Ö»ÄÜÔÚÕæ»úÉÏʵÏÖ£¬Ä£Äâ»ú²»Ö§³Ö
±¾´úÂëÊǰ³½è¼øµÄ£¬²¢¼ÓÈëÁËÏêϸµÄ×¢½â£¬Ö÷ÒªÓõ½AudioRecord£¬ºÍAudioTrackÁ½¸öÀà
¼òµ¥ËµÒ»ÏÂÁ½¸öÀàµÄ¹¹Ô캯ÊýºÍ»ù±¾·½·¨£º
AudioRecord
public AudioRecord (int audioSource, int sampleRateInHz, int channelConfig, int audioFormat, int bufferSizeInBytes) Ëĸö²ÎÊý·Ö±ðÊÇ
audioSource
ÒôƵԴ£ºÖ¸µÄÊÇ´ÓÄÄÀï²É¼¯ÒôƵ¡£ÕâÀïÎÒÃǵ±È»ÊÇ´ÓÂó¿Ë·ç²É¼¯ÒôƵ£¬ËùÒԴ˲ÎÊýµÄֵΪMIC
sampleRateInHz
²ÉÑùÂÊ£ºÒôƵµÄ²ÉÑùƵÂÊ£¬Ã¿ÃëÖÓÄܹ»²ÉÑùµÄ´ÎÊý£¬²ÉÑùÂÊÔ½¸ß£¬ÒôÖÊÔ½¸ß¡£¸ø³öµÄʵÀýÊÇ44100¡¢22050¡¢11025µ«²»ÏÞÓÚÕ⼸¸ö²ÎÊý¡£ÀýÈçÒª²É¼¯µÍÖÊÁ¿µÄÒôƵ¾Í¿ÉÒÔʹÓÃ4000¡¢8000µÈµÍ²ÉÑùÂÊ¡£
channelConfig
ÉùµÀÉèÖãºandroidÖ§³ÖË«ÉùµÀÁ¢ÌåÉùºÍµ¥ÉùµÀ¡£MONOµ¥ÉùµÀ£¬STEREOÁ¢ÌåÉù
audioFormat
±àÂëÖÆÊ½ºÍ²ÉÑù´óС£º²É¼¯À´µÄÊý¾Ýµ±È»Ê¹ÓÃPCM±àÂë(Âö³å´úÂëµ÷ÖÆ±àÂ룬¼´PCM±àÂë¡£PCMͨ¹ý³éÑù¡¢Á¿»¯¡¢±àÂëÈý¸ö²½Ö轫Á¬Ðø±ä»¯µÄÄ£ÄâÐźÅת»»ÎªÊý×Ö±àÂë¡£) androidÖ§³ÖµÄ²ÉÑù´óС16bit »òÕß8bit¡£µ±È»²ÉÑù´óСԽ´ó£¬ÄÇôÐÅÏ¢Á¿Ô½¶à£¬ÒôÖÊÒ²Ô½¸ß£¬ÏÖÔÚÖ÷Á÷µÄ²ÉÑù´óС¶¼ÊÇ16bit£¬ÔÚµÍÖÊÁ¿µÄÓïÒô´«ÊäµÄʱºò8bit ×ã¹»ÁË¡£
bufferSizeInBytes
²É¼¯Êý¾ÝÐèÒªµÄ»º³åÇøµÄ´óС£¬Èç¹û²»ÖªµÀ×îСÐèÒªµÄ´óС¿ÉÒÔÔÚgetMinBufferSize()²é¿´¡£
getMinBufferSize(frequency, channelConfiguration, audioEncoding);
AudioTrackÀà
AudioTrack±ÈAudioRecord¶à³öÀ´Ò»¸ö²ÎÊý
public AudioTrack (int streamType, int sampleRateInHz, int channelConfig, int audioFormat, int bufferSizeInBytes£¬int mode)
ÆäÖÐstreamType
<!--[if !supportLists]-->l <!--[endif]-->STREAM_ALARM£º¾¯¸æÉù
<!--[if !supportLists]-->l <!--[endif]-->STREAM_MUSCI£ºÒôÀÖÉù£¬ÀýÈçmusicµÈ
<!--[if !supportLists]-->l <!--[endif]-->STREAM_RING£ºÁåÉù
<!--[if !supportLists]-->l <!--[endif]-->STREAM_SYSTEM£ºÏµÍ³ÉùÒô
<!--[if !supportLists]-->l <!--[endif]-->STREAM_VOCIE_CALL£ºµç»°ÉùÒô
ÆäÖÐmode
AudioTrackÖÐÓÐMODE_STATICºÍMODE_STREAMÁ½ÖÖ·ÖÀà¡£STREAMµÄÒâ˼ÊÇÓÉÓû§ÔÚÓ¦ÓóÌÐòͨ¹ýwrite·½Ê½°ÑÊý¾ÝÒ»´ÎÒ»´ÎµÃдµ½audiotrackÖС£Õâ¸öºÍÎÒÃÇÔÚsocketÖз¢ËÍÊý¾ÝÒ»Ñù£¬Ó¦Óòã´Óij¸öµØ·½»ñÈ¡Êý¾Ý£¬ÀýÈçͨ¹ý±à½âÂëµÃµ½PCMÊý¾Ý£¬È»ºówriteµ½audiotrack¡£
ÕâÖÖ·½Ê½µÄ»µ´¦¾ÍÊÇ×ÜÊÇÔÚJAVA²ãºÍNative²ã½»»¥£¬Ð§ÂÊËðʧ½Ï´ó¡£
¶øSTATICµÄÒâ˼ÊÇÒ»¿ªÊ¼´´½¨µÄʱºò£¬¾Í°ÑÒôƵÊý¾Ý·Åµ½Ò»¸ö¹Ì¶¨µÄbuffer£¬È»ºóÖ±½Ó´«¸øaudiotrack£¬ºóÐø¾Í²»ÓÃÒ»´Î´ÎµÃwriteÁË¡£AudioTrack»á×Ô¼º²¥·ÅÕâ¸öbufferÖеÄÊý¾Ý¡£
ÕâÖÖ·½·¨¶ÔÓÚÁåÉùµÈÄÚ´æÕ¼ÓýÏС£¬ÑÓʱҪÇó½Ï¸ßµÄÉùÒôÀ´ËµºÜÊÊÓá£
´úÂ벿·Ö£º
1.²¼¾ÖÎļþ
<?xml version="1.0" encoding="utf-8"?>
<LinearLayout xmlns:android="http://schemas.android.com/apk/res/android"
android:orientation="vertical"
android:layout_width="fill_parent"
android:layout_height="fill_parent"
