查看: 24978|回复: 10
[midi] MIDI 设备初始化大全
发表于 2006-6-26 19:03:00 | 显示全部楼层 |阅读模式
ALESIS ADAT HOLD PLAY AND RECORD WHILE POWERING ON. { "DRUM ON" HRS WILL NOT BE RESET. }
ALESIS ADAT-LX-20 HOLD RECORD WHILE POWERING ON. { "DRUM ON" HRS WILL NOT BE RESET. }
ALESIS ADAT-XT HOLD PLAY AND RECORD WHILE POWERING ON. { "DRUM ON" HRS WILL NOT BE RESET. }
ALESIS ADAT-XT-20 HOLD PLAY AND RECORD WHILE POWERING ON. { "DRUM ON" HRS WILL NOT BE RESET. }
ALESIS AI-2 HOLD STORE WHILE POWERING ON. { ADAT TAPE HEAD INFO WILL ALSO BE CLEARED. }
ALESIS BRC HOLD PLAY AND RECORD WHILE POWERING ON.
ALESIS D4 HOLD VOICE AND OUTPUT WHILE POWERING ON.
ALESIS DM5 HOLD VOICE AND OUTPUT WHILE POWERING ON.
ALESIS HR-16 HOLD ERASE, DELETE AND RECORD WHILE POWERING ON.
ALESIS HR-16B HOLD ERASE, DELETE AND RECORD WHILE POWERING ON.
ALESIS M-20 HOLD PLAY AND RECORD WHILE POWERING ON. { "DRUM ON" HRS WILL NOT BE RESET. }
ALESIS MIDIVERB 4 HOLD 'D' AND 'PROG' WHILE POWERING ON.
ALESIS MIDIVERB III HOLD STORE AND INT PROG WHILE POWERING ON.
ALESIS MMT-8 HOLD ERASE, PAGE UP AND PAGE DOWN WHILE POWERING ON.
ALESIS Q-20 SOFT RESET: HOLD PROGRAM AND COMPARE AND POWER ON. ( SETS GLOBAL TO DEFAULT, CLEARS EDIT BUFFER, LEAVES USER MEMORY INTACT. )
ALESIS Q-20 HARD RESET: HOLD "PROGRAM", "COMPARE" AND "-BLOCK" AND POWER ON. ( SETS ALL FUNCTIONS TO DEFAULT AND CLEARS USER MEMORY. )
ALESIS QS6 HOLD KEYPADS '0' AND '3' WHILE TURNING ON POWER.
ALESIS QS6 KEYBOARD HOLD KEYPADS '0' AND '3' WHILE TURNING ON POWER.
ALESIS QS7 HOLD KEYPADS '0' AND '3' WHILE TURNING ON POWER.
ALESIS QS8 HOLD KEYPADS '0' AND '3' WHILE TURNING ON POWER.
ALESIS QSR HOLD BOTH SIDES OF "CURSOR" BUTTON WHILE POWERING ON.
ALESIS QUADRASYNTH KBDS HOLD DATA BUTTONS '1' AND '4' WHILE POWERING ON. ( CLEARS EDIT BUFFER ONLY; THERE IS NO HARD RESET. )
ALESIS QUADRAVERB HOLD BYPASS AND PROGRAM THEN POWER ON.
ALESIS QUADRAVERB 2 SOFT RESET: HOLD PROGRAM AND COMPARE AND POWER ON. ( SETS GLOBAL TO DEFAULT, CLEARS EDIT BUFFER, LEAVES USER MEMORY INTACT. )
ALESIS QUADRAVERB 2 HARD RESET: HOLD "PROGRAM", "COMPARE" AND "-BLOCK" AND POWER ON. ( SETS ALL FUNCTIONS TO DEFAULT AND CLEARS USER MEMORY. )
ALESIS QUADRAVERB GT HOLD BYPASS AND PROGRAM WHILE TURNING ON THE POWER.
ALESIS S4 SOUND MODULE HOLD DATA BUTTONS '1' AND '4' WHILE POWERING ON. ( CLEARS EDIT BUFFER ONLY; THERE IS NO HARD RESET. )
ALESIS S8 SOUND MODULE HOLD DATA BUTTONS '1' AND '4' WHILE POWERING ON. ( CLEARS EDIT BUFFER ONLY; THERE IS NO HARD RESET. )
ALESIS SR-16 HOLD PLAY AND ERASE WHILE TURNING ON POWER.
ALESIS WEDGE HOLD BYPASS AND PROG WHILE TURNING ON THE POWER.
ALESIS X2 CONSOLE HOLD 'ALT', 'ERASE FWD' AND 'DEC' WHILE POWERING ON. ( THIS IS SOFT RESET; FACTORY MUTE PARAMETERS WILL BE LOADED INTO MEMORY. )
ART ALPHA PRESS PRESET, 0, AND 4 BUTTONS SIMULTANEOUSLY.
ART ALPHA 2.0 PRESS PRESET, 0, AND 4 BUTTONS SIMULTANEOUSLY.
ART BCC HOLD STORE, PARAMETER, AND VALUE BUTTONS + POWER ON.
ART DRX PRESS PRESET DOWN, 0, AND 4 BUTTONS SIMULTANEOUSLY.
ART DRX 2100 PRESS PRESET, 0, AND 4 BUTTONS SIMULTANEOUSLY.
ART DRX 2100 SE PRESS PRESET, 0, AND 4 BUTTONS SIMULTANEOUSLY.
ART DST 820 PRESS PREAMP SELECT, PARAMETER SELECT, AND SAVE SIMULTANEOUSLY.
ART DST 830 PRESS PREAMP SELECT, PARAMETER SELECT, AND SAVE SIMULTANEOUSLY.
ART DST-4 PRESS DISTORTION SELECT, PARAMETER EDIT, AND SAVE SIMULTANEOUSLY.
ART DST-EIGHTY/EIGHTY PRESS DISTORTION SELECT, PARAMETER EDIT, AND SAVE BUTTONS SIMULTANEOUSLY.
ART DXR ELITE PRESS BANK, SOFT KEY, AND BYPASS BUTTONS SIMULTANEOUSLY.
ART ECC HOLD STORE, PARAMETER, AND VALUE BUTTONS + POWER ON.
ART EFFECTS NETWORK PRESS VALUE, SAVE, AND BYPASS BUTTONS SIMULTANEOUSLY.
ART FXR ELITE PRESS PRESET UP, DRY KILL, AND BYPASS BUTTONS SIMULTANEOUSLY.
ART FXR ELITE II PRESS MIX, STORE, AND BYPASS BUTTONS SIMULTANEOUSLY.
ART MULTIVERB PRESS PRESET DOWN, 0, AND 4 SIMULTANEOUSLY.
ART MULTIVERB ALPHA SE PRESS PRESET, 0, AND 4 BUTTONS SIMULTANEOUSLY.
ART MULTIVERB EXT PRESS PRESET DOWN, 0, AND 4 SIMULTANEOUSLY.
ART MULTIVERB II PRESS PRESET DOWN, 0, AND 4 SIMULTANEOUSLY.
ART MULTIVERB III PRESS PRESET DOWN, 0, AND 4 BUTTONS SIMULTANEOUSLY.
ART MULTIVERB LT no factory reset, remove battery for more than 5 hours.
ART MULTIVERB LTX no factory reset, remove battery for more than 5 hours.
ART NIGHT BASS PRESS PRESET, 0, AND 4 BUTTONS SIMULTANEOUSLY.
ART NITRO PRESS PRESET, 0, AND 4 BUTTONS SIMULTANEOUSLY.
ART PRO GATE PRESS BYPASS, 8, AND SELECT SIMULTANEOUSLY.
ART PROVERB no factory reset. remove battery for more than 5 hours.
ART PROVERB 200 no factory reset. remove battery for more than 5 hours.
ART RXR ELITE PRESS BANK, DRY KILL, AND BYPASS BUTTONS SIMULTANEOUSLY.
ART SGE HOLD PRESET DOWN, ADD EFFECT, AND MIDI/UTILITY WHILE POWERING ON.
ART SGE MACH II PRESS PRESET DOWN, 0, AND 4 BUTTONS SIMULTANEOUSLY.
ART SGX 2000 PRESS PRESET, 0, AND 4 BUTTONS SIMULTANEOUSLY.
ART SGX 2000 EXPRESS PRESS PRESET, 0, AND 4 BUTTONS SIMULTANEOUSLY.
ART SGX LT no factory reset, remove battery for more than 5 hours.
ART SGX NIGHTBASS SE PRESS PRESET, 0, AND 4 BUTTONS SIMULTANEOUSLY.
ART SGX T2 PRESS PRESET, 0, AND 4 BUTTONS SIMULTANEOUSLY.
ART X12 PRESS UP, 2, AND 5 PADS SIMULTANEOUSLY.
