[audio APP]ÊÕÒô»úÒôÁ¿¿ªµ½×î´ó¶¼Ã»ÓС°½«ÒôÁ¿µ÷¸ßµ½°²È«¼¶±ðÒÔÉÏ
tosdegs05h
2006-7-28 16:40:00
Ô­´´
[audio APP]ÊÕÒô»úÒôÁ¿¿ªµ½×î´ó¶¼Ã»ÓС°½«ÒôÁ¿µ÷¸ßµ½°²È«¼¶±ðÒÔÉÏ£¿»áËð»µÌýÁ¦¡±Ìáʾ
[DESCRIPTION]
²åÈë¶ú»ú¶Ë¿Ú,´ò¿ªÒôÀÖ¡£²à¼üÒôÁ¿¿ªµ½×î´ó£¬³öÏÖÌáʾ¿ò¡°½«ÒôÁ¿µ÷¸ßµ½°²È«¼¶±ðÒÔÉÏ£¿»áËð»µÌýÁ¦¡±ÕâÑùµÄÌáʾ¡£
¶øÍ¬ÑùµÄ·¾¶´ò¿ªÊÕÒô»ú£¬µã»÷²àÒôÁ¿¼ü°ÑÒôÁ¿µ÷µ½×î´ó£¬Ã»ÓÐÏàÓ¦µÄÌáʾ¡£
[SOLUTION]
ÐÞ¸Ä
1£¬privatestaticfinalintMSG_CHECK_FM_ACTIVE=29;
2£¬privatevoidonCheckFmActive(){
synchronized(mSafemediaVolumeState){
if(mSafeMediaVolumeState==SAFE_MEDIA_VOLUME_INACTIVE){
intdevice=getDeviceForStream(AudIOSystem.STREAM_FM);
if((device&mSafeMediaVolumeDevices)!=0){
sendMsg(mAudioHandler,MSG_CHECK_FM_ACTIVE,SENDMSG_REPLACE,0,0,null,
FM_ACTIVE_POLL_PERIOD_MS);
intindex=mStreamStates[Audiosystem.STREAM_FM]
.getIndex(device,false/*lastAudible*/);
if(AudioSystem.isStreamActive(AudioSystem.STREAM_FM,0)
&&(index>mSafeMediaVolumeIndex)){
//Approximatecumulativeactivemusictime
mFmems+=FM_ACTIVE_POLL_PERIOD_MS;
if(mFmeMs>UNSAFE_VOLUME_FM_ACTIVE_MS_MAX){
setSafeMediaVolumeenabled(true);
mFmeMs=0;
mVolumePanel.postdisplaySafeVolumeWarning();
3£¬ÔÚcaseMSG_CHECK_MUSIC_ACTIVE:
onCheckMusicActive();
break;
ºóÃæÔö¼Ó
///M:safemediaforFM@{
caseMSG_CHECK_FM_ACTIVE:
onCheckFmActive();
break;
///safemediaforFM@}
4£¬ÔÚprivatevoidonSetWiredDeviceConnectionState(intdevice,intstate,Stringname)
MSG_CHECK_MUSIC_ACTIVE,
SENDMSG_REPLACE,
0,
0,
null,
MUSIC_ACTIVE_POLL_PERIOD_MS);
ºóÃæÔö¼Ó
///safemediaforFM@{
///safemediaforFM@}
5£¬ÔÚprivatestaticfinalintSAFE_VOLUME_CONFIGURE_TIMEOUT_MS=30000;//30safterbootcompletedºóÃæÔö¼ÓÈçÏÂ
privateintmFmeMs;
privatestaticfinalintUNSAFE_VOLUME_FM_ACTIVE_MS_MAX=(20*3600*1000);//20
//hours
privatestaticfinalintFM_ACTIVE_POLL_PERIOD_MS=60000;//1minute
6£¬ÒÔϼ¸¸öº¯Êý¸ÄΪÈçÏÂ
privatevoidsetSafeMediaVolumeEnabled(booleanon){
synchronized(mSafeMediaVolumeState){
if((mSafeMediaVolumeState!=SAFE_MEDIA_VOLUME_NOT_CONFIGURED)
&&(mSafeMediaVolumeState!=SAFE_MEDIA_VOLUME_DISABLED)){
if(on&&(mSafeMediaVolumeState==SAFE_MEDIA_VOLUME_INACTIVE)){
mSafeMediaVolumeState=SAFE_MEDIA_VOLUME_ACTIVE;
enforceSafeMediaVolume();
}elseif(!on&&(mSafeMediaVolumeState==SAFE_MEDIA_VOLUME_ACTIVE)){
mSafeMediaVolumeState=SAFE_MEDIA_VOLUME_INACTIVE;
mMusicActiveMs=0;
sendMsg(mAudioHandler,MSG_CHECK_MUSIC_ACTIVE,SENDMSG_REPLACE,0,0,null,
mFmeMs=0;
privatevoidenforceSafeMediaVolume(){
enforceSafeMediaVolume(AudioSystem.STREAM_MUSIC);
enforceSafeMediaVolume(AudioSystem.STREAM_FM);
privatevoidenforceSafeMediaVolume(intstreamType){
VolumeStreamStatestreamState=mStreamStates[streamType];
booleanlastAudible=(streamState.muteCount()!=0);
intdevices=mSafeMediaVolumeDevices;
inti=0;
while(devices!=0){
intdevice=1<<i++;
if((device&devices)==0){
continue;
intindex=streamState.getIndex(device,lastAudible);
if(index>mSafeMediaVolumeIndex){
if(lastAudible){
streamState.setLastAudibleIndex(mSafeMediaVolumeIndex,device);
sendMsg(mAudioHandler,MSG_PERSIST_VOLUME,SENDMSG_QUEUE,PERSIST_LAST_AUDIBLE,
device,streamState,PERSIST_DELAY);
}else{
streamState.SETindex(mSafeMediaVolumeIndex,device,true);
sendMsg(mAudioHandler,MSG_SET_DEVICE_VOLUME,SENDMSG_QUEUE,device,0,
streamState,0);
devices&=~device;
privatebooleancheckSafeMediaVolume(intstreamType,intindex,intdevice){
if((mSafeMediaVolumeState==SAFE_MEDIA_VOLUME_ACTIVE)
&&(mStreamVolumeAlias[streamType]==AudioSystem.STREAM_MUSIC||mStreamVolumeAlias[streamType]==AudioSystem
.STREAM_FM)
&&((device&mSafeMediaVolumeDevices)!=0)&&(index>mSafeMediaVolumeIndex)){
mVolumePanel.postDisplaySafeVolumeWarning();
returnfalse;
returntrue;
///safemediaforFM@}
(alps/Frameworks/base/media/Java/android/media/AudioService.java)
È»ºó
mkxxx(project_name)mmframeworks/base
adbremount
adbpushframework.jarsystem/framework
adbreboot
¼´¿ÉÑéÖ¤¹¦ÄÜ¡£
