˹ÒôÏäBergantino·¢²¼fort¨¦ Ä£ÄâÏäÍ·
B | AMP µÄ¸ïз糱Ö÷ÒªÀ´×ÔÇ¿´óµÄÊý×Ö¹¦ÄܺÍÒ»¿éLCDÆÁÄ»£¬Éè¼ÆÕßΪËü½¾°Á£¬Ç¿´óµÄʵÓù¦ÄÜÉèÖÃÈýÓÊÜÁ¦ºÃµÄʹÓÃÕßΪ֮·è¿ñ£¬µ±È»Ò²ÓÐÒ»²¿·ÖÀÏÅɵÄÑÝ×àÕ߶ԿƼ¼ÓÐһЩÅų⡣
K.I.S.S.
¼«¼ò·ç¸ñÊÇàÐÔÓµ±´ú×îºÃµÄÐÄÁé³ö¿Ú£¬ÈËÃÇÖ𽥿ªÊ¼Ñ¡ÔñÐýÅ¥Éٵı´Ë¹£¬¼òµ¥Ò×µ÷½Ú£¬¹¦ÄÜ¿ÉÒÔÂú×ãÑÝ×àÐèÇó¼´¿É£¬Fort¨¦ÕýÈç´Ë£¬±£ÁôBergantino B | Amp×îºËÐĵÄÒôÉ«ºÍµ÷½Ú¹¦ÄÜ£¬ÈÃÉùÒô±£³Ö¸ß±ê×¼µÄͬʱ£¬°Ñµ÷½Ú±äµÃ¸ü¼Ó¼òµ¥¡£
VRCѹËõ£¬INPUT GAIN ,Ö÷ÒôÁ¿´óÅ¥£¬DSP TONE£¬ËùÓеÄÉè¼Æ¶¼ÊÇBergantino³É¹¦µÄԴȪ¡£½«Ê¹ÓÃÌùÐĵÄÉè¼Æ·Å´ó£¬ÈßÔӵIJ¿·ÖÈ«²¿ÌÞ³ý£¬Õâ¾ÍÊÇÐÂʱ´úÓÅÐã²úÆ·µÄÌØÖÊ£¡
The Bergantino Audio Systems fort¨¦£¨fort¨¦·Ò룺ӢÓïÇ¿Òô£¬Òâ´óÀûÓïÀ÷º¦£¬³£ÓÃÀ´ÐÎÈÝÒôÀֺܰô,¶ÁÒôFOR-TAY~£©ÏäÍ·ÊÇÒ»¿î±ãЯ±´Ë¹¹¦·ÅÉ豸¡£ÔÚ¼«ÖÂѹËõÌå»ýµÄͬʱÊÍ·Å×î´óµÄÒôÀÖÄÜÁ¿¡£fort¨¦ÏäÍ·¾ß±¸ºÍ¿ª´´ÐÔ²úÆ·B|Amp ¾ßÓÐͬÑùµÄÄ£Äâǰ¼¶Êä³öºÍ¹¦·Å±íÏÖÁ¦£¬Ö»ÊÇÉÙÁËÊý×Öµ÷½Ú¹¦ÄÜ¡£ÒôÉ«ÉÏͬÑù³õÖУ¬HeadroomºÍ·´À¡·Ç³£ÓÅÐ㣬¸ß¶È»¹ÔÑÝ×àÕßµÄBASSÐźţ¬¸ßÐԼ۱ȣ¬¾µäÉè¼Æ¡£
ÔÚfort¨¦µÄ¿ØÖÆÃæ°åÉÏÎÒÃÇ¿ÉÒÔÕÒµ½ÊìϤµÄ£ºËĶξùºâ£¬ÁÁ¶ÈÌáÉý£¬ÊäÈëÔöÒæµ÷½Ú£¬Ð§¹ûÆ÷»ØÂ·£¬¶ú»úÊä³ö¿×£¬µ÷Òô±íÊä³ö£¬Ë«SpeakOnÊä³ö¿Ú£¬DIÊä³ö¿Ú,ÍòÓõçѹµçÔ´¡£×î´óµÄ¾ªÏ²ÊÇ£¬ÈÃB|Amp¾ªÑÞÒµÄÚµÄVRCÖÇÄÜѹËõÊý×Ö¹¦ÄÜ£¬ÔÚfort¨¦Éϵõ½ÁËÓ²¼þ»¯±£Áô¡£
×îÊʺÏϲ»¶¼«¼ò£¬Old School£¬Í¬Ê±×·ÇóHIFIµÄÒôÀÖ¼Ò¡£
ÖØÒªµÄÊÂ˵Èý±é£ºOn-Board VRC (Variable Ratio Compressor)»úÔØÑ¹Ëõ
Brighter¸ßƵ¼¤Àø
DIÊä³ö£¬µ÷Òô±íÊä³ö¿Ú£¬¶ú»úÊä³ö¿Ú
¶¼»¹ÔÚ~~~
ÉÙµÄÊÇÒ»¿éÆÁÄ»ºÍÖÃЧ¹ûÆ÷µÈ
(The Bergantino Audio Systems fort¨¦ is an incredibly flexible, state-of-the-art Bass Amplifier, delivering maximum performance in a compact package. The fort¨¦ uses the same analog preamp and power amp section employed in the ground breaking Bergantino B|Amp, but with fewer options and control. The fort¨¦ and the B|Amp have the same great sound, headroom and immediate command of your bass instrument signal, but is offered in a lower-cost, traditional amplifier design.
You will find many familiar features of the B|Amp including 4-band EQ control, bright switch, variable input gain adjustment, effects send/return, auxiliary input and headphone jack, tuner out, dual SpeakOn jacks, studio quality direct output, 2-Ohm operation and universal power supply. The fort¨¦ also has a unique On-Board VRC (Variable Ratio Compressor) compressor adjustable from the front panel.)
•4-Band Tone Controls
•BassµÍƵ: +/- 10dB @ 63Hz
•Lo-MidÖеÍ: +/- 10dB @ 250Hz
•Hi-MidÖиß: +/- 10dB @ 1kHz
•Treble¸ßƵ: +/- 10dB @ 3.5kHz
•Bright switchÁÁ¶ÈÌáÉý: +6dB @ 6.5kHz
•On-Board adjustable VRC (Variable Ratio Compressor) Compressor VRCÖÇÄÜѹËõ
•Auxiliary input and headphone jack Á·Ï°¼àÌý¶ú»úÊä³ö
•Effects send and return loop Ч¹ûÆ÷»ØÂ·
•Studio quality Direct Output, software selectable Pre or Post EQ DIÊä³ö£¬EQǰºó¼¶Ñ¡Ôñ
•UPS ¨C Universal power supply 115VAC- 240VAC 50/60Hz ÍòÓõçѹ
•Power Section: 700W RMS at 4-Ohms, 800W RMS at 2-Ohms
•Dimensions³ß´ç CM(W¿íxDÉîxH¸ß): 22.6W x 21.27D x 9.5H
•Weight: 2.72 kg |