ART X15 ULTRAFOOT PRESS UP, 1, AND 5 PADS SIMULTANEOUSLY.
6516
 楼主| 发表于 2006-6-26 19:03:00 | 显示全部楼层
DIGITECH DHP 33 PRESS UTILITY BUTTON, SCROLL TO THE FACTORY RESTORE MENU, TURN EITHER DATA KNOB COUNTER-CLOCKWISE, THEN PRESS STORE.
DIGITECH DHP 55 PRESS UTILITY BUTTON, SCROLL TO THE FACTORY RESTORE MENU, PRESS PARAMETER EDIT, THEN LOAD.
DIGITECH DSP 128 HOLD PARAMETER EFFECT AND SELECT, THEN POWER ON.
DIGITECH DSP 128+ HOLD PARAMETER DOWN AND LEFT, THEN POWER ON.
DIGITECH DSP 256 HOLD UTILITY, POWER ON, THEN PRESS PARAMETER UP.
DIGITECH DSP 256XL HOLD UTILITY, POWER ON, THEN PRESS PARAMETER UP.
DIGITECH FX 7 PRESS/HOLD STORE, POWER ON, WAIT UNTIL "RS" APPEARS IN THE DISPLAY THEN RELEASE STORE.
DIGITECH G7 PRESS AND HOLD PROGRAM, POWER ON THEN PRESS THE STORE BUTTON.
DIGITECH GFX 1 HOLD UTILITY BUTTON, POWER ON, THEN PRESS PARAMETER UP.
DIGITECH GSP 21 HOLD TITLE BUTTON, POWER ON.
DIGITECH GSP 21 LEGEND HOLD UTILITY BUTTON, POWER ON, THEN PRESS PARAMETER UP.
DIGITECH GSP 21 PRO HOLD UTILITY BUTTON, POWER ON, THEN PRESS PARAMETER UP.
DIGITECH GSP 2112 HOLD THE PREAMP BUTTON, POWER ON. WHEN THE ASTERISK APPEARS IN THE TOP OF THE DISPLAY, PRESS THE MOD BUTTON.
DIGITECH GSP 5 HOLD PARAMETER DOWN THEN POWER ON.
DIGITECH GSP 7 HOLD UTILITY BUTTON, POWER ON, THEN PRESS PARAMETER UP.
DIGITECH GSP2101 HOLD ACCESS 1 BUTTON, POWER ON. AFTER * APPEARS IN THE UPPER LEFT OF THE LCD PRESS PROGRAM UP
DIGITECH IPS 33 HOLD BOTH FUNCTION SELECT BUTTONS THEN POWER ON.
DIGITECH IPS 33B PRESS UTILITY BUTTON, SCROLL TO THE FACTORY RESTORE MENU, PRESS PARAMETER DOWN, THEN STORE.
DIGITECH LEGEND II HOLD STORE, POWER ON. AFTER * APPEARS IN THE UPPER LEFT CORNER OF THE LCD PRESS PARAMETER UP.
DIGITECH MEQ 14 HOLD PROGRAM BUTTON THEN POWER ON.
DIGITECH MEQ 28 HOLD PROGRAM BUTTON THEN POWER ON.
DIGITECH MEQ 7 HOLD PROGRAM BUTTON THEN POWER ON.
DIGITECH MSP 4 HOLD THE DOWN AND LEFT BUTTONS THEN POWER ON.
DIGITECH PMC 10 PRESS AND HOLD FOOTSWITCH "ONE", POWER ON, THEN PRESS THE "SELECT" FOOTSWITCH.
DIGITECH RP 1 HOLD UTILITY BUTTON, POWER ON, THEN PRESS PARAMETER UP.
DIGITECH RP 10 HOLD NAME, POWER ON. AFTER * APPEARS IN THE UPPER LEFT CORNER OF LCD PRESS PROGRAM UP.
DIGITECH RP 12 HOLD NAME, POWER ON. AFTER * APPEARS IN THE UPPER LEFT CORNER OF LCD PRESS PROGRAM UP.
DIGITECH RP 5 HOLD PARAMETER SELECT UP BUTTON THEN POWER ON.
DIGITECH RP 6 HOLD PARAMETER SELECT UP BUTTON THEN POWER ON.
DIGITECH S-5000 PRESS UTILITY BUTTON, SCROLL TO THE FACTORY RESTORE MENU, PRESS PARAMETER EDIT, THEN LOAD.
DIGITECH STUDIO 400 PRESS AND HOLD THE "1" BUTTON, POWER ON. WHEN THE ASTERISK APPEARS IN THE TOP OF THE DISPLAY, PRESS PROGRAM.
DIGITECH STUDIO QUAD PRESS AND HOLD THE "1" BUTTON, POWER ON. WHEN THE ASTERISK APPEARS IN THE TOP OF THE DISPLAY, PRESS PROGRAM.
DIGITECH SV 5 PRESS UTILITY BUTTON, SELECT THE INIT MENU, PRESS THE STORE BUTTON TWICE (AS PROMPTED).
DIGITECH TEC 8 PRESS AND HOLD BOTH LOW EQ AND MID EQ, POWER ON.
DIGITECH TSR 12 HOLD NAME + POWER ON. AFTER * APPEARS IN THE UPPER LEFT CORNER OF LCD PRESS PROGRAM UP.
DIGITECH TSR 24 HOLD ACCESS 1 BUTTON, POWER ON. AFTER * APPEARS IN THE UPPER LEFT OF THE LCD PRESS PROGRAM UP.
DIGITECH TSR 6 PRESS AND HOLD EQ BUTTON, POWER ON. WAIT FOR "FA" TO APPEAR IN THE DISPLAY THEN PRESS STORE. NOTE: "FH" WILL APPEAR BRIEFLY TO ACKNOWLEDGE RE-INITIALIZATION.
DIGITECH VALVE FX HOLD STORE, POWER ON. AFTER * APPEARS IN THE UPPER LEFT CORNER OF LCD PRESS PARAMETER UP.
DIGITECH VHM 5 PRESS UTILITY BUTTON, SCROLL TO THE FACTORY RESTORE MENU, PRESS PARAMETER DOWN, THEN STORE.
DIGITECH VOCALIST II PRESS UTILITY BUTTON, SCROLL TO THE FACTORY RESTORE MENU, PRESS PARAMETER DOWN, THEN STORE.
DIGITECH XP PEDALS PRESS/HOLD THE BYPASS/(HOLD)TUNER FOOTSWITCH AND POWER ON.
6516
ENSONIQ DP-PRO HOLD SYSTEM BUTTON AND PRESS CANCEL. RELEASE BOTH BUTTONS, PRESS ENTER.
ENSONIQ DP/2 HOLD SYSTEM/MIDI AND PRESS THE "B" BUTTON, THEN RELEASE BOTH. PRESS RIGHT ARROW ONCE. PRESS WRITE BUTTON AT PROMPT.
ENSONIQ DP/4 HOLD SYSTEM/MIDI AND PRESS THE "B" BUTTON, THEN RELEASE BOTH. PRESS RIGHT ARROW ONCE. PRESS WRITE BUTTON AT PROMPT.
ENSONIQ DP/4+ HOLD SYSTEM/MIDI AND PRESS THE "B" BUTTON, THEN RELEASE BOTH. PRESS RIGHT ARROW ONCE. PRESS WRITE BUTTON AT PROMPT.
ENSONIQ ESQ-M PRESS PARAM, PRESS STORAGE. HOLD SCROLL, PRESS MASTER. RELEASE BOTH, SCROLL TO SELECT MEMORY PRESET PAGE. HOLD SCROLL, PRESS STORAGE. RELEASE BOTH, PRESS ( [ ).
ENSONIQ FIZMO HOLD THE SAVE BUTTON AND PRESS COMPARE. PRESS THE YES BUTTON AT THE PROMPT.
ENSONIQ FIZMO RACK HOLD THE SAVE BUTTON AND PRESS COMPARE. PRESS THE YES BUTTON AT THE PROMPT.
ENSONIQ KS-32 PRESS EDIT/SEQUENCES (PRESETS). PRESS AND HOLD BANK 9 (SYSTEM) AND THEN PRESS SCREEN 9. RELEASE BOTH AND PRESS YES AT THE PROMPT.
ENSONIQ KT-76 PRESS EDIT/SEQUENCES (PRESETS). PRESS AND HOLD THE UPPER 9 BUTTON AND THEN PRESS THE LOWER 9.RELEASE BOTH AND PRESS YES AT THE PROMPT.
ENSONIQ KT-88 PRESS EDIT/SEQUENCES (PRESETS). PRESS AND HOLD THE UPPER 9 BUTTON AND THEN PRESS THE LOWER 9.RELEASE BOTH AND PRESS YES AT THE PROMPT.
