NUENDOÖеÄÓ¢ÎĶÔÕÕ
yuhaoaiyue
2006-12-8 23:35:00
AAC automatic ampltiude control ×Ô¶¯·ù¶È¿ØÖÆ
AB ABÖÆÁ¢ÌåÉù¼Òô·¨
Abeyancd ÔÝÍ££¬Ç±Ì¬
A-B repeat A-BÖØ¸´
ABS absolute ¾ø¶ÔµÄ£¬ÍêÈ«µÄ£¬¾ø¶Ôʱ¼ä
ABS american bureau of standard ÃÀ¹ú±ê×¼¾Ö
ABSS auto blank secrion scanning ×Ô¶¯´Å´ø¿Õ°×²¿·ÖɨÃè
Abstime ¾ø¶ÔÔËÐÐʱ¼ä
A.DEF audio defeat ÒôƵ½µÔ룬ÔëÉùÒÖÖÆ£¬°éÒô¾²Ôë
ADJ adjective ¸½ÊôµÄ£¬¸½¼þ
ADJ Adjust µ÷½Ú
ADJ acoustic delay line ÉùÑÓ³ÙÏß
Admission ÔÊÐí½øÈ룬¹©¸ø
ADP acoustic data processor ÒôÏìÊý¾Ý´¦Àí»ú
ADP(T) adapter ÑÓÅäÆ÷£¬×ª½ÓÆ÷
ADRES automatic dynamic range expansion system
¶¯Ì¬·¶Î§À©Õ¹ÏµÍ³
ADRM analog to digital remaster
Ä£Äâ¼Òô¡¢Êý×Ö´¦ÀíÊýÂ볪ÅÌ
ADS audio distribution system ÒôƵ·ÖÅäϵͳ
A.DUB audio dubbing ÅäÒô£¬ÒôƵ¸´ÖÆ£¬ºóÆÚ¼Òô
ADV advance ËÍÈ룬ÌáÉý£¬Ç°ÖÃÁ¿
ADV adversum ¶Ô¿¹
ADV advancer Ïàλ³¬Ç°²¹³¥Æ÷
Adventure ¾ªÏÕЧ¹û
AE audio erasing ÒôƵ£¨ÉùÒô£©²Á³ý
AE auxiliary equipment ¸¨ÖúÉ豸
Aerial ÌìÏß
AES audio engineering society ÃÀ¹úÉùƵ¹¤³ÌЭ»á
AF audio fidelity ÒôƵ±£Õæ¶È
AF audio frequency ÒôƵƵÂÊ
AFC active field control ×Ô¶¯ÆµÂÊ¿ØÖÆ
AFC automatic frequency control Éù³¡¿ØÖÆ
Affricate Èû²ÁÒô
AFL aside fade listen Ë¥¼õºó£¨ÍÆ×Ӻ󣩼àÌý
A-fader ÒôƵ˥¼õ
AFM advance frequency modulation ¸ß¼¶µ÷Ƶ
AFS acoustic feedback speaker Éù·´À¡ÑïÉùÆ÷
AFT automatic fine tuning ×Ô¶¯Î¢µ÷
AFTAAS advanced fast time acoustic analysis system
¸ß¼¶¿ìËÙÒôÏì·ÖÎöϵͳ
After ×ªÒÆ²¿·ÖÎļþ
Afterglow Óà»Ô£¬Ï¦ÕÕʱ·ÖÒôÏìЧ¹û
Against ÒÔ¡­¡­Îª±³¾°
AGC automatic gain control ×Ô¶¯ÔöÒæ¿ØÖÆ
AHD audio high density ÒôƵ¸ßÃܶȳªÆ¬ÏµÍ³
