AKG P120 ÐÄÐ͵çÈÝ»°Í²
ÒôƵϵÁÐ
´Ë¿îΪAKG Perception 100ÐͺóÍÆ³ö¿î120¿î,Õâ¿î¸ü¾­¼Ãʵ»Ý¶àÓÃ;Perception 120µçÈÝʽÂó¿Ë·ç,¿ÉÒÑÊÕÈËÉù,Ò»°ãÀÖÆ÷,¼ÆËã»ú¼Òô»ò¹ã²¥µÈÓÃ;,²¢ÓÐÖ±¾¶2/3Ó¢…¼´óµÄÊÕÒôÕñĤ,¿ÉÒÔÊÕµ½·Ç³£ÇåÎú¶øÇÒ¾«×¼ÉùÒô,ËüµÄÒôÉ«ÈçͬAKG¾­µäÂó¿Ë·çÒ»Ñù³öÉ«.
AKG¹«Ë¾×ݺá***רҵÂó¿Ë·çÊг¡Òѳ¬¹ý60ÄêÖ®¾­Ñé,ÕâÖ§Perception 120Âó¿Ë·ç,ÎÞÂÛÊǼÛλÓëÊÕÒôÖÊÁ¿À´Ëµ,C/PÖʸ߹ýÐí¶àͬ¼¶´ó³§Éõ¶à,¶øÐ¿î³ýÓ¡ÓÐAKGÉè¼ÆÓëʹÓõÄLOGOÍâ,ËüÒ²¶àµÍƵÂ˲¨Ïû³ýÓëÊÕÒô-20dBË¥¼õÇл».
ÐÄÐÍÖ¸ÏòÊÕÒô,2/3…¼¸ÐÒôÕñĤ,ÁéÃô¶È18mV/Pa
ƵÂÊÏìÓ¦20 ~ 20KHz,Òôѹ135~150dB,×迹200 ohms
¸ß¼¶²ÊºÐÊÕÄÉ,¸½Âó¿Ë·ç¹Ì¶¨¼Ü,ʹÓÃ˵Ã÷Êé,Ô­³§LogoÌùÖ½ÓëPerceptionϵÁнéÉܵÈ.
Âó¿Ë·çÌå»ý : Ö±¾¶5.3¹«·Öx 16.5¹«·Ö¸ß/2x6.5 inch, ¾»ÖØ : 525g / 1.2 lbs
¼¼Êõ²ÎÊý£º
General
Audio Frequency bandwidth20 to 20000 Hz
Sensitivity24 mV/Pa
Equivalent Noise Level19 dB-A
Signal to Noise75 dB-A
Preattenuation Pad-20 dB
Bass Cut Filter300 - 6 dB/octave Hz
Electrical Impedance<= 200 Ohms
Recommended Load Impedance>= 1000 Ohms
Polar Patterns
Cardiod
µÇ¼/×¢²áºó¿É¿´´óͼ
P120 ÐÄÐ͵çÈÝ»°Í²
Powering Interface
Voltage44 to 52 V
Current<= 3 mA
Audio Output
TypeBalanced XLR
GenderMale
Contacts3-pin
Dimensions / Weight
Length165 mm
Diameter54 mm
Net Weight455 g