ENSONIQ MR-61/76 HOLD THE ERASE BUTTON (IN THE SONG EDITOR SECTION) AND POWER ON.
ENSONIQ MR-RACK HOLD SAVE AND PRESS ENTER, THEN PRESS ENTER AT THE PROMPT.
ENSONIQ SD-1 HOLD PRESET BUTTON AND PRESS SOFT #1 BUTTON (UPPER LEFT CORNER OF SCREEN). RELEASE BOTH, PRESS YES AT THE PROMPT.
ENSONIQ SQ-1 ( 21 VOICE ) PRESS EDIT/SEQUENCES (PRESETS). PRESS AND HOLD BANK 9 (SYSTEM) AND THEN PRESS SCREEN 9. RELEASE BOTH AND PRESS YES AT THE PROMPT.
ENSONIQ SQ-1/32 PRESS EDIT/SEQUENCES (PRESETS). PRESS AND HOLD BANK 9 (SYSTEM) AND THEN PRESS SCREEN 9. RELEASE BOTH AND PRESS YES AT THE PROMPT.
ENSONIQ SQ-2 ( 21 VOICE ) PRESS EDIT/SEQUENCES (PRESETS). PRESS AND HOLD BANK 9 (SYSTEM) AND THEN PRESS SCREEN 9. RELEASE BOTH AND PRESS YES AT THE PROMPT.
ENSONIQ SQ-2/32 PRESS EDIT/SEQUENCES (PRESETS). PRESS AND HOLD BANK 9 (SYSTEM) AND THEN PRESS SCREEN 9. RELEASE BOTH AND PRESS YES AT THE PROMPT.
ENSONIQ SQ-80 HOLD THE RECORD BUTTON AND PRESS THE #1 SOFT BUTTON (UPPER LEFT CORNER OF SCREEN). RELEASE BOTH BUTTONS, PRESS YES AT THE PROMPT.
ENSONIQ SQ-R HOLD SYSTEM BUTTON. QUICKLY PRESS "NO" THEN RELEASE BOTH BUTTONS. PRESS YES AT PROMPT.
ENSONIQ TS-10 HOLD PRESETS BUTTON AND PRESS SOFT 1 BUTTON (UPPER LEFT CORNER OF DISPLAY). RELEASE BOTH BUTTONS. SELECT YES AT THE PROMPT.
ENSONIQ TS-12 HOLD PRESETS BUTTON AND PRESS SOFT 1 BUTTON (UPPER LEFT CORNER OF DISPLAY). RELEASE BOTH BUTTONS. SELECT YES AT THE PROMPT.
ENSONIQ VFX HOLD PRESETS BUTTON, PRESS SOFT 1 BUTTON (UPPER LEFT CORNER OF SCREEN). SELECT YES AT PROMPT.
ENSONIQ VFX/SD HOLD PRESET BUTTON AND PRESS SOFT #1 BUTTON (UPPER LEFT CORNER OF SCREEN). RELEASE BOTH, PRESS YES AT THE PROMPT.
ENSONIQ ZR-76 HOLD THE ERASE BUTTON (IN THE SONG EDITOR SECTION) AND POWER ON.
KORG 01W HOLD RESET AND COMPARE THEN POWER ON.
KORG 01WFD HOLD RESET AND COMPARE THEN POWER ON.
KORG A1 HOLD WRITE AND -1 THEN POWER ON.
KORG A2 HOLD DOWN ARROW AND UP ARROW, POWER ON, PRESS "E" (YES).
KORG A3 HOLD DOWN ARROW AND UP ARROW, POWER ON, PRESS "E" (YES).
KORG A4 HOLD WRITE AND BYPASS, THEN POWER ON.
KORG AM8000-R HOLD FX1 AND FX2 THEN POWER ON.
KORG C-505 MIDI/TRANSPOSE + SPLIT AND RESTART UNIT.
KORG DDD-1 HOLD YES AND NO, THEN POWER ON.
KORG DL8000-R HOLD "MS/D" AND "HOLD", THEN POWER ON.
KORG DS-8/707 HOLD UP AND DOWN, THEN POWER ON.
KORG I1 HOLD PROGRAM AND DISK, THEN POWER ON.
KORG I2 HOLD ARR PLAY AND EDIT STYLE THEN POWER ON.
KORG I3 HOLD ARR PLAY AND EDIT STYLE THEN POWER ON.
KORG I30 HOLD ARRANGE PLAY AND GLOBAL, THEN POWER ON.
KORG I4S HOLD ARR. PLAY AND PROGRAM, THEN POWER ON.
KORG I5M HOLD ARR. PLAY AND GLOBAL, THEN POWER ON.
KORG I5S HOLD ARR. PLAY AND GLOBAL, THEN POWER ON.
KORG IH HOLD DETUNE AND BASS, THEN POWER ON.
KORG IS40/50/I40M HOLD ARR. PLAY AND GLOBAL, THEN POWER ON.
KORG KARMA HOLD ENTER AND 0, THEN POWER ON.
KORG M1 HOLD INT, CARD, AND COMBI THEN POWER ON.
KORG M1R HOLD INT, PROG, AND COMBI THEN POWER ON.
KORG M3R PAGE 5D OF GLOBAL MODE.
KORG N264 HOLD ENTER AND 7, THEN POWER ON.
KORG N364 HOLD ENTER AND 7, THEN POWER ON.
KORG O5RW HOLD +1 AND -1 THEN POWER ON.
KORG SG-PROX HOLD PROGRAM AND PIANO 1, THEN POWER ON.
KORG SG-RACK HOLD EDIT AND A4, THEN POWER ON.
KORG T SERIES HOLD LOWER KEYPAD 0 AND PROG A, POWER ON, AND THEN IMMEDIATELY TURN OFF.
KORG TR-RACK HOLD EDIT AND A4, THEN POWER ON.
KORG TRITON HOLD ENTER AND 0, THEN POWER ON.
KORG TRITON RACK HOLD ENTER AND 0, THEN POWER ON.
KORG X3 HOLD ENTER AND CURSOR DOWN THEN POWER ON.
KORG X3R HOLD ENTER AND CURSOR DOWN THEN POWER ON.
KORG X5 HOLD +1 AND -1, THEN POWER ON.
KORG X5D HOLD +1 AND -1 THEN POWER ON.
KORG X5DR HOLD +1 AND -1 THEN POWER ON.
KORG Z1 HOLD SW1 AND SW2, THEN POWER ON.
KORG Z1EX HOLD SW1 AND SW2, THEN POWER ON.
KURZWEIL K2000 HOLD "1", "2" AND "3" BUTTONS AND POWER ON. AFTER POWER UP PRESS ENTER. {EXCEPT V1.0 OS )
KURZWEIL K2000 OS VERSION 1.O: POWER OFF AND UNPLUG. REMOVE BATTERIES FOR @ 60-90 MINUTES. REINSTALL BATTERIES. POWER ON.
KURZWEIL K2500 AT POWER ON WHEN SCREEN DISPLAYS "PLEASE WAIT" PRESS THE EXIT BUTTON. AT MENU, SELECT HARD RESET AND FOLLOW DIRECTIONS.
OBERHEIM MATRIX-6 HOLD STORE WHILE POWERING ON.
6516
 楼主| 发表于 2006-6-26 19:04:00 | 显示全部楼层
PEAVEY ADDVERB HOLD THE - AND 5 KEYS THEN POWER ON.
PEAVEY ADDVERB II HOLD THE - AND 5 KEYS THEN POWER ON.
PEAVEY ADDVERB III HOLD THE ADD/DEL AND GLOBAL BUTTONS, POWER ON.
PEAVEY AEQ 2800 HOLD THE MIDI AND ASSIGN KEYS THEN POWER ON.
PEAVEY AUTOGRAPH HOLD THE MIDI AND ASSIGN KEYS THEN POWER ON.
PEAVEY BASSFEX HOLD THE PLAY AND GLOBAL BUTTONS THEN POWER ON.
PEAVEY CEQ 28 HOLD THE MIDI AND ASSIGN KEYS THEN POWER ON.
PEAVEY CEX 4 HOLD THE MASTER AND STORE/MEMORY BUTTONS THEN POWER ON.
PEAVEY CEX 4L HOLD THE MASTER AND STORE/MEMORY BUTTONS THEN POWER ON.
PEAVEY CYBERBASS (MODULE) HOLD THE PROGRAM AND RIGHT CURSOR BUTTONS THEN POWER ON.
PEAVEY DPM 2 HOLD 0 BUTTON, PRESS ENTER. RELEASE BOTH BUTTONS AND PRESS ENTER.
PEAVEY DPM 4 HOLD SAVE BUTTON, PRESS PAUSE. PRESS ENTER WHEN PROMPTED.
