ÑÅÂí¹þ TF1 TF3 TF5 Êý×Öµ÷Òǫ̂
TF5TF3TF1ÍÆ×ÓÅäÖÃ32 + 1 (Ö÷¿Ø)24 + 1 (Ö÷¿Ø)16 + 1 (Ö÷¿Ø)»ìÒôÄÜÁ¦ÊäÈëͨµÀ48 (40 µ¥ÉùµÀ + 2 Á¢ÌåÉù + 2 ·µËÍͨµÀ)48 (40 µ¥ÉùµÀ + 2 Á¢ÌåÉù + 2 ·µËÍͨµÀ)40 (32 µ¥ÉùµÀ + 2 Á¢ÌåÉù + 2 ·µËÍͨµÀ)Aux ×ÜÏß20 (8 µ¥ÉùµÀ + 6 Á¢ÌåÉù)20 (8 µ¥ÉùµÀ + 6 Á¢ÌåÉù)20 (8 µ¥ÉùµÀ + 6 Á¢ÌåÉù)Á¢ÌåÉù×ÜÏß111¸±×ÜÏß111ÊäÈëͨµÀ¹¦ÄÜ8 DCA ±à×é8 DCA ±à×é8 DCA ±à×éI/O½Ó¿ÚÊäÈë32 Âó¿Ë·ç/Ïß· (XLR/TRS »ìºÏ) + 2 Á¢ÌåÉùÏß· (RCA pin)24 Âó¿Ë·ç/Ïß· (XLR/TRS »ìºÏ) + 2 Á¢ÌåÉùÏß· (RCA pin)16 Âó¿Ë·ç/Ïß· (XLR/TRS »ìºÏ) + 2 Á¢ÌåÉùÏß· (RCA pin)Êä³ö16 (XLR)16 (XLR)16 (XLR)À©Õ¹²Û111°åÔØ´¦ÀíÆ÷DSP8 Ч¹ûÆ÷ + 10 GEQ8 Ч¹ûÆ÷ + 10 GEQ8 Ч¹ûÆ÷ + 10 GEQUSB34x34 USB ÒôƵ½Ó¿Ú, ͨ¹ýUSB´æ´¢É豸¿É½øÐÐ 2 ¹ì¼Òô34x34 USB ÒôƵ½Ó¿Ú, ͨ¹ýUSB´æ´¢É豸¿É½øÐÐ 2 ¹ì¼Òô34x34 USB ÒôƵ½Ó¿Ú, ͨ¹ýUSB´æ´¢É豸¿É½øÐÐ 2 ¹ì¼ÒôͨÓùæ¸ñ²ÉÑùƵÂÊÄÚ²¿48 kHz48 kHz48 kHzÐźÅÑÓ³ÙµÍÓÚ 2.6 ms, INPUT to OMNI OUT, Fs=48 kHzµÍÓÚ 2.6 ms, INPUT to OMNI OUT, Fs=48 kHzµÍÓÚ 2.6 ms, INPUT to OMNI OUT, Fs=48 kHzÍÆ×Ó100 mm Âí´ïÍÆ×Ó, ¾«¶È = 10-bit, +10 dB to ¨C138 dB, ¨C¡Þ dB ËùÓÐÍÆ×Ó100 mm Âí´ïÍÆ×Ó, ¾«¶È = 10-bit, +10 dB to ¨C138 dB, ¨C¡Þ dB ËùÓÐÍÆ×Ó100 mm Âí´ïÍÆ×Ó, ¾«¶È = 10-bit, +10 dB to ¨C138 dB, ¨C¡Þ dB ËùÓÐÍÆ×Ó×Üг²¨Ê§ÕæµÍÓÚ 0.05% 20 Hz¨C20 kHz @+4 dBu into 600 , INPUT to OMNI OUT, ÊäÈëÔöÒæ=С (Measured with a ¨C18 dB/octave filter@80 kHz)µÍÓÚ 0.05% 20 Hz¨C20 kHz @+4 dBu into 600 , INPUT to OMNI OUT, ÊäÈëÔöÒæ=С (Measured with a ¨C18 dB/octave filter@80 kHz)µÍÓÚ 0.05% 20 Hz¨C20 kHz @+4 dBu into 600 , INPUT to OMNI OUT, ÊäÈëÔöÒæ=С (Measured with a ¨C18 dB/octave filter@80 kHz)ƵÂÊÏìÓ¦+0.5, ¨C1.5 dB 20 Hz¨C20 kHz, refer to +4 dBu