sonar²Ëµ¥Ïê½â
393968150
2004-8-31 21:29:00
ºóÆÚ
sonar²Ëµ¥Ïê½â7 [1 I8 H$ D- s( L3 k0 k2 Y' d
! n2 j2 {% j: K: |$ V
File
Edit
Process
View
Insert
Transport
Go
Track
Tools
Opions
Window
Help
Îļþ
±à¼­
´¦Àí
²é¿´
²åÈë
×ªÒÆ
Òô¹ì
¹¤¾ß
Ñ¡Ïî
´°¿Ú
°ïÖú
: Q; g% {! ]5 B' s0 l0 S8 m; d
3 D! q8 Z8 w1 n2 k% s; Z
0 b) Y' u( j+ t0 F& u  |: d( `( J) i) I- _% y
New
н¨
Open
´ò¿ª
Close
¹Ø±Õ
Save
±£´æ
Save As
Áí´æÎª
Info
±¸×¢ÐÅÏ¢
Project Audio Files
ÒôƵÎļþÐÅÏ¢
Import
µ¼Èë
Export
µ¼³ö
Print
´òÓ¡
Print Preview
´òÓ¡Ô¤ÀÀ
Print Setup
´òÓ¡ÉèÖÃ
Send
·¢ËÍ
Recent File
×î½üÎļþ
Exit
! H% ~9 j/ z. B0 l9 r
  F5 u' w* ?- _! v2 X5 n1 ]" W
Undo
³·Ïú
Redo
ÖØ×ö
History
ÀúÊ·²Ù×÷
Select
Ñ¡Ôñ
Cut
¼ôÇÐ
Copy
¸´ÖÆ
Paste
Õ³Ìù
Delete
ɾ³ý
Bounce to Colp
ºÏ²¢ÒôƵÇÐÆ¬
Bounce to Track
ºÏ²¢ÒôƵµ½Òô¹ì
Groove-Clip Looping
ת»»Loop״̬
Clip Mute/Unmute
ÇÐÆ¬¾²Òô/»¹Ô­
Isolate Clip in Layer
Split
·Ö¸î
Apply Trimming
ÐÞ¼ôÉúЧ
Convert MIDI To Shapes
½«MIDI¿ØÖÆÐÅϢת»»Îª°üÂç
8 Y) i* n6 M- J+ R" E% [) i
Audio
ÒôƵ±à¼­
Apply Audio Effects
¹Ì»¯ÒôƵЧ¹û
Audio Effects
ÒôƵЧ¹û
Apply MIDI Effects
¹Ì»¯MIDIЧ¹û
MIDI Effects
MIDIЧ¹û
Quantize
Á¿»¯
Groove Quantize
Ä£¾ßÁ¿»¯
Transpose
ÒÆµ÷
Slide
ÒÆ¶¯
Nudge
ÇáÒÆ
Interpolate
¸ß¼¶Ìæ»»
Length
µ÷Õûʱ³¤
Scale Velovity
Á¦¶ÈËõ·Å
Retrograde
ǰºóµ¹ÖÃ
Deglitch
Â˳ýÒô·û
Fit to Time
ʱ¼äÊÊÅä
Fit Improvisation
¼´ÐËÊÊÅä
Run CAL
ÔËÐÐCAL³ÌÐò
( F1 f3 m4 `7 ]& z5 N
Piano Roll
¸ÖÇÙ¾íÁ±´°
Event List
ʼþÁÐ±í´°
Staff
ÎåÏ߯״°
Loop Construction
Ñ­»·ËزĴ°
Lyrics
¸è´Ê´°
Loop Explorer
Loop×ÊÔ´ä¯ÀÀÆ÷
Console
µ÷Òǫ̀
Synth Rack
ÐéÄâÀÖÆ÷¼Ü
Video
ÊÓÆµ´°
Big Time
´óʱ¼ä±í
Markers
±ê¼Ç´°
Tempo
ËÙ¶È´°
Meter/key
ÅĺÅ/µ÷ºÅ
Sysx
ϵͳÂë
Navigator
µ¼º½Æ÷
Surround Panner
»·ÈÆÉù
Layouts
°æÃæ
Toolbars
¹¤¾ßÀ¸
  X: K, l: S9 @, n3 f
Bank/Patch Change
ÒôÉ«¿â/ÒôÉ«±ä¸ü
Meter/Key Change
ÅĺÅ/µ÷ºÅ±ä¸ü
Tempo Change
Ëٶȱä¸ü
Time/Measures
ʱ¼ä/С½Ú
Marker
Series of Controllers
ϵÁпØÖÆÆ÷
Series of Tempos
ϵÁÐËٶȱä¸ü
DXi Synth
ÐéÄâÀÖÆ÷
Audio Track
ÒôƵ¹ì