PEAVEY DPM C8 HOLD THE 0 AND ENTER BUTTONS, POWER ON, WAIT FORTHE "UNIT INITIALIZED" DISPLAY THEN RELEASE THE BUTTONS.
PEAVEY DPM C8P HOLD THE 0 AND COPY BUTTONS, POWER ON, WAIT FOR THE "UNIT INITIALIZED" DISPLAY THEN RELEASE THE BUTTONS.
PEAVEY DPM SI TURN POWER ON. HOLD '0' AND PRESS ENTER. PRESS ENTER AT THE PROMPT TO RE-INITIALIZE KEYBOARD.
PEAVEY DSR 1000 HOLD THE - AND 5 KEYS THEN POWER ON.
PEAVEY LIBRARIAN HOLD LOAD, SAVE, AND UTIL BUTTONS AND POWER ON.
PEAVEY MAP 8X4 HOLD BYPASS + POWER WHILE PLUGGING UNIT IN.
PEAVEY MFP 2128/MIDI MANA HOLD + AND - KEYS THEN POWER ON.
PEAVEY MIDI MANAGER HOLD + AND - KEYS THEN POWER ON.
PEAVEY MIDI MASTER HOLD FUNCTION AND PROC A KEYS THEN POWER ON.
PEAVEY MIDI MASTER II HOLD FUNCTION AND PROC A KEYS THEN POWER ON.
PEAVEY MIDI STREAMER HOLD THE RECORD (SYSX, SAMP, + SEQ) KEYS AND POWER ON. AT PROMPT PRESS START TO RE-INITIALIZE.
PEAVEY MULTIFEX HOLD THE 2 KEYS NEXT TO DISPLAY AND POWER ON.
PEAVEY PC 1600 HOLD THE UTILITY + ENTER KEYS AND POWER ON.
PEAVEY PC4-X HOLD THE MASTER + MIDI KEYS AND POWER ON.
PEAVEY PC4-XL HOLD THE MASTER + MIDI KEYS AND POWER ON.
PEAVEY PGP 20 HOLD THE A/B + MUTE KEYS AND POWER ON.
PEAVEY PLM 8128 PRESS TWO RIGHT-MOST SOFT KEYS IN BOTTOM ROW AND POWER ON. (VCA CAL UNAFFECTED)
PEAVEY PLM 8128E HOLD THE SOLO AND MUTE KEYS, POWER ON. (VCA CAL UNAFFECTED)
PEAVEY PROFEX HOLD THE PLAY AND MIDI KEYS THEN POWER ON.
PEAVEY PROFEX II HOLD THE PLAY AND GLOBAL BUTTONS, POWER ON.
PEAVEY PROGRAMAX HOLD THE A/B AND MUTE KEYS THEN POWER ON.
PEAVEY PV LITE 3000 FACTORY PRESETS: HOLD CHASE + AUTO SOUND, POWER ON. HARD RESET: HOLD DOWN + STORE, POWER ON. IN BOTH CASES, HOLD UNTIL 00 APPEARS IN THE DISPLAY.
PEAVEY SDR 20/20 HOLD THE PLAY AND STORE KEYS WHILE POWERING ON.
PEAVEY SPECTRUM ANALOG FI HOLD THE DEC AND EXEC BUTTONS, POWER ON. ( TO INIT. FOR USE W/ CYBERBASS, HOLD DEC AND BYPASS THEN POWER ON.
PEAVEY SPECTRUM BASS II HOLD THE + AND - BUTTONS THEN POWER ON.
PEAVEY SPECTRUM ORGAN HOLD THE + AND - BUTTONS THEN POWER ON.
PEAVEY SPECTRUM SYNTH HOLD THE + AND - BUTTONS THEN POWER ON.
PEAVEY ULTRAVERB HOLD THE - AND 5 KEYS THEN POWER ON.
PEAVEY ULTRAVERB II HOLD THE + AND 9 BUTTONS THEN POWER ON.
ROLAND A-220 HOLD B AND MEMORY THEN POWER ON.
ROLAND A-30 HOLD WRITE WHILE POWERING ON (30 SECONDS)
ROLAND A-33 HOLD WRITE WHILE POWERING ON (30 SECONDS)
ROLAND A-37 HOLD WRITE BUTTON AND POWER ON. DISPLAY SHOWS FACTORY SETUP AT COMPLETION.
ROLAND A-50 HOLD 1ST+3RD+4TH BUTTONS UNDER DISPLAY, PRESS CHANNEL, THEN PRESS ANY CURSOR KEY.
ROLAND A-80 HOLD 1ST+3RD+4TH BUTTONS UNDER DISPLAY, PRESS CHANNEL, THEN PRESS ANY CURSOR KEY.
ROLAND A-880 HOLD SIGNAL AND MEMORY THEN POWER ON.
ROLAND A-90 HOLD EDIT, POWER ON THEN PRESS ENTER. WITH VOICE EXPANDER BOARD: HOLD MANUAL, POWER ON, THEN PRESS ENTER.
ROLAND A90EX HOLD MANUAL BUTTON AND POWER ON. THEN PRESS ENTER.
ROLAND ADA-8024 no rom reset.
ROLAND ALPHA JUNO-1 no rom reset.
ROLAND ALPHA JUNO-2 no rom reset.
ROLAND AP-700 PWR ON, EXIT REPEATEDLY TO ANALYZER/FILTER SCREEN. CURSOR TO: MENU + ENTER, SYSTEM + ENTER, INIT + ENTER. USE VALUE SELECT ALL THEN EXEC + ENTER TWICE.
ROLAND AR SERIES no rom reset.
ROLAND AT SERIES HOLD ONE TOUCH PROGRAM + POWER ON.
ROLAND AX-1 HOLD WRITE BUTTON + POWER ON (HOLD 30 SECONDS).
ROLAND AXIS-1 POWER ON. HOLD FUNCTION; PRESS F#0, C#2, AND D#2 KEYS.
ROLAND CA-30 RESETS EVERY TIME TOGGLED OF AND THEN ON.
ROLAND CDX1 PRESS UTILITY. CURSOR RIGHT, SELECT INIT AND PRESS ENTER THEN CURSOR TO GLOBAL. PRESS ENTER THREE TIMES.
ROLAND CR ( ALL OTHER) no rom reset.
ROLAND CR-80 DEL + REPEAT + POWER ON, THEN PRESS ENTER.
ROLAND CSQ SERIES no rom reset.
ROLAND D-10 HOLD TUNE/FUNCTION AND WRITE WHILE POWERING ON.
ROLAND D-110 no rom reset.
ROLAND D-20 HOLD TUNE/FUNCTION AND WRITE WHILE POWERING ON.
ROLAND D-5 no rom reset.
ROLAND D-50 TUNE/FUNCTION AND MIDI DATA INIT: HOLD 0 AND DATA TRANSFER, POWER ON. PATCH + REVERB MUST BE LOADED FROM CARD OR SYSEX FILE.
ROLAND D-550 TUNE/FUNCTION AND MIDI DATA INIT: HOLD PATCH BANK 2, PATCH NUMBER6, AND ENTER, POWER ON. PATCH AND REVERD DATA MUST BE LOADED FROM CARD OR SYSEX FILE.
6516
ROLAND D-70 HOLD BANK 8 WHILE POWERING ON. PRESS ENTER, THENPRESS WRITE TWICE.
ROLAND D2 HOLD WRITE + PRESS SYSTEM. PRESS ENTER TWICE.
ROLAND DDR-30 HOLD #1 BUTTON AND POWER ON.
ROLAND DEP-3 MEMORY NO UP AND DOWN BUTTONS WHILE POWERING ON.
ROLAND DEP-5 MEMORY NO UP AND DOWN BUTTONS WHILE POWERING ON.
ROLAND DJ-70 no rom reset.
ROLAND DJ-70MKII no rom reset.
ROLAND DM SERIES no rom reset.
ROLAND DR-202 HOLD MUTE + ROLL AND POWER ON. VALUE DIAL TO SELECT 'ALL', THEN PRESS TAP/ENTER TWICE.
ROLAND DR-5 FRET LEFT + FRET RIGHT + POWER ON; 2 X ENTER.
ROLAND DR-550 HOLD -1 AND +1 AND POWER ON, THEN PRESS START.
ROLAND DR-550MKII HOLD -1 AND +1 AND POWER ON, THEN PRESS START.
ROLAND DR-660 UTILITY THEN CURSOR TO SELECT (8) INIT; 2 X ENTER.
ROLAND DR-670 HOLD RECORD + STOP/CONT BUTTONS AND POWER ON. PRESS ENTER TWICE.
ROLAND DR-770 PRESS UTILITY AND THEN CURSOR RT TO 9.F.RST. VALUE DIAL TO SELECT ALL, AND THEN PRESS ENTER TWICE.
ROLAND DS-330 HOLD REVERB + SPLIT AND POWER ON; PRESS YES.