output @1kHz, INPUT to OMNI OUT+0.5, ¨C1.5 dB 20 Hz¨C20 kHz, refer to +4 dBu output @1kHz, INPUT to OMNI OUT+0.5, ¨C1.5 dB 20 Hz¨C20 kHz, refer to +4 dBu output @1kHz, INPUT to OMNI OUT¶¯Ì¬·¶Î§110 dB typ., DA Converter, 107 dB typ., INPUT to OMNI OUT, Input Gain=Min.110 dB typ., DA Converter, 107 dB typ., INPUT to OMNI OUT, Input Gain=Min.110 dB typ., DA Converter, 107 dB typ., INPUT to OMNI OUT, Input Gain=Min.ÎËÉùºÍÔëÉùµÈЧÊäÈëÔëÉù¨C128 dBu typ., Input Gain=Max. (Measured with an A-Weight filter)¨C128 dBu typ., Input Gain=Max. (Measured with an A-Weight filter)¨C128 dBu typ., Input Gain=Max. (Measured with an A-Weight filter)²ÐÓàÊä³öÔëÉù¨C85 dBu, ST Ö÷¿Ø off (Measured with an A-Weight filter)¨C85 dBu, ST Ö÷¿Ø off (Measured with an A-Weight filter)¨C85 dBu, ST Ö÷¿Ø off (Measured with an A-Weight filter)´®ÈŨC100 dB (Measured with a ¨C30 dB/octave filter@22 kHz), adjacent INPUT/OMNI OUT channels, Input Gain=Min.¨C100 dB (Measured with a ¨C30 dB/octave filter@22 kHz), adjacent INPUT/OMNI OUT channels, Input Gain=Min.¨C100 dB (Measured with a ¨C30 dB/octave filter@22 kHz), adjacent INPUT/OMNI OUT channels, Input Gain=Min.¹©µçÒªÇó100¨C240 V 50/60 Hz100¨C240 V 50/60 Hz100¨C240 V 50/60 Hz¹¦ºÄ120 W110 W100 WÍâ¹Û³ß´ç¿í866 mm (34.1in)716 mm (28.2in)510 mm (20.1in)¸ß225 mm (8.9in)225 mm (8.9in)225 mm (8.9in)Éî599 mm (23.6in)599 mm (23.6in)599 mm (23.6in)¾»ÖØ20.0 kg (44.1lb)17.0 kg (37.5lb)13.5 kg (29.8lb)¸½¼þʹÓÃ˵Ã÷Êé, µçÔ´Ïß, CUBASE AI ÏÂÔØÐÅϢʹÓÃ˵Ã÷Êé, µçÔ´Ïß, CUBASE AI ÏÂÔØÐÅϢʹÓÃ˵Ã÷Êé, µçÔ´Ïß, CUBASE AI ÏÂÔØÐÅϢѡÅä¼þÀ©Õ¹¿¨, ½Å̤¿ª¹Ø (FC5)À©Õ¹¿¨, ½Å̤¿ª¹Ø (FC5)RK5014 »ú¼Ü°²×°Ì×¼þ, À©Õ¹¿¨, ½Å̤¿ª¹Ø (FC5)ÆäËûʹÓÃζȷ¶Î§: 0¨C40 ¡ãC, ´¢´æÎ¶ȷ¶Î§: -20¨C60 ¡ãCʹÓÃζȷ¶Î§: 0¨C40 ¡ãC, ´¢´æÎ¶ȷ¶Î§: -20¨C60 ¡ãCʹÓÃζȷ¶Î§: 0¨C40 ¡ãC, ´¢´æÎ¶ȷ¶Î§: -20¨C60 ¡ãC
