ÉäÉùÖ®¼äµÄÑÓ³Ùʱ¼ä
LPF4.0kHz1.0kHz-16.0kHz.THRUµÍͨÂ˲¨Æ÷µÄ½ØÖ¹ÆµÂÊ
Reverb Vocal ÓÃÓÚÈËÉù,ºÏ³ªµÄ»ìÏì
²ÎÊýÊýÖµ·¶Î§ËµÃ÷
Rev.Time1.9s0.3-30.0s»ìÏìʱ¼ä
Ini.Dly16ms0.1-200.0msÖ±´ïÉùÓëÔçÆÚ·´ÉäÉùÖ®¼äµÄÑÓ³Ùʱ¼ä
LPF12kHz1.0kHz-16.0kHz.THRUµÍͨÂ˲¨Æ÷µÄ½ØÖ¹ÆµÂÊ
HPF100HzTHRU,32Hz-8kHz¸ßͨÂ˲¨Æ÷µÄ½ØÖ¹ÆµÂÊ
Chorus Reverb Á¢ÌåÉùºÏ³ªºó½Ó»ìÏì
ÆÀÂÛÁÐ±í£¨2£©
²ÎÊýÊýÖµ·¶Î§ËµÃ÷
Mod.Freq0.8Hz0.1-20Hzµ÷ÖÆËÙ¶È
Mod.Depth40%0-100%µ÷ÖÆÉî¶È
Mod.Dly1.3ms0-24msÔÚ¿ªÊ¼µ÷ÖÆÇ°µÄÑÓ³Ùʱ¼ä
High Ratio0.70.1-1¸ßƵ˥¼õÂÊ
Ini.Dly30ms0.1-139msÖ±´ïÉùÓëÔçÆÚ·´ÉäÉùÖ®¼äµÄÑÓ³Ùʱ¼ä
LPF6.3kHz1kHz--16kHz, THRUµÍͨÂ˲¨Æ÷µÄ½ØÖ¹ÆµÂÊ
HPFTHRUTHRU,32Hz--8kHz¸ßͨÂ˲¨Æ÷µÄ½ØÖ¹ÆµÂÊ
Rev.Depth24%0-100%»ìÏìÉî¶È
Flange Reverb Á¢ÌåÉùÆ®ºöºó½Ó»ìÏì
²ÎÊýÊýÖµ·¶Î§ËµÃ÷
Mod.Freq1.4Hz0.1-20Hzµ÷ÖÆËÙ¶È
Mod.Depth22%0-100%µ÷ÖÆÉî¶È
FB Gain+45%-99--+99%´¦ÀíºóµÄÐźŷµ»ØÆ®ºöµÄÔöÒæ
Mod.Dly13ms0-15.5msÔÚ¿ªÊ¼µ÷ÖÆÇ°µÄÑÓ³Ùʱ¼ä
Ini.Dly26ms0.1-200msÖ±´ïÉùÓëÔçÆÚ·´ÉäÉùÖ®¼äµÄÑÓ³Ùʱ¼ä
LPF4.5kHz1kHz--16kHz, THRUµÍͨÂ˲¨Æ÷µÄ½ØÖ¹ÆµÂÊ
HPF45HzTHRU,32Hz--8kHz¸ßͨÂ˲¨Æ÷µÄ½ØÖ¹ÆµÂÊ
Rev.Depth30%0-100%»ìÏìÉî¶È
Delay L-C-R ×ó£¬ÖУ¬ÓÒÉùµÀ¶ÀÁ¢µÄÑÓ³Ù
²ÎÊýÊýÖµ·¶Î§ËµÃ÷
Dly L250ms0.1-661ms×óÉùµÀÑÓ³Ùʱ¼ä
Dly R500ms0.1-661msÓÒÉùµÀÑÓ³Ùʱ¼ä
Dly C125ms0.1-661msÖÐÑëÉùµÀÑÓ³Ùʱ¼ä
Level C700-100ÖÐÑëÉùµÀÑÓ³ÙÒôÁ¿
FB.Dly500ms0.1-661msÔÚ¿ªÊ¼·´À¡Ç°µÄÑÓ³Ùʱ¼ä
FB.Gain+40%-99--+99%´¦ÀíºóµÄÐźŷµ»ØÑÓ³ÙµÄÔöÒæ
High Ratio0.80.1-1·´À¡µÄµ÷Ƶ˥¼õÂÊ
Monodly-Chorus µ¥ÉùµÀÑÓ³Ùºó½ÓÁ¢ÌåÉùºÏ³ª