ROLAND E-10 HOLD WRITE WHILE TURNING POWER ON.
ROLAND E-12 no rom reset.
ROLAND E-14US resets at power on.
ROLAND E-15 resets at power on.
ROLAND E-16 resets at power on.
ROLAND E-20 HOLD WRITE + POWER ON.
ROLAND E-28US resets at power on.
ROLAND E-30 HOLD WRITE + POWER ON.
ROLAND E-35 HOLD REC/PUNCH IN + POWER ON.
ROLAND E-36 RECORDER + POWER ON.
ROLAND E-5 no rom reset.
ROLAND E-56 HOLD WRITE + POWER ON.
ROLAND E-66 RECORD (IN DISK RECORDER SECTION) + POWER ON.
ROLAND E-68US HOLD WRITE + POWER ON.
ROLAND E-70 HOLD WRITE + POWER ON.
ROLAND E-86 HOLD WRITE + POWER ON.
ROLAND E-96 HOLD WRITE + POWER ON.
ROLAND E300 PRESS UTILITY. USE BUTTONS BELOW 'PAGE' TO SELECT FACTORY PRESET. PRESS EXECUTE, THEN OK. WHEN RESET COMPLETE POWER OFF, THEN ON.
ROLAND E500 PRESS UTILITY. USE BUTTONS BELOW 'PAGE' TO SELECT FACTORY PRESET. PRESS EXECUTE, THEN OK. WHEN RESET COMPLETE POWER OFF, THEN ON.
ROLAND E600 PRESS UTILITY. USE PAGE BUTTONS TO SELECT FACTORY PRESET, THEN EXECUTE.
ROLAND EF303 HOLD SHIFT AND THEN POWER ON. PRESS WRITE TWICE,THEN POWER OFF AN ON AGAIN.
ROLAND EM-10 HOLD WRITE AND POWER ON.
ROLAND EM-101 no rom reset.
ROLAND EM-15 HOLD THE WRITE BUTTON WHILE TURNING ON THE POWER.
ROLAND EM-20 HOLD WRITE AND POWER ON.
ROLAND EM-25 HOLD THE WRITE BUTTON WHILE TURNING ON THE POWER.
ROLAND EM-30 HOLD WRITE AND POWER ON.
ROLAND EM-303 resets at power on.
ROLAND EM-305 resets at power on.
ROLAND EM-50 HOLD WRITE AND POWER ON.
ROLAND EP (ALL OTHER) no rom reset.
ROLAND EP-3 resets at power on.
ROLAND EP-5 HOLD REC + PLAY, PRESS STRINGS, POWER OFF / ON.
ROLAND EP-7 HOLD REC + PLAY, PRESS STRINGS, POWER OFF / ON.
ROLAND EP-707 resets at power on.
ROLAND EP-75 HOLD REC AND POWER ON.
ROLAND EP-7MKII HOLD REC + PLAY, PRESS STRINGS, POWER OFF AND ON.
ROLAND EP-85 HOLD REC AND POWER ON.
ROLAND EP-9 HOLD REC + PLAY, PRESS CHOIR, POWER OFF AND ON.
ROLAND EP-95 HOLD REC BUTTON WHILE POWERING ON.
ROLAND FA76 PRESS MENU THEN UP/DOWN TO FACTORY PRESET. PRESSF8 TWICE ( SELECT THEN EXECUTE ) TO RESET.
ROLAND FANTOM PRESS MENU THEN UP/DOWN TO FACTORY PRESET. PRESSF8 TWICE ( SELECT THEN EXECUTE ) TO RESET.
ROLAND FC-100 no rom reset.
ROLAND FC-100MKII HOLD #1 + #2 + #8 AND POWER ON.
ROLAND FC-200 HOLD #10 AND POWER ON, THEN PRESS CTL PEDAL.
ROLAND FG-10 HOLD CLEAR AND EXIT THEN POWER ON.
ROLAND FG-1000 HOLD CLEAR AND EXIT THEN POWER ON.
ROLAND FP-1 resets at power on.
ROLAND FP-8 PRESS FUNC AND RELEASE HOLD PIANO PRESS FUNC AGAIN.
ROLAND FP-9 resets at power on.
ROLAND G-600 HOLD WRITE AND POWER ON.
ROLAND G-800 HOLD WRITE, THEN POWER ON.
ROLAND GC-8 no rom reset.
ROLAND GI-10 HOLD PARAMETER + AND -, POWER ON THEN PRESS VALUE +.
ROLAND GM-70 POLY MODE: HOLD PLAY, GENERAL EDIT, + IND EDIT THEN POWER ON. MONO MODE: HOLD TUNE, CONTROL ASSIGN, AND DATA TRANSFER THEN POWER ON.
ROLAND GP-100 HOLD IN PARAMETER KNOB, POWER ON, PRESS WRITE.
ROLAND GP-16 HOLD #6, #7, #8, THEN POWER ON. USE FUNCTION LEFT AND RUGHT TO SELECT "2. ALL FACTORY PRESET"THEN PRESS WRITE 3 TIMES.
ROLAND GP-8 no rom reset.
ROLAND GR (ALL OTHER) no rom reset.
ROLAND GR-09 HOLD PEDAL #2 THEN POWER ON. PRESS VALUE+ THEN PRESS EDIT/PLAY.
ROLAND GR-1 HOLD WRITE/COPY THEN POWER ON THEN PRESS YES.
ROLAND GR-30 HOLD PEDAL #2, POWER ON. PRESS PATCH + TO SELECT INIT. PRESS EDIT/PLAY, THEN PATCH + AND - SIMULTANEOUSLY.
ROLAND GR-33 PRESS SYSTEM THEN PARAMETER, USE VALUE DIAL TO SELECT ALL. PRESS WRITE TWICE.
ROLAND GR-50 no rom reset.
ROLAND GS-6 no rom reset.
ROLAND GT-3 HOLD MOD AND SFX AND POWER ON. PRESS WRITE.
ROLAND GT-5 HOLD MOD + FEED BACKER/SLOW GEAR, POWER ON. THEN PRESS WRITE.
ROLAND GX-700 PRESS TUNER/UTILITY. USE PARAMETER LEFT AND RIGHT TO SELECT FACT INIT. CURSOR TO LEFT, DIAL SYSTEM, THEN RIGHT AND DIAL P#100. PRESS WRITE THEN TUNER/UTILITY.
6516
 楼主| 发表于 2006-6-26 19:05:00 | 显示全部楼层
ROLAND HP (ALL OTHER) resets at power on.
ROLAND HP-100 no rom reset.
ROLAND HP-300 no rom reset.
ROLAND HP-400 no rom reset.
ROLAND HS SERIES no rom reset.
ROLAND JD-800 PRESS DATA TRANSFER. PAGE UP TO SELECT FACTORY PRESET, PRESS YES.
ROLAND JD-990 HOLD EXIT AND PRESS UTILITY. PRESS F6 THEN F5.
ROLAND JP-6 no rom reset.
ROLAND JP-8 no rom reset.
ROLAND JP-8000 HOLD SHIFT, PRESS INIT/BULK. PRESS BUTTON 7, USE UP/DOWN (SELECT FACTORY RESET), PRESS WRITE TO SELECT FACTORY PRESETS.
ROLAND JS-30 HOLD RECORD BUTTON (SEQUENCER SECTION), POWER ON.
ROLAND JUN0-106 no rom reset.
ROLAND JUN0-60 no rom reset.
ROLAND JUNO-1 no rom reset.
ROLAND JUNO-2 no rom reset.
ROLAND JUNO-6 no rom reset.
ROLAND JUPITER-6 no rom reset.
ROLAND JUPITER-8 no rom reset.
ROLAND JV-1000 HOLD NUMBER 8, POWER ON. PRESS ENTER THEN WRITE.
ROLAND JV-1080 PRESS UTILITY. CURSOR DOWN ONCE THEN RIGHT 3 TIMES TO FACTORY PRESET. PRESS ENTER TWICE, THEN UTILITY.
ROLAND JV-2080 PRESS UTILITY. PRESS F6 TWICE TO MENU 3. PRESS F1 THEN F6. IF REQ'D USE VALUE DIAL TO TURN OFF MEM. PROT. AND PRESS F6 TWICE.
ROLAND JV-30 PRESS CHORUS + REVERB (ABOVE INIT) TOGETHER THEN PRESS VALUE UP.
ROLAND JV-35 PRESS CONTROL + MASTER TOGETHER. USE PARAMETER UP AND DOWN TO SELECT ALL. PRESS VALUE UP.
ROLAND JV-50 PRESS CONTROL + MASTER TOGETHER. USE PARAMETER UP AND DOWN TO SELECT ALL. PRESS VALUE UP.
ROLAND JV-80 HOLD NUMBER 8, POWER ON. PRESS ENTER THEN WRITE.