AI advanced integrated Ô¤»ãÁ÷
AI amplifier input ·Å´óÆ÷ÊäÈë
AI artificial intelligence È˹¤ÖÇÄÜ
AI azimuth indicator ·½Î»Ö¸Ê¾Æ÷
A-IN ÒôƵÊäÈë
A-INSEL audio input selection ÒôƵÊäÈëÑ¡Ôñ
Alarm ¾¯±¨Æ÷
ALC automatic level control ×Ô¶¯µçƽ¿ØÖÆ
ALC automatic load control×Ô¶¯¸ºÔØ¿ØÖÆ
Alford loop °®¸£ÌØ»·ÐÎÌìÏß
Algorithm ÑÝʾ
Aliasing Á¿»¯ÔëÉù£¬ÆµÆ×»ìµþ
Aliasing distortion ÕÛµþÊ§Õæ
Align alignment УÕý£¬²¹³¥£¬Î¢µ÷£¬Æ¥Åä
Al-Si-Fe alloy head Ìú¹èÂÁºÏ½ð´ÅÍ·
Allegretto С¿ì°å£¬ÉÔ¿ìµØ
Allegro ¿ì°å£¬Ñ¸ËÙµØ
Allocation ÅäÖ㬶¨Î»
All rating È«£¨Òô£©Óò
ALM audio level meter ÒôƵµçƽ±í
ALT alternating Õðµ´£¬½»ÌæµÄ
ALT alternator ½»Á÷·¢µç»ú
ALT altertue ת·
ALT-CH alternate channel ת»»Í¨µÀ£¬½»ÌæÉùµÀ
Alter ת»»£¬½»Á÷µç£¬±ä»»Æ÷
AM amperemeter °²Åà¼Æ£¬µçÁ÷±í
AM amplitude modulation µ÷·ù£¨¹ã²¥£©
AM auxiliary memory ¸¨Öú´æ´¢Æ÷
Ambience ÁÙ³¡¸Ð£¬»·ÈƸÐ
ABTD automatic bulk tape degausser
´Å´ø×Ô¶¯ÕûÌåÈ¥´Åµç·
Ambient »·¾³µÄ
Ambiophonic system »·ÈÆÉùϵͳ
Ambiophony ÏÖ³¡»ìÏ죬»·¾³Á¢ÌåÉù
AMLS automatic music locate system
×Ô¶¯ÒôÀÖ¶¨Î»ÏµÍ³
AMP ampere °²Åà
AMP amplifier ·Å´óÆ÷
AMPL amplification ·Å´ó
AMP amplitude ·ù¶È£¬¾àÀë
Amorphous head ·Ç¾§Ì¬´ÅÍ·
Abort ÖÕÖ¹£¬Í£Ö¹£¨Â¼ÖÆ»ò²¥·Å£©
A-B TEST AB±È½ÏÊÔÌý
Absorber ¼õÕðÆ÷
Absorption ÉùÒô±»ÎïÌåÎüÊÕ
ABX acoustic bass extension µÍÒôÀ©Õ¹
AC accumulator ³äµçµç³Ø
AC adjustment caliration µ÷½Ú-У׼
AC alternating current ½»Á÷µç£¬½»Á÷
AC audio coding ÊýÂëÉù£¬ÒôƵ±àÂë
AC audio center ÒôƵÖÐÐÄ
AC azimuth comprator ·½Î»±È½ÏÆ÷
AC-3 ¶Å±ÈÊýÂë»·ÈÆÉùϵͳ