²ÎÊýÊýÖµ·¶Î§ËµÃ÷
Delay400ms0.1-618msÑÓ³Ùʱ¼ä
FB.Gain+32%-99--+99%´¦ÀíºóµÄÐźŷµ»ØÑÓ³ÙµÄÔöÒæ
Mod.Freq0.4Hz0.1-20HzºÏ³ªµ÷ÖÆËÙ¶È
Mod.Depth10%0-100%ºÏ³ªµ÷ÖÆÉî¶È
Mod.Dly0.1Ms0-24msºÏ³ª¿ªÊ¼µ÷ÖÆÇ°µÄÑÓ³Ùʱ¼ä
Chrous-Dly L C R Á¢ÌåÉùºÏ³ªºó½Ó×ó£¬ÖУ¬ÓÒÉùµÀ¶ÀÁ¢µÄÑÓ³Ù
²ÎÊýÊýÖµ·¶Î§ËµÃ÷
Mod.Depth24%0-100%µ÷ÖÆÉî¶È
Mod.Dly5.9ms0-24msÔÚ¿ªÊ¼µ÷ÖÆÇ°µÄÑÓ³Ùʱ¼ä
Dly L26.4ms0.1-618ms×óÉùµÀÑÓ³Ùʱ¼ä
Dly R33.2ms0.1-618msÓÒÉùµÀÑÓ³Ùʱ¼ä
Dly C13.1ms0.1-618msÖÐÑëÉùµÀÑÓ³Ùʱ¼ä
Level C600-100ÖÐÑëÉùµÀÑÓ³ÙÒôÁ¿
FB.Dly40.5ms0.1-618msÔÚ¿ªÊ¼·´À¡Ç°µÄÑÓ³Ùʱ¼ä
FB.Gain-48%-99--+99%´¦ÀíºóµÄÐźŷµ»ØÑÓ³ÙµÄÔöÒæ
High Ratio0.10.1-1·´À¡µÄµ÷Ƶ˥¼õÂÊ
Delay-Chrous Á½¼¶ÑÓ³Ùºó½ÓÁ¢ÌåÉùºÏ³ª
²ÎÊýÊýÖµ·¶Î§ËµÃ÷
Dly 1250ms0.1-618ms1 ÑÓ³Ùʱ¼ä
Dly 2500ms0.1-618ms2 ÑÓ³Ùʱ¼ä
FB.Dly500ms0.1-618msÔÚ¿ªÊ¼·´À¡Ç°µÄÑÓ³Ùʱ¼ä
FB.Gain+33%-99--+99%´¦ÀíºóµÄÐźŷµ»ØÑÓ³ÙµÄÔöÒæ
High Ratio0.70.1-1·´À¡µÄµ÷Ƶ˥¼õÂÊ
Mod.Freq1.2Hz0.1-20Hzµ÷ÖÆËÙ¶È
Mod.Depth25%0-100%µ÷ÖÆÉî¶È
Mod.Dly10ms0-24msÔÚ¿ªÊ¼µ÷ÖÆÇ°µÄÑÓ³Ùʱ¼ä
Karaoke Echo 1 ¿¨À­OKЧ¹û
²ÎÊýÊýÖµ·¶Î§ËµÃ÷
Dly L220ms0.1-332ms×óÉùµÀÑÓ³Ùʱ¼ä
FB.Gain L+40%-99--+99%×óÉùµÀ´¦ÀíºóµÄÐźŷµ»ØµÄÔöÒæ
Dly R223ms0.1-332msÓÒÉùµÀÑÓ³Ùʱ¼ä
FB.Gain R+40%-99--+99%ÓÒÉùµÀ´¦ÀíºóµÄÐźŷµ»ØµÄÔöÒæ
High Ratio0.40.1-1·´À¡µÄµ÷Ƶ˥¼õÂÊ
Karaoke Echo 2 ¿¨À­OKЧ¹û
²ÎÊýÊýÖµ·¶Î§ËµÃ÷
FB.Gain L+44%-99--+99%×óÉùµÀ´¦ÀíºóµÄÐźŷµ»ØµÄÔöÒæ
Dly R180ms0.1-332msÓÒÉùµÀÑÓ³Ùʱ¼ä
FB.Gain R-55%-99--+99%ÓÒÉùµÀ´¦ÀíºóµÄÐźŷµ»ØµÄÔöÒæ