ROLAND JV-880 PRESS UTILITY, USE DATA DIAL TO SELECT FACTORY PRESET. PRESS ENTER TWICE.
ROLAND JV-90 HOLD NUMBER 8, POWER ON. PRESS ENTER THEN WRITE.
ROLAND JW-50 PRESS TUNE/FUNCTION. PRESS F5 THEN F4 THEN F3 THEN F4.
ROLAND JX-1 HOLD WRITE AND FLUTE THEN POWER ON.
ROLAND JX-10 no rom reset.
ROLAND JX-3P no rom reset.
ROLAND JX-8P no rom reset.
ROLAND KR-100 resets at power on.
ROLAND KR-3000 HOLD FROM AND TO BUTTONS, THEN PRESS WRITE.
ROLAND KR-33 resets at power on.
ROLAND KR-350 HOLD LOAD AND SAVE, THEN PRESS WRITE.
ROLAND KR-3500 HOLD LOAD AND SAVE, THEN PRESS WRITE.
ROLAND KR-370 resets at power on.
ROLAND KR-4500 HOLD LOAD AND SAVE, THEN PRESS WRITE.
ROLAND KR-4700 HOLD LOAD AND EDIT, THEN PRESS SAVE.
ROLAND KR-500 HOLD FROM AND TO, THEN PRESS WRITE.
ROLAND KR-5000 HOLD LOAD AND EDIT, THEN PRESS SAVE.
ROLAND KR-55 HOLD MIDI FUNCTION AND PRESS CARDS (5 SECONDS).
ROLAND KR-5500 HOLD LOAD AND SAVE, THEN PRESS WRITE.
ROLAND KR-575 PRESS FUNCTION; PAGE TO 'FACTORY RESET'. TOUCH EXECUTE, THEN OK.
ROLAND KR-577 PRESS UTILITY; USE BUTTONS BELOW PAGE TO SELECT 'FACTORY PRESET'. PRESS EXECUTE, THEN OK.
ROLAND KR-650 HOLD LOAD AND SAVE, THEN PRESS WRITE.
ROLAND KR-770 HOLD PART VOLUME ACCOMP, PRESS TRACK 2 + 4 BUTTONS SIMULTANEOUSLY. USE PART VOLUME ACCOMP REPEATEDLY TO GET FACTORY SET-UP LOAD. WHEN DONE PWR OFF/ON.
ROLAND KR-977 PRESS FUNCTION; USE PAGE BUTTONS TO 'FACTORY RESET'. TOUCH EXECUTE, THEN OK.
ROLAND LVC-1N HOLD ENTER BUTTON THEN POWER ON.
ROLAND M-760 HOLD EDIT, PRESS WRITE. PARAMETER UP/DOWN TO SELECT ALL + PRESS WRITE. ON COMPLETION PRESS EDIT TO RETURN TO PLAY.
ROLAND M-DC1 HOLD F3 AND THEN POWER ON.
ROLAND M-GS64 HOLD F3 AND THEN POWER ON. CONTRIBUTED-: HOLD SELECT AND PRESS F4, PRESSF3 AND THEN PRESS ENTER.
ROLAND M-OC1 HOLD F3 AND THEN POWER ON.
ROLAND M-SE1 HOLD F3 AND THEN POWER ON.
ROLAND M-VS1 HOLD F3 AND THEN POWER ON.
ROLAND MBD1 HOLD F3 AND THEN POWER ON.
ROLAND MC-303 HOLD SHIFT AND THEN POWER ON, THEN PRESS ENTER.
ROLAND MC-307 PRESS SYSTEM, THEN F2 (UTIL). CURSOR DN TO FACTORY RESET. PRESS F1 AND THEN F4.
ROLAND MC-50 no rom reset.
ROLAND MC-505 HOLD SHIFT BUTTON AND POWER ON. PRESS ENTER.
ROLAND MC-50MKII no rom reset.
ROLAND MC-80 no rom reset.
ROLAND MC-80EX no rom reset.
ROLAND MDC-1 HOLD F3 AND POWER ON.
ROLAND ME-10 HOLD BANK DOWN PEDAL, THEN PRESS WRITE.
ROLAND ME-30 HOLD PARAMETER RIGHT AND VALUE WHILE POWERING ON. PRESS WRITE/COPY.
ROLAND ME-33 HOLD EZ TONE AND AMP/EFFECT RIGHT WHILE POWERING ON. THEN PRESS WRITE.
ROLAND ME-5 HOLD PEDALS 1 AND 2, POWER ON; PRESS WRITE IMMEDIATELY.
ROLAND ME-6 HOLD LEFT + DOWN AND POWER ON; THEN PRESS WRITE.
ROLAND ME-6B HOLD LEFT + DOWN AND POWER ON; THEN PRESS WRITE.
ROLAND ME-8 HOLD LEFT + DOWN AND POWER ON; PRESS WRITE/COPY.
ROLAND ME-8B HOLD PARAMETER LEFT + DOWN BUTTONS, THEN PRESS WRITE/COPY.
ROLAND ME-X HOLD PARAMETER LEFT + DOWN AND POWER ON, THEN PRESS WRITE.
ROLAND MGS-64 HOLD F3 AND POWER ON.
ROLAND MK-60 no rom reset.
ROLAND MK-80 HOLD WRITE, PRESS EDIT. HOLD LEFT AND RIGHT CURSOR BUTTONS AND PRESS UP.
ROLAND MKB SERIES no rom reset.
ROLAND MKS-50 POLY MODE: HOLD NUMBER BUTTONS 4 AND 8 AND POWER ON.
ROLAND MKS-50 MONO MODE: HOLD NUMBER BUTTONS 3 AND 7 AND POWER ON.
ROLAND MMP-2 PRESS SYSTEM UNTIL LIGHTS ORANGE. USE PAGE LEFT/RIGHT BUTTONS TO SELECT INITIALIZE. USE LEFT VALUE TO SELECT ALL; PRESS ENTER TWICE.
6516
ROLAND MP SERIES no rom reset.
ROLAND MS-1 no rom reset.
ROLAND MSE-1 HOLD F3 AND POWER ON.
ROLAND MSQ-100 no rom reset.
ROLAND MSQ-700 no rom reset.
ROLAND MT-100 HOLD STOP, PRESS DELETE. AFTER THE DISPLAY FLASHES "ALL CLEAR" PRESS EXECUTE.
ROLAND MT-120 HOLD REPEAT, SONG (BLUE), AND PLAY, POWER ON. PRESS FWD REPEATEDLY UNTIL READS T13. PRESS PLAY THEN RECORD, THEN POWER OFF/ON.
ROLAND MT-120S HOLD REPEAT, SONG (BLUE), AND PLAY, POWER ON. PRESS FWD REPEATEDLY UNTIL READS T13. PRESS PLAY THEN RECORD, THEN POWER OFF/ON.
ROLAND MT-200 HOLD REPEAT, SONG (BLUE), AND PLAY, POWER ON. USE DIAL TO SELECT T-15 ON DISPLAY. PRESS PLAY THEN RECORD, THEN POWER OFF/ON.
ROLAND MT-300 PRESS MENU, DIAL TO FACTORY PRESET. PRESS ENTER TWICE.
ROLAND MT-32 HOLD MASTER VOLUME, PRESS RHYTHM PART, PRESS PART 1.
ROLAND MT-80 resets at power on.
ROLAND MV-30 no rom reset.
ROLAND MVS-1 HOLD F3 AND POWER ON.
ROLAND OCTAPAD HOLD MIDI CH AND NOTE NUMBER, POWER ON. POWER OFF, THEN POWER ON AGAIN.
ROLAND OCTAPAD II HOLD BOTH VALUE BUTTONS, POWER ON.
ROLAND P-330 no rom reset.
ROLAND P-55 HOLD BOTH INSTRUMENT BUTTONS, POWER ON, THEN PRESS PARAM 1.
ROLAND PAD-8 HOLD MIDI CH AND NOTE NUMBER, POWER ON. POWER OFF, THEN POWER ON.
ROLAND PAD-80 HOLD BOTH VALUE BUTTONS, POWER ON.
ROLAND PC-150 HOLD COMMAND (LEFT), POWER ON.
ROLAND PC-200 HOLD THE 2 BUTTONS UNDER "STANDARD", POWER ON.
ROLAND PIANO PLUS (ALL) no rom reset.
ROLAND PK-5 HOLD OCT/PARAM AND POWER ON.
ROLAND PK-7 no rom reset.
ROLAND PLANET-P no rom reset.
ROLAND PLANET-S no rom reset.
ROLAND PM-16 no rom reset.
ROLAND PMA-5 HOLD VALUE, POWER ON. TOUCH 2 CAL. POINTS TOP RIGHT + BOTTOM LEFT OF DISPLAY W/ TOUCH PEN. DISPLAYS COMPLETED THEN INITIALIZE, TOUCH EXEC.