AC-3 RF ¶Å±ÈÊýÂë»·ÈÆÉùÊý¾ÝÁ÷£¨½Ó¿Ú£©
ACC Acceleration ¼ÓËÙ
Accel ½¥¿ì£¬¼ÓËÙ
Accent ÖØÒô£¬Éùµ÷
Accentuator Ô¤¼ÓÖØµç·
Access ´æÈ¡£¬½øÈ룬Ôö¼Ó£¬Í¨Â·
Accessory ¸½¼þ£¨½Ó¿Ú£©£¬Åä¼þ
Acryl ±û»ùõ£»ù
Accompaniment °é×࣬ºÏ×࣬°éËæ
Accord ºÍг£¬µ÷ºÍ
Accordion ÊÖ·çÇÙ
ACD automatic call distributor ×Ô¶¯ºô½Ð·ÖÅäÆ÷
ACE audio control erasing ÒôƵ¿ØÖÆÏû´Å
A-Channel A£¨×ó£©ÉùµÀ
Acoumeter ²âÌý¼Æ
Acoustical ÉùµÄ£¬ÉùÒôµÄ
Acoustic coloring ÉùȾɫ
Acoustic image ÉùÏñ
Across ½»²æ£¬²¢ÐУ¬¿ç½Ó
Across frequency ½»²æÆµÂÊ£¬·ÖƵƵÂÊ
ACST access time ´æÈ¡Ê±¼ä
Active Ö÷¶¯µÄ£¬ÓÐÔ´µÄ£¬ÓÐЧµÄ£¬ÔËÐеÄ
Active crossover Ö÷¶¯·ÖƵ£¬µç×Ó·ÖÆµ£¬ÓÐÔ´·ÖƵ
Active loudsperker ÓÐÔ´ÒôÏä
Armstrong MOD °¢Ä·Ë¹ÌØÀʵ÷ÖÆ
ARP azimuth reference pulse ·½Î»»ù×¼Âö³å
Arpeggio ÅÃÒô
Articulation ÉùÒôÇåÎú¶È£¬·¢Òô
Artificial ·Â¡­¡­µÄ£¬È˹¤µÄ£¬ÊÖ¶¯£¨¿ØÖÆ£©
AAD active acoustic devide ÓÐÔ´ÉùѧÈí¼þ
ABC auto base and chord ×Ô¶¯µÍÒôºÏÏÒ
Architectural acoustics ½¨ÖþÉùѧ
Arm motor ³ª±Û³ª»ú
Arpeggio single ÅÃÒôºÍÏÒ£¬·Ö½âºÍÏÒ
ARL aerial ÌìÏß
ASC automatic sensitivity control ×Ô¶¯ÁéÃô¶È¿ØÖÆ
ASGN Assign ·ÖÅ䣬ָ¶¨£¬É趨
ASP audio signal processing ÒôƵÐźŴ¦Àí
ASS assembly ×é¼þ£¬×°Å䣬×ܳÉ
ASSEM assemble »ã±à£¬¼ô¼­
ASSEM Assembly ×é¼þ£¬×°Å䣬×ܳÉ
Assign Ö¸¶¨£¬×ª·¢£¬·ÖÅä
Assist ¸¨Öú£¨×°Öã©
ASSY accessory ×é¼þ£¬¸½¼þ
AST active servo techonology ÓÐÔ´ËÅ·þ¼¼Êõ
A Tempo »Øµ½Ô­ËÙ
Astigmatism methord ÏóÉ¢·¨
B band Ƶ´ø
B Bit ±ÈÌØ£¬´æ´¢µ¥Ôª
B Button °´Å¥
Babble ¶à·¸ÐÓ¦µÄ¸´ÔÓÊ§Õæ
Back ·µ»Ø
Back clamping ·´Ïòǯλ
Back drop ½»Á÷ºßÉù£¬¸ÉÈÅÉù
Background noise ±³¾°ÔëÉù£¬±¾µ×ÔëÉù
Backing copy ¸±°æ
