DAYTON AUDIOÔ­×°ÃÀ¹ú½ø¿ÚEMM-6 ²âÊÔÂó¿Ë·ç
Ô­´´
²úÆ·Ãû³Æ£ºDAYTON AUDIOÔ­×°ÃÀ¹ú½ø¿ÚEMM-6 ²âÊÔÂó¿Ë·ç
²úÆ·ÐͺţºDAYTON AUDIO
²úƷ˵Ã÷£º
Æ·ÅÆ: ÐéÒǿƼ¼
ÐͺÅ: EMM-6
ÊÕÒôÍ·ÀàÐÍ: µçÈÝʽ
ÓÐÎÞÏß: ÎÞÏß
ÑÕÉ«·ÖÀà: Òø°×
ÉùµÀÀàÐÍ: Á¢ÌåÉù
Âó¿Ë·çÓÃ;: ÆäËûÓÃ;
Ö¸ÏòÌØÕ÷: ȫָÏò/ÎÞÖ¸Ïò
ÃÀ¹úÔ­×°½ø¿Ú¡£Ò»¶ÔÒ»±ê¶¨Îļþ£¬½øÐе¥¶À±ê¶¨µÄƵÂÊÏìÓ¦ÇúÏß
The Dayton Audio EMM-6 is a precision electret condenser microphone designed for measurement and critical recording applications. The extremely flat frequency response and true omni-directional polar pattern make it perfect for use with room acoustic analyzers and audio measurement systems. Each microphone includes stand mount, foam windscreen, transport case, and its own unique printed and downloadable calibration response graph and data!
Perfect for use with room acoustic analyzers and audio measurement systemsTrue omni-directional polar patternWorks with phantom power from +15V to +48VLow noise FET input reduces low-frequency distortionGold-plated XLR output connector for accurate signal transferHigh-quality components and rugged constructionIncludes stand mount, foam windscreen, and transport caseIncludes its own unique calibration response graph
Specifications:• Capsule type: 6 mm electret condenser • Polar pattern: omni-directional • Frequency response: 18 Hz - 20 kHz • Impedance: 200 ohms between pins 2 and 3 • Sensitivity at 1 kHz into 1K ohm: 10mV/Pa (-40 dBV, re. 0 dB = 1V/Pa) • Max SPL for 1% THD @ 1 kHz: 127 dB • S/N ratio: 70 dB A-weighted • Connector: gold plated XLR • Phantom power: +15V to +48V • Weight: 144 grams.
EMM-6ÊÇÒ»Ö§ÎÞÖ¸ÏòÐÔ×ÔÓɳ¡²âÁ¿Âó¿Ë·ç¡£Ëü²ÉÓÃ6mmÔ¤¼«»¯µçÈÝÒôÍ·£¬×¨ÒµÉè¼ÆµÄ¸ß¿É¿¿µç·£¬Ê¹Âó¿Ë·ç¾ßÓиßÎȶ¨ÐÔ¡¢µÍÊ§Õæ¡¢µÍÔëÉù¡£ÓÈÆäÊǼ«ÆäƽֱµÄƵÂÊÏìÓ¦ÇúÏßÊǸ÷ÀàÒôƵ·ÖÎöϵͳºÍÌØÊâ¼ÒôµÄÊ×Ñ¡Âó¿Ë·çÖ®Ò»
ÌØÕ÷
½ðÊô½á¹¹£¬ÒøÉ«Í¿¸²
·Ç³£Æ½Ö±µÄƵÂÊÏìÓ¦£¬³öÉ«µÄµçÉùÌØÐÔ
ÊÊÓÃÓÚÊÒÄÚÒôƵ·ÖÎöϵͳ£¬ÒÔ¼°¸÷Àà²âÊÔ¡¢²âÒôºÍ¼Òô
±ê×¼1/2Ó¢…¼²âÁ¿Ö±¾¶
¼¼ÊõÊý¾Ý
Àà ÐÍ 6mmפ¼«µçÈÝʽÂó¿Ë·ç
Ô­ Àí Éù³¡ÐÍ
Ö¸ Ïò ÐÔ ÎÞÖ¸Ïò
ƵÂÊÏìÓ¦ 18~20000Hz
Áé Ãô ¶È 10mV/Pa (-40dBV, re. 0dB = 1V/Pa)±ê³Æ×迹 200¦¸
×迹 200¦¸Òý½Å2ºÍ3Ö®¼ä
×î´óÉùѹ¼¶ 127dB (г²¨Ê§Õæ¨Q1% 1000Hz)
ÐÅ Ôë ±È 70dBA¼ÓȨ
µç Ô´ 15~48V »ÃÏ󹩵ç
Á¬½Ó²åÍ· 3ÕëXLR¶Æ½ð½Ó²å¼þ
Íâ¹ÛÑÕÉ« Òø É«
ÍâÐͳߴç ×î´óÖ±¾¶21mm(0.83")x193mm(7.6")
ÖØ Á¿ 144¿Ë
ÆäËüÐÅÏ¢:
Ëæ¸½HM-10BÂó¿Ë·ç¼Ð×Ó¡¢YA-1ÂÝÎÆ×ª½ÓÍ·¸÷Ò»¼þ¡£
±¾Æ·²ÉÓÃA1ÊÖÌáºÐ°ü×°¡£
