Manley Dual Mono ˫ͨµÀ»°Í²·Å´óÆ÷
Ô­´´
Manley¹«Ë¾µÄÈ«µç×ӹܻ°Í²»°Í²·Å´óÆ÷£¬ÊÊÓÃÓÚÏÖ´úµçÈÝ»°Í²ºÍÌõ´øÊ½ÕñĤ»°Í²¡£MANLEYÈ«µç×ӹܻ°Í²·Å´óÆ÷ÓÐ˫ͨµÀºÍµ¥Í¨Â·Á½ÖÖ°æ±¾¡£Ö÷ÒªÉè¼ÆÓÃÓÚÅäºÏÏÖ´úµçÈÝ»°Í²µÄʹÓá£Ëü¾ßÓÐ40-60dBµÄÔöÒæ£¬×ãÒÔÂú×ã´ó¶àÊýÌõ´øÊ½ÕñĤ»°Í²µÄÐèÒª£¬ËüµÄÔöÒæ´óС¿ÉÒÔ¸ù¾ÝÔöÒæÑ¡Ôñ¿ª¹ØÒÔ¾«È·µÄ5dB²½½øÖµ½øÐе÷Õû¡£¶øÕâµÄÈ·ÊÇÒ»¸ö±È½ÏÓÐȤµÄ¹¦ÄÜ£¬Ëü¿ÉÒԸıäÉùÒôµÄ»Ø×ªËÙÂÊ¡¢Î»ÖúÍÒôµ÷ƽºâ£¬´Ó¶øÊ¹ÉùÒô´Ó´¼ÃÀÈáºÍ²»¶Ï±ä»¯ÖÁÃ÷ÁÁ¸ß¿º¡£
¹¦ÄÜÌØÐÔ£º
¡ñ Ò»¸ö12AX7EHµÄµÍÔëÉùÊÖ¶¯Ñ¡Ôñ¿ª¹Ø
¡ñ ÿ¸ö´óµç·Êä³ö²¿·Ö¶¼Ê¹ÓÃÁËÒ»¸ö6414
¡ñ ËùÓÐÁ¬Ïß¶¼ÊÇÊÖ¹¤Íê³É£¬ÒÔ´¿Òøº¸½Ó£¬²¢È«²¿Ñ¡Ó÷¢ÉÕ¼¶ÔªÆ÷¼þ
¡ñ ÍêÈ«¶¨ÖƵÄË«²ãÆÁ±ÎµçÔ´±äѹÆ÷
¡ñ ¶¨ÖƵĴóÈÝÁ¿µçÈÝÆ÷
¡ñ ²ÉÓÃÆ½ºâʽ±äѹÆ÷ÊäÈëºÍÊä³ö£¬²¢ÔÚ½ðÊô»úÏäÖÐʹÓÃÁËÄøºÏ½ðµüƬ½á¹¹
¡ñ µ±ÄãÐèÒª½«Ä³Ð©ÉùÒô¾­¹ýµç×ӹܵĴ¦ÀíºóÔÙÊäÈ뵽ƽֱµÄÊý×Ö¼Òô»úÖУ¬Í¨¹ýÇ°Ãæ°åµÄ1/4¡¨DIRECT INPUT²å¿×£¬ÄãÄܹ»Îª±´Ë¾¡¢¹Ä»úºÍ¼üÅ̵ÈÀÖÆ÷ÐźŽ¨Á¢Ò»¸öÍêÈ«µÄµç×Ó¹ÜÏß·´¦ÀíͨµÀ
Manley Dual Mono Mic Pre Features:
Manley input & output transformers with nickel laminations in mu-metal cases
Flat frequency response from 10Hz-60KHz
Mic input PHASE REVERSE switch
2400 ohm mic input Z; 48V phantom power built-in
hi-Z (100Kohm) 1/4" DIRECT INPUT
Noiseless conductive plastic INPUT attenuators
<0.05% THD @ 1Khz S/N ratio: 80dB
EIN: -125dB
Adjustable FEEDBACK / GAIN switch selects 5dB steps between 40 to 60dB of gain
Hi-current drive <50 ohm LO-Z 1/4" & XLR outputs
AUTO MUTE w/ warm-up delay for power up/down
Max. input (with input pad fully open): 450mV
Max. output: +32dBu
Max. output (into 600 ohm load): (+15dBm)
Power consumption Mono units: 18 watts; Dual Mono units: 36 watts
Mains Voltage Frequency: 50~ 60Hz
Dimensions: 19" x 1-3/4" x 10" (occupies 1 RU)
Shipping Weight: 12 lbs.
The Dual Mono Mic Pre gives you two channels of pure Manley tone!
Tech SpecsPreamp TypeNumber of ChannelsFrequency ResponsePhantom PowerEQCompressionAnalog InputsAnalog OutputsDigital InputsDigital OutputsOther I/OComputer ConnectivityRack SpacesHeightDepthWidthWeightManufacturer Part Number
Tube
10Hz-60kHz
Yes
No
No
2 x XLR (Mid), 2 x 1/4" (Hi-Z)
2 x XLR
No Digital Inputs
No Digital Outputs
No Other I/O
No Computer Connectivity
1U
1.75"
10"
19"
12 lbs.
DMMPX