Backoff µ¹¿Û£¬²¹³¥
Back tracking ²¹Â¼
Back up ´Å´ø±¸·Ý£¬Ö§³Ö£¬Ô¤±¸
Backward ¿ìµ¹ËÑË÷
Baffle box ÒôÏä
BAL balance ƽºâ£¬Á¢ÌåÉù×óÓÒÉùµÀÒôÁ¿±ÈÀý£¬Æ½ºâÁ¬½Ó
Balanced ÒÑÆ½ºâµÄ
Balancing µ÷Áã×°Ö㬲¹³¥£¬ÖкÍ
Balun ƽºâ=²»Æ½ºâת»»Æ÷
Banana jack Ïã½¶²åÍ·
Banana bin Ïã½¶²å×ù
Banana pin Ïã½¶²åÍ·
Banana plug Ïã½¶²åÍ·
Band Ƶ¶Î£¬
Band pass ´øÍ¨Â˲¨Æ÷
Bandwidth Ƶ´ø¿í£¬Îó²î£¬·¶Î§
Band ´æ´¢µ¥Ôª
Bar С½Ú£¬À­¸Ë
BAR barye ΢°Í
Bargraph ÏßÌõ
Barrier ¾øÔµ£¨Ì×£©
Base µÍÒô
Bass µÍÒô£¬±¶Ë¾£¨µÍÒôÌáÇÙ£©
Bass tube µÍÒôºÅ£¬´óºÅ
Bassy µÍÒô¼ÓÖØ
BATT battery µç³Ø
Baud ²¨ÌØ£¨ÐÅÏ¢´«ÊäËÙÂʵĵ¥Î»£©
Bazooka µ¼Ï߯½ºâת½ÓÆ÷
BB base band »ù´ø
BBD Bucket brigade device ìæÁ´Æ÷¼þ£¨Ð§¹ûÆ÷£©
B BAT Battery µç³Ø
BBE ÌØÖ¸BBE¹«Ë¾Éè¼ÆµÄ¸ÄÉÆ½Ï¸ß´Îг²¨Ð£Õý³Ì¶ÈµÄϵͳ
BC balanced current ƽºâµçÁ÷
BC Broadcast control ¹ã²¥¿ØÖÆ
BCH band chorus ·ÖƵ¶ÎºÏ³ª
BCST broadcast £¨ÎÞÏߵ磩¹ã²¥
BD board ÒDZí°å
Beat ÅÄ£¬Âö¶¯ÐźÅ
Beat cancel switch ²îÅĸÉÈÅÏû³ý¿ª¹Ø
Bel ±´¶û
Below ÏÂÁУ¬ÏòÏÂ
Bench ¹¤×÷̨
Bend ÍäÇú£¬»¬Òô
Bender »¬ÒôÆ÷
BER bit error rate ÐÅÏ¢²î´íÂÊ
BF back feed ·´À¡
BF Backfeed flanger ·´À¡Ïâ±ß
BF Band filter ´øÍ¨Â˲¨Æ÷
BGM background music ±³¾°ÒôÀÖ
Bias Æ«Öã¬Æ«´Å£¬Æ«Ñ¹£¬¼È¶¨³ÌÐò
Bidirectional Ë«ÏòÐԵģ¬8×ÖÐÍÖ¸ÏòµÄ
Bifess Bi-feedback sound system Ë«·´À¡ÏµÍ³
Big bottom µÍÒôÀ©Õ¹£¬¼ÓÖØµÍÒô
Bin ½ÓÊÕÆ÷£¬²ÖÊÒ
BNG BNCÁ¬½ÓÆ÷£¨²åÍ·¡¢²å×ù£©£¬¿¨¿ÚͬÖáµçÀÂÁ¬½ÓÆ÷
Binaural effect Ë«¶úЧӦ£¬Á¢ÌåÉù
Binaural synthesis Ë«¶úºÏ³É·¨
Bin go ÒâÍâÏÖÏó
Bit binary digit ×Ö½Ú£¬¶þ½øÖÆÊý×Ö£¬Î»
Bitstream ÊýÂëÁ÷£¬±ÈÌØÁ÷
Bit yield ´æ´¢µ¥Ôª
Bi-AMP Ë«£¨Í¨µÀ£©¹¦·Åϵͳ