ROLAND PRO-E HOLD WRITE, POWER ON.
ROLAND R-5 HOLD PAGE + SELECT AND POWER ON. PRESS ENTER TWICE AT PROMPTS.
ROLAND R-70 HOLD MIDI + ASSIGN AND POWER ON. PRESS YES TWICE AT PROMPTS.
ROLAND R-8 HOLD CURSOR PAGE AND PARAM SELECT THEN POWER ON.PRESS ENTER TWICE.
ROLAND R-880 no rom reset.
ROLAND R-8M HOLD CURSOR RIGHT AND ENTER, POWER ON. PRESS ENTER TWICE AT PROMPTS.
ROLAND RA-50 HOLD WRITE THEN POWER ON.
ROLAND RA-90 HOLD WRITE THEN POWER ON.
ROLAND RA-95 HOLD REC, POWER ON.
ROLAND RD-150 HOLD THE PLAY AND REC BUTTONS WHILE POWERING ON.
ROLAND RSP-550 POWER ON WHILE HOLDING PROG PAGE UP AND DOWN, THEN PRESS WRITE.
ROLAND SB-55 POWER ON WHILE HOLDING CLEAR BUTTON.
ROLAND SC-155 POWER IN STANDBY MODE. HOLD BOTH INSTRUMENT BUTTONS, PRESS POWER ON AND THEN PRESS ALL.
ROLAND SC-33 HOLD SPLIT AND REVERB WHILE POWERING ON, THEN PRESS YES.
ROLAND SC-50 HOLD BOTH INSTRUMENT BUTTONS AND POWER ON. THEN PRESS ALL.
ROLAND SC-55 HOLD BOTH INSTRUMENT BUTTONS AND POWER ON. THEN PRESS ALL.
ROLAND SC-55MKII HOLD BOTH INSTRUMENT BUTTONS AND POWER ON. THEN PRESS ALL.
ROLAND SDD-320 no rom reset.
ROLAND SH-101 no rom reset.
ROLAND SH-2000 no rom reset.
ROLAND SN700 no rom reset.
ROLAND SP700 no rom reset.
ROLAND SPD-11 HOLD ALL/ENTER WHILE POWERING ON. PRESS ALL/ENTER AGAIN.
ROLAND SPD-8 HOLD EDIT BUTTON WHILE POWERING ON.
ROLAND SRV-1000 no rom reset.
ROLAND TB-303 no rom reset.
ROLAND TD-10 HOLD SETUP AND EXIT KEYS AND TURN POWER ON, THENPRESS F4.
ROLAND TD-7 PRESS SYSTEM. CURSOR TO 'INT' AND PRESS ENTER. CURSOR TO 'HIHAT' THEN DATA DIAL TO SELECT 'ALL'. PRESS ENTER TWICE.
ROLAND TD-8 V CUSTOM PRESS SETUP THEN [F3 (MENU)]. PRESS INC/+, ROTATE THE VALUE DIAL, OR PRESS CURSOR TO MOVE THE CURSOR TO "RESET".
ROLAND TR-505 HOLD PATTERN GROUP A AND MODE AND POWER ON.
ROLAND TR-626 HOLD TRACK #1 AND MODE AND POWER ON.
ROLAND TR-707 HOLD TRACK WRITE AND PATTERN 1 AND POWER ON.
ROLAND TR-727 HOLD TRACK WRITE AND PATTERN 1 AND POWER ON.
ROLAND TR-808 no rom reset.
ROLAND TR-909 HOLD TRACK #1 AND PATTERN #1 AND POWER ON.
ROLAND U-110 HOLD THE EDIT AND PART BUTTONS AND POWER ON.
ROLAND U-20 no rom reset.
ROLAND U-220 no rom reset.
ROLAND VP-70 HOLD MIDI, PLAY, AND VOICE EXP AND POWER ON.
ROLAND VS-1680 no rom reset.
ROLAND VS-1680EX no rom reset.
ROLAND VS-1824 no rom reset.
ROLAND VS-1824CD no rom reset.
ROLAND VS-1880 no rom reset.
ROLAND VS-2480 no rom reset.
ROLAND VS-2480CD no rom reset.
ROLAND VS-840 no rom reset.
ROLAND VS-840EX no rom reset.
ROLAND VS-840GX no rom reset.
ROLAND VS-880 no rom reset.
ROLAND VS-880EX no rom reset.
ROLAND VS-890 no rom reset.
ROLAND VT-1 HOLD PRESET/USER BUTTON AND POWER ON.
ROLAND W-30 no rom reset.
ROLAND W-50 PRESS CONTROL AND MASTER BUTTONS SIMULTANEOUSLY.USE PARAMETER UP AND DOWN BUTTONS TO SELECT ALL. PRESS VALUE UP BUTTON.
ROLAND XP-50 PRESS DISK UTIL, SELECT SOUND, THEN PROTECT, SETMEM PROTECT OFF. EXIT, SELECT PRESET AND PRESS ENTER. (REMEMBER TO SET MEM PROTECT BACK ON ).
ROLAND XV-5050 PRESS UTILITY AND CURSOR LEFT BUTTONS. VALUE DIAL TO SELECT FACTORY RESET AND PRESS ENTER TWICE.
ROLAND XV-5080 PRESS SYSTEM/UTILITY SO LIGHT BLINKING. PRESS F6 AND THEN F5. PRESS F6 (EXECUTE) AGAIN.
ROLAND XV-88 PRESS UTILITY, CURSOR DOWN TO UTIL PAGE 2. PRESS4 (BASS), PRESS ENTER TWICE.
6516
6516
 楼主| 发表于 2006-6-26 19:06:00 | 显示全部楼层
YAMAHA 02R HOLD "CURSOR LEFT" AND POWER ON.
YAMAHA CLP-100 HOLD KEY "F0" AND POWER ON.
YAMAHA CLP-121 HOLD KEY "F0" AND POWER ON.
YAMAHA CLP-121S HOLD KEY "F0" AND POWER ON.
YAMAHA CLP-122 HOLD KEY "F0" OR KEY "B1" AND POWER ON.
YAMAHA CLP-122S HOLD KEY "F0" OR KEY "B1" AND POWER ON.
YAMAHA CLP-123 HOLD KEY "F0" OR KEY "B1" AND POWER ON.
YAMAHA CLP-124 HOLD KEY "F0" OR KEY "B1" AND POWER ON.
YAMAHA CLP-133 HOLD KEY "F0" OR KEY "B1" AND POWER ON.
YAMAHA CLP-134 HOLD KEY "F0" OR KEY "B1" AND POWER ON.
YAMAHA CLP-152 HOLD KEY "F0" AND POWER ON.
YAMAHA CLP-152S HOLD KEY "F0" AND POWER ON.
YAMAHA CLP-153 HOLD KEY "F0" OR KEY "B1" AND POWER ON.
YAMAHA CLP-153S HOLD KEY "F0" OR KEY "B1" AND POWER ON.
YAMAHA CLP-153SG HOLD KEY "F0" OR KEY "B1" AND POWER ON.
YAMAHA CLP-154 HOLD KEY "F0" OR KEY "B1" AND POWER ON.
YAMAHA CLP-154F HOLD KEY "F0" OR KEY "B1" AND POWER ON.
YAMAHA CLP-154S HOLD KEY "F0" OR KEY "B1" AND POWER ON.
YAMAHA CLP-155 HOLD KEY "F0" OR KEY "B1" AND POWER ON.
YAMAHA CLP-156 HOLD KEY "F0" OR KEY "B1" AND POWER ON.
YAMAHA CLP-157 HOLD KEY "F0" OR KEY "B1" AND POWER ON.
YAMAHA CLP-158 HOLD KEY "F0" OR KEY "B1" AND POWER ON.
YAMAHA CLP-20 HOLD KEY "F0" AND POWER ON.
YAMAHA CLP-250 HOLD KEY "F0" AND POWER ON.
YAMAHA CLP-260 HOLD KEY "F0" AND POWER ON.
YAMAHA CLP-30 HOLD KEY "B1" AND POWER ON.
YAMAHA CLP-311 HOLD KEY "B1" AND POWER ON.
YAMAHA CLP-350 HOLD KEY "B1" AND POWER ON.
YAMAHA CLP-360 HOLD KEY "F0" AND POWER ON.
YAMAHA CLP-411 HOLD KEY "B1" AND POWER ON.
YAMAHA CLP-500 HOLD KEY "B1" AND POWER ON.
YAMAHA CLP-511 HOLD KEY "B1" AND POWER ON.
YAMAHA CLP-550 HOLD KEY "B1" AND POWER ON.
YAMAHA CLP-555 HOLD KEY "B1" AND POWER ON.