<TextView
android:layout_height="wrap_content"
android:text="@string/hello"
<Button android:text="¿ªÊ¼±ß¼±ß·Å" android:id="@+id/recordButton" android:layout_width="fill_parent" android:layout_height="wrap_content"></Button>
<Button android:text="Í£Ö¹" android:id="@+id/stopButton" android:layout_width="fill_parent" android:layout_height="wrap_content"></Button>
<Button android:text="Í˳ö" android:id="@+id/exitButton" android:layout_width="fill_parent" android:layout_height="wrap_content"></Button>
<TextView android:text="ÒôÁ¿µ÷½Ú" android:id="@+id/textView1" android:layout_width="fill_parent" android:layout_height="wrap_content"></TextView>
<SeekBar android:layout_width="fill_parent" android:layout_height="wrap_content" android:id="@+id/seekBar1"></SeekBar>
</LinearLayout>
2.ΪAudioRecordÉêÇëÐí¿É£¬ÐÞ¸ÃAndroidManifes.xmlÈçÏ£º
<manifest xmlns:android="http://schemas.android.com/apk/res/android"
package="com.testrecord"
android:versionCode="1"
android:versionName="1.0">
<uses-sdk android:minSdkVersion="9" />
<application android:icon="@drawable/icon" android:label="@string/app_name">
<activity android:name=".textRecord"
<intent-filter>
<action android:name="android.intent.action.MAIN" />
<category android:name="android.intent.category.LAUNCHER" />
</intent-filter>
</activity>
<uses-permission android:name="android.permission.RECORD_AUDIO"></uses-permission>
</application>
</manifest>
3.Ö÷ҪʵÏÖ´úÂ룺
import android.app.Activity;
import android.media.AudioFormat;
import android.media.AudioManager;
import android.media.AudioRecord;
import android.media.AudioTrack;
import android.media.MediaRecorder;
import android.os.Bundle;
import android.view.View;
import android.widget.Button;
import android.widget.SeekBar;
import android.widget.Toast;
public class textRecord extends Activity {
Button recordButton,stopButton,exitButton;
SeekBar skbVolume;
boolean isRecording = false;
static final int frequency = 44100;
static final int channelConfiguration=AudioFormat.CHANNEL_CONFIGURATION_MONO;
static final int audioEncoding = AudioFormat.ENCODING_PCM_16BIT;
int recBufSize,playBufSize;
AudioRecord audioRecord;
AudioTrack audioTrack;
public void onCreate(Bundle savedInstanceState) {
super.onCreate(savedInstanceState);
setContentView(R.layout.main);
setTitle("ÖúÌýÆ÷");
//ÓÃgetMinBufferSize()·½·¨µÃµ½²É¼¯Êý¾ÝËùÐèÒªµÄ×îС»º³åÇøµÄ´óС