Bi-wire Ë«Ïߣ¨´«Êä¡¢·ÖÒô£©
Bi-Wring Ë«Ïß
BK break Í£¶Ù£¬¼ä¶Ï
BKR breaker ¶ÏµçÆ÷
Blamp Á½Â·µç×Ó·ÖÒô
Blanking ¹Ø±Õ£¬ÏûÒþ£¬¶Ï·
Blaster ±¬ÁÑЧ¹ûÆ÷
Blend Èںϣ¨¶È£©¡¢µ÷ºÍ¡¢»ìºÏ
Block ·Ö³ÌÐò£¬Áª¶¯£¬ÖжÏ
Block Repeat ·Ö¶ÎÖØ¸´
Block up ×èÈû
Bloop £¨´Å´øµÄ£©½ÓÍ·ÔëÉù£¬ÏûÒôÌùƬ
BNC bayonet connector ¿¨¿ÚµçÀÂÁ¬½ÓÆ÷
Body mike СÐÍ»°Í²
Bond ½ÓÍ·£¬Á¬½ÓÆ÷
Bongo Ë«¹Ä
Boom »ìÏ죬ºäÃùÉù
Boomy ÎËÎËÉù£¨Ö¸µÍÒô¹ýÇ¿£©
Boost ÌáÉý£¨Ò»°ãÖ¸µÍÒô£©£¬·Å´ó£¬ÔöÇ¿
Booth ¿ØÖÆÊÒ£¬Â¼ÒôÅï
Bootstrap ¸¨Öú³ÌÐò£¬×Ô¾Ùµç·
Both sides play disc stereo system
Ë«ÃæÑÝ×àʽ³ªÆ¬Á¢ÌåÉùϵͳ
Bottoming µ×²¿Çгý£¬Ä©¶ËÇгý
Bounce ºÏ²¢
Bourclon µ¥µ÷µÍÒô
Bowl Íë×´ÌåÓý³¡Ð§¹û
BP bridge bypass µçÇÅÅÔ·
BY bypass ÅÔͨ
BPC basic pulse generator »ù×¼Âö³å·¢ÉúÆ÷
BPF band pass filter ´øÍ¨Â˲¨Æ÷
BPS band pitch shift ·ÖƵ¶Î±äµ÷½ÚÆ÷
Body mike СÐÍ»°Í²
Bond ½ÓÍ·£¬Á¬½ÓÆ÷
Bongo Ë«¹Ä
Boom »ìÏ죬ºäÃùÉù
Bounce ºÏ²¢
Bourclon µ¥µ÷µÍÒô
Bowl Íë×´ÌåÓý³¡Ð§¹û
BY bypass ÅÔͨ
BR bregister ±äÖ·¼Ä´æÆ÷
BR Bridge µçÇÅ
Break ÖÐÖ¹£¨³ÌÐò£©£¬¼õÈõ
Breathing ´­Ï¢Ð§Ó¦
B.Reso base resolve »ù±¾½âÎö¶È
Bridge ÇŽӣ¬µçÇÅ£¬ÇÅ£¬£¨ÀÖÇúµÄ£©±ä×à¹ý¶É
Bright Ã÷ÁÁ£¨¸Ð£©
Brightness Ã÷ÁÁ¶È£¬Ö¸ÖиßÒôÌýÒô¸Ð¾õ
Brilliance ÏìÁÁ
BRKRS breakers ¶Ï·Æ÷
Broadcast ¹ã²¥
BTB bass tuba µÍÒô´óÀ®°È
BTL balanced transformer-less ÇÅÊ½ÍÆÍì·Å´óµç·
BTM bottom ×îС£¬µÍÒô
BU backup nuit ±¸ÓÃÆ÷¼þ
Bumper ¼õÕðÆ÷
Bus ĸÏߣ¬×ÜÏß
Busbar ĸÏß
Buss ĸÏß
Busy Õ¼Ïß
BUT button °´Å¥£¬ÐýÅ¥
BW band width Ƶ´ø¿í¶È£¬´ø¶È
BYP bypass ÅÔ·
By path ÅÔ·
BZ buzzer ·äÒôÆ÷
ÆÀÂÛÁÐ±í£¨1£©
·ÖÏí£¬Ð»Ð»Â¥Ö÷°¡
2006-12-10 19:07:00 »Ø¸´