MIDI Track
MIDI¹ì
Track Folder
Òô¹ì¼Ð
Stereo Bus
Á¢ÌåÉù×ÜÏß
Surround Bus
»·ÈÆÉù×ÜÏß
6 E6 z+ S0 j, u( i5 l. z+ Q; }
Play
²¥·Å
Audition
ÊÔÌý
Record
Record Automation
Â¼ÖÆ×Ô¶¯¿ØÖÆÇúÏß
Rewind
µ¹»ØÀÖÇú¿ªÍ·
Stop
Í£Ö¹
Run Audio
¿ªÆôÒôƵÒýÇæ
Reset
¸´Î»MIDIÉ豸
Step Record
²½½øÂ¼Òô
Loop and Auto Shuttle
×Ô¶¯Ñ­»·
Record Options
¼ÒôÉèÖÃ
Reject Loop Take
µ¯³öLoopÇÐÆ¬
Update Patch Cache
¸üÐÂÒôÉ«»º´æ
Temp Ratio 1
ËÙÂÊ1
Temp Ratio 2
ËÙÂÊ2
Temp Ratio 3
ËÙÂÊ3
Set Timecode At Now
# i3 e- I4 H1 [
Time
ʱ¼ä
From
Æðµã
Thru
ÖÕµã
Beginning
ÀÖÇú¿ªÍ·
End
ÀÖÇú½áβ
Previous Measure
ÉÏһС½ÚÆðµã
Next Measure
ÏÂһС½ÚÆðµã
Previous Marker
ÉÏÒ»±ê¼Ç´¦
Next Marker
ÏÂÒ»±ê¼Ç´¦
Search
Search Next
ËÑË÷ÏÂÒ»¸ö
" o+ s: a/ g, [. z! ?; z3 C& b
Property
²ÎÊý
Mute
¾²Òô
Archive
´æµµ
Show Automated Mute
ÏÔʾ×Ô¶¯¾²Òô
Solo
¶À×à
Arm for Recording
Ô¤±¸Â¼Òô
Arm for Automation
Ô¤ÖÃÂ¼ÖÆ×Ô¶¯¿ØÖÆÇúÏß
Input Monitor/Echo
ÊäÈë¼àÌý/ÑÓ³Ù
Freeze
¶³½á
Clone
¿Ë¡
Delete
ɾ³ý
Wipe
Çå³ý
Hide
Òþ²Ø
Show Layers
ÏÔʾ²ã
Sort
ÅÅÐò
  d& T1 G! D, r$ N. ^* O" u
Consolidate Project Audio
±¸·Ý¹¤³ÌÒôƵ
Clean Audio Folder
ÇåÀíAudioÎļþ¼Ð
Change Audio Format
¸Ä±äÒôƵ¸ñʽ
Cakewalk Ext.Encoder Config
ÍⲿÒôƵ±àÂë
- J7 ?2 W+ [/ Z, r4 S. c) B4 g
MIDI Devices
MIDIÉ豸
Instruments
¶¨ÒåÒôÉ«±í
Audio
ÒôƵÉ豸
Audio Meter Settings
ÒôƵ±íÉèÖÃ
Project
¹¤³Ì
Global
Colors
ÑÕÉ«
SoundFonts
´´ÐÂÒôÉ«¿â
Key Bindings
¿ì½Ý¼ü
Initialization File
ÉèÖóõʼ»¯Îļþ
Non-Destructive MIDI Editing
·ÇÆÆ»µÐÔMIDI±à¼­
Time Ruler Format
ʱ¼ä±ê³ß¸ñʽ
Drum Map Manager
¹Ä±íÉèÖÃ
Control Surfaces
Íⲿ¿ØÖÆÆ÷
/ Y* d% K, J  @3 f9 V9 i# }
Cascade
²ãµþ
Tile in Rows
ºáÏòƽÆÌ
Tile in Columns
×ÝÏòƽÆÌ
Arrange Icons
ÅÅÁÐͼ±ê
$ m2 b3 h, F3 T3 _! w: e% ?
Help Topics
°ïÖú
What's New
ÐÂÌØÐÔ
View README.RTF
²é¿´×ÔÊö
Quick Start
¿ìËÙÉÏÊÖ
Keyboard Shortcuts
¿ì½Ý¼üÒ»ÀÀ
Tip of the Day
ÿÈÕÒ»Ìû
Register Online
ÔÚÏß×¢²á
Cakewalk Problem Reporter
±¨¸æ´íÎóÖÁCakewalk
SONAR on the Web
¹Ù·½ÍøÕ¾
About SONAR
¹ØÓÚSonar