recBufSize = AudioRecord.getMinBufferSize(frequency, channelConfiguration, audioEncoding);
playBufSize = AudioTrack.getMinBufferSize(frequency, channelConfiguration, audioEncoding);
//ʵÀý»¯AudioRecord(ÉùÒôÀ´Ô´£¬²ÉÑùÂÊ£¬ÉùµÀÉèÖ㬲ÉÑùÉùÒô±àÂ룬»º´æ´óС£©
audioRecord = new AudioRecord(MediaRecorder.AudioSource.MIC,frequency,channelConfiguration,audioEncoding,recBufSize);
audioTrack = new AudioTrack(AudioManager.STREAM_MUSIC,frequency,channelConfiguration,audioEncoding,playBufSize,AudioTrack.MODE_STREAM);
recordButton =(Button)this.findViewById(R.id.recordButton);
stopButton =(Button) this.findViewById(R.id.stopButton);
exitButton =(Button)this.findViewById(R.id.exitButton);
recordButton.setOnClickListener(new ClickEvent());
stopButton.setOnClickListener(new ClickEvent());
exitButton.setOnClickListener(new ClickEvent());
skbVolume = (SeekBar)this.findViewById(R.id.seekBar1);
skbVolume.setMax(100);
skbVolume.setProgress(70);
// ÉèÖÃÉùÒô´óС
audioTrack.setStereoVolume(0.7f, 0.7f);
skbVolume.setOnSeekBarChangeListener(new SeekBar.OnSeekBarChangeListener() {
public void onStopTrackingTouch(SeekBar seekBar) {
float vol = (float)(seekBar.getProgress())/(float)(seekBar.getMax());
audioTrack.setStereoVolume(vol, vol);
@Override
public void onStartTrackingTouch(SeekBar seekBar) {
// TODO Auto-generated method stub
@Override
public void onProgressChanged(SeekBar seekBar, int progress,
boolean fromUser) {
protected void onDestroy(){
super.onDestroy();
// ɱËÀµ±Ç°½ø³Ì
android.os.Process.killProcess(android.os.Process.myPid());
class ClickEvent implements View.OnClickListener{
public void onClick(View v){
if(v == recordButton){
isRecording = true;
new RecordPlayThread().start();
}else if(v == stopButton){
}else if(v== exitButton){
textRecord.this.finish();
class RecordPlayThread extends Thread{
public void run(){
try{
//byte ÎļþÀ´´æ´¢ÉùÒô
byte[] buffer = new byte[recBufSize];
//¿ªÊ¼²É¼¯ÉùÒô
audioRecord.startRecording();
//²¥·ÅÉùÒô
audioTrack.play();
while(isRecording){
//´ÓMIC´æ´¢µ½»º´æÇø
int bufferReadResult = audioRecord.read(buffer,0, recBufSize);
byte[] tmpBuf = new byte[bufferReadResult];
System.arraycopy(buffer, 0, tmpBuf, 0, bufferReadResult);
//²¥·Å»º´æÇøµÄÊý¾Ý
audioTrack.write(tmpBuf, 0, tmpBuf.length);
audioTrack.stop();
audioRecord.stop();
}catch(Throwable t){
Toast.makeText(textRecord.this, t.getMessage(), 1000);