Ä£ÄâÊäÈëÌØÐÔ
ÊäÈë¶Ë¿ÚÔöÒæÊäÈë
×迹±ê³ÆÓ¦ÓÃÊäÈëµçƽ½Ó¿Úƽºâ /
·ÇƽºâÁéÃô¶È*1±ê³ÆÊ§ÕæÇ°´óINPUT1-32 (TF5)
INPUT1-24 (TF3)
INPUT1-16 (TF1)+66dB7.5k¦¸50-600¦¸ Âó¿Ë·ç
»ò 600¦¸ Ïß·-82dBu (61.6¦ÌV)-62dBu (0.616mV)-42dBu (6.16mV)»ìºÏÐÍCombo½Ó¿Ú (XLR-3-31 type *2
or TRS phone *3)ƽºâʽ-6dB-10dBu (245mV)+10dBu (2.45V)+30dBu (24.5V)ST IN 1,2-10k¦¸600¦¸ Ïß·-30dBV (31.6¦ÌV)-10dBV (316mV)+10dBV (3.16V)RCA Pin JackUnbalanced
*1. ÁéÃô¶ÈÊǵ±É豸ÉèÓÚ´óÔöÒæÊ±£¨ËùÓÐË¥¼õÆ÷ºÍµçƽ¿ØÖÆÓÚ´óµÄλÖã©£¬µÍÄܲúÉú +4dBu (1.23V) Êä³ö»òÊÇ±ê³ÆÊä³öµçƽËùÐèÒªµÄµÍµçƽ¡£
*2. 1: µØ, 2: ÈÈ, 3: Àä
*3. Tip: HOT, Ring: COLD, Sleeve: GND
*4 ÔÚÒÔÉϲÎÊýÖÐ, 0dBu = 0.775Vrms.
*5.+48V DC (»ÃÏóµçÔ´) ¿Éͨ¹ýµ¥¸öÈí¼þ¿ª¹Ø±»ÓÃÓÚ INPUT XLR Àà½Ó¿Ú¡£
Ä£ÄâÊä³öÌØÐÔ
Êä³öÖÕ¶Ëʵ¼ÊÀ´Ô´×è ¿¹±ê³ÆÓ¦ÓÃÔöÒæ¿ª¹ØÊä³öµçƽ½Ó¿Úƽºâ /
·Çƽºâ±ê³ÆÊ§ÕæÇ°´óOMNI OUT 1-1675¦¸600¦¸ Ïß·¡°+24dBu¡± position (default)+4dBu (1.23 V)+24dBu (12.3 V)XLR-3-32 type *1ƽºâPHONES *5100¦¸40¦¸ ¶ú»ú¡ª3mW75mWStereo Phone Jack (TRS) *2Unbalanced
*1.1: µØ,2: ÈÈ, 3: Àä
*2. Tip: LEFT, Ring: RIGHT, Sleeve: GND
*3 ÉÏÊöÌØÐÔÒÔ 0dBu = 0.775VrmsΪ±ê×¼¡£
*4 ËùÓеÄÊýģת»»Æ÷¶¼ÊÇ 24bit, ÏßÐÔ128±¶³¬²ÉÑù¡£
*5 µçƽ¿ØÖÆÎ»ÓÉ´óÖµ½µÖÁ 16dB¡£
Êý×ÖÊäÈë/Êä³öÌØÐÔ
¶Ë×Ó¸ñʽÊý¾Ý³¤¶ÈÒôƵ½Ó¿ÚUSB (TO HOST)USB24bit34ch ÊäÈë / 34ch Êä³ö, PCMUSB (B Àà)iPadUSB-»Ø·Å: MP3 or WAV Îļþ¸ñʽ / ¼Òô: WAV Îļþ¸ñʽUSB (A Àà)
¿ØÖÆ I/O ÌØÐÔ
¶Ë×Ó¸ñʽ²ã½Ó¿ÚÍøÂçIEEE802.310BASE-T/100Base-TXRJ-45½Å̤¿ª¹Ø-- |