High Ratio0.20.1-1·´À¡µÄµ÷Ƶ˥¼õÂÊ
ST.Pitch Change Á½²¿·ÖµÄÁ¢ÌåÉùÒô¸ß±ä»¯Æ÷£¬ÓжÀÁ¢µÄÉùÏñ²ÎÊý
²ÎÊýÊýÖµ·¶Î§ËµÃ÷
Pitch0-12--+12Òô¸ß´Öµ÷
Fine 1+10-50--+50±ä»¯Æ÷1µÄÒô¸ß΢µ÷
Fine 2-10-50--+50±ä»¯Æ÷2µÄÒô¸ß΢µ÷
Out.Lvl 1+100-100--+100±ä»¯Æ÷1µÄÊä³öÒôÁ¿
Out.Lvl 2+100-100--+100±ä»¯Æ÷2µÄÊä³öÒôÁ¿
Pan 1L100L100--R100±ä»¯Æ÷1µÄÉùÏñ
Pan 2R100L100--R100±ä»¯Æ÷2µÄÉùÏñ
FB.Gain 1+28%-99--+99%´¦ÀíºóµÄÐźŷµ»Ø±ä»¯Æ÷1µÄÔöÒæ
FB.Gain 2-28%-99--+99%´¦ÀíºóµÄÐźŷµ»Ø±ä»¯Æ÷2µÄÔöÒæ
FB.Dly25ms0.1-223msÔÚ¿ªÊ¼·´À¡Ç°µÄÑÓ³Ùʱ¼ä
2007-5-16 17:30:30 »Ø¸´
"MALE
VOCAL"ÄÐÐÔÉùÒô,Ç¿µ÷ÖеÍÒôG+3db+1db+2db
F280Hz1.8KHz5KHz
Q3oct3/4octÆÂ×´
"FEMALE
VOCAL"Å®ÐÔÉùÒô,Ç¿µ÷¸ßÖÐÒôG-1db+1db+2db
F220Hz2KHz7KHz
QÆÂ×´3oct3oct
CHROUSÈËÉùºÏ³ªG+1db+2db+5db
F280Hz1.4KHz5.6KHz
Q3oct3/2octÆÂ×´
"MALE
ANNOUCER"ÄÐÐÔ½²»°,Ôö¼ÓÇåÎú¶ÈG-3db+2db-4db
F100Hz4.5KHz7KHz
Q1oct3octÆÂ×´
"FEMALE
ANNOUCER"Å®ÐÔ½²»°,Ç¿µ÷ÖÐÒôG-3db+3db-1db
F200Hz2KHz8KHz
QÆÂ×´1octÆÂ×´
"TELEPHONE
VOICE"Ä£Äâµç»°Éù,¼õÉٸߵÍÒôG-15db+12db-10db
F500Hz1.1KHz9KHz
QÆÂ×´2oct3/4oct
"NOTCH
4KHz"ÔÚ4Hz´¦Â˲¨ÒÔ¼õÉÙ·´À¡Ð¥½ÐG0db0db-10db
F80Hz2KHz4KHz
QÆÂ×´3/2oct1/6oct
"HUM
REDUCE
50Hz"ÔÚ50Hz´¦Â˲¨ÒÔ¼õÉÙÎËÎËÉùG-9db-10db0db
F50Hz160Hz10KHz
Q1/6oct1/6octÆÂ×´
"HUM
REDUCE
60Hz"ÔÚ60Hz´¦Â˲¨ÒÔ¼õÉÙÎËÎËÉùG-9db-10db0db
F60Hz180Hz10KHz
Q1/6oct1/6octÆÂ×´
"W.NOISE
REDUCE"Ϊ´Å´ø·ÅÒô¼õÉÙ¸ßÆµÔëÒôG0db0db-13db
F80Hz2KHz16KHz
QÆÂ×´3/2octÆÂ×´
2008-5-21 13:27:16 »Ø¸´
