Apogee Symphony 64 | ThunderBridge À×µç½Ó¿Ú
Apogee Symphony 64 | ThunderBridge À×µç½Ó¿Ú" l* w  e# _+ E& N9 o
- T; c7 a8 D6 m5 v+ {  v5 z% y9 y# G5 H
% L4 N0 a( a* {) L4 h+ b" M' U! a
( g6 }8 f8 h1 w2 C6 j64ͨµÀÀ×µç½Ó¿ÚÓÃÓÚ´îÅäApogeeSymphonyʹÓÃ6 U  P6 k3 {" M6 N/ @6 _$ S  {
6 s) k) v7 u& A' H: K; M
·¢»ÓÀ×µç½Ó¿ÚµÄЧ¹û0 N4 [+ e* K* F7 `+ F( p
Apogee&££39;s Symphony 64 | ThunderBridge is a 64-channel Thunderbolt connection for Apogee&££39;s Symphony I/O. Using the Symphony 64 | ThunderBridge, you can connect Symphony I/O to any Thunderbolt-equipped Macintosh for rock-solid compatibility and blazing-fast performance. A trim desktop unit, Symphony | 64 ThunderBridge will also connect X-Symphony-equipped AD-16X, DA-16X, and Rosetta Series converters to Thunderbolt Macs. Apple&££39;s Thunderbolt connectivity has opened up a world of professional recording possibilities. If you&££39;re into high-performance recording on your Thunderbolt-equipped Mac, check out Apogee&££39;s Symphony 64 | ThunderBridge.
% g1 ^& ?$ f& g0 ?0 HApogee Symphony 64 | ThunderBridge Thunderbolt Connection Features at a Glance:
+ q6 `! ?% t! M+ I! e2 x4 d  ]% N+ k! S% b
Connects up to 64 channels of Apogee I/O to any Thunderbolt-equipped Mac
' o  E+ Y* @2 ^5 y* F4 i, _7 H$ W3 G. i# \
Operates at sample rates from 44.1-192kHz6 y& M- v  u7 p1 y
2 e" Q0 B  r/ @Compatible with Symphony I/O and X-Symphony-equipped Rosetta 800, 200, AD16X, and DA16X.
% w, @# \" O% q/ n4 ]. A
( n" ]$ _( e/ u8 A0 E  P' H: MLatency = 1.8 ms at 96kHz/32 buffer4 E7 t8 L6 U. [  J. e
/ W/ u0 ]1 ?- WTwo Thunderbolt ports for connecting additional devices
& S: c4 y# {: O# C8 T
9 c) d4 H7 g4 r$ @Two PC-32 ports for connection to Apogee interfaces
" ^( ]: \# o& ~  s
/ U, t6 a& F. I: s1 E( S$ ~9 ?Word Clock Out
: J) s9 M" E! W% G" N" C2 L% F- ?& Z- M! \/ i3 N
DC Input - 12V DC 30W (power supply included)9 n; O* ]5 J" u" S
: U; X0 A# _& a: U& C
Status LED to indicate whether or not the device has been configured properly& H; L; s* j' f( H& ~
  Y6 K- ]/ T/ c' [0 C* t
ÆÀÂÛÁÐ±í£¨1£©
! B# p( S% v$ {* I( r3 b# E# {+ G  [em17]
2006-12-24 04:12:00 »Ø¸´
