Rolls RA62C ¶ú»ú·ÖÅä·Å´óÆ÷
²úÆ·ÃèÊö
The ROLLS RA62c is a six-channel headphone/earphone amplifier for professional audio monitoring. A variety of input options are available including 1/4", RCA, and balanced XLR. Since the MONO/STEREO switch is after the pan control, it will mix 2 MONO signals and their balance can be adjusted with the Pan control. With the addition of rear panel Direct Input connectors, each channel may mix a second stereo signal.
Specifications
•Input Impedance: 10K Ohms unbalanced
•Max Input Level: +18 dBV
•Input Connectors: 1/4" TRS stereo, R & L bal. / unbal. 1/4", RCA, R & L balanced XLR, 6: 1/4" TRS Direct Input jacks
Output Connectors: 12: 1/4" TRS Stereo jacks, 6: 1/8" (3.5 mm) TRS Stereo jacks
•Max Gain: 20 dB/Channel
•Max Output Power: up to 300 mW/side, 600 mW/Channel ( @ 16 Ohms )
•Frequency Response: DC - 30 kHz
•S/N Ratio: 90 dB
•THD: <.008%
•IMD: <.008%
•Phase Shift (In to Out): 0 deg.
•Slew Rate: 25 V per microsecond Second
•Crosstalk: - 65 dB
•Power: 12 VAC (Rolls Model PS12)
•Size: 19" x 1.75" x 6.5" (48cm x 4.5cm x 17cm)
•Weight: 7 lbs (3KG)