YAMAHA CLP-560 HOLD KEY "B1" AND POWER ON.
YAMAHA CLP-570 HOLD KEY "B1" AND POWER ON.
YAMAHA CLP-611 HOLD KEY "B1" AND POWER ON.
YAMAHA CLP-705 HOLD KEY "B1" AND POWER ON.
YAMAHA CLP-711 HOLD KEY "B1" AND POWER ON.
YAMAHA CLP-760 HOLD KEY "B1" AND POWER ON.
YAMAHA CLP-811 HOLD KEY "B1" AND POWER ON.
YAMAHA CLP-911 HOLD KEY "B1" AND POWER ON.
YAMAHA CLW-12 HOLD KEY "B1" AND POWER ON.
YAMAHA CLW-14 HOLD KEY "B1" AND POWER ON.
YAMAHA CS1X HOLD BUTTONS 7, 8, AND 9, AND POWER ON.
YAMAHA CS2X HOLD BUTTONS 7, 8, AND 9, AND POWER ON.
YAMAHA CVP-105 HOLD DOWN THE RIGHTMOST KEY (C7) AND POWER ON.
YAMAHA CVP-35 HOLD KEY "B1" AND POWER ON.
YAMAHA CVP-45 HOLD KEY "B1" AND POWER ON.
YAMAHA CVP-49 HOLD KEY "F0" AND POWER ON.
YAMAHA CVP-50 HOLD KEY "B1" AND POWER ON.
YAMAHA CVP-55 HOLD KEY "B1" AND POWER ON.
YAMAHA CVP-59 HOLD KEY "B1" AND POWER ON.
YAMAHA CVP-65 HOLD KEY "B1" AND POWER ON.
YAMAHA CVP-69 HOLD KEY "B1" AND POWER ON.
YAMAHA CVP-69A HOLD KEY "B1" AND POWER ON.
YAMAHA CVP-70 HOLD KEY "B1" AND POWER ON.
YAMAHA CVP-75 HOLD KEY "B1" AND POWER ON.
YAMAHA CVP-79 HOLD KEY "B1" AND POWER ON.
YAMAHA CVP-79A HOLD KEY "B1" AND POWER ON.
YAMAHA CVP-83 HOLD KEY "B1" AND POWER ON.
YAMAHA CVP-83S HOLD KEY "B1" AND POWER ON.
YAMAHA CVP-85 HOLD KEY "B1" AND POWER ON.
YAMAHA CVP-85A HOLD KEY "B1" AND POWER ON.
YAMAHA CVP-87 HOLD KEY "B1" AND POWER ON.
YAMAHA CVP-87A HOLD KEY "B1" AND POWER ON.
YAMAHA CVP-89 HOLD KEY "B1" AND POWER ON.
YAMAHA CVP-89WH HOLD KEY "B1" AND POWER ON.
YAMAHA D2040 PRESS 'PEQ/D.ATT' KEY OF CHANNEL 1 AND 'LIMIT/COMP' OF CHANNEL 3 AND POWER ON.
YAMAHA D5000 PRESS STORE AND POWER THEN PRESS RECALL.
YAMAHA DD-11 no rom reset.
YAMAHA DDL3 RUN TEST PROGRAM. PRESS 'RECALL' AND THEN PRESS 'STORE'.
YAMAHA DEQ5 HOLD THE 'L' AND 'FLAT' KEYS AND POWER UNIT ON. PRESS 'RECALL'.
YAMAHA DEQ5E RUN TEST MODE. WHEN TEST 10 IS PERFORMED, UNIT IS INITIALIZED AND FACTORY PRESETS ARE RESTORED.
YAMAHA DEQ7 HOLD DELAY/LEVEL AND PROTECT ON/OFF, POWER ON.
YAMAHA DMP-11 PRESS FADER FLIP, PARAMETER LEFT, POWER ON.
YAMAHA DMP-7 PRESS FADER FLIP, PARAMETER LEFT, POWER ON.
YAMAHA DMP9-16/8 PRESS MEMORY [RECALL], RETURN [SEL], [UTILITY], THEN POWER ON.
YAMAHA DOU10 PRESS SHIFT AND POWER ON.
YAMAHA DTS70 PRESS UTILITY AND STORE WHILE POWERING ON.
YAMAHA DX-7II INSERT ROM CARTRIDGE AND POWER ON.
YAMAHA DX-7S INSERT ROM CARTRIDGE AND POWER ON.
YAMAHA EMP-700 PRESS F1 AND ^ WHILE POWERING ON.
YAMAHA FX-500 HOLD COMP AND MOD WHILE POWERING ON.
YAMAHA FX-770 HOLD COMP AND PLAY WHILE POWERING ON.
YAMAHA GW-10 HOLD CHO WHILE POWERING ON.
YAMAHA GW-33 HOLD DOWN/NO AND UP/YES WHILE POWERING ON.
YAMAHA MDP-2 HOLD SHIFT AND POWER ON.
YAMAHA MFC-10 HOLD MEMORY, EDIT, AND FC EDIT AND POWER ON.
YAMAHA MLP-11 HOLD KEY "B1" AND POWER ON.
YAMAHA MLP51 HOLD KEY "F0" AND POWER ON.
YAMAHA MU-90 HOLD ENTER AND UTIL WHILE POWERING ON.
6516
YAMAHA P-100 HOLD KEY "B1" AND POWER ON.
YAMAHA P-150 HOLD KEY "B1" AND POWER ON.
YAMAHA P-300 HOLD KEY "B1" AND POWER ON.
YAMAHA P-500 HOLD KEY "B1" AND POWER ON.
YAMAHA PDP-300 HOLD KEY "F0" AND POWER ON.
YAMAHA PDP-400 HOLD KEY "B1" AND POWER ON.
YAMAHA PDP-500 HOLD KEY "B1" AND POWER ON.
YAMAHA PROMIX 01 PRESS STORE AND INC+ WHILE POWERING ON.
YAMAHA PSR-220 PRESS YES AND NO WHILE POWERING ON.
YAMAHA PSR-230 PRESS YES AND NO WHILE POWERING ON.
YAMAHA PSR-410 HOLD [+] AND [-] AND POWER ON.
YAMAHA PSR-420 HOLD [+/YES] AND [-/NO] AND POWER ON.
YAMAHA PSR-510 HOLD [+] AND [-] AND POWER ON.
YAMAHA PSR-520 HOLD [+/YES] AND [-/NO] AND POWER ON.
YAMAHA PSR-530 HOLD RIGHT-MOST WHITE KEY ON THE KEYBOARD WHILE TURNING ON THE POWER.
YAMAHA PSR-6000 UTILITY MODE, RECALL PRESET DATA, SELECT ALL DATA.
YAMAHA PSR-620 HOLD [+/YES] AND [-/NO] AND POWER ON.
YAMAHA PSR-6300 HOLD KEY "C6" AND POWER ON.
YAMAHA PSR-70 HOLD KEY "C5" AND POWER ON.
YAMAHA PSR-9000 HOLD DEMO AND POWER ON.
YAMAHA PSR-A3 HOLD [+/YES] AND [-/NO] AND POWER ON.
YAMAHA REV-100 PRESS STORE BUTTON WHILE POWERING ON. THEN PRESS V AND STORE.
YAMAHA RX-8 HOLD STOP/CONTINUE, +1/YES, AND -1/NO AND POWER ON.
YAMAHA SPX-90 HOLD BALANCE, FOOT TRIGGER AND POWER ON.
YAMAHA SPX-90II HOLD BALANCE, FOOT TRIGGER AND POWER ON.
YAMAHA SPX990 HOLD PAGE, STORE, AND BYPASS WHILE POWERING ON. also test #8 is ram initialization.
YAMAHA TMX HOLD UTILITY AND STORE THEN POWER ON.
YAMAHA YDP-200 HOLD KEY "F0" OR KEY "B1", WHILE POWERING ON.
YAMAHA YDP-300 HOLD KEY "F0" OR KEY "B1", WHILE POWERING ON.
YAMAHA YDP-301 HOLD KEY "B1", WHILE POWERING ON.
YAMAHA YDP-88 HOLD KEY "B1", WHILE POWERING ON.
YAMAHA YDP-88II HOLD KEY "B1", WHILE POWERING ON.
ZOOM 505 HOLD THE STORE BUTTON WHILE POWERING ON. DISPLAY FLASHES "AL"; PRESS STORE AGAIN.
ZOOM 506II HOLD STORE BUTTON WHILE PLUGGING IN ADAPTOR. PRESS STORE ONCE MORE.
8204
发表于 2006-7-7 18:28:00 | 显示全部楼层
看着头大,软件中应用,理论上和实际上都已收藏
GMT+8, 2025-7-16 12:33 , Processed in 0.032727 second(s), 5 queries , Redis On.
